How I see it you need to put 2, 1 and 6.
The 0.102 = 100% + 2% Surcharge
1 = Absolute surcharge
1.06 = 100% + 6% tax
SOLUTION for SmartEnergy.AT is the screenshot HERE!
Thank you @AkshayR and of course @webwude for the information and the detailed description of the steps.
Iâve had the same issues with SmartEnergy.AT and tried all values from their homepage but without any success.
Yourâs screenshot here was the solution, although I donât understand the shown figures ![]()
Many, many, many thanks @webwude to you for the big effort.
Helped me a lot and is exactly what I was looking for.
But Iâm struggling with some details.
I copied all the code into the respective two (current prices, tomorrowâs prices) cards in the dashboard and also got the corresponding layout - see screenshots, BUT:
The marking âNowâ - the current price is set back in time for me, approx. 30-45 minutes â why? - see screenshot
Prices for tomorrow are displayed in the dashboard (the condition in the card must be deleted) - BUT the prices are not updated for me - see also screenshots
Servus , hast du es inzwischen hin bekommen ?
@webwude
könntes du mir bitte mal wegen Awattar Dasboard weiter helfen ?
danke
Hi there, great integration and great sensor!
I have set-up everything and it works great.
I want to add one more thing that I canât seem to find out how to do this. I saw @mmartin327 also wants to have this info.
Is there a way to check if next day price in the morning has a certain spread to the current evening price?
I managed to do this for the current day by template sensor and current day high and low prices. With this template sensor I decide to charge or not charge my battery.
But I would also like to decide when to discharge the battery in the evening based on the next days price. When the price spread is not large enough, then I donât want to discharge the battery (I also use solar forecast as well as condition). So when it is not sunny and there is a small price difference I donât want to dischargeâŠ
So how can I get next day high and low price into an entity?
a GitHub issue has already been opened here!
there is an uptdate to 3.0.0
Hallo Webwude,
Seit dem Update auf Version 3.0 mĂŒssen die Scripte fĂŒr die Apex Graphen aktualisiert werden.
entry.price_ct_per_kwh Muss mit entry.price_per_kwh ersetzt werden.
Falls die Werte weiterhin in Cent angezeigt werden sollen, muss man diesen Wert nochmals mit 100 multiplizieren.
Viele GrĂŒĂe
Michel
Ja das war leider eine Ănderung, die meine config zerstört hat.
Hier ist meine reparierte Darstellung, die die Awattar Preise fĂŒr heute und morgen anzeigt. Weil ich noch einen Fixpreis habe, ist der als horizontale Linie als Referenz dabei. Vielleicht braucht es ja jemand ![]()
Code:
type: vertical-stack
cards:
- type: custom:apexcharts-card
graph_span: 24h
experimental:
color_threshold: true
header:
title: Strom Einkaufspreis aWATTar (heute)
show: true
show_states: true
span:
start: day
now:
show: true
label: now
color: darkblue
series:
- entity: sensor.epex_spot_data_net_price
type: column
extend_to: end
unit: âŹ/kWh
float_precision: 3
yaxis_id: Price
show:
in_header: before_now
extremas: true
header_color_threshold: true
color_threshold:
- value: 0.02
color: 00ed01
- value: 0.04
color: 3af901
- value: 0.06
color: 87fa00
- value: 0.08
color: cefb02
- value: 0.1
color: eeff00
- value: 0.12
color: ffde1a
- value: 0.14
color: ffa700
- value: 0.16
color: ff8d00
- value: 0.18
color: ff7400
- value: 0.2
color: ff4d00
- value: 0.22
color: ff4d00
- value: 0.24
color: ff0000
- value: 0.26
color: e60000
- value: 0.28
color: cc0000
- value: 0.3
color: b30000
- value: 0.32
color: "990000"
- value: 0.34
color: "800000"
- value: 0.36
color: "660000"
- value: 0.38
color: 4d0000
- value: 0.4
color: "330000"
data_generator: |
return entity.attributes.data.map((entry) => {
return [new Date(entry.start_time), entry.price_per_kwh];
group_by:
func: avg
duration: 1h
yaxis:
- id: Price
decimals: 3
apex_config:
title:
text: âŹ/kWh
tickAmount: 5
min: 0
apex_config:
legend:
show: false
tooltip:
x:
show: true
format: HH:00 - HH:59
annotations:
yaxis:
- "y": 0.089
borderColor: "#00E396"
borderWidth: 2
strokeDashArray: 15
label:
style:
color: "#fff"
background: "#00E396"
fontSize: "16"
text: Fixpreis
graph_span: 24h
experimental:
header:
title: Strom Einkaufspreis aWATTar (morgen)
show: true
show_states: false
span:
start: day
offset: +1day
series:
type: column
extend_to: end
unit: âŹ/kWh
float_precision: 3
yaxis_id: Price
show:
extremas: true
color_threshold:
- value: 0.02
color: 00ed01
- value: 0.04
color: 3af901
- value: 0.06
color: 87fa00
- value: 0.08
color: cefb02
- value: 0.1
color: eeff00
- value: 0.12
color: ffde1a
- value: 0.14
color: ffa700
- value: 0.16
color: ff8d00
- value: 0.18
color: ff7400
- value: 0.2
color: ff4d00
- value: 0.22
color: ff4d00
- value: 0.24
color: ff0000
- value: 0.26
color: e60000
- value: 0.28
color: cc0000
- value: 0.3
color: b30000
- value: 0.32
color: "990000"
- value: 0.34
color: "800000"
- value: 0.36
color: "660000"
- value: 0.38
color: 4d0000
- value: 0.4
color: "330000"
data_generator: |
group_by:
func: avg
duration: 1h
yaxis:
- id: Price
decimals: 3
apex_config:
title:
text: âŹ/kWh
tickAmount: 5
min: 0
apex_config:
legend:
show: false
tooltip:
x:
show: true
annotations:
yaxis:
- "y": 0.089
borderWidth: 2
strokeDashArray: 15
label:
style:
color: "#fff"
fontSize: "16"
text: Fixpreis
I did not get any mails or they were moved to spam, usually I was getting any question as notification, sorry.
I updated my dashboards and will post the updates shortly. I will follow up with the questions as well. Sorry for the delay.
Nein, habe ich leider nicht.
Bin auch durch viele Recherchen nirgendwo auf eine Lösung gekommen?
Hast Du eine Idee?
Good morning everyone,
Last night, for the first time, my dishwasher successfully started its program automatically, thanks to the amazing Super-Sensor ha_epex_spot from mampfes in its latest version 3.0.0. Huge thanks for this great work!
BUT â despite following all the instructions, I still canât get the electricity price chart (EPEX Sensor Configuration) for Smart Energy to display the correct values.
I have entered everything exactly as described on the GitHub page.
Why am I seeing discrepancies in the prices? â See screenshots.
Can anyone help me?
Have a look into your APEX chart config.
What to look for?
I cannot find any errors or wrong formulas - please see:
Summary
graph_span: 24h
experimental:
header:
title: Strom Einkaufspreis SMART-ENERGY (heute)
show: true
show_states: true
span:
start: day
now:
show: true
label: now
color: darkblue
series:
type: column
extend_to: end
unit: ct/kWh
float_precision: 3
yaxis_id: Price
show:
extremas: true
color_threshold:
- value: 2
color: 00ed01
- value: 4
color: 3af901
- value: 6
color: 87fa00
- value: 8
color: cefb02
- value: 10
color: eeff00
- value: 12
color: ffde1a
- value: 14
color: ffa700
- value: 16
color: ff8d00
- value: 18
color: ff7400
- value: 20
color: ff4d00
- value: 22
color: ff4d00
- value: 24
color: ff0000
- value: 26
color: e60000
- value: 28
color: cc0000
- value: 30
color: b30000
- value: 32
color: "990000"
- value: 34
color: "800000"
- value: 36
color: "660000"
- value: 38
color: 4d0000
- value: 40
color: "330000"
data_generator: |
return [new Date(entry.start_time), entry.price_per_kwh*100];
group_by:
func: avg
duration: 1h
yaxis:
- id: Price
decimals: 3
apex_config:
title:
text: ct/kWh
tickAmount: 5
min: 0
apex_config:
legend:
show: false
tooltip:
x:
show: true
Your code looks completely correct. I think you took the wrong config from the screenshot.
For SmartEnergy the EPEX Spot configuration values have to be:
Percent Surcharge (%):
0
Absolute Surcharge (⏠per kWh):
0,012
Tax (%):
20
@webwude
May can you please post the Update? Or did i miss it? Thanks
Thx for the reminder. I will post the updates today.
Ok not today, but soon. Very busy lately.
