I have a question to eq3 Max integration. Like most I have my Max cube integrated into Home Assistant, however update intervals and requests to thermostats are unstable and periodic.
Has anyone considered/implemented the interface from http://www.dmitry-kazakov.de/ada/max_home_automation.htm and redirected (or bridged) the Mqtt server to that of home assistant? Then HA should be able to interface directly via Mqtt to the thermostats using the home automation interface. Further, there are many more options such as valve positions, battery status and thermostat conditions. What also drew my attention is the monitoring of the RF trafic to prevent congestion, which may solve the config issues with the cube?
I suppose the main question is has anyone got any experience with using the the interface with home assistant?
I will install the Max Home Automation Interface in a seperate pc and let the values track for some time to determine if it’s more stable given the same hardware and locations.
I have switched to using the software (running on a PC within the LAN) and then bridging the MQTT brokers. Seems to work great so far and much more stable than the integrated solution but have only been monitoring so far (subscribing to 4 different radiator thermostats). Will be looking at integrating some update/scheduling functions soon though so will see how that goes
I have also had good experience sofar with the integration, seems much more stable with faster polling intervals possible.
I also determined that with the home-assistant built-in integration, the configuration is reset if the official windows application (daemon) is running at the same time in the same network. I now always ensure that I have closed the official application after setting up the temperature profiles for automatic mode on the thermostats.
I want to know try installing max_home_automation on my ubuntu server (same machine as home assistant) and then linking my mosquitto Mqtt server.
Home Assistant MQTT integration unfortunately doesn’t work with MAX Home Automation. Even with mosquito in between.
But the MAX Home Automation HTTP API works fine. Here is freshely publised integration I just made for myself https://github.com/koleo9am/hass_max_home_automation/tree/master . Feel free to try.
looks great
I’d be glad to try it (and I have wall thermostats) when I have time
however I tried to install the max home automation on my raspberry pi but have been facing issues (plus it seems to slow the pi quite much so I’m not sure if it is a long term solution)
What was the problem? Instalation of Max! Home Automation or Home Assistant?
For Installing Max! Home Automation you have to upgrade Raspbian to Buster - as described here: https://sourceforge.net/p/max-home-automation/wiki/Raspberry%20installation/.
When I was installing the HA to raspberry, I had to install the wheel and home assistant python packages outside the virtual environment first. Than I had run HASS also outside the virtual environment. I was able to run it in virtual environment after finishing first setup.
Yes the issue was installing max home automation on a stretch hassbian
Two questions: did upgrading hassbian to buster provoke any issue? Also didn’t you have any slowing issue?
Well, I have started with freshly installed Raspbian Stretch Lite. The upgrade was without any issues. I wrote a guide for it, which is published by Dimitri Kazakov on sourceforge: https://sourceforge.net/p/max-home-automation/wiki/Raspberry%20installation/.
Problem of running max_home_automation on Stretch is, that it needs libgnat-8 which has no packages for Stretch.
I really don’t know if there is some slowing issue.
“top” output - hope this helps a bit:
Tasks: 106 total, 1 running, 105 sleeping, 0 stopped, 0 zombie
%Cpu(s): 4.0 us, 1.2 sy, 0.0 ni, 94.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 927.2 total, 353.1 free, 115.2 used, 458.9 buff/cache
MiB Swap: 100.0 total, 100.0 free, 0.0 used. 742.8 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1240 pi 20 0 131836 38180 22124 S 11.3 4.0 20:43.44 Xvfb
1247 pi 20 0 259040 73596 60260 S 7.9 7.8 13:13.90 max_home_automa
1756 root 20 0 0 0 0 I 0.3 0.0 0:03.64 kworker/u8:1
2516 pi 20 0 10596 3064 2548 R 0.3 0.3 0:00.40 top
1 root 20 0 30960 7332 5872 S 0.0 0.8 0:08.76 systemd
There is running HA, max_home_automation, headless X11 (xvfb) on the RPi. It is model 3B+.
So far I have not encounter any slow responses.
I had some minor problems when installing HA in virtual python environment. It was some perrmisions issues. I solved it by installing and first run of HA without virtual environment. After that I was able to run HA in virtual environment.
not your fault!
I did a backup before, but now I can’t get my Zwave stick to work on the backup… I don’t understand why! -> Issue after restoring a backup
I might start from scratch with a docker container this time…
so I tried again to install max home automation on a spare Pi, followed your instructions and everything seemed fine
the only (big) problem I have is that the X11 forwarding does not work (neither on a Mac or Windows) so I cannot set up the software
The integration is using JSON API for whole cube from max_home_automation. I encounter, that sometimes, usually after restart of RPi, some windows sensors and eco button get to some strange state, that max_home_automation is not able to process. Unfortunatelly the JSON API returns empty device list.
Open&close window and clicking the button usually helps to resolve the issue.
I plan to read list of devices via another max_home_automation API, that does’n suffer this issue and use JSON API for separate devices. Hope I will finish this by end of week.
So your setup is as follows?
Two RPis, one with HA and second with MHA.
MHA with HTTP API enabled and set to be available not on localhost and port 8080, but on IP of your RPi with MHA.
Did you try to call MHA with wget or curl?
Something like: http://192.168.1.123:8080/get-status-json?cube=ABCDEF
It should return JSON with devices. If this doesn’t work, then there is problem with MHA configuration.
Run MHA X11 forwarded. Look in the “trace”. To run HTTP API on port 80 may return in error, if ths port is already used.
