From Home Assistant log (ver. 0.105.4):
2020-02-16 22:15:03 INFO (SyncWorker_8) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2020-02-16 22:15:03 INFO (MainThread) [homeassistant.bootstrap] Setting up {'logger', 'system_log'}
2020-02-16 22:15:03 INFO (MainThread) [homeassistant.setup] Setting up logger
2020-02-16 22:15:07 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 415, in _async_add_entity
raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: switch.switch_2. Platform mqtt does not generate unique IDs
homeassistant.exceptions.HomeAssistantError: Entity id already exists: switch.switch_9. Platform mqtt does not generate unique IDs
I tried to locate these switch_2
and switch_9
duplicate entries:
# find . -type f -exec grep -Hn "switch_2" {} \;
./home-assistant.log:5:homeassistant.exceptions.HomeAssistantError: Entity id already exists: switch.switch_2. Platform mqtt does not generate unique IDs
./home-assistant.log:15:homeassistant.exceptions.HomeAssistantError: Entity id already exists: switch.switch_2. Platform mqtt does not generate unique IDs
./.storage/core.entity_registry:504: "entity_id": "switch.switch_2",
./.storage/core.restore_state:861: "friendly_name": "switch_2",
./.storage/core.restore_state:869: "entity_id": "switch.switch_2",
Binary file ./home-assistant_v2.db matches
It looks like it is registered only once in ./.storage/core.entity_registry
. I have stopped HA, deleted core.*
files and restarted HA → the output above is after that operation. (switch_9
is the same).
These names used to exist a long time ago (more than just these two) but are long gone and not present in any configuration.
Is this a bug?
