I would like to have my humidy sensors state from past, lets say 10min before exhaust fan turned on, so that i could refer to that value and shutdown exhaust fan when humidy is returned to “normal”.
I can get timestamp with this {{ states.switch.waveshare_rele_6.last_changed }}
This is sensor that i would like to get value from that timestamp sensor.bthome_sensor_51c5_humidity
I read about using SQL database, and i got so far that i get value from that sensor, but how i can get that -10 minutes??
- name: Suihkun kosteus ennen poistoa
query: >
SELECT
states.state
FROM
states
INNER JOIN states_meta ON
states.metadata_id = states_meta.metadata_id
WHERE
states_meta.entity_id = 'sensor.bthome_sensor_51c5_humidity'
AND last_updated_ts <= strftime('states.switch.waveshare_rele_6.last_changed - timedelta(minutes=5)')
ORDER BY
last_updated_ts DESC
LIMIT
1;
column: "state"
But this does not work, i get latest value instead of from that timestamp
How should i change my query??
I had some progress, but cant get two messages together, it shows unknown
With this query i can get humidy -5 min ago.
SELECT
states.state
FROM
states
WHERE
AND last_updated_ts <= strftime('%s', 'now', '-5 minute')
ORDER BY
LIMIT
1;
And this is to get timestamp from another entity, to be used
SELECT
last_updated_ts
FROM
states
WHERE
metadata_id = (
SELECT
metadata_id
FROM
states_meta
WHERE
states_meta.entity_id = 'switch.waveshare_rele_6'
ORDER BY
LIMIT
1
Tried to put second query inside strftime
SELECT
states.state
FROM
states
WHERE
AND last_updated_ts <= strftime('%s',(SELECT
last_updated_ts
FROM
states
WHERE
metadata_id = (
SELECT
metadata_id
FROM
states_meta
WHERE
ORDER BY
LIMIT
1), '-5 minute')
ORDER BY
LIMIT
1;
edit.
Found right query, replaced strftime with timestamp query and subtracted 5 min (300s)
SELECT
states.state
FROM
states
WHERE
AND last_updated_ts <= (SELECT
last_updated_ts
FROM
states
WHERE
ORDER BY
LIMIT
1) - 300
ORDER BY
LIMIT
1;
I tried that blueprint, it didnt work when i used sauna, it started exhaust fan but never stopped.
Problem is that humidy doesnt fall fast enought when sauna is in use, to use derivate sensor.
I try to make another SQL query, but dont know how to convert value to timestamp.
Current query is allmost copy from above
SELECT
states.state
FROM
states
WHERE
states_meta.entity_id = 'sensor.power_production_next_24hours_3'
states.state
FROM
states
WHERE
states_meta.entity_id = 'sensor.power_highest_peak_time_tomorrow_3'
ORDER BY
LIMIT
1)
ORDER BY
LIMIT
1;
Subquery gives value 2025-05-28T10:00:00+00:00, that is in future, how this can be converted to -1day and used as timestamp to query value from sensor.power_production_next_24hours_3 sensor?
