I’m rebuilding my Home Assistant on new hardware and I can’t seem to get the hourly forecast.
If I drill down into the Forecast I can see the “Daily” and “Hourly” but I can’t seem to get weather.forecast_hourly enabled.
Was this killed post HA Ver. 2023.11.3?
Nevermind, Figure out that Hourly is selectable in the Weather Forecast card.
@rlongfield
Would you mind sharing your findings with me. A “Breaking Change” in 2024.04.01 removed the weather.forecast_hourly . I have a template that used that sensor. It’s no longer functioning because of the change. My template looks like this;
template:
- trigger:
{SENSORS OMITTED FOR CLARITY}
- name: Weatherman Data
state: "OK"
attributes:
weather_condition_now: >
{% set cond_now = states('weather.stratford_hourly') %}
{% if states('sun.sun') == 'below_horizon' %}
{% if cond_now == 'sunny' %} night {% elif cond_now == 'partlycloudy' %} night-partly-cloudy {% else %} {{ cond_now }} {% endif %}
{% else %}
{{ cond_now }}
{% endif %}
weather_temperature_now: >
{{ state_attr('weather.stratford', 'temperature') | float(0.0) }}
weather_condition_0: >
{% set cond0 = state_attr('weather.stratford_hourly', 'forecast')[0].condition %}
{% set next_setting = as_timestamp(state_attr('sun.sun', 'next_setting')) %}
{% set next_rising = as_timestamp(state_attr('sun.sun', 'next_rising')) %}
{% set cond0_time = as_timestamp(state_attr('weather.stratford_hourly', 'forecast')[0].datetime) %}
{% if cond0_time < next_rising and next_rising < next_setting %}
{% if cond0 == 'sunny' %} night {% elif cond0 == 'partlycloudy' %} night-partly-cloudy {% else %} {{ cond0 }} {% endif %}
{% else %}
{{ cond0 }}
{% endif %}
The only place I found it was in the Weather Card. I stopped trying to figure out where (or how to get) the weather.*_hourly went
pcwii
(Pcwii)
April 4, 2024, 11:28pm
4
The hourly has broken for me too with the latest HA.
I noticed the hourly is still found in the weather sensor, it is just not available on my dashboard.
I notice it is mentioned in the Backward incompatible changes, but it doesn’t say how to utilize the hourly forecast now.
Time for spring cleaning 🧹 Introducing new ways to organize your automations (and more) with floors, labels, and categories. Easily add Matter devices from other controllers, and two brand new map ...
pcwii
(Pcwii)
April 4, 2024, 11:53pm
5
Found this.
With the latest HA there is a new Service-Call introduced for the Weather-Forecast Integration
And im not sure if there is an “Official” solution “printed” down somewhere, but there is a few suggestions here in the forum, in regards to using these data (forecasts) in i.e templates … depending upon in what way one will need these data, … you are in for a journey in automations/templates/template-sensors/binary sensors etc
EDIT: 2023.12
Note that the Service have changed to " Service w…
The Get Forecast service works, just need to figure out how to get this into a template then dashboard.
service: weather.get_forecasts
entity_id: weather.kitchener_waterloo
type: hourly
Here is one example ( Ive done 1 for each day/hour i need in UI ) so i don’t have all i.e 24 hours
# Trigger 0 Hourly
- trigger:
- platform: state
entity_id: weather.forecast_home
- service: weather.get_forecasts
type: hourly
response_variable: hourly
- name: weather-0
availability: "true"
unique_id: weather_0
state: "{{ hourly['weather.forecast_home'].forecast[0].temperature }}"
unit_of_measurement: °C
attributes:
weather_datetime: "{{ hourly['weather.forecast_home'].forecast[0].datetime }}"
weather_condition: "{{ hourly['weather.forecast_home'].forecast[0].condition }}"
weather_temp: "{{ hourly['weather.forecast_home'].forecast[0].temperature }}"
weather_humid: "{{ hourly['weather.forecast_home'].forecast[0].humidity }}"
weather_wind_bearing: "{{ hourly['weather.forecast_home'].forecast[0].wind_bearing }}"
weather_wind_speed: "{{ hourly['weather.forecast_home'].forecast[0].wind_speed }}"
weather_wind_gust: "{{ hourly['weather.forecast_home'].forecast[0].wind_gust_speed }}"
weather_precipitationt: "{{ hourly['weather.forecast_home'].forecast[0].precipitation }}"
Below is another with i.e all_attr(in 1) + 5 days-attr in 1 sensor ( This can be adapted to hourly, by changing the type/response_variable, like above )
ApexCharts card - A highly customizable graph card - #3454 by Mariusthvdb .
Edit: The reason i choosed 1 for each hour/day, is because i Changed my Weather-overview to Custom:button-cards
I’m glad my use of hourly forecast was covered by the existing weather card. This change doesn’t feel like an improvement.
pcwii
(Pcwii)
April 6, 2024, 1:33am
8
So after trying to create an hourly trigger template I realized all I had to do was update my dashboard so that the hourly entity was changed to my standard weather entity and my hourly forecast showed up.
MEAUTO
(MEAUTO)
April 8, 2024, 4:15am
9
Hello, mine doesn’t the hourly on the dashboard, how did you exactly updated your dashboard? I am using custom:Weather_card. Thanks
pcwii
(Pcwii)
April 8, 2024, 10:41am
10
Just use the primary weather entity that is created as the standard entity.
Make sure forecast_type is hourly or daily, and make sure show_forecast is true.
show_current: true
show_forecast: true
type: weather-forecast
entity: weather.kitchener_waterloo
forecast_type: hourly
MEAUTO
(MEAUTO)
April 8, 2024, 3:44pm
11
Thank you, doesn’t work for me, I am using Weather-Card with animated icons, not the weather-forecast. It seems the custom:weather-card that needs an update. Will play with it later this week. Thanks again
pcwii
(Pcwii)
April 8, 2024, 8:14pm
12
I use both.
- type: custom:weather-card
- type: weather-forecast
show_current: false
show_forecast: true
show_current: false
show_forecast: true
forecast_type: daily
