I’ve been getting the INCextensionerrordomain 1307 error for a while now (even though the HA automations do run correctly through shortcuts) so I tried to fix it by editing the automation (it’s the “call service” option which uses automation.trigger + dictionary; in the dictionary I’ve got entity_id with the automation ID). However, now I get an ‘unknown error’ whenever I select the “service” variable.
So now I can’t even return my automation to its working version, because it constantly gives the unknown error whenever trying to select the service (automation.trigger). I’ve updated the HA companion app, restarted the iPhone and updated it to its latest iOS version (26.0.1), but the issue persists. Creating a new automation instead of editing the old one, gives the same unknown error.
For context: I use two shortcuts in the morning: trigger ‘when my wake-up alarm goes off’, then run “automation.routine_wekker_gaat_af” and trigger ‘when my wake-up alarm is turned off’, then run “automation.routine_wekker_uit”
How can I fix these two issues?
