Entities/Device/Area dropdown selection not working properly
So inside Home Assistant I use Node Red.
When I want to choose area/device/entity every things is populated sideway instead as before, in a proper dropdown.
Tried this in Safari/Firefox/Chrome with same problem.
I’m on
Home Assistant 2022.10.5
Supervisor 2022.10.0
Operating System 9.2
Frontend 20221010.0 - latest
and
Node Red
Current version: 13.5.0
Hopefully this is a known bug and a fix is near future and if that is the case I apologise posting this, in other case I hope this can be fixed in near future.
//Boz
I have heard of this before and I think it was due to some name of the entities with a special character that cause it.
Thanks for answering, it was a time ago but I have now tried to find the special character but without success.
Still a problem, is there a way to debug this better?
It’s a bit annoying.
You could open up your Developer Tools (not the HA one) in your browser. It is normally F12 that activates that.
Then look at the HTML code to find the special character, but you would need to know a bit of HTML to spot it.
The special character is normally one of the HTML used characters, like ’ or " or < or > or /
it can be a hint where the error occur, because then it is likely an error in the previous section in the code, so if your entity list is placed wrongly and the area list is before, then area is most likely to cause the issue, but it is not certain though.
Thanks for the tip.
I tried it but couldn’t really find any special characters in that code either.
The lights name is called - Kitchentable 1, Kitchentable 2, Kitchentable 3, Kitchentable 4, Kitchentable 5.
Could it be a problem with space in the name?
<span class="selection">
  <span class="select2-selection select2-selection--multiple" role="combobox" aria-haspopup="true" aria-expanded="true" tabindex="-1" aria-disabled="false" aria-owns="select2-node-input-deviceId-results" aria-activedescendant="select2-node-input-deviceId-result-s8rv-8de13f769e3b35e5f7e638d855ea51a7">
    <ul class="select2-selection__rendered" id="select2-node-input-deviceId-container">
      <li class="select2-selection__choice" title="Kitchen" data-select2-id="select2-data-717-utde">
        <button type="button" class="select2-selection__choice__remove" tabindex="-1" title="Remove item" aria-label="Remove item" aria-describedby="select2-node-input-deviceId-container-choice-x8k6-8de13f769e3b35e5f7e638d855ea51a7">
          <span aria-hidden="true">×</span>
        </button>
        <span class="select2-selection__choice__display" id="select2-node-input-deviceId-container-choice-x8k6-8de13f769e3b35e5f7e638d855ea51a7">Kitchentable 1</span>
      </li>
      <li class="select2-selection__choice" title="Kitchen" data-select2-id="select2-data-718-941v">
        <button type="button" class="select2-selection__choice__remove" tabindex="-1" title="Remove item" aria-label="Remove item" aria-describedby="select2-node-input-deviceId-container-choice-0f3t-deff0a422cb445d01370564ffb08fd82">
        </button>
        <span class="select2-selection__choice__display" id="select2-node-input-deviceId-container-choice-0f3t-deff0a422cb445d01370564ffb08fd82">Kitchentable 2</span>
      </li>
      <li class="select2-selection__choice" title="Kitchen" data-select2-id="select2-data-719-dbdf">
        <button type="button" class="select2-selection__choice__remove" tabindex="-1" title="Remove item" aria-label="Remove item" aria-describedby="select2-node-input-deviceId-container-choice-kbps-d00141597a24d9eb0b23a14db8cd27a3">
        </button>
        <span class="select2-selection__choice__display" id="select2-node-input-deviceId-container-choice-kbps-d00141597a24d9eb0b23a14db8cd27a3">Kitchentable 3</span>
      </li>
      <li class="select2-selection__choice" title="Kitchen" data-select2-id="select2-data-720-qjf5">
        <button type="button" class="select2-selection__choice__remove" tabindex="-1" title="Remove item" aria-label="Remove item" aria-describedby="select2-node-input-deviceId-container-choice-87iq-397c0ffba985a749943608f7fdedddf2">
        </button>
        <span class="select2-selection__choice__display" id="select2-node-input-deviceId-container-choice-87iq-397c0ffba985a749943608f7fdedddf2">Kitchentable 4</span>
      </li>
      <li class="select2-selection__choice" title="Kitchen" data-select2-id="select2-data-721-dz4q">
        <button type="button" class="select2-selection__choice__remove" tabindex="-1" title="Remove item" aria-label="Remove item" aria-describedby="select2-node-input-deviceId-container-choice-nqw8-7176dc9642a8206546523bcb1e4bc7c9">
        </button>
        <span class="select2-selection__choice__display" id="select2-node-input-deviceId-container-choice-nqw8-7176dc9642a8206546523bcb1e4bc7c9">Kitchentable 5</span>
      </li>
    </ul>
    <span class="select2-search select2-search--inline">
      <textarea class="select2-search__field" type="search" tabindex="0" autocorrect="off" autocapitalize="none" spellcheck="false" role="searchbox" aria-autocomplete="list" autocomplete="off" aria-label="Search" aria-describedby="select2-node-input-deviceId-container" placeholder="" style="width: 0.75em;" aria-controls="select2-node-input-deviceId-results" aria-activedescendant="select2-node-input-deviceId-result-s8rv-8de13f769e3b35e5f7e638d855ea51a7"></textarea>
    </span>
  </span>
</span>
Spaces should not cause such an issue.
First goto HA and make a screenshot of your areas and post it here.
Then post the list of your entities from developer tools. Check if there are any sensitive data, like passwords, usernames, public IPs and so on.
We really only need the entity name (the one in blue text starting with climate. light. and so on), the name (the one below the blue text) and the friendly name (the one listed as friendly_name in the right side column).
Ok, I’ll fix a list, will take a while to produce one, a LOT of entities…
Ok, the entities is arround 120.000 post and the current allowed character limit in this post is 32000.
How should I share this?
Split it into several posts.
First 700 (of 4102)
alarm_control_panel.home_alarm
Home Alarm
friendly_name: Home Alarm
automation.21_clock_turn_off
21 clock turn off
friendly_name: 21 clock turn off
binary_sensor.4_in_1_multisensor_low_battery_level
4 in 1 MultiSensor Low battery level
friendly_name: 4 in 1 MultiSensor Low battery level
binary_sensor.all_motions
Group All Motions
friendly_name: Group All Motions
binary_sensor.back_door
Back door
friendly_name: Back door
binary_sensor.backdoor_detections_motion
Backdoor Detections: Motion
friendly_name: Backdoor Detections: Motion
binary_sensor.backdoor_hdr_mode
Backdoor Hdr Mode
friendly_name: Backdoor Hdr Mode
binary_sensor.backdoor_is_dark
Backdoor Is Dark
friendly_name: Backdoor Is Dark
binary_sensor.backdoor_motion
Backdoor Motion
friendly_name: Backdoor Motion
binary_sensor.backdoor_overlay_show_bitrate
Backdoor Overlay: Show Bitrate
friendly_name: Backdoor Overlay: Show Bitrate
binary_sensor.backdoor_overlay_show_date
Backdoor Overlay: Show Date
friendly_name: Backdoor Overlay: Show Date
binary_sensor.backdoor_overlay_show_logo
Backdoor Overlay: Show Logo
friendly_name: Backdoor Overlay: Show Logo
binary_sensor.backdoor_overlay_show_name
Backdoor Overlay: Show Name
friendly_name: Backdoor Overlay: Show Name
binary_sensor.carbon_monoxide_sensor_co_alarm_carbon_monoxide_detected
Carbon Monoxide Sensor Carbon monoxide detected
friendly_name: Carbon Monoxide Sensor Carbon monoxide detected
binary_sensor.carbon_monoxide_sensor_co_alarm_carbon_monoxide_test
friendly_name: Carbon Monoxide Sensor Carbon monoxide test
binary_sensor.carbon_monoxide_sensor_co_alarm_replacement_required
Carbon Monoxide Sensor Replacement required
friendly_name: Carbon Monoxide Sensor Replacement required
binary_sensor.carbon_monoxide_sensor_heat_alarm_overheat_detected
Carbon Monoxide Sensor Overheat detected
friendly_name: Carbon Monoxide Sensor Overheat detected
binary_sensor.carbon_monoxide_sensor_home_security_tampering_product_cover_removed
Carbon Monoxide Sensor Tampering, product cover removed
friendly_name: Carbon Monoxide Sensor Tampering, product cover removed
binary_sensor.carbon_monoxide_sensor_low_battery_level
Carbon Monoxide Sensor Low battery level
friendly_name: Carbon Monoxide Sensor Low battery level
binary_sensor.carbon_monoxide_sensor_power_management_replace_battery_soon
Carbon Monoxide Sensor Replace battery soon
friendly_name: Carbon Monoxide Sensor Replace battery soon
binary_sensor.carbon_monoxide_sensor_system_system_hardware_failure
Carbon Monoxide Sensor System hardware failure
friendly_name: Carbon Monoxide Sensor System hardware failure
binary_sensor.entertainment_area_entertainment_configuration
Entertainment area: Entertainment Configuration
friendly_name: Entertainment area: Entertainment Configuration
binary_sensor.first_floor_motion
First Floor Motion
friendly_name: First Floor Motion
binary_sensor.flood_sensor_home_security_tampering_product_cover_removed
Flood Sensor Tampering, product cover removed
friendly_name: Flood Sensor Tampering, product cover removed
binary_sensor.flood_sensor_low_battery_level
Flood Sensor Low battery level
friendly_name: Flood Sensor Low battery level
binary_sensor.flood_sensor_water_alarm_water_leak_detected
Flood Sensor Water leak detected
friendly_name: Flood Sensor Water leak detected
binary_sensor.front_door
Front door
friendly_name: Front door
binary_sensor.front_door_ding
Front Door Ding
friendly_name: Front Door Ding
binary_sensor.front_door_motion
Front Door Motion
friendly_name: Front Door Motion
binary_sensor.frontdoor_detections_motion
Frontdoor Detections: Motion
friendly_name: Frontdoor Detections: Motion
binary_sensor.frontdoor_hdr_mode
Frontdoor Hdr Mode
friendly_name: Frontdoor Hdr Mode
binary_sensor.frontdoor_is_dark
Frontdoor Is Dark
friendly_name: Frontdoor Is Dark
binary_sensor.frontdoor_motion
Frontdoor Motion
friendly_name: Frontdoor Motion
binary_sensor.frontdoor_overlay_show_bitrate
Frontdoor Overlay: Show Bitrate
friendly_name: Frontdoor Overlay: Show Bitrate
binary_sensor.frontdoor_overlay_show_date
Frontdoor Overlay: Show Date
friendly_name: Frontdoor Overlay: Show Date
binary_sensor.frontdoor_overlay_show_logo
Frontdoor Overlay: Show Logo
friendly_name: Frontdoor Overlay: Show Logo
binary_sensor.frontdoor_overlay_show_name
Frontdoor Overlay: Show Name
friendly_name: Frontdoor Overlay: Show Name
binary_sensor.g3_dome_detections_motion
G3 Dome Detections: Motion
friendly_name: G3 Dome Detections: Motion
binary_sensor.g3_dome_is_dark
G3 Dome Is Dark
friendly_name: G3 Dome Is Dark
binary_sensor.g3_dome_motion
G3 Dome Motion
friendly_name: G3 Dome Motion
binary_sensor.g3_dome_overlay_show_bitrate
G3 Dome Overlay: Show Bitrate
friendly_name: G3 Dome Overlay: Show Bitrate
binary_sensor.g3_dome_overlay_show_date
G3 Dome Overlay: Show Date
friendly_name: G3 Dome Overlay: Show Date
binary_sensor.g3_dome_overlay_show_logo
G3 Dome Overlay: Show Logo
friendly_name: G3 Dome Overlay: Show Logo
binary_sensor.g3_dome_overlay_show_name
G3 Dome Overlay: Show Name
friendly_name: G3 Dome Overlay: Show Name
binary_sensor.g3_dome_status_light_on
G3 Dome Status Light On
friendly_name: G3 Dome Status Light On
binary_sensor.garage_door
Garage door
friendly_name: Garage door
binary_sensor.garage_port
Garage Port
friendly_name: Garage Port
binary_sensor.group_bathroom_pir
Group Bathroom PIR
friendly_name: Group Bathroom PIR
binary_sensor.group_kitchen_pir
Group Kitchen PIR
friendly_name: Group Kitchen PIR
binary_sensor.group_outside_pir
Group Outside PIR
friendly_name: Group Outside PIR
binary_sensor.group_pir_downstairs
Group PIR Downstairs
friendly_name: Group PIR Downstairs
binary_sensor.house_outside_doors
House Outside Doors
friendly_name: House Outside Doors
binary_sensor.ipad_focus
iPad Focus
friendly_name: iPad Focus
binary_sensor.jul_switch_on_off
Jul Switch ON/OFF
friendly_name: Jul Switch ON/OFF
binary_sensor.kitchen_door
Kitchen door
friendly_name: Kitchen door
binary_sensor.light_kitchen_sink_heat_alarm_overheat_detected
Light Kitchen - Sink: Heat Alarm - Overheat detected
friendly_name: Light Kitchen - Sink: Heat Alarm - Overheat detected
binary_sensor.light_kitchen_sink_power_management_over_current_detected
Light Kitchen - Sink: Power Management - Over-current detected
friendly_name: Light Kitchen - Sink: Power Management - Over-current detected
binary_sensor.light_outside_backside_heat_alarm_overheat_detected
Light Outside - Backside: Heat Alarm - Overheat detected
friendly_name: Light Outside - Backside: Heat Alarm - Overheat detected
binary_sensor.light_outside_backside_power_management_load_error
Light Outside - Backside: Power Management - Load error
friendly_name: Light Outside - Backside: Power Management - Load error
binary_sensor.light_outside_backside_power_management_over_current_detected
Light Outside - Backside: Power Management - Over-current detected
friendly_name: Light Outside - Backside: Power Management - Over-current detected
binary_sensor.light_outside_backside_power_management_over_load_detected
Light Outside - Backside: Power Management - Over-load detected
friendly_name: Light Outside - Backside: Power Management - Over-load detected
binary_sensor.light_outside_backside_system_system_hardware_failure
Light Outside - Backside: System - System hardware failure
friendly_name: Light Outside - Backside: System - System hardware failure
binary_sensor.light_outside_frontdoor_heat_alarm_overheat_detected_3
Light Outside - Frontdoor: Heat Alarm - Overheat detected
friendly_name: Light Outside - Frontdoor: Heat Alarm - Overheat detected
binary_sensor.light_outside_frontdoor_power_management_load_error_3
Light Outside - Frontdoor: Power Management - Load error
friendly_name: Light Outside - Frontdoor: Power Management - Load error
binary_sensor.light_outside_frontdoor_power_management_over_current_detected_3
Light Outside - Frontdoor: Power Management - Over-current detected
friendly_name: Light Outside - Frontdoor: Power Management - Over-current detected
binary_sensor.light_outside_frontdoor_power_management_over_load_detected_3
Light Outside - Frontdoor: Power Management - Over-load detected
friendly_name: Light Outside - Frontdoor: Power Management - Over-load detected
binary_sensor.light_outside_frontdoor_system_system_hardware_failure_3
Light Outside - Frontdoor: System - System hardware failure
friendly_name: Light Outside - Frontdoor: System - System hardware failure
binary_sensor.light_outside_garage_heat_alarm_overheat_detected_4
Light Outside - Garage: Heat Alarm - Overheat detected
friendly_name: Light Outside - Garage: Heat Alarm - Overheat detected
binary_sensor.light_outside_garage_power_management_load_error_4
Light Outside - Garage: Power Management - Load error
friendly_name: Light Outside - Garage: Power Management - Load error
binary_sensor.light_outside_garage_power_management_over_current_detected_4
Light Outside - Garage: Power Management - Over-current detected
friendly_name: Light Outside - Garage: Power Management - Over-current detected
binary_sensor.light_outside_garage_power_management_over_load_detected_4
Light Outside - Garage: Power Management - Over-load detected
friendly_name: Light Outside - Garage: Power Management - Over-load detected
binary_sensor.light_outside_garage_system_system_hardware_failure_4
Light Outside - Garage: System - System hardware failure
friendly_name: Light Outside - Garage: System - System hardware failure
binary_sensor.light_outside_kitchen_heat_alarm_overheat_detected_2
Light Outside - Kitchen: Heat Alarm - Overheat detected
friendly_name: Light Outside - Kitchen: Heat Alarm - Overheat detected
binary_sensor.light_outside_kitchen_motion_detection
Light Outside - Kitchen Motion detection
friendly_name: Light Outside - Kitchen Motion detection
binary_sensor.light_outside_kitchen_power_management_load_error_2
Light Outside - Kitchen: Power Management - Load error
friendly_name: Light Outside - Kitchen: Power Management - Load error
binary_sensor.light_outside_kitchen_power_management_over_current_detected_2
Light Outside - Kitchen: Power Management - Over-current detected
friendly_name: Light Outside - Kitchen: Power Management - Over-current detected
binary_sensor.light_outside_kitchen_power_management_over_load_detected_2
Light Outside - Kitchen: Power Management - Over-load detected
friendly_name: Light Outside - Kitchen: Power Management - Over-load detected
binary_sensor.light_outside_kitchen_system_system_hardware_failure_2
Light Outside - Kitchen: System - System hardware failure
friendly_name: Light Outside - Kitchen: System - System hardware failure
binary_sensor.lights_bathroom_ground_floor_heat_alarm_overheat_detected_2
Lights Bathroom - Ground Floor: Heat Alarm - Overheat detected
friendly_name: Lights Bathroom - Ground Floor: Heat Alarm - Overheat detected
binary_sensor.lights_bathroom_ground_floor_power_management_over_current_detected_2
Lights Bathroom - Ground Floor: Power Management - Over-current detected
friendly_name: Lights Bathroom - Ground Floor: Power Management - Over-current detected
binary_sensor.lights_bathroom_top_floor_heat_alarm_overheat_detected_3
Lights Bathroom - Top Floor: Heat Alarm - Overheat detected
friendly_name: Lights Bathroom - Top Floor: Heat Alarm - Overheat detected
binary_sensor.lights_bathroom_top_floor_power_management_over_current_detected_3
Lights Bathroom - Top Floor: Power Management - Over-current detected
friendly_name: Lights Bathroom - Top Floor: Power Management - Over-current detected
binary_sensor.lights_kitchen_heat_alarm_overheat_detected
Lights Kitchen: Heat Alarm - Overheat detected
friendly_name: Lights Kitchen: Heat Alarm - Overheat detected
binary_sensor.lights_kitchen_power_management_over_current_detected
Lights Kitchen: Power Management - Over-current detected
friendly_name: Lights Kitchen: Power Management - Over-current detected
binary_sensor.living_connect_z_thermostat_battery_is_disconnected
Radiator Working Area Battery is disconnected
friendly_name: Radiator Working Area Battery is disconnected
binary_sensor.living_connect_z_thermostat_battery_temperature_is_low
Radiator Working Area Battery temperature is low
friendly_name: Radiator Working Area Battery temperature is low
binary_sensor.living_connect_z_thermostat_fluid_is_low
Radiator Working Area Fluid is low
friendly_name: Radiator Working Area Fluid is low
binary_sensor.living_connect_z_thermostat_low_battery_level
Radiator Working Area Low battery level
friendly_name: Radiator Working Area Low battery level
binary_sensor.living_connect_z_thermostat_overheating
Radiator Working Area Overheating
friendly_name: Radiator Working Area Overheating
binary_sensor.living_connect_z_thermostat_rechargeable
Radiator Working Area Rechargeable
friendly_name: Radiator Working Area Rechargeable
binary_sensor.living_connect_z_thermostat_used_as_backup
Radiator Working Area Used as backup
friendly_name: Radiator Working Area Used as backup
binary_sensor.metered_wall_plug_switch_home_security_motion_detection
Power Living room AirCleaner Motion detection
friendly_name: Power Living room AirCleaner Motion detection
binary_sensor.motion_livingroom_motion
Motion Livingroom Motion
friendly_name: Motion Livingroom Motion
binary_sensor.motion_sensor_water_alarm_water_temperature_alarm
PIR Hallway Top Floor Water temperature alarm
friendly_name: PIR Hallway Top Floor Water temperature alarm
binary_sensor.nebo_tv_area_entertainment_configuration
Nebo TV area: Entertainment Configuration
friendly_name: Nebo TV area: Entertainment Configuration
binary_sensor.pir_bathroom_top_floor_mirror_home_security_motion_detection
PIR Bathroom Top Floor Mirror: Home Security - Motion detection
friendly_name: PIR Bathroom Top Floor Mirror: Home Security - Motion detection
binary_sensor.pir_bathroom_top_floor_mirror_home_security_tampering_product_cover_removed
PIR Bathroom Top Floor Mirror: Home Security - Tampering, product cover removed
friendly_name: PIR Bathroom Top Floor Mirror: Home Security - Tampering, product cover removed
binary_sensor.pir_bathroom_top_floor_mirror_low_battery_level_4
PIR Bathroom Top Floor Mirror: Low battery level
friendly_name: PIR Bathroom Top Floor Mirror: Low battery level
binary_sensor.pir_ground_floor_bathroom_celling_occupancy
PIR Ground Floor Bathroom Celling occupancy
friendly_name: PIR Ground Floor Bathroom Celling occupancy
binary_sensor.pir_hallway_downstairs_occupancy
PIR Hallway downstairs occupancy
friendly_name: PIR Hallway downstairs occupancy
binary_sensor.pir_hallway_frontdoor_occupancy
PIR Hallway Frontdoor occupancy
friendly_name: PIR Hallway Frontdoor occupancy
binary_sensor.pir_hallway_top_floor_home_security_motion_detection_3
PIR Hallway Top Floor: Home Security - Motion detection
friendly_name: PIR Hallway Top Floor: Home Security - Motion detection
binary_sensor.pir_hallway_top_floor_home_security_tampering_product_cover_removed_3
PIR Hallway Top Floor: Home Security - Tampering, product cover removed
friendly_name: PIR Hallway Top Floor: Home Security - Tampering, product cover removed
binary_sensor.pir_hallway_top_floor_low_battery_level_7
PIR Hallway Top Floor: Low battery level
friendly_name: PIR Hallway Top Floor: Low battery level
binary_sensor.pir_kitchen_left_occupancy
PIR Kitchen Left occupancy
friendly_name: PIR Kitchen Left occupancy
binary_sensor.pir_kitchen_middle_left_occupancy
PIR Kitchen Middle Left occupancy
friendly_name: PIR Kitchen Middle Left occupancy
binary_sensor.pir_kitchen_middle_right_occupancy
PIR Kitchen Middle Right occupancy
friendly_name: PIR Kitchen Middle Right occupancy
binary_sensor.pir_kitchen_right_occupancy
PIR Kitchen Right occupancy
friendly_name: PIR Kitchen Right occupancy
binary_sensor.pir_kitchen_table_occupancy
PIR Kitchen Table occupancy
friendly_name: PIR Kitchen Table occupancy
binary_sensor.pir_outside_front_sensor_state_any_2_2
PIR Outside Front: Garage
friendly_name: PIR Outside Front: Garage
binary_sensor.pir_outside_front_sensor_state_any_3
PIR Outside Front: Frontdoor
friendly_name: PIR Outside Front: Frontdoor
binary_sensor.pir_stairs_occupancy
PIR Stairs occupancy
friendly_name: PIR Stairs occupancy
binary_sensor.pir_top_floor_bathroom_celling_occupancy
PIR Top Floor Bathroom Celling occupancy
friendly_name: PIR Top Floor Bathroom Celling occupancy
binary_sensor.power_ac_motion_detection
Power AC Motion detection
friendly_name: Power AC Motion detection
binary_sensor.power_ac_power_management_over_current_detected_4
Power AC: Power Management - Over-current detected
friendly_name: Power AC: Power Management - Over-current detected
binary_sensor.power_ac_power_management_over_load_detected_4
Power AC: Power Management - Over-load detected
friendly_name: Power AC: Power Management - Over-load detected
binary_sensor.power_barndoor_power_management_over_current_detected_5
Power Barndoor: Power Management - Over-current detected
friendly_name: Power Barndoor: Power Management - Over-current detected
binary_sensor.power_barndoor_power_management_over_load_detected_5
Power Barndoor: Power Management - Over-load detected
friendly_name: Power Barndoor: Power Management - Over-load detected
binary_sensor.power_dryer_power_management_over_current_detected_15
Power Dryer: Power Management - Over-current detected
friendly_name: Power Dryer: Power Management - Over-current detected
binary_sensor.power_dryer_power_management_over_load_detected_15
Power Dryer: Power Management - Over-load detected
friendly_name: Power Dryer: Power Management - Over-load detected
binary_sensor.power_ecoflow_delta_battery_power_management_over_current_detected_12
Power EcoFlow Delta Battery: Power Management - Over-current detected
friendly_name: Power EcoFlow Delta Battery: Power Management - Over-current detected
binary_sensor.power_ecoflow_delta_battery_power_management_over_load_detected_12
Power EcoFlow Delta Battery: Power Management - Over-load detected
friendly_name: Power EcoFlow Delta Battery: Power Management - Over-load detected
binary_sensor.power_garage_freezer_power_management_over_current_detected
Power Garage Freezer: Power Management - Over-current detected
friendly_name: Power Garage Freezer: Power Management - Over-current detected
binary_sensor.power_garage_freezer_power_management_over_load_detected
Power Garage Freezer: Power Management - Over-load detected
friendly_name: Power Garage Freezer: Power Management - Over-load detected
binary_sensor.power_homeassistant_and_others_power_management_over_current_detected_10
Power HomeAssistant and others: Power Management - Over-current detected
friendly_name: Power HomeAssistant and others: Power Management - Over-current detected
binary_sensor.power_homeassistant_and_others_power_management_over_load_detected_10
Power HomeAssistant and others: Power Management - Over-load detected
friendly_name: Power HomeAssistant and others: Power Management - Over-load detected
binary_sensor.power_kitchen_freezer_power_management_over_current_detected_13
Power Kitchen Freezer: Power Management - Over-current detected
friendly_name: Power Kitchen Freezer: Power Management - Over-current detected
binary_sensor.power_kitchen_freezer_power_management_over_load_detected_13
Power Kitchen Freezer: Power Management - Over-load detected
friendly_name: Power Kitchen Freezer: Power Management - Over-load detected
binary_sensor.power_kitchen_fridge_power_management_over_current_detected_14
Power Kitchen Fridge: Power Management - Over-current detected
friendly_name: Power Kitchen Fridge: Power Management - Over-current detected
binary_sensor.power_kitchen_fridge_power_management_over_load_detected_14
Power Kitchen Fridge: Power Management - Over-load detected
friendly_name: Power Kitchen Fridge: Power Management - Over-load detected
binary_sensor.power_living_room_aircleaner_power_management_over_current_detected_3
Power Living room AirCleaner: Power Management - Over-current detected
friendly_name: Power Living room AirCleaner: Power Management - Over-current detected
binary_sensor.power_living_room_aircleaner_power_management_over_load_detected_3
Power Living room AirCleaner: Power Management - Over-load detected
friendly_name: Power Living room AirCleaner: Power Management - Over-load detected
binary_sensor.power_nebos_dator_power_management_over_current_detected_11
Power Nebos Dator: Power Management - Over-current detected
friendly_name: Power Nebos Dator: Power Management - Over-current detected
binary_sensor.power_nebos_dator_power_management_over_load_detected_11
Power Nebos Dator: Power Management - Over-load detected
friendly_name: Power Nebos Dator: Power Management - Over-load detected
binary_sensor.power_primary_switch_power_management_over_current_detected_9
Power Primary switch: Power Management - Over-current detected
friendly_name: Power Primary switch: Power Management - Over-current detected
binary_sensor.power_primary_switch_power_management_over_load_detected_9
Power Primary switch: Power Management - Over-load detected
friendly_name: Power Primary switch: Power Management - Over-load detected
binary_sensor.power_rack_power_management_over_current_detected_2
Power Rack: Power Management - Over-current detected
friendly_name: Power Rack: Power Management - Over-current detected
binary_sensor.power_rack_power_management_over_load_detected_2
Power Rack: Power Management - Over-load detected
friendly_name: Power Rack: Power Management - Over-load detected
binary_sensor.power_second_switch_power_management_over_current_detected_7
Power Second Switch: Power Management - Over-current detected
friendly_name: Power Second Switch: Power Management - Over-current detected
binary_sensor.power_second_switch_power_management_over_load_detected_7
Power Second Switch: Power Management - Over-load detected
friendly_name: Power Second Switch: Power Management - Over-load detected
binary_sensor.power_synology_nas_power_management_over_current_detected_6
Power Synology NAS: Power Management - Over-current detected
friendly_name: Power Synology NAS: Power Management - Over-current detected
binary_sensor.power_synology_nas_power_management_over_load_detected_6
Power Synology NAS: Power Management - Over-load detected
friendly_name: Power Synology NAS: Power Management - Over-load detected
binary_sensor.power_unifi_internet_usg_power_management_over_current_detected_8
Power Unifi Internet (Usg): Power Management - Over-current detected
friendly_name: Power Unifi Internet (Usg): Power Management - Over-current detected
binary_sensor.power_unifi_internet_usg_power_management_over_load_detected_8
Power Unifi Internet (Usg): Power Management - Over-load detected
friendly_name: Power Unifi Internet (Usg): Power Management - Over-load detected
binary_sensor.radiator_emil_low_battery_level_2
Radiator Emil: Low battery level
friendly_name: Radiator Emil: Low battery level
binary_sensor.radiator_master_bedroom_low_battery_level_2
Radiator Master Bedroom: Low battery level
friendly_name: Radiator Master Bedroom: Low battery level
binary_sensor.radiator_nebo_low_battery_level_2
Radiator Nebo: Low battery level
friendly_name: Radiator Nebo: Low battery level
binary_sensor.remote_ui
Remote UI
friendly_name: Remote UI
binary_sensor.side_door
Side door
friendly_name: Side door
binary_sensor.smoke_emils_room_detector_heat_alarm_overheat_detected
Smoke Emils room Detector: Heat Alarm - Overheat detected
friendly_name: Smoke Emils room Detector: Heat Alarm - Overheat detected
binary_sensor.smoke_emils_room_detector_home_security_tampering_product_cover_removed
Smoke Emils room Detector: Home Security - Tampering, product cover removed
friendly_name: Smoke Emils room Detector: Home Security - Tampering, product cover removed
binary_sensor.smoke_emils_room_detector_low_battery_level
Smoke Emils room Detector: Low battery level
friendly_name: Smoke Emils room Detector: Low battery level
binary_sensor.smoke_emils_room_detector_power_management_replace_battery_soon
Smoke Emils room Detector: Power Management - Replace battery soon
friendly_name: Smoke Emils room Detector: Power Management - Replace battery soon
binary_sensor.smoke_emils_room_detector_smoke_alarm_smoke_alarm_test
Smoke Emils room Detector: Smoke Alarm - Smoke alarm test
friendly_name: Smoke Emils room Detector: Smoke Alarm - Smoke alarm test
binary_sensor.smoke_emils_room_detector_smoke_alarm_smoke_detected
Smoke Emils room Detector: Smoke Alarm - Smoke detected
friendly_name: Smoke Emils room Detector: Smoke Alarm - Smoke detected
binary_sensor.smoke_emils_room_detector_system_system_hardware_failure
Smoke Emils room Detector: System - System hardware failure
friendly_name: Smoke Emils room Detector: System - System hardware failure
binary_sensor.smoke_garage_sensor_low_battery_level_2
Smoke Garage Sensor: Low battery level
friendly_name: Smoke Garage Sensor: Low battery level
binary_sensor.smoke_kitchen_detector_heat_alarm_overheat_detected_2
Smoke Kitchen Detector: Heat Alarm - Overheat detected
friendly_name: Smoke Kitchen Detector: Heat Alarm - Overheat detected
binary_sensor.smoke_kitchen_detector_home_security_tampering_product_cover_removed_2
Smoke Kitchen Detector: Home Security - Tampering, product cover removed
friendly_name: Smoke Kitchen Detector: Home Security - Tampering, product cover removed
binary_sensor.smoke_kitchen_detector_low_battery_level_2
Smoke Kitchen Detector: Low battery level
friendly_name: Smoke Kitchen Detector: Low battery level
binary_sensor.smoke_kitchen_detector_power_management_replace_battery_soon_2
Smoke Kitchen Detector: Power Management - Replace battery soon
friendly_name: Smoke Kitchen Detector: Power Management - Replace battery soon
binary_sensor.smoke_kitchen_detector_smoke_alarm_smoke_alarm_test_2
Smoke Kitchen Detector: Smoke Alarm - Smoke alarm test
friendly_name: Smoke Kitchen Detector: Smoke Alarm - Smoke alarm test
binary_sensor.smoke_kitchen_detector_smoke_alarm_smoke_detected_2
Smoke Kitchen Detector: Smoke Alarm - Smoke detected
friendly_name: Smoke Kitchen Detector: Smoke Alarm - Smoke detected
binary_sensor.smoke_kitchen_detector_system_system_hardware_failure_2
Smoke Kitchen Detector: System - System hardware failure
friendly_name: Smoke Kitchen Detector: System - System hardware failure
binary_sensor.smoke_nebos_bedroom_detector_heat_alarm_overheat_detected
Smoke Nebos Bedroom Detector: Heat Alarm - Overheat detected
friendly_name: Smoke Nebos Bedroom Detector: Heat Alarm - Overheat detected
binary_sensor.smoke_nebos_bedroom_detector_home_security_tampering_product_cover_removed
Smoke Nebos Bedroom Detector: Home Security - Tampering, product cover removed
friendly_name: Smoke Nebos Bedroom Detector: Home Security - Tampering, product cover removed
binary_sensor.smoke_nebos_bedroom_detector_low_battery_level
Smoke Nebos Bedroom Detector: Low battery level
friendly_name: Smoke Nebos Bedroom Detector: Low battery level
binary_sensor.smoke_nebos_bedroom_detector_power_management_replace_battery_soon
Smoke Nebos Bedroom Detector: Power Management - Replace battery soon
friendly_name: Smoke Nebos Bedroom Detector: Power Management - Replace battery soon
binary_sensor.smoke_nebos_bedroom_detector_smoke_alarm_smoke_alarm_test
Smoke Nebos Bedroom Detector: Smoke Alarm - Smoke alarm test
friendly_name: Smoke Nebos Bedroom Detector: Smoke Alarm - Smoke alarm test
binary_sensor.smoke_nebos_bedroom_detector_smoke_alarm_smoke_detected
Smoke Nebos Bedroom Detector: Smoke Alarm - Smoke detected
friendly_name: Smoke Nebos Bedroom Detector: Smoke Alarm - Smoke detected
binary_sensor.smoke_nebos_bedroom_detector_system_system_hardware_failure
Smoke Nebos Bedroom Detector: System - System hardware failure
friendly_name: Smoke Nebos Bedroom Detector: System - System hardware failure
binary_sensor.smoke_working_area_detector_heat_alarm_overheat_detected
Smoke Working Area Detector: Heat Alarm - Overheat detected
friendly_name: Smoke Working Area Detector: Heat Alarm - Overheat detected
binary_sensor.smoke_working_area_detector_home_security_tampering_product_cover_removed
Smoke Working Area Detector: Home Security - Tampering, product cover removed
friendly_name: Smoke Working Area Detector: Home Security - Tampering, product cover removed
binary_sensor.smoke_working_area_detector_low_battery_level
Smoke Working Area Detector: Low battery level
friendly_name: Smoke Working Area Detector: Low battery level
700-1400 (of 4102)
binary_sensor.smoke_working_area_detector_power_management_replace_battery_soon
Smoke Working Area Detector: Power Management - Replace battery soon
friendly_name: Smoke Working Area Detector: Power Management - Replace battery soon
binary_sensor.smoke_working_area_detector_smoke_alarm_smoke_alarm_test
Smoke Working Area Detector: Smoke Alarm - Smoke alarm test
friendly_name: Smoke Working Area Detector: Smoke Alarm - Smoke alarm test
binary_sensor.smoke_working_area_detector_smoke_alarm_smoke_detected
Smoke Working Area Detector: Smoke Alarm - Smoke detected
friendly_name: Smoke Working Area Detector: Smoke Alarm - Smoke detected
binary_sensor.smoke_working_area_detector_system_system_hardware_failure
Smoke Working Area Detector: System - System hardware failure
friendly_name: Smoke Working Area Detector: System - System hardware failure
binary_sensor.sonos_move_microphone
Sonos Move Microphone
friendly_name: Sonos Move Microphone
binary_sensor.sonos_move_power
Sonos Move Power
friendly_name: Sonos Move Power
binary_sensor.temperature_and_humidity_sensor_low_battery_level
Temperature and Humidity Sensor Low battery level
friendly_name: Temperature and Humidity Sensor Low battery level
binary_sensor.workday_sensor
Workday Sensor
friendly_name: Workday Sensor
button.4_in_1_multisensor_ping
4 in 1 MultiSensor Ping
friendly_name: 4 in 1 MultiSensor Ping
button.arbetsrum_identify
Arbetsrum Identify
friendly_name: Arbetsrum Identify
button.arbetsrum_my_position
Arbetsrum My position
friendly_name: Arbetsrum My position
button.double_relay_switch_2x1_5kw_ping
WaterFuse: Ping
friendly_name: WaterFuse: Ping
button.emil_identify
Emil Identify
friendly_name: Emil Identify
button.emil_my_position
Emil My position
friendly_name: Emil My position
button.larm_ping_3
Larm: Ping
friendly_name: Larm: Ping
button.light_kitchen_sink_ping
Light Kitchen - Sink: Ping
friendly_name: Light Kitchen - Sink: Ping
button.light_outside_backside_ping
Light Outside - Backside: Ping
friendly_name: Light Outside - Backside: Ping
button.light_outside_frontdoor_ping_3
Light Outside - Frontdoor: Ping
friendly_name: Light Outside - Frontdoor: Ping
button.light_outside_garage_ping_4
Light Outside - Garage: Ping
friendly_name: Light Outside - Garage: Ping
button.light_outside_kitchen_ping_2
Light Outside - Kitchen: Ping
friendly_name: Light Outside - Kitchen: Ping
button.lights_bathroom_ground_floor_ping_2
Lights Bathroom - Ground Floor: Ping
friendly_name: Lights Bathroom - Ground Floor: Ping
button.lights_bathroom_top_floor_ping_3
Lights Bathroom - Top Floor: Ping
friendly_name: Lights Bathroom - Top Floor: Ping
button.lights_kitchen_ping
Lights Kitchen: Ping
friendly_name: Lights Kitchen: Ping
button.metered_wall_plug_switch_ping
Light Working Area - DVD: Ping
friendly_name: Light Working Area - DVD: Ping
button.msovrum_sida_identify
MSovrum Sida Identify
friendly_name: MSovrum Sida Identify
button.msovrum_sida_my_position
MSovrum Sida My position
friendly_name: MSovrum Sida My position
button.node_24_ping
PIR Hallway Top Floor: Ping
friendly_name: PIR Hallway Top Floor: Ping
button.node_39_ping
PIR Bathroom Top Floor Mirror: Ping
friendly_name: PIR Bathroom Top Floor Mirror: Ping
button.node_48_ping
Flood Sensor Ping
friendly_name: Flood Sensor Ping
button.node_58_ping
Carbon Monoxide Sensor Ping
friendly_name: Carbon Monoxide Sensor Ping
button.node_59_ping
Smoke Kitchen Detector: Ping
friendly_name: Smoke Kitchen Detector: Ping
button.node_61_ping
Smoke Nebos Bedroom Detector Ping
friendly_name: Smoke Nebos Bedroom Detector Ping
button.node_64_ping
Smoke Garage Sensor: Ping
friendly_name: Smoke Garage Sensor: Ping
button.node_65_ping
Temperature and Humidity Sensor Ping
friendly_name: Temperature and Humidity Sensor Ping
button.node_67_ping
Power Emils Desktop Ping
friendly_name: Power Emils Desktop Ping
button.node_69_ping
Radiator Master Bedroom Ping
friendly_name: Radiator Master Bedroom Ping
button.node_70_ping
Radiator Emil Ping
friendly_name: Radiator Emil Ping
button.node_71_ping
Radiator Nebo Ping
friendly_name: Radiator Nebo Ping
button.node_73_ping
Smoke Bedroom Sensor Ping
friendly_name: Smoke Bedroom Sensor Ping
button.node_74_ping
Smoke Emils room Detector Ping
friendly_name: Smoke Emils room Detector Ping
button.node_75_ping
Smoke Working Area Detector Ping
friendly_name: Smoke Working Area Detector Ping
button.node_76_ping
Smart Switch 6 Ping
friendly_name: Smart Switch 6 Ping
button.pir_outside_back_side_ping
PIR Outside Back Side: Ping
friendly_name: PIR Outside Back Side: Ping
button.pir_outside_front_ping_2
PIR Outside Front: Ping
friendly_name: PIR Outside Front: Ping
button.power_ac_ping_6
Power AC: Ping
friendly_name: Power AC: Ping
button.power_barndoor_ping_9
Power Barndoor: Ping
friendly_name: Power Barndoor: Ping
button.power_coutch_ping_8
Power Coutch: Ping
friendly_name: Power Coutch: Ping
button.power_dishwasher_ping_28
Power Dishwasher: Ping
friendly_name: Power Dishwasher: Ping
button.power_dryer_ping_26
Power Dryer: Ping
friendly_name: Power Dryer: Ping
button.power_ecoflow_delta_battery_ping_20
Power EcoFlow Delta Battery: Ping
friendly_name: Power EcoFlow Delta Battery: Ping
button.power_faketv_ping
Power fakeTV Ping
friendly_name: Power fakeTV Ping
button.power_garage_freezer_ping_3
Power Garage Freezer: Ping
friendly_name: Power Garage Freezer: Ping
button.power_garage_stereo_and_misc_ping_7
Power Garage Stereo and Misc: Ping
friendly_name: Power Garage Stereo and Misc: Ping
button.power_homeassistant_and_others_ping_14
Power HomeAssistant and others: Ping
friendly_name: Power HomeAssistant and others: Ping
button.power_ipad_ping_2
Power iPad Ping
friendly_name: Power iPad Ping
button.power_kitchen_fan_ping_21
Power Kitchen FAN: Ping
friendly_name: Power Kitchen FAN: Ping
button.power_kitchen_freezer_ping_24
Power Kitchen Freezer: Ping
friendly_name: Power Kitchen Freezer: Ping
button.power_kitchen_fridge_ping_25
Power Kitchen Fridge: Ping
friendly_name: Power Kitchen Fridge: Ping
button.power_living_room_aircleaner_ping_5
Power Living room AirCleaner: Ping
friendly_name: Power Living room AirCleaner: Ping
button.power_motion_detector_backyard_ping_23
Power Motion Detector Backyard: Ping
friendly_name: Power Motion Detector Backyard: Ping
button.power_motion_detectors_frontdoor_and_garage_ping_22
Power - Motion Detectors Frontdoor and Garage: Ping
friendly_name: Power - Motion Detectors Frontdoor and Garage: Ping
button.power_nebos_dator_ping_15
Power Nebos Dator: Ping
friendly_name: Power Nebos Dator: Ping
button.power_primary_switch_ping_13
Power Primary switch: Ping
friendly_name: Power Primary switch: Ping
button.power_projector_ping_2
Power Projector: Ping
friendly_name: Power Projector: Ping
button.power_rack_ping_4
Power Rack: Ping
friendly_name: Power Rack: Ping
button.power_second_switch_ping_11
Power Second Switch: Ping
friendly_name: Power Second Switch: Ping
button.power_synology_nas_ping_10
Power Synology NAS: Ping
friendly_name: Power Synology NAS: Ping
button.power_tv_ping_19
Power TV: Ping
friendly_name: Power TV: Ping
button.power_unifi_internet_usg_ping_12
Power Unifi Internet (Usg): Ping
friendly_name: Power Unifi Internet (Usg): Ping
button.power_washer_ping_27
Power Washer: Ping
friendly_name: Power Washer: Ping
button.power_wine_cooler_ping_16
Power Wine Cooler: Ping
friendly_name: Power Wine Cooler: Ping
button.power_working_area_laptop_docking_station_ping_18
Power Working Area Laptop Docking Station: Ping
friendly_name: Power Working Area Laptop Docking Station: Ping
button.power_working_room_switch_ping_17
Power Working Room Switch: Ping
friendly_name: Power Working Room Switch: Ping
button.radioator_working_area_ping
Radioator Working Area: Ping
friendly_name: Radioator Working Area: Ping
button.sovrum_markis_identify
Sovrum Markis Identify
friendly_name: Sovrum Markis Identify
button.sovrum_markis_my_position
Sovrum Markis My position
friendly_name: Sovrum Markis My position
button.stora_altan_markisen_identify
Stora Altan Markisen Identify
friendly_name: Stora Altan Markisen Identify
button.stora_altan_markisen_my_position
Stora Altan Markisen My position
friendly_name: Stora Altan Markisen My position
button.trappa1_identify
Trappa1 Identify
friendly_name: Trappa1 Identify
button.trappa1_my_position
Trappa1 My position
friendly_name: Trappa1 My position
calendar.emil
Emil
friendly_name: Emil
calendar.nebo
Nebo
friendly_name: Nebo
camera.backdoor_high
Backdoor High
friendly_name: Backdoor High
camera.front_door
Front Door
camera.frontdoor_high
Frontdoor High
friendly_name: Frontdoor High
camera.g3_dome_high
G3 Dome High
friendly_name: G3 Dome High
climate.garage
garage
friendly_name: garage
climate.living_connect_z_thermostat
climate.living_connect_z_thermostat_2
Radiator Nebo
climate.radiator_emil_2
Radiator Emil
climate.radiator_master_bedroom_2
climate.radiator_nebo_2
Radiator Nebo
cover.arbetsrum
Arbetsrum
cover.emil
Emil
friendly_name: Emil
cover.msovrum_sida
MSovrum Sida
cover.sovrum_markis
Sovrum Markis
cover.stora_altan_markisen
cover.trappa1
Trappa1
device_tracker.ipad
B’s iPad
friendly_name: B’s iPad
fan.nibe_1_ventilation
Ventilation
friendly_name: Ventilation
fan.zhimi_z9_fan
Fan under trappan Fan
friendly_name: Fan under trappan Fan
fan.zhimi_z7_fan
Fläkt i vardagen Fan
friendly_name: Fläkt i vardagen Fan
light.bedroom
Bedroom
friendly_name: Bedroom
light.emil_bedroom
Emil bedroom
friendly_name: Emil bedroom
light.emil_fonster
Emil plugg
friendly_name: Emil plugg
light.emil_play
Emil Play
friendly_name: Emil Play
light.emils_lightstrip
Emils lightstrip
friendly_name: Emils lightstrip
light.fonster_hoger
Fönster höger
friendly_name: Fönster höger
light.fonster_vanster
Fönster vänster
friendly_name: Fönster vänster
light.garage
Garage
light.garaget_stereo
Light Kitchen - Small Lamp
friendly_name: Light Kitchen - Small Lamp
light.group_kitchentable_hue_lights
Group Kitchentable Hue Lights
friendly_name: Group Kitchentable Hue Lights
light.hallen
Hallen
friendly_name: Hallen
light.hue_color_lamp_1
Light Living Room - Dinner Table
friendly_name: Light Living Room - Dinner Table
light.hue_filament_bulb_1
Light Bedroom Right
friendly_name: Light Bedroom Right
light.hue_filament_bulb_1_2
Light Bedroom Left
friendly_name: Light Bedroom Left
light.hue_lampor
HUE Lampor
friendly_name: HUE Lampor
light.hue_lightstrip_plus_1
Nebo Hue lightstrip plus
friendly_name: Nebo Hue lightstrip plus
light.hue_play_1
Nebo Hue play vänster
friendly_name: Nebo Hue play vänster
light.hue_play_2
Nebo Hue play höger
friendly_name: Nebo Hue play höger
light.hue_play_gradient_lightstrip_tv
Hue play gradient lightstrip TV
friendly_name: Hue play gradient lightstrip TV
light.hue_smart_plug_1
friendly_name: Emils plugg
light.kitchen
Kitchen
light.kitchentable_1
Kitchentable 1
friendly_name: Kitchentable 1
light.kitchentable_2
Kitchentable 2
friendly_name: Kitchentable 2
light.kitchentable_3
Kitchentable 3
friendly_name: Kitchentable 3
light.kitchentable_4
Kitchentable 4
friendly_name: Kitchentable 4
light.kitchentable_5
Kitchentable 5
friendly_name: Kitchentable 5
light.lampa_hallen
Lampa Hallen
friendly_name: Lampa Hallen
light.lampa_ovre_hallen
Lampa Övre Hallen
friendly_name: Lampa Övre Hallen
light.light_outside_backside
light.light_outside_backside_2
Light Outside - Backside (2)
friendly_name: Light Outside - Backside (2)
light.light_outside_frontdoor_2_3
Light Outside - Frontdoor (2)
friendly_name: Light Outside - Frontdoor (2)
light.light_outside_frontdoor_4
light.light_outside_garage_2_4
Light Outside - Garage (2)
friendly_name: Light Outside - Garage (2)
light.light_outside_garage_5
light.light_outside_kitchen_2_2
Light Outside - Kitchen (2)
friendly_name: Light Outside - Kitchen (2)
light.light_outside_kitchen_3
light.living_room
Living room
friendly_name: Living room
light.livingroom_couch_light
Livingroom Couch Light
friendly_name: Livingroom Couch Light
light.livingroom_table_light
Livingroom Table Light
friendly_name: Livingroom Table Light
light.nebo_bedroom
Nebo bedroom
friendly_name: Nebo bedroom
light.outside_lamps_group
Outside Lamps Group
friendly_name: Outside Lamps Group
light.overskap
Överskåp
friendly_name: Överskåp
light.power_faketv
friendly_name:
light.power_projector
friendly_name:
light.power_synology_nas
light.smart_switch_6
Smart Switch 6
light.soffa_hoger
Soffa höger
friendly_name: Soffa höger
light.soffa_vanster
Soffa vänster
friendly_name: Soffa vänster
light.underskap
Underskåp
friendly_name: Underskåp
light.underskap
Underskåp
light.waterfuse
friendly_name:
light.zhimi_za4_39a9_indicator_light
Fan under trappan Indicator Light
friendly_name: Fan under trappan Indicator Light
light.zhimi_za4_9f17_indicator_light
Fläkt i vardagen Indicator Light
friendly_name: Fläkt i vardagen Indicator Light
media_player.lg_webos_tv_oled65c7v
[LG] webOS TV OLED65C7V
friendly_name: [LG] webOS TV OLED65C7V
media_player.living_room
source_list: Line-in
media_player.living_room_2
Living room (2)
friendly_name: Living room (2)
media_player.ovre_hallen
Övre Hallen
friendly_name: Övre Hallen
media_player.sonos
Sonos
media_player.sonos_living_room
Sonos Living Room
friendly_name: Sonos Living Room
media_player.sonos_move
Sonos Move
media_player.sovrum
Sovrum
number.arbetsrum_my_position
number.emil_my_position
Emil My position
number.living_room_bass
Bass
friendly_name: Bass
number.living_room_treble
Treble
friendly_name: Treble
number.livingroom_couch_light_ballast_maximum_level
Livingroom Couch Light ballast maximum level
friendly_name: Livingroom Couch Light ballast maximum level
number.livingroom_couch_light_ballast_minimum_level
Livingroom Couch Light ballast minimum level
friendly_name: Livingroom Couch Light ballast minimum level
number.livingroom_table_light_ballast_maximum_level
Livingroom Table Light ballast maximum level
friendly_name: Livingroom Table Light ballast maximum level
number.livingroom_table_light_ballast_minimum_level
Livingroom Table Light ballast minimum level
friendly_name: Livingroom Table Light ballast minimum level
number.msovrum_sida_my_position
number.pir_kitchen_left_detection_interval
PIR Kitchen Left detection interval
friendly_name: PIR Kitchen Left detection interval
number.pir_kitchen_middle_left_detection_int
PIR Kitchen Middle Left detection interval
friendly_name: PIR Kitchen Middle Left detection interval
number.pir_kitchen_middle_right_detection_interval
PIR Kitchen Middle Right detection interval
friendly_name: PIR Kitchen Middle Right detection interval
number.pir_kitchen_right_detection_interval
PIR Kitchen Right detection interval
friendly_name: PIR Kitchen Right detection interval
number.pir_kitchen_table_detection_interval
PIR Kitchen Table detection interval
friendly_name: PIR Kitchen Table detection interval
1400-2100 (of 4102)
number.sonos_living_room_bass
Sonos Living Room Bass
friendly_name: Sonos Living Room Bass
number.sonos_living_room_treble
Sonos Living Room Treble
friendly_name: Sonos Living Room Treble
number.sonos_move_bass
Sonos Move Bass
friendly_name: Sonos Move Bass
number.sonos_move_treble
Sonos Move Treble
friendly_name: Sonos Move Treble
number.sovrum_bass
Sovrum Bass
friendly_name: Sovrum Bass
number.sovrum_markis_my_position
number.sovrum_treble
Sovrum Treble
friendly_name: Sovrum Treble
number.stora_altan_markisen_my_position
number.trappa1_my_position
Trappa1 My position
remote.living_room_2
Living room (2)
remote.ovre_hallen
Övre Hallen
scene.all_lights
All Lights
friendly_name: All Lights
scene.bedroom_dimmed
Bedroom Dimmed
friendly_name: Bedroom Dimmed
scene.before_hallen_lights_settings
friendly_name: before_hallen_lights_settings
scene.before_lights_settings
friendly_name: before_lights_settings
scene.emil_bedroom_bright
Emil bedroom Bright
friendly_name: Emil bedroom Bright
scene.kitchen_smitten
Kitchen Smitten
friendly_name: Kitchen Smitten
scene.living_room_arctic_aurora
Living room Arctic aurora
friendly_name: Living room Arctic aurora
scene.living_room_autumn_gold
Living room Autumn gold
friendly_name: Living room Autumn gold
scene.living_room_glitz_and_glam
Living room Glitz and glam
friendly_name: Living room Glitz and glam
scene.living_room_nightlight
Living room Nightlight
friendly_name: Living room Nightlight
scene.sido_markis_ner
Sido markis - Ner
friendly_name: Sido markis - Ner
scene.sido_markis_upp
Sido Markis - Upp
friendly_name: Sido Markis - Upp
scene.sido_markiser_sol
Sido markiser - Sol
friendly_name: Sido markiser - Sol
scene.soffa_scene
Goodnight
friendly_name: Goodnight
script.1662914382885
Turn OFF All Lights
friendly_name: Turn OFF All Lights
select.livingroom_couch_light_dimmer_mode
Livingroom Couch Light dimmer mode
friendly_name: Livingroom Couch Light dimmer mode
select.livingroom_table_light_dimmer_mode
Livingroom Table Light dimmer mode
friendly_name: Livingroom Table Light dimmer mode
sensor.4_in_1_multisensor_node_status
4 in 1 MultiSensor Node status
friendly_name: 4 in 1 MultiSensor Node status
sensor.accumulated_consumption_current_hour_huset
accumulated consumption current hour Huset
friendly_name: accumulated consumption current hour Huset
sensor.accumulated_consumption_huset
accumulated consumption Huset
friendly_name: accumulated consumption Huset
sensor.accumulated_cost_huset
accumulated cost Huset
friendly_name: accumulated cost Huset
sensor.accumulated_production_current_hour_huset
accumulated production current hour Huset
friendly_name: accumulated production current hour Huset
sensor.accumulated_production_huset
accumulated production Huset
friendly_name: accumulated production Huset
sensor.average_power_huset
average power Huset
friendly_name: average power Huset
sensor.backdoor_disk_write_rate
Backdoor Disk Write Rate
friendly_name: Backdoor Disk Write Rate
sensor.backdoor_infrared_mode
Backdoor Infrared Mode
friendly_name: Backdoor Infrared Mode
sensor.backdoor_microphone_level
Backdoor Microphone Level
friendly_name: Backdoor Microphone Level
sensor.backdoor_recording_mode
Backdoor Recording Mode
friendly_name: Backdoor Recording Mode
sensor.backdoor_storage_used
Backdoor Storage Used
friendly_name: Backdoor Storage Used
sensor.carbon_monoxide_sensor_air_temperature
Carbon Monoxide Sensor Air temperature
friendly_name: Carbon Monoxide Sensor Air temperature
sensor.carbon_monoxide_sensor_battery_level
Carbon Monoxide Sensor Battery level
friendly_name: Carbon Monoxide Sensor Battery level
sensor.carbon_monoxide_sensor_carbon_monoxide_co_level
Carbon Monoxide Sensor Carbon monoxide (CO) level
friendly_name: Carbon Monoxide Sensor Carbon monoxide (CO) level
sensor.cloudkey_recording_capacity
CloudKey Recording Capacity
friendly_name: CloudKey Recording Capacity
sensor.cloudkey_resolution_4k_video
CloudKey Resolution: 4K Video
friendly_name: CloudKey Resolution: 4K Video
sensor.cloudkey_resolution_free_space
CloudKey Resolution: Free Space
friendly_name: CloudKey Resolution: Free Space
sensor.cloudkey_resolution_hd_video
CloudKey Resolution: Hd Video
friendly_name: CloudKey Resolution: Hd Video
sensor.cloudkey_storage_utilization
CloudKey Storage Utilization
friendly_name: CloudKey Storage Utilization
sensor.cloudkey_type_continuous_video
CloudKey Type: Continuous Video
friendly_name: CloudKey Type: Continuous Video
sensor.cloudkey_type_detections_video
CloudKey Type: Detections Video
friendly_name: CloudKey Type: Detections Video
sensor.cloudkey_type_timelapse_video
CloudKey Type: Timelapse Video
friendly_name: CloudKey Type: Timelapse Video
sensor.cloudkey_uptime
CloudKey Uptime
friendly_name: CloudKey Uptime
sensor.connection_status
connection status
friendly_name: connection status
sensor.current_l1_huset
current L1 Huset
friendly_name: current L1 Huset
sensor.current_l2_huset
current L2 Huset
friendly_name: current L2 Huset
sensor.current_l3_huset
current L3 Huset
friendly_name: current L3 Huset
sensor.date
Date
friendly_name: Date
sensor.date_time
Date & Time
friendly_name: Date & Time
sensor.date_time_iso
Date & Time (ISO)
friendly_name: Date & Time (ISO)
sensor.date_time_utc
Date & Time (UTC)
friendly_name: Date & Time (UTC)
sensor.double_relay_switch_2x1_5kw_node_status
WaterFuse: Node Status
friendly_name: WaterFuse: Node Status
sensor.dreame_p2028_536e_battery_level
Dreame Bot Z10 Pro Battery Level
friendly_name: Dreame Bot Z10 Pro Battery Level
sensor.dreame_p2028_536e_brush_left_time
Dreame Bot Z10 Pro Main Cleaning Brush Left Time
friendly_name: Dreame Bot Z10 Pro Main Cleaning Brush Left Time
sensor.dreame_p2028_536e_brush_left_time_2
Dreame Bot Z10 Pro Side Cleaning Brush Left Time
friendly_name: Dreame Bot Z10 Pro Side Cleaning Brush Left Time
sensor.dreame_p2028_536e_brush_life_level
Dreame Bot Z10 Pro Main Cleaning Brush Life Level
friendly_name: Dreame Bot Z10 Pro Main Cleaning Brush Life Level
sensor.dreame_p2028_536e_brush_life_level_2
Dreame Bot Z10 Pro Side Cleaning Brush Life Level
friendly_name: Dreame Bot Z10 Pro Side Cleaning Brush Life Level
sensor.dreame_p2028_536e_filter_left_time
Dreame Bot Z10 Pro Filter Left Time
friendly_name: Dreame Bot Z10 Pro Filter Left Time
sensor.dreame_p2028_536e_filter_life_level
Dreame Bot Z10 Pro Filter Life Level
friendly_name: Dreame Bot Z10 Pro Filter Life Level
sensor.dreame_p2028_536e_status
Dreame Bot Z10 Pro Robot Cleaner Status
friendly_name: Dreame Bot Z10 Pro Robot Cleaner Status
sensor.electricity_price_huset
Electricity price Huset
friendly_name: Electricity price Huset
sensor.emil_play_energy
Emil Play energy
friendly_name: Emil Play energy
sensor.emil_play_power
Emil Play Powersensor
friendly_name: Emil Play Powersensor
sensor.emils_lightstrip_energy
Emils lightstrip energy
friendly_name: Emils lightstrip energy
sensor.emils_lightstrip_powersensor
Emils lightstrip Powersensor
friendly_name: Emils lightstrip Powersensor
sensor.estimated_consumption_current_hour_huset
Estimated consumption current hour Huset
friendly_name: Estimated consumption current hour Huset
sensor.flood_sensor_air_temperature
Flood Sensor Air temperature
friendly_name: Flood Sensor Air temperature
sensor.flood_sensor_battery_level
Flood Sensor Battery level
friendly_name: Flood Sensor Battery level
sensor.fonster_hoger_energy
Fönster höger energy
friendly_name: Fönster höger energy
sensor.fonster_hoger_power
Fönster höger Powersensor
friendly_name: Fönster höger Powersensor
sensor.fonster_vanster_energy
Fönster vänster energy
friendly_name: Fönster vänster energy
sensor.fonster_vanster_power
Fönster vänster Powersensor
friendly_name: Fönster vänster Powersensor
sensor.framsida_luminance
Framsida Luminance
friendly_name: Framsida Luminance
sensor.front_door_battery
Front Door Battery
friendly_name: Front Door Battery
sensor.front_door_last_activity
Front Door Last Activity
friendly_name: Front Door Last Activity
sensor.front_door_last_ding
Front Door Last Ding
friendly_name: Front Door Last Ding
sensor.front_door_last_motion
Front Door Last Motion
friendly_name: Front Door Last Motion
sensor.front_door_volume
Front Door Volume
friendly_name: Front Door Volume
sensor.frontdoor_disk_write_rate
Frontdoor Disk Write Rate
friendly_name: Frontdoor Disk Write Rate
sensor.frontdoor_infrared_mode
Frontdoor Infrared Mode
friendly_name: Frontdoor Infrared Mode
sensor.frontdoor_microphone_level
Frontdoor Microphone Level
friendly_name: Frontdoor Microphone Level
sensor.frontdoor_recording_mode
Frontdoor Recording Mode
friendly_name: Frontdoor Recording Mode
sensor.frontdoor_storage_used
Frontdoor Storage Used
friendly_name: Frontdoor Storage Used
sensor.g3_dome_disk_write_rate
G3 Dome Disk Write Rate
friendly_name: G3 Dome Disk Write Rate
sensor.g3_dome_infrared_mode
G3 Dome Infrared Mode
friendly_name: G3 Dome Infrared Mode
sensor.g3_dome_microphone_level
G3 Dome Microphone Level
friendly_name: G3 Dome Microphone Level
sensor.g3_dome_recording_mode
G3 Dome Recording Mode
friendly_name: G3 Dome Recording Mode
sensor.g3_dome_storage_used
G3 Dome Storage Used
friendly_name: G3 Dome Storage Used
sensor.garage_day_consumption
garage Day consumption
friendly_name: garage Day consumption
sensor.garage_freezer_battery
Garage Freezer Battery
friendly_name: Garage Freezer Battery
sensor.garage_freezer_signal_strength
Garage Freezer Signal strength
friendly_name: Garage Freezer Signal strength
sensor.garage_freezer_temperature
Garage Freezer Temperature
friendly_name: Garage Freezer Temperature
sensor.garage_year_consumption
garage Year consumption
friendly_name: garage Year consumption
sensor.hacs
hacs
friendly_name: hacs
sensor.has_alarmed
has alarmed
friendly_name: has alarmed
sensor.home_alarm_keypad
Home Alarm Keypad
friendly_name: Home Alarm Keypad
sensor.homekit_setup_code
TaHoma V2 HomeKit setup code
friendly_name: TaHoma V2 HomeKit setup code
sensor.house_heater_power_consumption
House Heater Power Consumption
friendly_name: House Heater Power Consumption
sensor.internet_time
Internet Time
friendly_name: Internet Time
sensor.ipad_activity
iPad Activity
friendly_name: iPad Activity
sensor.ipad_battery_level
iPad Battery Level
friendly_name: iPad Battery Level
sensor.ipad_bssid
iPad BSSID
friendly_name: iPad BSSID
sensor.ipad_connection_type
iPad Connection Type
friendly_name: iPad Connection Type
sensor.ipad_geocoded_location
iPad Geocoded Location
friendly_name: iPad Geocoded Location
sensor.ipad_ssid
iPad SSID
friendly_name: iPad SSID
sensor.ipad_storage
iPad Storage
friendly_name: iPad Storage
sensor.jul_switch_on_off_signal_strength
Jul Switch ON/OFF Signal strength
friendly_name: Jul Switch ON/OFF Signal strength
sensor.kitchen_freezer_battery
Kitchen Freezer Battery
friendly_name: Kitchen Freezer Battery
sensor.kitchen_freezer_signal_strength
Kitchen Freezer Signal strength
friendly_name: Kitchen Freezer Signal strength
sensor.kitchen_freezer_temperature
Kitchen Freezer Temperature
friendly_name: Kitchen Freezer Temperature
sensor.kitchen_table_hue_lights_energy
Kitchen_Table_Hue_lights energy
friendly_name: Kitchen_Table_Hue_lights energy
sensor.kitchen_table_hue_lights_powersensor
Kitchen_Table_Hue_lights Powersensor
friendly_name: Kitchen_Table_Hue_lights Powersensor
sensor.kitchentable_1_energy
Kitchentable 1 energy
friendly_name: Kitchentable 1 energy
sensor.kitchentable_1_powersensor
Kitchentable 1 Powersensor
friendly_name: Kitchentable 1 Powersensor
sensor.kitchentable_2_energy
Kitchentable 2 energy
friendly_name: Kitchentable 2 energy
sensor.kitchentable_2_powersensor
Kitchentable 2 Powersensor
friendly_name: Kitchentable 2 Powersensor
sensor.kitchentable_3_energy
Kitchentable 3 energy
friendly_name: Kitchentable 3 energy
sensor.kitchentable_3_powersensor
Kitchentable 3 Powersensor
friendly_name: Kitchentable 3 Powersensor
sensor.kitchentable_4_energy
Kitchentable 4 energy
friendly_name: Kitchentable 4 energy
sensor.kitchentable_4_powersensor
Kitchentable 4 Powersensor
friendly_name: Kitchentable 4 Powersensor
sensor.kitchentable_5_energy
Kitchentable 5 energy
friendly_name: Kitchentable 5 energy
sensor.kitchentable_5_powersensor
Kitchentable 5 Powersensor
friendly_name: Kitchentable 5 Powersensor
sensor.l2020_heaterpowerconsumption
L2020-HeaterPowerConsumption
friendly_name: L2020-HeaterPowerConsumption
sensor.l2020_houseoutsidetemper
L2020-HouseOutsideTemper
friendly_name: L2020-HouseOutsideTemper
sensor.l2020_housepowerconsumption
L2020-HousePowerConsumption
friendly_name: L2020-HousePowerConsumption
sensor.l2020_housesystem1intemp
L2020-HouseSystem1INTemp
friendly_name: L2020-HouseSystem1INTemp
sensor.l2020_housesystem1outtemp
L2020-HouseSystem1OutTemp
friendly_name: L2020-HouseSystem1OutTemp
sensor.l2020_housesystem2intemp
L2020-HouseSystem2InTemp
friendly_name: L2020-HouseSystem2InTemp
sensor.lampa_hallen_energy
Lampa Hallen energy
friendly_name: Lampa Hallen energy
sensor.lampa_hallen_power
Lampa Hallen Powersensor
friendly_name: Lampa Hallen Powersensor
sensor.lampa_ovre_hallen_energy
Lampa Övre Hallen energy
friendly_name: Lampa Övre Hallen energy
sensor.lampa_ovre_hallen_powersensor
Lampa Övre Hallen Powersensor
friendly_name: Lampa Övre Hallen Powersensor
sensor.larm_node_status_3
Larm: Node Status
friendly_name: Larm: Node Status
sensor.larm_power
Larm Power
friendly_name: Larm Power
sensor.last_activity
last activity
friendly_name: last activity
sensor.last_meter_consumption_huset
last meter consumption Huset
friendly_name: last meter consumption Huset
sensor.last_meter_consumption_huset_cost
sensor.last_meter_production_huset
last meter production Huset
friendly_name: last meter production Huset
sensor.light_kitchen_sink_electric_consumption_kwh
Light Kitchen - Sink: Electric Consumption [kWh]
friendly_name: Light Kitchen - Sink: Electric Consumption [kWh]
sensor.light_kitchen_sink_electric_consumption_w
Light Kitchen - Sink: Electric Consumption [W]
friendly_name: Light Kitchen - Sink: Electric Consumption [W]
sensor.light_kitchen_sink_electric_w
Light Kitchen - Sink Electric [W]
friendly_name: Light Kitchen - Sink Electric [W]
sensor.light_kitchen_sink_node_status
Light Kitchen - Sink: Node Status
friendly_name: Light Kitchen - Sink: Node Status
Power
sensor.light_living_room_dinner_table_energy
Light Living Room - Dinner Table energy
friendly_name: Light Living Room - Dinner Table energy
sensor.light_living_room_dinner_table_power
Light Living Room - Dinner Table Powersensor
friendly_name: Light Living Room - Dinner Table Powersensor
sensor.light_outside_backside_electric_consumption_kwh
Light Outside - Backside: Electric Consumption [kWh]
friendly_name: Light Outside - Backside: Electric Consumption [kWh]
sensor.light_outside_backside_electric_consumption_w
Light Outside - Backside: Electric Consumption [W]
friendly_name: Light Outside - Backside: Electric Consumption [W]
sensor.light_outside_backside_node_status
Light Outside - Backside: Node Status
friendly_name: Light Outside - Backside: Node Status
sensor.light_outside_backside_velocity
Light Outside - Backside Velocity
friendly_name: Light Outside - Backside Velocity
sensor.light_outside_frontdoor_electric_consumption_kwh_3
Light Outside - Frontdoor: Electric Consumption [kWh]
friendly_name: Light Outside - Frontdoor: Electric Consumption [kWh]
sensor.light_outside_frontdoor_electric_consumption_w_3
Light Outside - Frontdoor: Electric Consumption [W]
friendly_name: Light Outside - Frontdoor: Electric Consumption [W]
sensor.light_outside_frontdoor_node_status_3
Light Outside - Frontdoor: Node Status
friendly_name: Light Outside - Frontdoor: Node Status
sensor.light_outside_frontdoor_power_3
sensor.light_outside_garage_current
Light Outside - Garage Current
friendly_name: Light Outside - Garage Current
sensor.light_outside_garage_electric_consumption_kwh_4
Light Outside - Garage: Electric Consumption [kWh]
friendly_name: Light Outside - Garage: Electric Consumption [kWh]
sensor.light_outside_garage_electric_consumption_w_4
Light Outside - Garage: Electric Consumption [W]
friendly_name: Light Outside - Garage: Electric Consumption [W]
sensor.light_outside_garage_formaldehyde_ch2o_level
Light Outside - Garage: Formaldehyde (CH₂O) level
friendly_name: Light Outside - Garage: Formaldehyde (CH₂O) level
sensor.light_outside_garage_node_status_4
Light Outside - Garage: Node Status
friendly_name: Light Outside - Garage: Node Status
sensor.light_outside_garage_power_4
sensor.light_outside_kitchen_air_temperature
Light Outside - Kitchen Air temperature
friendly_name: Light Outside - Kitchen Air temperature
sensor.light_outside_kitchen_electric_consumption_kwh_2
Light Outside - Kitchen: Electric Consumption [kWh]
friendly_name: Light Outside - Kitchen: Electric Consumption [kWh]
sensor.light_outside_kitchen_electric_consumption_w_2
Light Outside - Kitchen: Electric Consumption [W]
friendly_name: Light Outside - Kitchen: Electric Consumption [W]
sensor.light_outside_kitchen_node_status_2
Light Outside - Kitchen: Node Status
friendly_name: Light Outside - Kitchen: Node Status
sensor.light_outside_kitchen_power_2
sensor.light_working_area_dvd_electric_kwh
Light Working Area - DVD Electric [kWh]
friendly_name: Light Working Area - DVD Electric [kWh]
2100-2800 (of 4102)
sensor.lights_bathroom_ground_floor_electric_consumption_kwh_2_2
Lights Bathroom - Ground Floor: Electric Consumption [kWh] (2)
friendly_name: Lights Bathroom - Ground Floor: Electric Consumption [kWh] (2)
sensor.lights_bathroom_ground_floor_electric_consumption_kwh_3
sensor.lights_bathroom_ground_floor_electric_consumption_w_2_2
Lights Bathroom - Ground Floor: Electric Consumption [W] (2)
friendly_name: Lights Bathroom - Ground Floor: Electric Consumption [W] (2)
sensor.lights_bathroom_ground_floor_electric_consumption_w_3
sensor.lights_bathroom_ground_floor_node_status_2
Lights Bathroom - Ground Floor: Node Status
friendly_name: Lights Bathroom - Ground Floor: Node Status
sensor.lights_bathroom_top_floor_electric_consumption_kwh_2_3
Lights Bathroom - Top Floor: Electric Consumption [kWh] (2)
friendly_name: Lights Bathroom - Top Floor: Electric Consumption [kWh] (2)
sensor.lights_bathroom_top_floor_electric_consumption_kwh_4
sensor.lights_bathroom_top_floor_electric_consumption_w_2_3
Lights Bathroom - Top Floor: Electric Consumption [W] (2)
friendly_name: Lights Bathroom - Top Floor: Electric Consumption [W] (2)
sensor.lights_bathroom_top_floor_electric_consumption_w_4
sensor.lights_bathroom_top_floor_node_status_3
Lights Bathroom - Top Floor: Node Status
friendly_name: Lights Bathroom - Top Floor: Node Status
sensor.lights_kitchen_electric_consumption_kwh
Lights Kitchen: Electric Consumption [kWh]
friendly_name: Lights Kitchen: Electric Consumption [kWh]
sensor.lights_kitchen_electric_consumption_kwh_2
Lights Kitchen: Electric Consumption [kWh] (2)
friendly_name: Lights Kitchen: Electric Consumption [kWh] (2)
sensor.lights_kitchen_electric_consumption_w
Lights Kitchen: Electric Consumption [W]
friendly_name: Lights Kitchen: Electric Consumption [W]
sensor.lights_kitchen_electric_consumption_w_2
Lights Kitchen: Electric Consumption [W] (2)
friendly_name: Lights Kitchen: Electric Consumption [W] (2)
sensor.lights_kitchen_node_status
Lights Kitchen: Node Status
friendly_name: Lights Kitchen: Node Status
Power
sensor.living_connect_z_thermostat_battery_level
Radiator Working Area Battery level
friendly_name: Radiator Working Area Battery level
sensor.living_connect_z_thermostat_charging_status
Radiator Working Area Charging status
friendly_name: Radiator Working Area Charging status
sensor.living_connect_z_thermostat_maximum_capacity
Radiator Working Area Maximum capacity
friendly_name: Radiator Working Area Maximum capacity
sensor.living_connect_z_thermostat_recharge_or_replace
Radiator Working Area Recharge or replace
friendly_name: Radiator Working Area Recharge or replace
sensor.living_connect_z_thermostat_temperature
Radiator Working Area Temperature
friendly_name: Radiator Working Area Temperature
sensor.livingroom_couch_energy
Livingroom_Couch energy
friendly_name: Livingroom_Couch energy
sensor.livingroom_couch_powersensor
Livingroom_Couch Powersensor
friendly_name: Livingroom_Couch Powersensor
sensor.max_power_huset
max power Huset
friendly_name: max power Huset
sensor.metered_wall_plug_switch_distance
Power HomeAssistant and others Distance
friendly_name: Power HomeAssistant and others Distance
sensor.metered_wall_plug_switch_electric_consumption_kwh
Light Working Area - DVD: Electric Consumption [kWh]
friendly_name: Light Working Area - DVD: Electric Consumption [kWh]
sensor.metered_wall_plug_switch_electric_consumption_w
Light Working Area - DVD: Electric Consumption [W]
friendly_name: Light Working Area - DVD: Electric Consumption [W]
sensor.metered_wall_plug_switch_electric_kwh
Power Washer Electric [kWh]
friendly_name: Power Washer Electric [kWh]
sensor.metered_wall_plug_switch_electric_kwh_2
Power Wine Cooler Electric [kWh]
friendly_name: Power Wine Cooler Electric [kWh]
sensor.metered_wall_plug_switch_electric_kwh_3
Power Projector Electric [kWh]
friendly_name: Power Projector Electric [kWh]
sensor.metered_wall_plug_switch_formaldehyde_ch2o_level
Power Dishwasher Formaldehyde (CH₂O) level
friendly_name: Power Dishwasher Formaldehyde (CH₂O) level
sensor.metered_wall_plug_switch_humidity
Power HomeAssistant and others Humidity
friendly_name: Power HomeAssistant and others Humidity
sensor.metered_wall_plug_switch_node_status
Light Working Area - DVD: Node Status
friendly_name: Light Working Area - DVD: Node Status
sensor.metered_wall_plug_switch_power
Light Working Area - DVD: Power
friendly_name: Light Working Area - DVD: Power
sensor.metered_wall_plug_switch_rain_rate
Power Washer Rain rate
friendly_name: Power Washer Rain rate
sensor.metered_wall_plug_switch_velocity
Power Dishwasher Velocity
friendly_name: Power Dishwasher Velocity
sensor.metered_wall_plug_switch_velocity_2
Power Washer Velocity
friendly_name: Power Washer Velocity
sensor.metered_wall_plug_switch_water_oxidation_reduction_potential
Power HomeAssistant and others Water Oxidation reduction potential
friendly_name: Power HomeAssistant and others Water Oxidation reduction potential
sensor.mi_6466969507_message
Xiaomi 6466969507 message
friendly_name: Xiaomi 6466969507 message
sensor.min_power_huset
min power Huset
friendly_name: min power Huset
sensor.monthly_cost_huset
Monthly cost Huset
friendly_name: Monthly cost Huset
sensor.monthly_net_consumption_huset
Monthly net consumption Huset
friendly_name: Monthly net consumption Huset
sensor.monthly_peak_hour_consumption_huset
Monthly peak hour consumption Huset
friendly_name: Monthly peak hour consumption Huset
sensor.moon_phase
Moon Phase
friendly_name: Moon Phase
sensor.motion_livingroom_battery
Motion Livingroom Battery
friendly_name: Motion Livingroom Battery
sensor.motion_livingroom_temperature
Motion Livingroom Temperature
friendly_name: Motion Livingroom Temperature
sensor.nebo_hue_lightstrip_plus_energy
Nebo Hue lightstrip plus energy
friendly_name: Nebo Hue lightstrip plus energy
sensor.nebo_hue_lightstrip_plus_powersensor
Nebo Hue lightstrip plus Powersensor
friendly_name: Nebo Hue lightstrip plus Powersensor
sensor.nebo_hue_play_hoger_energy
Nebo Hue play höger energy
friendly_name: Nebo Hue play höger energy
sensor.nebo_hue_play_hoger_powersensor
Nebo Hue play höger Powersensor
friendly_name: Nebo Hue play höger Powersensor
sensor.nebo_hue_play_vanster_energy
Nebo Hue play vänster energy
friendly_name: Nebo Hue play vänster energy
sensor.nebo_hue_play_vanster_powersensor
Nebo Hue play vänster Powersensor
friendly_name: Nebo Hue play vänster Powersensor
sensor.nibe_156732_0
unavailable
sensor.nibe_156732_10001
fan speed
friendly_name: fan speed
sensor.nibe_156732_10012
blocked
friendly_name: blocked
sensor.nibe_156732_10033
bLocked
sensor.nibe_156732_10069
price of electricity
friendly_name: price of electricity
sensor.nibe_156732_40004
outdoor temp.
friendly_name: outdoor temp.
sensor.nibe_156732_40007
heat medium flow
friendly_name: heat medium flow
sensor.nibe_156732_40008
heat medium flow
sensor.nibe_156732_40012
condenser return
friendly_name: condenser return
sensor.nibe_156732_40013
hot water top
friendly_name: hot water top
sensor.nibe_156732_40014
hot water charging
friendly_name: hot water charging
sensor.nibe_156732_40017
condenser out
friendly_name: condenser out
sensor.nibe_156732_40018
hot gas
friendly_name: hot gas
sensor.nibe_156732_40019
liquid line
friendly_name: liquid line
sensor.nibe_156732_40020
evaporator
friendly_name: evaporator
sensor.nibe_156732_40022
suction gas
friendly_name: suction gas
sensor.nibe_156732_40025
exhaust air
friendly_name: exhaust air
sensor.nibe_156732_40026
extract air
friendly_name: extract air
sensor.nibe_156732_40032
room temperature
friendly_name: room temperature
sensor.nibe_156732_40033
room temperature
sensor.nibe_156732_40047
heat medium flow
sensor.nibe_156732_40048
heat medium return
friendly_name: heat medium return
sensor.nibe_156732_40050
value, air velocity sensor
friendly_name: value, air velocity sensor
sensor.nibe_156732_40067
avg. outdoor temp
friendly_name: avg. outdoor temp
sensor.nibe_156732_40079
current
sensor.nibe_156732_40081
current
sensor.nibe_156732_40083
current
sensor.nibe_156732_40129
heat medium return
sensor.nibe_156732_43005
degree minutes
friendly_name: degree minutes
sensor.nibe_156732_43008
calculated flow temp.
friendly_name: calculated flow temp.
sensor.nibe_156732_43009
sensor.nibe_156732_43064
heat: dT calc. value
friendly_name: heat: dT calc. value
sensor.nibe_156732_43065
heat: dT is (BT12 | BT63)-BT3
friendly_name: heat: dT is (BT12 | BT63)-BT3
sensor.nibe_156732_43066
defrosting time
friendly_name: defrosting time
sensor.nibe_156732_43081
time factor
friendly_name: time factor
sensor.nibe_156732_43084
electrical addition power
friendly_name: electrical addition power
sensor.nibe_156732_43115
HW: charge calc value
friendly_name: HW: charge calc value
sensor.nibe_156732_43116
HW:curr charge val BT12|BT63
friendly_name: HW:curr charge val BT12|BT63
sensor.nibe_156732_43123
allowed compr. freq.
friendly_name: allowed compr. freq.
sensor.nibe_156732_43124
reference, air velocity sensor
friendly_name: reference, air velocity sensor
sensor.nibe_156732_43125
decrease from reference
friendly_name: decrease from reference
sensor.nibe_156732_43136
current compr. frequency
friendly_name: current compr. frequency
sensor.nibe_156732_43144
compressor time factor
friendly_name: compressor time factor
sensor.nibe_156732_43146
dT Inverter - exhaust air
friendly_name: dT Inverter - exhaust air
sensor.nibe_156732_43160
external adjustment
friendly_name: external adjustment
sensor.nibe_156732_43161
external adjustment
sensor.nibe_156732_43181
speed heat med. pump 1
friendly_name: speed heat med. pump 1
sensor.nibe_156732_43305
compressor time factor hot water
friendly_name: compressor time factor hot water
sensor.nibe_156732_43371
hotgas limit
friendly_name: hotgas limit
sensor.nibe_156732_43372
evaporating limit
friendly_name: evaporating limit
sensor.nibe_156732_43416
compressor starts
friendly_name: compressor starts
sensor.nibe_156732_43420
compressor operating time
friendly_name: compressor operating time
sensor.nibe_156732_43424
compressor operating time hot water
friendly_name: compressor operating time hot water
sensor.nibe_156732_44896
heating
friendly_name: heating
sensor.nibe_156732_44897
hot water
sensor.nibe_156732_44908
status
friendly_name: status
sensor.nibe_156732_47212
set max electrical add.
friendly_name: set max electrical add.
sensor.nibe_156732_47214
fuse size
friendly_name: fuse size
sensor.nibe_156732_47407
AUX5
friendly_name: AUX5
sensor.nibe_156732_47408
AUX4
friendly_name: AUX4
sensor.nibe_156732_47409
AUX3
friendly_name: AUX3
sensor.nibe_156732_47410
AUX2
friendly_name: AUX2
sensor.nibe_156732_47411
AUX1
friendly_name: AUX1
sensor.nibe_156732_47412
X7
friendly_name: X7
sensor.nibe_156732_48745
country
friendly_name: country
sensor.node_24_node_status
PIR Hallway Top Floor: Node Status
friendly_name: PIR Hallway Top Floor: Node Status
sensor.node_39_node_status
PIR Bathroom Top Floor Mirror: Node Status
friendly_name: PIR Bathroom Top Floor Mirror: Node Status
sensor.node_48_node_status
Flood Sensor Node status
friendly_name: Flood Sensor Node status
sensor.node_58_node_status
Carbon Monoxide Sensor Node status
friendly_name: Carbon Monoxide Sensor Node status
sensor.node_59_node_status
Smoke Kitchen Detector: Node Status
friendly_name: Smoke Kitchen Detector: Node Status
sensor.node_61_node_status
Smoke Nebos Bedroom Detector Node status
friendly_name: Smoke Nebos Bedroom Detector Node status
sensor.node_64_node_status
Smoke Garage Sensor: Node Status
friendly_name: Smoke Garage Sensor: Node Status
sensor.node_65_node_status
Temperature and Humidity Sensor Node status
friendly_name: Temperature and Humidity Sensor Node status
sensor.node_67_node_status
Power Emils Desktop Node status
friendly_name: Power Emils Desktop Node status
sensor.node_69_node_status
Radiator Master Bedroom Node status
friendly_name: Radiator Master Bedroom Node status
sensor.node_70_node_status
Radiator Emil Node status
friendly_name: Radiator Emil Node status
sensor.node_71_node_status
Radiator Nebo Node status
friendly_name: Radiator Nebo Node status
sensor.node_73_node_status
Smoke Bedroom Sensor Node status
friendly_name: Smoke Bedroom Sensor Node status
sensor.node_74_node_status
Smoke Emils room Detector Node status
friendly_name: Smoke Emils room Detector Node status
sensor.node_75_node_status
Smoke Working Area Detector Node status
friendly_name: Smoke Working Area Detector Node status
sensor.node_76_node_status
Smart Switch 6 Node status
friendly_name: Smart Switch 6 Node status
sensor.nordpool_kwh_se3_sek_3_10_025
friendly_name: nordpool_kwh_se3_sek_3_10_025
sensor.pir_bathroom_top_floor_mirror_acceleration_x_axis
PIR Bathroom Top Floor Mirror: Acceleration X-axis
friendly_name: PIR Bathroom Top Floor Mirror: Acceleration X-axis
sensor.pir_bathroom_top_floor_mirror_acceleration_y_axis
PIR Bathroom Top Floor Mirror: Acceleration Y-axis
friendly_name: PIR Bathroom Top Floor Mirror: Acceleration Y-axis
sensor.pir_bathroom_top_floor_mirror_acceleration_z_axis
PIR Bathroom Top Floor Mirror: Acceleration Z-axis
friendly_name: PIR Bathroom Top Floor Mirror: Acceleration Z-axis
sensor.pir_bathroom_top_floor_mirror_air_temperature_4
PIR Bathroom Top Floor Mirror: Air temperature
friendly_name: PIR Bathroom Top Floor Mirror: Air temperature
sensor.pir_bathroom_top_floor_mirror_battery_level_4
PIR Bathroom Top Floor Mirror: Battery level
friendly_name: PIR Bathroom Top Floor Mirror: Battery level
sensor.pir_bathroom_top_floor_mirror_home_security_motion_sensor_status
Motion Sensor: Home Security - Motion sensor status
friendly_name: Motion Sensor: Home Security - Motion sensor status
sensor.pir_bathroom_top_floor_mirror_seismic_intensity
PIR Bathroom Top Floor Mirror: Seismic Intensity
friendly_name: PIR Bathroom Top Floor Mirror: Seismic Intensity
sensor.pir_ground_floor_bathroom_celling_battery
PIR Ground Floor Bathroom Celling battery
friendly_name: PIR Ground Floor Bathroom Celling battery
PIR Ground Floor Bathroom Celling device temperature
friendly_name: PIR Ground Floor Bathroom Celling device temperature
PIR Ground Floor Bathroom Celling power outage count
friendly_name: PIR Ground Floor Bathroom Celling power outage count
sensor.pir_hallway_downstairs_battery
PIR Hallway downstairs battery
friendly_name: PIR Hallway downstairs battery
PIR Hallway downstairs device temperature
friendly_name: PIR Hallway downstairs device temperature
PIR Hallway downstairs power outage count
friendly_name: PIR Hallway downstairs power outage count
sensor.pir_hallway_frontdoor_battery
PIR Hallway Frontdoor battery
friendly_name: PIR Hallway Frontdoor battery
PIR Hallway Frontdoor device temperature
friendly_name: PIR Hallway Frontdoor device temperature
PIR Hallway Frontdoor power outage count
friendly_name: PIR Hallway Frontdoor power outage count
sensor.pir_hallway_top_floor_acceleration_x_axis_3
PIR Hallway Top Floor: Acceleration X-axis
friendly_name: PIR Hallway Top Floor: Acceleration X-axis
sensor.pir_hallway_top_floor_acceleration_y_axis_3
PIR Hallway Top Floor: Acceleration Y-axis
friendly_name: PIR Hallway Top Floor: Acceleration Y-axis
sensor.pir_hallway_top_floor_acceleration_z_axis_3
PIR Hallway Top Floor: Acceleration Z-axis
friendly_name: PIR Hallway Top Floor: Acceleration Z-axis
sensor.pir_hallway_top_floor_air_temperature_7
PIR Hallway Top Floor: Air temperature
friendly_name: PIR Hallway Top Floor: Air temperature
sensor.pir_hallway_top_floor_battery_level_7
PIR Hallway Top Floor: Battery level
friendly_name: PIR Hallway Top Floor: Battery level
sensor.pir_hallway_top_floor_home_security_motion_sensor_status_3
PIR Hallway Top Floor Motion sensor status
friendly_name: PIR Hallway Top Floor Motion sensor status
sensor.pir_hallway_top_floor_seismic_intensity_3
PIR Hallway Top Floor: Seismic Intensity
friendly_name: PIR Hallway Top Floor: Seismic Intensity
sensor.pir_kitchen_left_battery
PIR Kitchen Left battery
friendly_name: PIR Kitchen Left battery
sensor.pir_kitchen_left_device_temperature
PIR Kitchen Left device temperature
friendly_name: PIR Kitchen Left device temperature
sensor.pir_kitchen_middle_left_battery
PIR Kitchen Middle Left battery
friendly_name: PIR Kitchen Middle Left battery
sensor.pir_kitchen_middle_left_device_temperature
PIR Kitchen Middle Left device temperature
friendly_name: PIR Kitchen Middle Left device temperature
sensor.pir_kitchen_middle_right_battery
PIR Kitchen Middle Right battery
friendly_name: PIR Kitchen Middle Right battery
sensor.pir_kitchen_middle_right_device_temperature
PIR Kitchen Middle Right device temperature
friendly_name: PIR Kitchen Middle Right device temperature
sensor.pir_kitchen_right_battery
PIR Kitchen Right battery
friendly_name: PIR Kitchen Right battery
sensor.pir_kitchen_right_device_temperature
PIR Kitchen Right device temperature
friendly_name: PIR Kitchen Right device temperature
sensor.pir_kitchen_table_battery
PIR Kitchen Table battery
friendly_name: PIR Kitchen Table battery
sensor.pir_kitchen_table_device_temperature
PIR Kitchen Table device temperature
friendly_name: PIR Kitchen Table device temperature
sensor.pir_outside_back_side_air_temperature
Air temperature
friendly_name: Air temperature
sensor.pir_outside_back_side_node_status
PIR Outside Back Side: Node Status
friendly_name: PIR Outside Back Side: Node Status
sensor.pir_outside_front_node_status_2
PIR Outside Front: Node Status
friendly_name: PIR Outside Front: Node Status
sensor.pir_outside_front_power
Power
sensor.pir_stairs_battery
PIR Stairs battery
friendly_name: PIR Stairs battery
sensor.pir_stairs_device_temperature
PIR Stairs device temperature
friendly_name: PIR Stairs device temperature
sensor.pir_stairs_power_outage_count
PIR Stairs power outage count
friendly_name: PIR Stairs power outage count
sensor.pir_top_floor_bathroom_celling_battery
PIR Top Floor Bathroom Celling battery
friendly_name: PIR Top Floor Bathroom Celling battery
sensor.pir_top_floor_bathroom_celling_device_temperature
PIR Top Floor Bathroom Celling device temperature
friendly_name: PIR Top Floor Bathroom Celling device temperature
sensor.pir_top_floor_bathroom_celling_power_outage_count
PIR Top Floor Bathroom Celling power outage count
friendly_name: PIR Top Floor Bathroom Celling power outage count
2800-3500 (of 4102)
sensor.power_ac_device_energy
Power AC Device Energy
friendly_name: Power AC Device Energy
sensor.power_ac_device_power
Power AC Device Power
friendly_name: Power AC Device Power
sensor.power_ac_electric_consumption_kwh_6
Power AC: Electric Consumption [kWh]
friendly_name: Power AC: Electric Consumption [kWh]
sensor.power_ac_electric_consumption_w_6
Power AC: Electric Consumption [W]
friendly_name: Power AC: Electric Consumption [W]
sensor.power_ac_node_status_6
Power AC: Node Status
friendly_name: Power AC: Node Status
sensor.power_ac_power_5
Power AC: Power
friendly_name: Power AC: Power
sensor.power_barndoor_device_energy
Power Barndoor Device Energy
friendly_name: Power Barndoor Device Energy
sensor.power_barndoor_device_power
Power Barndoor Device Power
friendly_name: Power Barndoor Device Power
sensor.power_barndoor_electric_consumption_kwh_9
Power Barndoor: Electric Consumption [kWh]
friendly_name: Power Barndoor: Electric Consumption [kWh]
sensor.power_barndoor_electric_consumption_w_9
Power Barndoor: Electric Consumption [W]
friendly_name: Power Barndoor: Electric Consumption [W]
sensor.power_barndoor_electric_kwh
Power Barndoor Electric [kWh]
friendly_name: Power Barndoor Electric [kWh]
sensor.power_barndoor_node_status_9
Power Barndoor: Node Status
friendly_name: Power Barndoor: Node Status
sensor.power_barndoor_power_8
Power Barndoor: Power
friendly_name: Power Barndoor: Power
sensor.power_coutch_distance
Power Coutch Distance
friendly_name: Power Coutch Distance
sensor.power_coutch_electric_consumption_kwh_8
Power Coutch: Electric Consumption [kWh]
friendly_name: Power Coutch: Electric Consumption [kWh]
sensor.power_coutch_electric_consumption_w_8
Power Coutch: Electric Consumption [W]
friendly_name: Power Coutch: Electric Consumption [W]
sensor.power_coutch_formaldehyde_ch2o_level
Power Coutch Formaldehyde (CH₂O) level
friendly_name: Power Coutch Formaldehyde (CH₂O) level
sensor.power_coutch_heart_rate_lf_hf_ratio
Power Coutch Heart Rate LF/HF ratio
friendly_name: Power Coutch Heart Rate LF/HF ratio
sensor.power_coutch_node_status_8
Power Coutch: Node Status
friendly_name: Power Coutch: Node Status
sensor.power_coutch_power_7
Power Coutch: Power
friendly_name: Power Coutch: Power
sensor.power_coutch_velocity
Power Coutch Velocity
friendly_name: Power Coutch Velocity
sensor.power_dishwasher_electric_consumption_kwh_28
Power Dishwasher: Electric Consumption [kWh]
friendly_name: Power Dishwasher: Electric Consumption [kWh]
sensor.power_dishwasher_energy
Power Dishwasher energy
friendly_name: Power Dishwasher energy
sensor.power_dishwasher_energy_daily
Power Dishwasher energy daily
friendly_name: Power Dishwasher energy daily
sensor.power_dishwasher_energy_monthly
Power Dishwasher energy monthly
friendly_name: Power Dishwasher energy monthly
sensor.power_dishwasher_energy_weekly
Power Dishwasher energy weekly
friendly_name: Power Dishwasher energy weekly
sensor.power_dishwasher_node_status_28
Power Dishwasher: Node Status
friendly_name: Power Dishwasher: Node Status
sensor.power_dishwasher_power_27
Power Dishwasher: Power
friendly_name: Power Dishwasher: Power
sensor.power_dishwasher_powersensor
Power Dishwasher Powersensor
friendly_name: Power Dishwasher Powersensor
sensor.power_dryer_device_energy
Power Dryer Device Energy
friendly_name: Power Dryer Device Energy
sensor.power_dryer_device_power
Power Dryer Device Power
friendly_name: Power Dryer Device Power
sensor.power_dryer_electric_consumption_kwh_26
Power Dryer: Electric Consumption [kWh]
friendly_name: Power Dryer: Electric Consumption [kWh]
sensor.power_dryer_electric_consumption_w_26
Power Dryer: Electric Consumption [W]
friendly_name: Power Dryer: Electric Consumption [W]
sensor.power_dryer_node_status_26
Power Dryer: Node Status
friendly_name: Power Dryer: Node Status
sensor.power_dryer_power_25
Power Dryer: Power
friendly_name: Power Dryer: Power
sensor.power_ecoflow_delta_battery_device_energy
Power EcoFlow Delta Battery Device Energy
friendly_name: Power EcoFlow Delta Battery Device Energy
sensor.power_ecoflow_delta_battery_device_power
Power EcoFlow Delta Battery Device Power
friendly_name: Power EcoFlow Delta Battery Device Power
sensor.power_ecoflow_delta_battery_electric_consumption_kwh_20
Power EcoFlow Delta Battery: Electric Consumption [kWh]
friendly_name: Power EcoFlow Delta Battery: Electric Consumption [kWh]
sensor.power_ecoflow_delta_battery_electric_consumption_w_20
Power EcoFlow Delta Battery: Electric Consumption [W]
friendly_name: Power EcoFlow Delta Battery: Electric Consumption [W]
sensor.power_ecoflow_delta_battery_node_status_20
Power EcoFlow Delta Battery: Node Status
friendly_name: Power EcoFlow Delta Battery: Node Status
sensor.power_ecoflow_delta_battery_power_19
Power EcoFlow Delta Battery: Power
friendly_name: Power EcoFlow Delta Battery: Power
sensor.power_emils_desktop_electric_consumption_kwh_2
Power Emils Desktop: Electric Consumption [kWh]
friendly_name: Power Emils Desktop: Electric Consumption [kWh]
sensor.power_emils_desktop_electric_consumption_w_2
Power Emils Desktop: Electric Consumption [W]
friendly_name: Power Emils Desktop: Electric Consumption [W]
sensor.power_emils_desktop_electric_kwh
Power Emils Desktop Electric [kWh]
friendly_name: Power Emils Desktop Electric [kWh]
sensor.power_emils_desktop_formaldehyde_ch2o_level
Power Emils Desktop Formaldehyde (CH₂O) level
friendly_name: Power Emils Desktop Formaldehyde (CH₂O) level
sensor.power_emils_desktop_power_2
Power Emils Desktop: Power
friendly_name: Power Emils Desktop: Power
sensor.power_factor_huset
power factor Huset
friendly_name: power factor Huset
sensor.power_faketv_electric_consumption_a
Power fakeTV Electric Consumption [A]
friendly_name: Power fakeTV Electric Consumption [A]
sensor.power_faketv_electric_consumption_kwh
Power fakeTV Electric Consumption [kWh]
friendly_name: Power fakeTV Electric Consumption [kWh]
sensor.power_faketv_electric_consumption_v
Power fakeTV Electric Consumption [V]
friendly_name: Power fakeTV Electric Consumption [V]
sensor.power_faketv_electric_consumption_w
Power fakeTV Electric Consumption [W]
friendly_name: Power fakeTV Electric Consumption [W]
sensor.power_faketv_node_status
Power fakeTV Node status
friendly_name: Power fakeTV Node status
sensor.power_garage_freezer_device_energy
Power Garage Freezer Device Energy
friendly_name: Power Garage Freezer Device Energy
sensor.power_garage_freezer_device_power
Power Garage Freezer Device Power
friendly_name: Power Garage Freezer Device Power
sensor.power_garage_freezer_electric_consumption_kwh_3
Power Garage Freezer: Electric Consumption [kWh]
friendly_name: Power Garage Freezer: Electric Consumption [kWh]
sensor.power_garage_freezer_electric_consumption_w_3
Power Garage Freezer: Electric Consumption [W]
friendly_name: Power Garage Freezer: Electric Consumption [W]
sensor.power_garage_freezer_node_status_3
Power Garage Freezer: Node Status
friendly_name: Power Garage Freezer: Node Status
sensor.power_garage_freezer_power_2
Power Garage Freezer: Power
friendly_name: Power Garage Freezer: Power
sensor.power_garage_stereo_and_misc_electric_consumption_kwh_7
Power Garage Stereo and Misc: Electric Consumption [kWh]
friendly_name: Power Garage Stereo and Misc: Electric Consumption [kWh]
sensor.power_garage_stereo_and_misc_electric_consumption_w_7
Power Garage Stereo and Misc: Electric Consumption [W]
friendly_name: Power Garage Stereo and Misc: Electric Consumption [W]
sensor.power_garage_stereo_and_misc_node_status_7
Power Garage Stereo and Misc: Node Status
friendly_name: Power Garage Stereo and Misc: Node Status
sensor.power_garage_stereo_and_misc_power_6
Power Garage Stereo and Misc: Power
friendly_name: Power Garage Stereo and Misc: Power
sensor.power_homeassistant_and_others_device_energy
Power HomeAssistant and others Device Energy
friendly_name: Power HomeAssistant and others Device Energy
sensor.power_homeassistant_and_others_device_power
Power HomeAssistant and others Device Power
friendly_name: Power HomeAssistant and others Device Power
sensor.power_homeassistant_and_others_electric_consumption_kwh_14
Power HomeAssistant and others: Electric Consumption [kWh]
friendly_name: Power HomeAssistant and others: Electric Consumption [kWh]
sensor.power_homeassistant_and_others_electric_consumption_w_14
Power HomeAssistant and others: Electric Consumption [W]
friendly_name: Power HomeAssistant and others: Electric Consumption [W]
sensor.power_homeassistant_and_others_formaldehyde_ch2o_level
Power HomeAssistant and others Formaldehyde (CH₂O) level
friendly_name: Power HomeAssistant and others Formaldehyde (CH₂O) level
sensor.power_homeassistant_and_others_node_status_14
Power HomeAssistant and others: Node Status
friendly_name: Power HomeAssistant and others: Node Status
sensor.power_homeassistant_and_others_power_13
Power HomeAssistant and others: Power
friendly_name: Power HomeAssistant and others: Power
sensor.power_homeassistant_and_others_rain_rate
Power HomeAssistant and others Rain rate
friendly_name: Power HomeAssistant and others Rain rate
sensor.power_huset
power Huset
friendly_name: power Huset
sensor.power_ipad_electric_consumption_a_2
Power iPad Electric Consumption [A]
friendly_name: Power iPad Electric Consumption [A]
sensor.power_ipad_electric_consumption_kwh_2
Power iPad Electric Consumption [kWh]
friendly_name: Power iPad Electric Consumption [kWh]
sensor.power_ipad_electric_consumption_v_2
Power iPad Electric Consumption [V]
friendly_name: Power iPad Electric Consumption [V]
sensor.power_ipad_electric_consumption_w_2
Power iPad Electric Consumption [W]
friendly_name: Power iPad Electric Consumption [W]
sensor.power_ipad_electric_w
Power iPad Electric [W]
friendly_name: Power iPad Electric [W]
sensor.power_ipad_node_status_2
Power iPad Node status
friendly_name: Power iPad Node status
sensor.power_ipad_power
Power
sensor.power_kitchen_fan_electric_consumption_kwh_21
Power Kitchen FAN: Electric Consumption [kWh]
friendly_name: Power Kitchen FAN: Electric Consumption [kWh]
sensor.power_kitchen_fan_electric_consumption_w_21
Power Kitchen FAN: Electric Consumption [W]
friendly_name: Power Kitchen FAN: Electric Consumption [W]
sensor.power_kitchen_fan_node_status_21
Power Kitchen FAN: Node Status
friendly_name: Power Kitchen FAN: Node Status
sensor.power_kitchen_fan_power_20
Power Kitchen FAN: Power
friendly_name: Power Kitchen FAN: Power
sensor.power_kitchen_fan_velocity
Power Kitchen FAN Velocity
friendly_name: Power Kitchen FAN Velocity
sensor.power_kitchen_freezer_device_energy
Power Kitchen Freezer Device Energy
friendly_name: Power Kitchen Freezer Device Energy
sensor.power_kitchen_freezer_device_power
Power Kitchen Freezer Device Power
friendly_name: Power Kitchen Freezer Device Power
sensor.power_kitchen_freezer_electric_consumption_kwh_24
Power Kitchen Freezer: Electric Consumption [kWh]
friendly_name: Power Kitchen Freezer: Electric Consumption [kWh]
sensor.power_kitchen_freezer_electric_consumption_w_24
Power Kitchen Freezer: Electric Consumption [W]
friendly_name: Power Kitchen Freezer: Electric Consumption [W]
sensor.power_kitchen_freezer_node_status_24
Power Kitchen Freezer: Node Status
friendly_name: Power Kitchen Freezer: Node Status
sensor.power_kitchen_freezer_power_23
Power Kitchen Freezer: Power
friendly_name: Power Kitchen Freezer: Power
sensor.power_kitchen_fridge_device_energy
Power Kitchen Fridge Device Energy
friendly_name: Power Kitchen Fridge Device Energy
sensor.power_kitchen_fridge_device_power
Power Kitchen Fridge Device Power
friendly_name: Power Kitchen Fridge Device Power
sensor.power_kitchen_fridge_electric_consumption_kwh_25
Power Kitchen Fridge: Electric Consumption [kWh]
friendly_name: Power Kitchen Fridge: Electric Consumption [kWh]
sensor.power_kitchen_fridge_electric_consumption_w_25
Power Kitchen Fridge: Electric Consumption [W]
friendly_name: Power Kitchen Fridge: Electric Consumption [W]
sensor.power_kitchen_fridge_node_status_25
Power Kitchen Fridge: Node Status
friendly_name: Power Kitchen Fridge: Node Status
sensor.power_kitchen_fridge_power_24
Power Kitchen Fridge: Power
friendly_name: Power Kitchen Fridge: Power
sensor.power_living_room_aircleaner_device_energy
Power Living room AirCleaner Device Energy
friendly_name: Power Living room AirCleaner Device Energy
sensor.power_living_room_aircleaner_device_power
Power Living room AirCleaner Device Power
friendly_name: Power Living room AirCleaner Device Power
sensor.power_living_room_aircleaner_electric_consumption_kwh_5
Power Living room AirCleaner: Electric Consumption [kWh]
friendly_name: Power Living room AirCleaner: Electric Consumption [kWh]
sensor.power_living_room_aircleaner_electric_consumption_w_5
Power Living room AirCleaner: Electric Consumption [W]
friendly_name: Power Living room AirCleaner: Electric Consumption [W]
sensor.power_living_room_aircleaner_node_status_5
Power Living room AirCleaner: Node Status
friendly_name: Power Living room AirCleaner: Node Status
sensor.power_living_room_aircleaner_power_4
Power Living room AirCleaner: Power
friendly_name: Power Living room AirCleaner: Power
sensor.power_motion_detector_backyard_electric_consumption_kwh_23
Power Motion Detector Backyard: Electric Consumption [kWh]
friendly_name: Power Motion Detector Backyard: Electric Consumption [kWh]
sensor.power_motion_detector_backyard_electric_consumption_w_23
Power Motion Detector Backyard: Electric Consumption [W]
friendly_name: Power Motion Detector Backyard: Electric Consumption [W]
sensor.power_motion_detector_backyard_node_status_23
Power Motion Detector Backyard: Node Status
friendly_name: Power Motion Detector Backyard: Node Status
sensor.power_motion_detector_backyard_power
Power Motion Detector Backyard Power
friendly_name: Power Motion Detector Backyard Power
sensor.power_motion_detector_backyard_power_22
Power Motion Detector Backyard: Power
friendly_name: Power Motion Detector Backyard: Power
sensor.power_motion_detectors_frontdoor_and_garage_electric_consumption_kwh_22
Power - Motion Detectors Frontdoor and Garage: Electric Consumption [kWh]
friendly_name: Power - Motion Detectors Frontdoor and Garage: Electric Consumption [kWh]
sensor.power_motion_detectors_frontdoor_and_garage_electric_consumption_w_2
friendly_name: Electric Consumption [W] (2)
sensor.power_motion_detectors_frontdoor_and_garage_electric_consumption_w_22
Power - Motion Detectors Frontdoor and Garage: Electric Consumption [W]
friendly_name: Power - Motion Detectors Frontdoor and Garage: Electric Consumption [W]
sensor.power_motion_detectors_frontdoor_and_garage_node_status_22
Power - Motion Detectors Frontdoor and Garage: Node Status
friendly_name: Power - Motion Detectors Frontdoor and Garage: Node Status
sensor.power_motion_detectors_frontdoor_and_garage_power_21
Power - Motion Detectors Frontdoor and Garage: Power
friendly_name: Power - Motion Detectors Frontdoor and Garage: Power
sensor.power_nebos_dator_device_energy
Power Nebos Dator Device Energy
friendly_name: Power Nebos Dator Device Energy
sensor.power_nebos_dator_device_power
Power Nebos Dator Device Power
friendly_name: Power Nebos Dator Device Power
sensor.power_nebos_dator_electric_consumption_kwh_15
Power Nebos Dator: Electric Consumption [kWh]
friendly_name: Power Nebos Dator: Electric Consumption [kWh]
sensor.power_nebos_dator_electric_consumption_w_15
Power Nebos Dator: Electric Consumption [W]
friendly_name: Power Nebos Dator: Electric Consumption [W]
sensor.power_nebos_dator_node_status_15
Power Nebos Dator: Node Status
friendly_name: Power Nebos Dator: Node Status
sensor.power_nebos_dator_power_14
Power Nebos Dator: Power
friendly_name: Power Nebos Dator: Power
sensor.power_primary_switch_device_energy
Power Primary switch Device Energy
friendly_name: Power Primary switch Device Energy
sensor.power_primary_switch_device_power
Power Primary switch Device Power
friendly_name: Power Primary switch Device Power
sensor.power_primary_switch_electric_consumption_kwh_13
Power Primary switch: Electric Consumption [kWh]
friendly_name: Power Primary switch: Electric Consumption [kWh]
sensor.power_primary_switch_electric_consumption_w_13
Power Primary switch: Electric Consumption [W]
friendly_name: Power Primary switch: Electric Consumption [W]
sensor.power_primary_switch_node_status_13
Power Primary switch: Node Status
friendly_name: Power Primary switch: Node Status
sensor.power_primary_switch_power_12
Power Primary switch: Power
friendly_name: Power Primary switch: Power
sensor.power_projector_electric_consumption_kwh_2
Power Projector: Electric Consumption [kWh]
friendly_name: Power Projector: Electric Consumption [kWh]
sensor.power_projector_electric_consumption_w_2
Power Projector: Electric Consumption [W]
friendly_name: Power Projector: Electric Consumption [W]
sensor.power_projector_node_status_2
Power Projector: Node Status
friendly_name: Power Projector: Node Status
sensor.power_projector_power
Power
sensor.power_projector_power_28
Power Projector: Power
friendly_name: Power Projector: Power
sensor.power_rack_device_energy
Power Rack Device Energy
friendly_name: Power Rack Device Energy
sensor.power_rack_device_power
Power Rack Device Power
friendly_name: Power Rack Device Power
sensor.power_rack_electric_consumption_kwh_4
Power Rack: Electric Consumption [kWh]
friendly_name: Power Rack: Electric Consumption [kWh]
sensor.power_rack_electric_consumption_w_4
Power Rack: Electric Consumption [W]
friendly_name: Power Rack: Electric Consumption [W]
sensor.power_rack_node_status_4
Power Rack: Node Status
friendly_name: Power Rack: Node Status
sensor.power_rack_power_3
Power Rack: Power
friendly_name: Power Rack: Power
sensor.power_second_switch_device_energy
Power Second Switch Device Energy
friendly_name: Power Second Switch Device Energy
sensor.power_second_switch_device_power
Power Second Switch Device Power
friendly_name: Power Second Switch Device Power
sensor.power_second_switch_electric_consumption_kwh_11
Power Second Switch: Electric Consumption [kWh]
friendly_name: Power Second Switch: Electric Consumption [kWh]
sensor.power_second_switch_electric_consumption_w_11
Power Second Switch: Electric Consumption [W]
friendly_name: Power Second Switch: Electric Consumption [W]
sensor.power_second_switch_node_status_11
Power Second Switch: Node Status
friendly_name: Power Second Switch: Node Status
sensor.power_second_switch_power_10
Power Second Switch: Power
friendly_name: Power Second Switch: Power
sensor.power_synology_nas_device_energy
Power Synology NAS Device Energy
friendly_name: Power Synology NAS Device Energy
sensor.power_synology_nas_device_power
Power Synology NAS Device Power
friendly_name: Power Synology NAS Device Power
sensor.power_synology_nas_electric_consumption_kwh_10
Power Synology NAS: Electric Consumption [kWh]
friendly_name: Power Synology NAS: Electric Consumption [kWh]
sensor.power_synology_nas_electric_consumption_w_10
Power Synology NAS: Electric Consumption [W]
friendly_name: Power Synology NAS: Electric Consumption [W]
sensor.power_synology_nas_node_status_10
Power Synology NAS: Node Status
friendly_name: Power Synology NAS: Node Status
sensor.power_synology_nas_power
Power
sensor.power_synology_nas_power_9
Power Synology NAS: Power
friendly_name: Power Synology NAS: Power
sensor.power_tv_electric_consumption_kwh_19
Power TV: Electric Consumption [kWh]
friendly_name: Power TV: Electric Consumption [kWh]
sensor.power_tv_electric_consumption_w_19
Power TV: Electric Consumption [W]
friendly_name: Power TV: Electric Consumption [W]
sensor.power_tv_node_status_19
Power TV: Node Status
friendly_name: Power TV: Node Status
sensor.power_tv_power_18
Power TV: Power
friendly_name: Power TV: Power
sensor.power_unifi_internet_usg_device_energy
Power Unifi Internet (Usg) Device Energy
friendly_name: Power Unifi Internet (Usg) Device Energy
sensor.power_unifi_internet_usg_device_power
Power Unifi Internet (Usg) Device Power
friendly_name: Power Unifi Internet (Usg) Device Power
sensor.power_unifi_internet_usg_electric_consumption_kwh_12
Power Unifi Internet (Usg): Electric Consumption [kWh]
friendly_name: Power Unifi Internet (Usg): Electric Consumption [kWh]
sensor.power_unifi_internet_usg_electric_consumption_w_12
Power Unifi Internet (Usg): Electric Consumption [W]
friendly_name: Power Unifi Internet (Usg): Electric Consumption [W]
sensor.power_unifi_internet_usg_node_status_12
Power Unifi Internet (Usg): Node Status
friendly_name: Power Unifi Internet (Usg): Node Status
sensor.power_unifi_internet_usg_power_11
Power Unifi Internet (Usg): Power
friendly_name: Power Unifi Internet (Usg): Power
sensor.power_washer_distance
Power Washer Distance
friendly_name: Power Washer Distance
sensor.power_washer_electric_consumption_kwh_27
Power Washer: Electric Consumption [kWh]
friendly_name: Power Washer: Electric Consumption [kWh]
sensor.power_washer_electric_consumption_w_27
Power Washer: Electric Consumption [W]
friendly_name: Power Washer: Electric Consumption [W]
sensor.power_washer_node_status_27
Power Washer: Node Status
friendly_name: Power Washer: Node Status
sensor.power_washer_power_26
Power Washer: Power
friendly_name: Power Washer: Power
sensor.power_wine_cooler_electric_consumption_kwh_16
Power Wine Cooler: Electric Consumption [kWh]
friendly_name: Power Wine Cooler: Electric Consumption [kWh]
sensor.power_wine_cooler_electric_consumption_w_16
Power Wine Cooler: Electric Consumption [W]
friendly_name: Power Wine Cooler: Electric Consumption [W]
sensor.power_wine_cooler_humidity
Power Wine Cooler Humidity
friendly_name: Power Wine Cooler Humidity
sensor.power_wine_cooler_node_status_16
Power Wine Cooler: Node Status
friendly_name: Power Wine Cooler: Node Status
sensor.power_wine_cooler_outside_temperature
Power Wine Cooler Outside temperature
friendly_name: Power Wine Cooler Outside temperature
sensor.power_wine_cooler_power_15
Power Wine Cooler: Power
friendly_name: Power Wine Cooler: Power
sensor.power_wine_cooler_velocity
Power Wine Cooler Velocity
friendly_name: Power Wine Cooler Velocity
sensor.power_working_area_laptop_docking_station_electric_consumption_kwh_18
Power Working Area Laptop Docking Station: Electric Consumption [kWh]
friendly_name: Power Working Area Laptop Docking Station: Electric Consumption [kWh]
sensor.power_working_area_laptop_docking_station_electric_consumption_w_18
Power Working Area Laptop Docking Station: Electric Consumption [W]
friendly_name: Power Working Area Laptop Docking Station: Electric Consumption [W]
sensor.power_working_area_laptop_docking_station_electric_kwh
Power Working Area Laptop Docking Station: Electric [kWh]
friendly_name: Power Working Area Laptop Docking Station: Electric [kWh]
sensor.power_working_area_laptop_docking_station_electric_kwh_2
Power Working Area Laptop Docking Station Electric [kWh]
friendly_name: Power Working Area Laptop Docking Station Electric [kWh]
sensor.power_working_area_laptop_docking_station_humidity
Power Working Area Laptop Docking Station Humidity
friendly_name: Power Working Area Laptop Docking Station Humidity
sensor.power_working_area_laptop_docking_station_node_status_18
Power Working Area Laptop Docking Station: Node Status
friendly_name: Power Working Area Laptop Docking Station: Node Status
3500-4102
sensor.power_working_area_laptop_docking_station_power_17
Power Working Area Laptop Docking Station: Power
friendly_name: Power Working Area Laptop Docking Station: Power
sensor.power_working_area_laptop_docking_station_velocity
Power Working Area Laptop Docking Station Velocity
friendly_name: Power Working Area Laptop Docking Station Velocity
sensor.power_working_area_laptop_docking_station_water_oxidation_reduction_potential
Power Working Area Laptop Docking Station Water Oxidation reduction potential
friendly_name: Power Working Area Laptop Docking Station Water Oxidation reduction potential
sensor.power_working_room_switch_electric_consumption_kwh_17
Power Working Room Switch: Electric Consumption [kWh]
friendly_name: Power Working Room Switch: Electric Consumption [kWh]
sensor.power_working_room_switch_electric_consumption_w_17
Power Working Room Switch: Electric Consumption [W]
friendly_name: Power Working Room Switch: Electric Consumption [W]
sensor.power_working_room_switch_electric_kwh
Power Working Room Switch Electric [kWh]
friendly_name: Power Working Room Switch Electric [kWh]
sensor.power_working_room_switch_node_status_17
Power Working Room Switch: Node Status
friendly_name: Power Working Room Switch: Node Status
sensor.power_working_room_switch_power_16
Power Working Room Switch: Power
friendly_name: Power Working Room Switch: Power
sensor.powercalc
powercalc
friendly_name: powercalc
sensor.powersaver
Powersaver
friendly_name: Powersaver
sensor.radiator_emil_battery_level_2
Radiator Emil: Battery level
friendly_name: Radiator Emil: Battery level
sensor.radiator_emil_electric_consumption_kwh
friendly_name: Electric Consumption [kWh]
sensor.radiator_master_bedroom_battery_level_2
Radiator Master Bedroom: Battery level
friendly_name: Radiator Master Bedroom: Battery level
sensor.radiator_nebo_battery_level_2
Radiator Nebo: Battery level
friendly_name: Radiator Nebo: Battery level
sensor.radioator_working_area_node_status
Radioator Working Area: Node Status
friendly_name: Radioator Working Area: Node Status
sensor.sakerhetsdocka_battery_level
säkerhetsdocka Battery level
friendly_name: säkerhetsdocka Battery level
sensor.sida_av_huset_luminance
Sida av huset Luminance
friendly_name: Sida av huset Luminance
sensor.sl_departure_sensor_2410_lovisedal
SL Departure Sensor 2410 (Lovisedal)
friendly_name: SL Departure Sensor 2410 (Lovisedal)
sensor.sl_departure_sensor_2412_tallasvagen_nytt_api
SL Departure Sensor 2412 (Tallåsvägen (Nytt API))
friendly_name: SL Departure Sensor 2412 (Tallåsvägen (Nytt API))
sensor.sl_departure_sensor_2510_uthamra_strand_nytt_api
SL Departure Sensor 2510 (Uthamra Strand (Nytt API))
friendly_name: SL Departure Sensor 2510 (Uthamra Strand (Nytt API))
sensor.sl_departure_sensor_9628_kragstalund_nytt_api
SL Departure Sensor 9628 (Kragstalund (Nytt API))
friendly_name: SL Departure Sensor 9628 (Kragstalund (Nytt API))
sensor.smart_switch_6_electric_consumption_a
Smart Switch 6 Electric Consumption [A]
friendly_name: Smart Switch 6 Electric Consumption [A]
sensor.smart_switch_6_electric_consumption_kwh
Smart Switch 6 Electric Consumption [kWh]
friendly_name: Smart Switch 6 Electric Consumption [kWh]
sensor.smart_switch_6_electric_consumption_v
Smart Switch 6 Electric Consumption [V]
friendly_name: Smart Switch 6 Electric Consumption [V]
sensor.smart_switch_6_electric_consumption_w
Smart Switch 6 Electric Consumption [W]
friendly_name: Smart Switch 6 Electric Consumption [W]
sensor.smoke_bedroom_sensor_air_temperature
Smoke Bedroom Sensor: Air temperature
friendly_name: Smoke Bedroom Sensor: Air temperature
sensor.smoke_bedroom_sensor_battery_level
Smoke Bedroom Sensor: Battery level
friendly_name: Smoke Bedroom Sensor: Battery level
sensor.smoke_bedroom_sensor_general_purpose_duration
Smoke Bedroom Sensor: General Purpose duration
friendly_name: Smoke Bedroom Sensor: General Purpose duration
sensor.smoke_bedroom_sensor_general_purpose_severity
Smoke Bedroom Sensor: General Purpose severity
friendly_name: Smoke Bedroom Sensor: General Purpose severity
sensor.smoke_bedroom_sensor_heat_duration
Smoke Bedroom Sensor: Heat duration
friendly_name: Smoke Bedroom Sensor: Heat duration
sensor.smoke_bedroom_sensor_heat_severity
Smoke Bedroom Sensor: Heat severity
friendly_name: Smoke Bedroom Sensor: Heat severity
sensor.smoke_bedroom_sensor_smoke_duration
Smoke Bedroom Sensor: Smoke duration
friendly_name: Smoke Bedroom Sensor: Smoke duration
sensor.smoke_bedroom_sensor_smoke_severity
Smoke Bedroom Sensor: Smoke severity
friendly_name: Smoke Bedroom Sensor: Smoke severity
sensor.smoke_emils_room_detector_air_temperature
Smoke Emils room Detector: Air temperature
friendly_name: Smoke Emils room Detector: Air temperature
sensor.smoke_emils_room_detector_battery_level
Smoke Emils room Detector: Battery level
friendly_name: Smoke Emils room Detector: Battery level
sensor.smoke_garage_sensor_air_temperature_2
Smoke Garage Sensor: Air temperature
friendly_name: Smoke Garage Sensor: Air temperature
sensor.smoke_garage_sensor_battery_level_2
Smoke Garage Sensor: Battery level
friendly_name: Smoke Garage Sensor: Battery level
sensor.smoke_garage_sensor_general_purpose_duration_2
Smoke Garage Sensor: General Purpose duration
friendly_name: Smoke Garage Sensor: General Purpose duration
sensor.smoke_garage_sensor_general_purpose_severity_2
Smoke Garage Sensor: General Purpose severity
friendly_name: Smoke Garage Sensor: General Purpose severity
sensor.smoke_garage_sensor_heat_duration_2
Smoke Garage Sensor: Heat duration
friendly_name: Smoke Garage Sensor: Heat duration
sensor.smoke_garage_sensor_heat_severity_2
Smoke Garage Sensor: Heat severity
friendly_name: Smoke Garage Sensor: Heat severity
sensor.smoke_garage_sensor_power
Smoke Garage Sensor Power
friendly_name: Smoke Garage Sensor Power
sensor.smoke_garage_sensor_smoke_duration_2
Smoke Garage Sensor: Smoke duration
friendly_name: Smoke Garage Sensor: Smoke duration
sensor.smoke_garage_sensor_smoke_severity_2
Smoke Garage Sensor: Smoke severity
friendly_name: Smoke Garage Sensor: Smoke severity
sensor.smoke_kitchen_detector_air_temperature_2
Smoke Kitchen Detector: Air temperature
friendly_name: Smoke Kitchen Detector: Air temperature
sensor.smoke_kitchen_detector_battery_level_2
Smoke Kitchen Detector: Battery level
friendly_name: Smoke Kitchen Detector: Battery level
sensor.smoke_nebos_bedroom_detector_air_temperature
Smoke Nebos Bedroom Detector: Air temperature
friendly_name: Smoke Nebos Bedroom Detector: Air temperature
sensor.smoke_nebos_bedroom_detector_battery_level
Smoke Nebos Bedroom Detector: Battery level
friendly_name: Smoke Nebos Bedroom Detector: Battery level
sensor.smoke_working_area_detector_air_temperature
Smoke Working Area Detector: Air temperature
friendly_name: Smoke Working Area Detector: Air temperature
sensor.smoke_working_area_detector_battery_level
Smoke Working Area Detector: Battery level
friendly_name: Smoke Working Area Detector: Battery level
sensor.soffa_hoger_energy
Soffa höger energy
friendly_name: Soffa höger energy
sensor.soffa_hoger_powersensor
Soffa höger Powersensor
friendly_name: Soffa höger Powersensor
sensor.soffa_vanster_energy
Soffa vänster energy
friendly_name: Soffa vänster energy
sensor.soffa_vanster_powersensor
Soffa vänster Powersensor
friendly_name: Soffa vänster Powersensor
sensor.software_version
software version
friendly_name: software version
sensor.sonos_move_battery
Sonos Move Battery
friendly_name: Sonos Move Battery
sensor.temperature_and_humidity_sensor_air_temperature
Temperature and Humidity Sensor Air temperature
friendly_name: Temperature and Humidity Sensor Air temperature
sensor.temperature_and_humidity_sensor_air_temperature_2
sensor.temperature_and_humidity_sensor_battery_level
Temperature and Humidity Sensor Battery level
friendly_name: Temperature and Humidity Sensor Battery level
sensor.temperature_and_humidity_sensor_humidity
Temperature and Humidity Sensor Humidity
friendly_name: Temperature and Humidity Sensor Humidity
sensor.temperature_and_humidity_sensor_humidity_2
Temperature and Humidity Sensor Humidity (2)
friendly_name: Temperature and Humidity Sensor Humidity (2)
sensor.temperature_and_humidity_sensor_power
Temperature and Humidity Sensor Power
friendly_name: Temperature and Humidity Sensor Power
sensor.time
Time
friendly_name: Time
sensor.time_date
Time & Date
friendly_name: Time & Date
sensor.time_utc
Time (UTC)
friendly_name: Time (UTC)
sensor.tradfri_remote_control
TRADFRI remote control
friendly_name: TRADFRI remote control
sensor.ups_battery_charge
Ups Battery Charge
friendly_name: Ups Battery Charge
sensor.ups_load
Ups Load
friendly_name: Ups Load
sensor.ups_status
Ups Status
friendly_name: Ups Status
sensor.ups_status_data
Ups Status Data
friendly_name: Ups Status Data
sensor.upstairs_volume
Upstairs Volume
friendly_name: Upstairs Volume
sensor.waterfuse_electric_consumption_kwh
sensor.waterfuse_humidity
Humidity
friendly_name: Humidity
sensor.waterfuse_power
Power
sensor.ws2300_49_00_battery
WS2300 49:00 Battery
friendly_name: WS2300 49:00 Battery
sensor.ws2300_49_00_signal_strength
WS2300 49:00 Signal strength
friendly_name: WS2300 49:00 Signal strength
sensor.ws2300_49_00_wind_average_speed
WS2300 49:00 Wind average speed
friendly_name: WS2300 49:00 Wind average speed
sensor.ws2300_49_00_wind_direction
WS2300 49:00 Wind direction
friendly_name: WS2300 49:00 Wind direction
sensor.ws2300_49_00_wind_gust
WS2300 49:00 Wind gust
friendly_name: WS2300 49:00 Wind gust
sensor.ws2300_4e_00_battery
WS2300 4e:00 Battery
friendly_name: WS2300 4e:00 Battery
sensor.ws2300_4e_00_signal_strength
WS2300 4e:00 Signal strength
friendly_name: WS2300 4e:00 Signal strength
sensor.ws2300_4e_00_wind_average_speed
WS2300 4e:00 Wind average speed
friendly_name: WS2300 4e:00 Wind average speed
sensor.ws2300_4e_00_wind_direction
WS2300 4e:00 Wind direction
friendly_name: WS2300 4e:00 Wind direction
sensor.ws2300_4e_00_wind_gust
WS2300 4e:00 Wind gust
friendly_name: WS2300 4e:00 Wind gust
sensor.ws2300_4f_00_battery
WS2300 4f:00 Battery
friendly_name: WS2300 4f:00 Battery
sensor.ws2300_4f_00_signal_strength
WS2300 4f:00 Signal strength
friendly_name: WS2300 4f:00 Signal strength
sensor.ws2300_4f_00_wind_average_speed
WS2300 4f:00 Wind average speed
friendly_name: WS2300 4f:00 Wind average speed
sensor.ws2300_4f_00_wind_direction
WS2300 4f:00 Wind direction
friendly_name: WS2300 4f:00 Wind direction
sensor.ws2300_4f_00_wind_gust
WS2300 4f:00 Wind gust
friendly_name: WS2300 4f:00 Wind gust
siren.upstairs_siren
Upstairs Siren
friendly_name: Upstairs Siren
sun.sun
Sun
friendly_name: Sun
switch.double_relay_switch_2x1_5kw
WaterFuse
friendly_name: WaterFuse
switch.jul_switch_on_off
Jul Switch ON/OFF
switch.light_kitchen_sink
switch.light_kitchen_sink_2
Light Kitchen - Sink (2)
friendly_name: Light Kitchen - Sink (2)
switch.lights_bathroom_ground_floor_2_2
Lights Bathroom - Celling
friendly_name: Lights Bathroom - Celling
switch.lights_bathroom_ground_floor_3
Lights Bathroom - Mirror
friendly_name: Lights Bathroom - Mirror
switch.lights_bathroom_top_floor_2_3
Lights Bathroom Top Floor Celling
friendly_name: Lights Bathroom Top Floor Celling
switch.lights_bathroom_top_floor_4
Lights Bathroom Top Floor Mirror
friendly_name: Lights Bathroom Top Floor Mirror
switch.lights_kitchen
Table Lamp Switch
friendly_name: Table Lamp Switch
switch.lights_kitchen_2
Kitchen Lamp - Celling
friendly_name: Kitchen Lamp - Celling
switch.living_room_crossfade
Crossfade
friendly_name: Crossfade
switch.living_room_loudness
Loudness
friendly_name: Loudness
switch.metered_wall_plug_switch
switch.motion_livingroom_motion
Motion Livingroom Motion
friendly_name: Motion Livingroom Motion
switch.nibe_156732_48043
Holiday
friendly_name: Holiday
switch.power_ac_6
Power AC
switch.power_barndoor_9
Power Barndoor
switch.power_coutch_8
Power Coutch
switch.power_dishwasher_28
Power Dishwasher
switch.power_dryer_26
Power Dryer
switch.power_ecoflow_delta_battery_20
switch.power_emils_desktop_2
Power Emils Desktop
switch.power_faketv
Power fakeTV
switch.power_garage_freezer_3
switch.power_garage_stereo_and_misc_7
switch.power_homeassistant_and_others_14
switch.power_ipad_2
Power iPad
switch.power_kitchen_fan_21
Power Kitchen FAN
switch.power_kitchen_freezer_24
switch.power_kitchen_fridge_25
switch.power_living_room_aircleaner_5
switch.power_motion_detector_backyard_23
switch.power_motion_detectors_frontdoor_and_garage_22
switch.power_nebos_dator_15
Power Nebos Dator
switch.power_primary_switch_13
switch.power_projector_2
Power Projector
switch.power_rack_4
Power Rack
switch.power_second_switch_11
Power Second Switch
switch.power_synology_nas_10
Power Synology NAS
switch.power_tv_19
Power TV
switch.power_unifi_internet_usg_12
switch.power_washer_27
Power Washer
switch.power_wine_cooler_16
Power Wine Cooler
switch.power_working_area_laptop_docking_station_18
switch.power_working_room_switch_17
switch.smart_switch_6
Smart Switch 6
switch.sonos_alarm_78
Sonos Move Weekdays alarm 06:45
friendly_name: Sonos Move Weekdays alarm 06:45
switch.sonos_alarm_83
Sonos Move Weekends alarm 08:30
friendly_name: Sonos Move Weekends alarm 08:30
switch.sonos_living_room_crossfade
Sonos Living Room Crossfade
friendly_name: Sonos Living Room Crossfade
switch.sonos_living_room_loudness
Sonos Living Room Loudness
friendly_name: Sonos Living Room Loudness
switch.sonos_move_crossfade
Sonos Move Crossfade
friendly_name: Sonos Move Crossfade
switch.sonos_move_loudness
Sonos Move Loudness
friendly_name: Sonos Move Loudness
switch.sovrum_crossfade
Sovrum Crossfade
friendly_name: Sovrum Crossfade
switch.sovrum_loudness
Sovrum Loudness
friendly_name: Sovrum Loudness
switch.zhimi_za4_39a9_physical_control_locked
Fan under trappan Physical Control Locked
friendly_name: Fan under trappan Physical Control Locked
switch.zhimi_za4_9f17_physical_control_locked
Fläkt i vardagen Physical Control Locked
friendly_name: Fläkt i vardagen Physical Control Locked
vacuum.dreame_p2028_536e_robot_cleaner
Dreame Bot Z10 Pro Robot Cleaner
friendly_name: Dreame Bot Z10 Pro Robot Cleaner
water_heater.nibe_hot_water
Hot Water
friendly_name: Hot Water
zone.home
Home
friendly_name: Home
zone.home_2
Home
friendly_name: Home
Layout
Please let me know if I have missed any more information of you’re request…
I have not listed all the things I found, but just some examples of potential issues.
They are all in the name of the entity, but this is typically also the thing that is showed in NodeRed.
comma is probably okay in most cases, but there might be issues in some integrations.
Colon is slightly worse that comma, but should still be generally okay.
The / can really cause issues, because it can be used as a escape or control character in some places.
These characters I would avoid using in the name for sure. The friendly name should be okay with it.
The ’ is often used as a text indicator and having only one of them is actually the worst, because that means you could make a text after the character be seen as text and it will not be closed again, so the effect can be huge.
[ and ] is sometimes used for control codes and sometimes for special inputs.
( and ) is sometimes used for control codes and sometimes for special inputs, but though to a lesser degree than [ and ]
| is a special character for pipe and should never be used in my opinion in a text field, not even in the friendly name.
Excellent, all of these name are automatically set when I import theme in the import process.
Now I have go trough theme manually and see if that solves my problem.
Thanks for your time and help, really appreciated!
Regards Boz
Start with the | / '
They are the ones that stick most out to me and they are few in your setup.
Ok, I went trough theme all and added the entities in a customization.yaml file with the entityID and a clean friendly name, but still the same issue.
If I look in the entity dropdown the corrected names is shown properly, but still the same issue.
I removed all ,/|() and all that could be an issue.
