Here is the code I came up with;
substitutions:
# The following lines may be modified #
software_version: Date 2023 10 26, v140
log_level: debug # Enable levels logging https://esphome.io/components/logger.html
# none, error, warn, info, debug (default), verbose, very_verbose
# DO NOT CHANGE ANYTHING BELOW THIS LINE #
esphome_name: weatherman-dashboard
esphome_friendly_name: Weatherman Dashboard
esphome_board: esp32dev # ESP32-D0WDQ6(version 1)
esphome_framework_type: arduino
esphome_comment: Local Weatherman, Home Maintenance Dashboard
esphome_project_name: RCB.Local Weatherman, Home Maintenance Dashboard
esphome_project_version: Weatherman Dashboard, $software_version
devicename: weatherman_dashboard
upper_devicename: "Weatherman Dashboard"
gpio_dc_pin: GPIO04
gpio_cs_pin: GPIO05
gpio_reset_pin: GPIO16
gpio_spi_clk_pin: GPIO18
gpio_busy_pin: GPIO19
gpio_spi_mosi_pin: GPIO23
gpio_sda_pin: GPIO21
gpio_scl_pin: GPIO22
i2c:
sda: $gpio_sda_pin
scl: $gpio_scl_pin
esphome:
friendly_name: $esphome_friendly_name
comment: $esphome_comment
project:
version: $esphome_project_version
on_boot:
priority: 200.0
then:
- component.update: eink_display
- wait_until:
condition:
lambda: 'return id(data_updated) == true;'
# Wait a bit longer so all the items are received
- delay: 8s
- logger.log: "Initial sensor data received: Refreshing display..."
- lambda: 'id(initial_data_received) = true;'
- script.execute: update_screen
esp32:
board: $esphome_board
framework:
type: $esphome_framework_type
light:
- platform: status_led
pin: GPIO2
restore_mode: ALWAYS_ON
internal: true
effects:
- strobe:
name: "Slow Blink" # 0.1s on, 2s off
colors:
- state: true
brightness: 100%
duration: 100ms
- state: false
duration: 2s
on_turn_on:
then:
- light.turn_on:
effect: "Slow Blink"
wifi:
ssid: !secret 'wifi_ssid'
password: !secret 'wifi_password'
logger:
level: ${log_level}
logs:
text_sensor: WARN
ota:
password: !secret 'ota_password'
captive_portal:
web_server:
port: 80
time:
- platform: sntp
timezone: America/Toronto
on_time_sync:
then:
- ds1307.write_time
- logger.log:
level: INFO
format: "Time synchronized and written to DS1307"
- platform: ds1307
update_interval: never
on_time:
- seconds: 0
minutes: 0
hours: 6-23
then:
- if:
condition:
then:
- logger.log: "Sensor data updated and activity in home detected: Refreshing display..."
else:
- logger.log: "No sensors updated - skipping display refresh."
api:
encryption:
key: !secret 'api_encryption'
button:
- platform: shutdown
name: "Weatherman - Shutdown"
- platform: restart
name: "Weatherman - Restart"
name: "Weatherman - Refresh Screen"
entity_category: config
on_press:
globals:
- id: data_updated
type: bool
restore_value: no
initial_value: 'false'
- id: initial_data_received
type: bool
restore_value: no
- id: recorded_display_refresh
type: int
restore_value: yes
initial_value: '0'
- id: moon_phase_text
type: std::string
restore_value: no
initial_value: ''
script:
- id: update_screen
then:
- lambda: 'id(data_updated) = false;'
- lambda: 'id(recorded_display_refresh) += 1;'
- lambda: 'id(display_last_update).publish_state(id(ds1307_time).now().timestamp);'
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
# Expose WiFi information as sensor.
- platform: wifi_info
ip_address:
ssid:
# Pressure Trend
- platform: homeassistant
entity_id: sensor.weatherman_data
attribute: pressure_trend
internal: true
on_value:
then:
- lambda: 'id(data_updated) = true;'
# Temp Trend
entity_id: binary_sensor.outside_temperature
internal: true
on_value:
then:
# Weather Alert
attribute: weather_alert
internal: true
on_value:
then:
attribute: weather_condition_now
internal: true
on_value:
then:
attribute: weather_condition_0
internal: true
on_value:
then:
attribute: weather_timestamp_0
internal: true
on_value:
then:
attribute: weather_condition_1
internal: true
on_value:
then:
attribute: weather_timestamp_1
internal: true
on_value:
then:
attribute: weather_condition_2
internal: true
on_value:
then:
attribute: weather_timestamp_2
on_value:
then:
attribute: weather_condition_3
internal: true
on_value:
then:
attribute: weather_timestamp_3
internal: true
on_value:
then:
# Sunrise
attribute: sunrise_time
internal: true
on_value:
then:
# Sunset
attribute: sunset_time
internal: true
on_value:
then:
# Sun Position
attribute: sun_position
internal: true
on_value:
then:
# Moon phase
attribute: moon_phase
internal: true
on_value:
then:
- platform: uptime
- platform: wifi_signal
name: "WiFi RSSI dBm"
unit_of_measurement: "dBm"
entity_category: "diagnostic"
update_interval: 60s
name: "Display Last Update"
device_class: timestamp
name: "Recorded Display Refresh"
accuracy_decimals: 0
unit_of_measurement: "Refreshes"
state_class: "total_increasing"
lambda: 'return id(recorded_display_refresh);'
entity_id: weather.stratford_hourly
attribute: temperature
on_value:
then:
attribute: humidity
on_value:
then:
attribute: barometric_pressure
on_value:
then:
attribute: wind_bearing
on_value:
then:
attribute: wind_speed
on_value:
then:
attribute: uv_index
on_value:
then:
attribute: aqhi
internal: true
on_value:
then:
attribute: visibility
internal: true
on_value:
then:
attribute: weather_temperature_0
on_value:
then:
attribute: weather_temperature_1
on_value:
then:
attribute: weather_temperature_2
on_value:
then:
attribute: weather_temperature_3
on_value:
then:
# Include custom fonts
font:
- file:
type: gfonts
family: Ubuntu
weight: 500
- file:
type: gfonts
family: Ubuntu
weight: 500
- file:
type: gfonts
family: Ubuntu
weight: 500
glyphs: ['W', 'A', 'I', 'T', 'N', 'G', 'F', 'O', 'R', 'D', '.', ' ']
- file:
type: gfonts
family: Ubuntu
weight: 700
glyphs: ['E', 'H', 'L', 'M', 'W', 'e', 'a', 't', 'h', 'r', 'S', 'f', 'o', 'd', 'C', '1', '2', '3', '4', '5', '6', '7', '8', '9', '0', '.', '°', ' ']
- file:
type: gfonts
family: Ubuntu
weight: 700
glyphs: ['1', '2', '3', '4', '5', '6', '7', '8', '9', '0', '-', '.']
- file: 'fonts/materialdesignicons-webfont.ttf'
glyphs: &mdi-weather-glyphs
- "\U000F0590" # mdi-weather-cloudy
- "\U000F0E6E" # mdi-weather-cloudy-arrow-right
- "\U000F0592" # mdi-weather-hail
- "\U000F0F30" # mdi-weather-hazy
- "\U000F0593" # mdi-weather-lightning
- "\U000F0594" # mdi-weather-clear-night
- "\U000F0F31" # mdi-weather-night-partly-cloudy
- "\U000F0595" # mdi-weather-partly-cloudy
- "\U000F0F32" # mdi-weather-partly-lightning
- "\U000F0F33" # mdi-weather-partly-rainy
- "\U000F0F34" # mdi-weather-partly-snowy
- "\U000F0597" # mdi-weather-rainy
- "\U000F067F" # mdi-weather-snowy-rainy
- "\U000F0599" # mdi-weather-sunny
- "\U000F0F37" # mdi-weather-sunny-alert
- "\U000F14E4" # mdi-weather-sunny-off
- "\U000F059A" # mdi-weather-sunset
- "\U000F059B" # mdi-weather-sunset-down
- "\U000F059C" # mdi-weather-sunset-up
- "\U000F0D43" # mdi-air-filter
- "\U000F058E" # mdi-water-percent
- "\U000F0F61" # mdi-moon-first-quarter
- "\U000F0F62" # mdi-moon-full
- "\U000F0F63" # mdi-moon-last-quarter
- "\U000F0F64" # mdi-moon-new
- "\U000F0F65" # mdi-moon-waning-crescent
- "\U000F0F66" # mdi-moon-waning-gibbous
- "\U000F0F67" # mdi-moon-waxing-crescent
- "\U000F0F68" # mdi-moon-waxing-gibbous
- "\U000F15FA" # mdi-windsock
- "\U000F0535" # mdi-trending-up
- "\U000F0533" # mdi-trending-down
- "\U000F00A5" # mdi-binoculars
- "\U000F018C" # mdi-compass-outline
- "\U000F0928" # mdi-wifi-strength-4
- "\U000F0925" # mdi-wifi-strength-3
- "\U000F0922" # mdi-wifi-strength-2
- "\U000F091F" # mdi-wifi-strength-1
- "\U000F092B" # mdi-wifi-strength-alert-outline
- "\U000F0E03" # mdi-thermometer-chevron-up
- "\U000F0E02" # mdi-thermometer-chevron-down
- "\U000F0F36" # mdi-weather-snowy-heavy, Blizzard, Winter storm, WATCH, WARNING
- "\U000F059E" # mdi-weather-windy-variant, Blowing snow, ADVISORY
- "\U000F0E04" # mdi-thermometer-minus, Extreme cold, WARNING
- "\U000F0E01" # mdi-thermometer-alert, Flash freeze, WARNING
- "\U000F0591" # mdi-weather-fog, Fog, ADVISORY
- "\U000F0F35" # mdi-weather-partly-snowy-rainy, Freezing drizzle, Freezing rain, WARNING, ADVISORY
- "\U000F0F29" # mdi-snowflake-alert, Frost, ADVISORY
- "\U000F1A45" # mdi-heat-wave, heat, WARNING
- "\U000F0898" # mdi-weather-hurricane, Hurricane, WATCH, WARNING
- "\U000F0596" # mdi-weather-pouring, Rainfall, WARNING
- "\U000F067E" # mdi-weather-lightning-rainySevere thunderstorm, WATCH, WARNING
- "\U000F0598" # mdi-weather-snowy, Snowfall, WARNING
- "\U000F0026" # mdi-alert, Snow squall, WATCH, WARNING
- "\U000F0F38" # mdi-weather-tornado, Tornado, WATCH, WARNING
- "\U000F1C78" # mdi-weather-hurricane-outline, Tropical storm, WATCH, WARNING
- "\U000F0F2F" # mdi-weather-cloudy-alert, Weather, ADVISORY, WARNING
- "\U000F059D" # mdi-weather-windy, Wind, WARNING
glyphs: *mdi-weather-glyphs
# Define colors
# This design is white on black so this is necessary.
color:
- id: color_bg
red: 0%
green: 0%
blue: 0%
white: 50%
- id: color_text
red: 0%
green: 0%
blue: 0%
white: 0%
spi:
clk_pin: $gpio_spi_clk_pin
mosi_pin: $gpio_spi_mosi_pin
display:
- platform: waveshare_epaper
cs_pin: $gpio_cs_pin
busy_pin: $gpio_busy_pin
reset_pin: $gpio_reset_pin
dc_pin: $gpio_dc_pin
# waveshare 4.2" display, 400px x 300px.
model: 4.20in
lambda: |-
// Map weather states to MDI characters.
std::map<std::string, std::string> weather_icon_map
{"cloudy", "\U000F0590"},
{"cloudy-alert", "\U000F0F2F"},
{"cloudy-arrow-right", "\U000F0E6E"},
{"fog", "\U000F0591"},
{"hail", "\U000F0592"},
{"hazy", "\U000F0F30"},
{"hurricane", "\U000F0898"},
{"lightning", "\U000F0593"},
{"lightning-rainy", "\U000F067E"},
{"clear-night", "\U000F0594"},
{"night-partly-cloudy", "\U000F0F31"},
{"partlycloudy", "\U000F0595"},
{"partly-lightning", "\U000F0F32"},
{"partly-rainy", "\U000F0F33"},
{"partly-snowy", "\U000F0F34"},
{"partly-snowy-rainy", "\U000F0F35"},
{"pouring", "\U000F0596"},
{"rainy", "\U000F0597"},
{"snowy", "\U000F0598"},
{"snowy-heavy", "\U000F0F36"},
{"snowy-rainy", "\U000F067F"},
{"sunny", "\U000F0599"},
{"sunny-alert", "\U000F0F37"},
{"sunny-off", "\U000F14E4"},
{"sunset", "\U000F059A"},
{"sunset-down", "\U000F059B"},
{"sunset-up", "\U000F059C"},
{"tornado", "\U000F0F38"},
{"windy", "\U000F059D"},
{"windy-variant", "\U000F059E"},
std::map<std::string, std::string> moon_icon_map
{"first_quarter", "\U000F0F61"},
{"full_moon", "\U000F0F62"},
{"last_quarter", "\U000F0F63"},
{"new_moon", "\U000F0F64"},
{"waning_crescent", "\U000F0F65"},
{"waning_gibbous", "\U000F0F66"},
{"waxing_crescent", "\U000F0F67"},
{"waxing_gibbous", "\U000F0F68"},
std::map<std::string, std::string> warning_icon_map
{"Blizzard", "\U000F0F36"},
{"Blowing snow", "\U000F059E"},
{"Extreme cold", "\U000F0E04"},
{"Flash freeze", "\U000F0E01"},
{"Fog", "\U000F0591"},
{"Freezing drizzle", "\U000F0F35"},
{"Freezing rain", "\U000F0F35"},
{"Frost", "\U000F0F29"},
{"Heat", "\U000F1A45"},
{"Hurricane", "\U000F0898"},
{"Rainfall", "\U000F0596"},
{"Severe thunderstorm", "\U000F067E"},
{"Snowfall", "\U000F0598"},
{"Snow squall", "\U000F0026"},
{"Tornadao", "\U000F0F38"},
{"Tropical storm", "\U000F1C78"},
{"Weather", "\U000F0F2F"},
{"Wind", "\U000F059D"},
{"Winter storm", "\U000F0F36"},
// Fill background.
it.fill(color_bg);
// Show loading screen before data is received.
if (id(initial_data_received) == false) {
it.printf(200, 150, id(Medium_14pt), color_text, TextAlign::TOP_CENTER, "WAITING FOR DATA...");
} else {
// Weather Section
it.printf(200, 4, id(Bold_24pt), color_text, TextAlign::TOP_CENTER, "Stratford Weather");
// ----------------------------------------------------------------------------------- WEATHER STATE ICON
it.printf(57, 76, id(mdi_font_36pt), color_text, TextAlign::BASELINE_CENTER, "%s", weather_icon_map[id(weather_condition_now).state.c_str()].c_str());
// ----------------------------------------------------------------------------------- WARNINGS
if(id(weather_alert).has_state ()) {
if(id(weather_alert).state != "") {
it.printf(10, 81, id(mdi_font_22pt), color_text, TextAlign::BASELINE_LEFT, "\U000F0026");
it.printf(10, 90, id(Medium_10pt), color_text, TextAlign::BASELINE_LEFT, id(weather_alert).state.c_str());
// ----------------------------------------------------------------------------------- CURRENT TEMPERATURE
it.printf(215, 90, id(Bold_60pt), color_text, TextAlign::BASELINE_RIGHT, "%2.1f", id(weather_temperature).state);
it.printf(218, 40, id(Bold_24pt), color_text, TextAlign::TOP_LEFT, "°C");
if(id(temp_trend).has_state ()) {
if(id(temp_trend).state == "on") {
it.printf(218, 90, id(mdi_font_22pt), color_text, TextAlign::BASELINE_LEFT, "\U000F0E03");
} else if(id(temp_trend).state == "off") {
it.printf(218, 90, id(mdi_font_22pt), color_text, TextAlign::BASELINE_LEFT, "\U000F0E02");
// ----------------------------------------------------------------------------------- WIND
if(id(wind_speed).has_state ()) {
it.printf(280, 76, id(mdi_font_36pt), color_text, TextAlign::BASELINE_CENTER, "\U000F15FA");
it.printf(280, 90, id(Medium_12pt), color_text, TextAlign::BASELINE_CENTER, "%2.0f kmh", id(wind_speed).state);
// ----------------------------------------------------------------------------------- WIND DIRECTION
if(id(wind_bearing).has_state ()) {
it.printf(350, 76, id(mdi_font_36pt), color_text, TextAlign::BASELINE_CENTER, "\U000F018C");
if (id(wind_bearing).state > 337.5) {
it.printf(350, 42, id(Medium_12pt), color_text, TextAlign::BASELINE_CENTER, "N");
} else if(id(wind_bearing). state > 292.5) {
it.printf(338, 45, id(Medium_12pt), color_text, TextAlign::CENTER_RIGHT, "NW");
} else if(id(wind_bearing). state > 247.5) {
it.printf(330, 62, id(Medium_12pt), color_text, TextAlign::CENTER_RIGHT, "W");
} else if(id(wind_bearing). state > 202.5) {
it.printf(338, 78, id(Medium_12pt), color_text, TextAlign::CENTER_RIGHT, "SW");
} else if(id(wind_bearing). state > 157.5) {
it.printf(350, 90, id(Medium_12pt), color_text, TextAlign::BASELINE_CENTER, "S");
} else if(id(wind_bearing). state > 112.5) {
it.printf(362, 78, id(Medium_12pt), color_text, TextAlign::CENTER_LEFT, "SE");
} else if(id(wind_bearing). state > 67.5) {
it.printf(370, 62, id(Medium_12pt), color_text, TextAlign::CENTER_LEFT, "E");
} else if(id(wind_bearing). state > 22.5) {
it.printf(362, 45, id(Medium_12pt), color_text, TextAlign::CENTER_LEFT, "NE");
} else if(id(wind_bearing). state >= 0) {
// ----------------------------------------------------------------------------------- LINE
it.filled_rectangle(10, 100, 380, 2, color_text);
// ----------------------------------------------------------------------------------- FORECAST
it.printf(57, 110, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%s", id(weather_timestamp_0).state.c_str());
it.printf(57, 128, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "%s", weather_icon_map[id(weather_condition_0).state.c_str()].c_str());
it.printf(57, 166, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.0f°C", id(weather_temperature_0).state);
it.printf(114, 110, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%s", id(weather_timestamp_1).state.c_str());
it.printf(114, 128, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "%s", weather_icon_map[id(weather_condition_1).state.c_str()].c_str());
it.printf(114, 166, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.0f°C", id(weather_temperature_1).state);
it.printf(171, 110, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%s", id(weather_timestamp_2).state.c_str());
it.printf(171, 128, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "%s", weather_icon_map[id(weather_condition_2).state.c_str()].c_str());
it.printf(171, 166, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.0f°C", id(weather_temperature_2).state);
it.printf(228, 110, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%s", id(weather_timestamp_3).state.c_str());
it.printf(228, 128, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "%s", weather_icon_map[id(weather_condition_3).state.c_str()].c_str());
it.printf(228, 166, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.0f°C", id(weather_temperature_3).state);
// ----------------------------------------------------------------------------------- AQHI
if(id(aqhi).has_state ()) {
it.printf(285, 110, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "AQHI");
it.printf(285, 128, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F0D43");
it.printf(285, 166, id(Medium_12pt), color_text, TextAlign::TOP_RIGHT, "%2.1f", id(aqhi).state);
if (id(aqhi).state <= 3) {
// Low Risk # 1-3 Low health risk
it.printf(286, 166, id(Medium_12pt), color_text, TextAlign::TOP_LEFT, "(L)");
} else if (id(aqhi).state <= 6) {
//Moderate Rsik # 4-6 Moderate health risk
it.printf(286, 166, id(Medium_12pt), color_text, TextAlign::TOP_LEFT, "(M)");
} else if (id(aqhi).state <= 10) {
//High Risk # 7-10 High health risk
it.printf(286, 166, id(Medium_12pt), color_text, TextAlign::TOP_LEFT, "(H)");
} else {
//Extreme # 10 + Very high health risk
it.printf(286, 166, id(Medium_12pt), color_text, TextAlign::TOP_LEFT, "(E)");
// ----------------------------------------------------------------------------------- UV INDEX
if(id(uv_index).has_state ()) {
it.printf(343, 110, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "UV Index");
it.printf(343, 128, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F0F37");
it.printf(343, 166, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.0f", id(uv_index).state);
it.filled_rectangle(10, 186, 380, 2, color_text);
// ----------------------------------------------------------------------------------- VISIBILITY
if(id(visibility).has_state ()) {
it.printf(66, 196, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "Visibility");
it.printf(66, 214, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F00A5");
it.printf(66, 252, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.1f km", id(visibility).state);
// ----------------------------------------------------------------------------------- HUMIDITY
if(id(humidity).has_state ()) {
it.printf(133, 196, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "Humidity");
it.printf(133, 214, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F058E");
it.printf(133, 252, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.0f %%", id(humidity).state);
// ----------------------------------------------------------------------------------- PRESSURE
if(id(barometric_pressure).has_state ()) {
// pressure trend
it.printf(200, 196, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "Pressure");
if(id(pressure_trend).state == "Rising") {
it.printf(200, 214, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F0535");
} else if(id(pressure_trend).state == "Falling") {
it.printf(200, 214, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F0533");
it.printf(200, 252, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%2.0f hPa", id(barometric_pressure).state);
if(id(sun_position).state == "above_horizon") {
// ------------------------------------------------------------------------------------ SUNSET
it.printf(267, 196, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "Sunset");
it.printf(267, 214, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F059B");
it.printf(267, 252, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%s", id(sunset_time).state.c_str());
} else {
// ----------------------------------------------------------------------------------- SUNRISE
it.printf(267, 196, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "Sunrise");
it.printf(267, 214, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "\U000F059C");
it.printf(267, 252, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%s", id(sunrise_time).state.c_str());
// ------------------------------------------------------------------------------------- MOON PHASE ICON
if(id(moon_phase).has_state ()) {
if(id(moon_phase).state.c_str() == "new_moon") {
id(moon_phase_text) = "New Moon";
} else if(id(moon_phase).state == "waxing_crescent") {
id(moon_phase_text) = "Waxing Crescent";
} else if(id(moon_phase).state == "first_quarter") {
id(moon_phase_text) = "First Quarter";
} else if(id(moon_phase).state == "waxing_gibbous") {
id(moon_phase_text) = "Waxing Gibbous";
} else if(id(moon_phase).state == "full_moon") {
id(moon_phase_text) = "Full Moon";
} else if(id(moon_phase).state == "waning_gibbous") {
id(moon_phase_text) = "Waning Gibbous";
} else if(id(moon_phase).state == "last_quarter") {
id(moon_phase_text) = "Last Quarter";
} else if(id(moon_phase).state == "waning_crescent") {
id(moon_phase_text) = "Waning Crescent";
} else {
id(moon_phase_text) = "Unknown";
it.printf(334, 196, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "Moon Phase");
it.printf(334, 214, id(mdi_font_36pt), color_text, TextAlign::TOP_CENTER, "%s", moon_icon_map[id(moon_phase).state.c_str()].c_str());
it.printf(334, 252, id(Medium_12pt), color_text, TextAlign::TOP_CENTER, "%s", id(moon_phase_text).c_str());
// ------------------------------------------------------------------------------------- LINE
it.filled_rectangle(10, 272, 380, 2, color_text);
// ----------------------------------------------------------------------------------- WiFi
if(id(wifisignal).has_state ()) {
if (id(wifisignal).state >= -50) {
// Excellent # mdi-wifi-strength-4 "\U000F0928" 255, 230
it.printf(350, 285, id(mdi_font_22pt), color_text, TextAlign::CENTER, "\U000F0928");
} else if (id(wifisignal).state >= -60) {
//Good # mdi-wifi-strength-3 "\U000F0925"
it.printf(350, 285, id(mdi_font_22pt), color_text, TextAlign::CENTER, "\U000F0925");
} else if (id(wifisignal).state >= -67) {
//Fair # mdi-wifi-strength-2 "\U000F0922"
it.printf(350, 285, id(mdi_font_22pt), color_text, TextAlign::CENTER, "\U000F0922");
} else if (id(wifisignal).state >= -70) {
//Weak # mdi-wifi-strength-1 "\U000F091F"
it.printf(350, 285, id(mdi_font_22pt), color_text, TextAlign::CENTER, "\U000F091F");
} else {
//Unlikely working signal # mdi-wifi-strength-alert-outline "\U000F092B"
it.printf(350, 285, id(mdi_font_22pt), color_text, TextAlign::CENTER, "\U000F092B");
// Refresh Timestamp
// Code by EnsconcE from https://community.home-assistant.io/t/esphome-show-time/348903
char str[40];
time_t currTime = id(ds1307_time).now().timestamp;
strftime(str, sizeof(str), "%A %B %d, %Y at %I:%M %p", localtime(&currTime));
it.printf(200, 285, id(Medium_12pt), color_text, TextAlign::CENTER, "%s", str);
I had to delete most of the comments in order to post this reply. See the next message for TEMPLATE and SENSOR entries
EDIT: An error in the sunrise/sunset routine prevented Sunrise time from showing. Code was edited to include update that corrects problem.
Regards
