ENOcean - Add support for 1BS data frames (RORG=0xD5)
Hi guys,
I am a user of HomeAssistant and the ENOcean integration for some time now.
Very recently, I bought NodOn window sensor. The profile of this device is D5-00-01, which is a 1BS device according to the ENOcean documentation.
Sadely, I have not been able to use it in HomeAssistant : I only get an event if I declare it as a binary switch, but then the events contains no state.
Reading the code, it seems the 1BS profile is not handled, but it looks like it would be fairly simple to add support.
I am thinking about doing that, but I would like to be sure of the direction I am heading to (it would be my first contribution to the project). This device needs to have a state (open or close), but read only. It seems pretty close to what the EnOceanWindowHandle class, in the enocean/sensor.py file.
So my idea would be to add to this file this piece of code:
SENSOR_TYPE_CONTACT = "contact"
class EnOceanContactSensor(EnOceanSensor):
    """Representation of a single contact EnOcean sensor
    EEPs (EnOcean Equipment Profiles):
    - D5-00-01 (Single Input Contact)
    This profile is notably used by window / door sensors.
    def __init__(self, dev_id, dev_name):
        """Initialize the EnOcean window handle sensor device."""
        super().__init__(dev_id, dev_name, SENSOR_TYPE_CONTACT)
    def value_changed(self, packet):
        """Update the internal state of the sensor."""
        status = (packet.data[1] & 0x01)
        if status == 0x01:
            self._state = STATE_CLOSED
        else:
            self._state = STATE_OPEN
        self.schedule_update_ha_state()
Does this approach sound correct to you ?
Hi Jerome !
seems Enocean is not as popular as Zigbee !
I have the exact same Nodon sensor, and can’t use it in HA…
I would like to know what you did with this Enocean device; I’m thinking to switch to Zigbee (I come from Jeedom which is much more efficient with Enocean devices !)
Hello MisteurJ
Sadly, I did not do a lot: I tried to work on the enOcean integration to bring it up to speed, but it seems my python skills are not enough for that. I was able to add the UI configuration to this, but not more, despite the fact that the enOcean protocol is fairly simple.
As of today, my enOcean sensors are sitting on a shelf, and I bought a pair of zigbee sensors, even if in my case, the enOcean sensors would better fit my needs :frowning: .
Hi Jerome and MisteurJ,
I also just bought the sensor and was disappointed by the lack of integration. You were on the right path with your extension of the sensor.py. The only thing you were missing is the integration into the top-level.
I named it “windowsensor” to emphasise the similarity to “windowhandle”.
This code works for me:
sensor.py
"""Support for EnOcean sensors."""
from __future__ import annotations
from collections.abc import Callable
from dataclasses import dataclass
from enocean.utils import combine_hex
import voluptuous as vol
from homeassistant.components.sensor import (
    PLATFORM_SCHEMA,
    SensorDeviceClass,
    SensorEntity,
    SensorEntityDescription,
    SensorStateClass,
from homeassistant.const import (
    CONF_DEVICE_CLASS,
    CONF_ID,
    CONF_NAME,
    PERCENTAGE,
    STATE_CLOSED,
    STATE_OPEN,
    UnitOfPower,
    UnitOfTemperature,
from homeassistant.core import HomeAssistant
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.restore_state import RestoreEntity
from homeassistant.helpers.typing import ConfigType, DiscoveryInfoType
from .device import EnOceanEntity
CONF_MAX_TEMP = "max_temp"
CONF_MIN_TEMP = "min_temp"
CONF_RANGE_FROM = "range_from"
CONF_RANGE_TO = "range_to"
DEFAULT_NAME = "EnOcean sensor"
SENSOR_TYPE_HUMIDITY = "humidity"
SENSOR_TYPE_POWER = "powersensor"
SENSOR_TYPE_TEMPERATURE = "temperature"
SENSOR_TYPE_WINDOWHANDLE = "windowhandle"
SENSOR_TYPE_WINDOWSENSOR = "windowsensor"
@dataclass
class EnOceanSensorEntityDescriptionMixin:
    """Mixin for required keys."""
    unique_id: Callable[[list[int]], str | None]
@dataclass
class EnOceanSensorEntityDescription(
    SensorEntityDescription, EnOceanSensorEntityDescriptionMixin
    """Describes EnOcean sensor entity."""
SENSOR_DESC_TEMPERATURE = EnOceanSensorEntityDescription(
    key=SENSOR_TYPE_TEMPERATURE,
    name="Temperature",
    native_unit_of_measurement=UnitOfTemperature.CELSIUS,
    icon="mdi:thermometer",
    device_class=SensorDeviceClass.TEMPERATURE,
    state_class=SensorStateClass.MEASUREMENT,
    unique_id=lambda dev_id: f"{combine_hex(dev_id)}-{SENSOR_TYPE_TEMPERATURE}",
SENSOR_DESC_HUMIDITY = EnOceanSensorEntityDescription(
    key=SENSOR_TYPE_HUMIDITY,
    name="Humidity",
    native_unit_of_measurement=PERCENTAGE,
    icon="mdi:water-percent",
    device_class=SensorDeviceClass.HUMIDITY,
    unique_id=lambda dev_id: f"{combine_hex(dev_id)}-{SENSOR_TYPE_HUMIDITY}",
SENSOR_DESC_POWER = EnOceanSensorEntityDescription(
    key=SENSOR_TYPE_POWER,
    name="Power",
    native_unit_of_measurement=UnitOfPower.WATT,
    icon="mdi:power-plug",
    device_class=SensorDeviceClass.POWER,
    unique_id=lambda dev_id: f"{combine_hex(dev_id)}-{SENSOR_TYPE_POWER}",
SENSOR_DESC_WINDOWHANDLE = EnOceanSensorEntityDescription(
    key=SENSOR_TYPE_WINDOWHANDLE,
    name="WindowHandle",
    icon="mdi:window-open-variant",
    unique_id=lambda dev_id: f"{combine_hex(dev_id)}-{SENSOR_TYPE_WINDOWHANDLE}",
SENSOR_DESC_WINDOWSENSOR = EnOceanSensorEntityDescription(
    key=SENSOR_TYPE_WINDOWSENSOR,
    name="WindowSensor",
    unique_id=lambda dev_id: f"{combine_hex(dev_id)}-{SENSOR_TYPE_WINDOWSENSOR}",
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
        vol.Required(CONF_ID): vol.All(cv.ensure_list, [vol.Coerce(int)]),
        vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
        vol.Optional(CONF_DEVICE_CLASS, default=SENSOR_TYPE_POWER): cv.string,
        vol.Optional(CONF_MAX_TEMP, default=40): vol.Coerce(int),
        vol.Optional(CONF_MIN_TEMP, default=0): vol.Coerce(int),
        vol.Optional(CONF_RANGE_FROM, default=255): cv.positive_int,
        vol.Optional(CONF_RANGE_TO, default=0): cv.positive_int,
def setup_platform(
    hass: HomeAssistant,
    config: ConfigType,
    add_entities: AddEntitiesCallback,
    discovery_info: DiscoveryInfoType | None = None,
) -> None:
    """Set up an EnOcean sensor device."""
    dev_id = config[CONF_ID]
    dev_name = config[CONF_NAME]
    sensor_type = config[CONF_DEVICE_CLASS]
    entities: list[EnOceanSensor] = []
    if sensor_type == SENSOR_TYPE_TEMPERATURE:
        temp_min = config[CONF_MIN_TEMP]
        temp_max = config[CONF_MAX_TEMP]
        range_from = config[CONF_RANGE_FROM]
        range_to = config[CONF_RANGE_TO]
        entities = [
            EnOceanTemperatureSensor(
                dev_id,
                dev_name,
                SENSOR_DESC_TEMPERATURE,
                scale_min=temp_min,
                scale_max=temp_max,
                range_from=range_from,
                range_to=range_to,
    elif sensor_type == SENSOR_TYPE_HUMIDITY:
        entities = [EnOceanHumiditySensor(dev_id, dev_name, SENSOR_DESC_HUMIDITY)]
    elif sensor_type == SENSOR_TYPE_POWER:
        entities = [EnOceanPowerSensor(dev_id, dev_name, SENSOR_DESC_POWER)]
    elif sensor_type == SENSOR_TYPE_WINDOWHANDLE:
        entities = [EnOceanWindowHandle(dev_id, dev_name, SENSOR_DESC_WINDOWHANDLE)]
    elif sensor_type == SENSOR_TYPE_WINDOWSENSOR:
        entities = [EnOceanWindowSensor(dev_id, dev_name, SENSOR_DESC_WINDOWSENSOR)]
    add_entities(entities)
class EnOceanSensor(EnOceanEntity, RestoreEntity, SensorEntity):
    """Representation of an  EnOcean sensor device such as a power meter."""
    def __init__(
        self, dev_id, dev_name, description: EnOceanSensorEntityDescription
    ) -> None:
        """Initialize the EnOcean sensor device."""
        super().__init__(dev_id, dev_name)
        self.entity_description = description
        self._attr_name = f"{description.name} {dev_name}"
        self._attr_unique_id = description.unique_id(dev_id)
    async def async_added_to_hass(self) -> None:
        """Call when entity about to be added to hass."""
        # If not None, we got an initial value.
        await super().async_added_to_hass()
        if self._attr_native_value is not None:
            return
        if (state := await self.async_get_last_state()) is not None:
            self._attr_native_value = state.state
class EnOceanPowerSensor(EnOceanSensor):
    """Representation of an EnOcean power sensor.
    - A5-12-01 (Automated Meter Reading, Electricity)
        if packet.rorg != 0xA5:
            return
        packet.parse_eep(0x12, 0x01)
        if packet.parsed["DT"]["raw_value"] == 1:
            # this packet reports the current value
            raw_val = packet.parsed["MR"]["raw_value"]
            divisor = packet.parsed["DIV"]["raw_value"]
            self._attr_native_value = raw_val / (10**divisor)
class EnOceanTemperatureSensor(EnOceanSensor):
    """Representation of an EnOcean temperature sensor device.
    - A5-02-01 to A5-02-1B All 8 Bit Temperature Sensors of A5-02
    - A5-10-01 to A5-10-14 (Room Operating Panels)
    - A5-04-01 (Temp. and Humidity Sensor, Range 0°C to +40°C and 0% to 100%)
    - A5-04-02 (Temp. and Humidity Sensor, Range -20°C to +60°C and 0% to 100%)
    - A5-10-10 (Temp. and Humidity Sensor and Set Point)
    - A5-10-12 (Temp. and Humidity Sensor, Set Point and Occupancy Control)
    - 10 Bit Temp. Sensors are not supported (A5-02-20, A5-02-30)
    For the following EEPs the scales must be set to "0 to 250":
    - A5-04-01
    - A5-04-02
    - A5-10-10 to A5-10-14
    def __init__(
        self,
        dev_id,
        dev_name,
        description: EnOceanSensorEntityDescription,
        scale_min,
        scale_max,
        range_from,
        range_to,
    ) -> None:
        """Initialize the EnOcean temperature sensor device."""
        super().__init__(dev_id, dev_name, description)
        self._scale_min = scale_min
        self._scale_max = scale_max
        self.range_from = range_from
        self.range_to = range_to
        if packet.data[0] != 0xA5:
            return
        temp_scale = self._scale_max - self._scale_min
        temp_range = self.range_to - self.range_from
        raw_val = packet.data[3]
        temperature = temp_scale / temp_range * (raw_val - self.range_from)
        temperature += self._scale_min
        self._attr_native_value = round(temperature, 1)
class EnOceanHumiditySensor(EnOceanSensor):
    """Representation of an EnOcean humidity sensor device.
    - A5-10-10 to A5-10-14 (Room Operating Panels)
            return
        humidity = packet.data[2] * 100 / 250
        self._attr_native_value = round(humidity, 1)
class EnOceanWindowHandle(EnOceanSensor):
    """Representation of an EnOcean window handle device.
    - F6-10-00 (Mechanical handle / Hoppe AG)
        action = (packet.data[1] & 0x70) >> 4
        if action == 0x07:
            self._attr_native_value = STATE_CLOSED
        if action in (0x04, 0x06):
            self._attr_native_value = STATE_OPEN
        if action == 0x05:
            self._attr_native_value = "tilt"
class EnOceanWindowSensor(EnOceanSensor):
    - D5-00-01
        action = (packet.data[1] & 0x01)
        if action == 0x01:
        else:
I’ll try to submit it into the mainline code.
