I’ve just deleted cache in browser on desktop, and uninstalled HA app on mobile and now can access on both. So looks like it’s something to do with cached data. Hope it helps anyone else stumbling upon this.
Aaand it’s back. I tried to zap the entire history by uninstalling and reinstalling the MariaDB addon but that didn’t fix the issue. Looks like my database is NOT the issue here.
Yeah, when I upgraded to 2021.11.5 it worked for a few minutes after the reboot but went back to throwing the error. I couldn’t see anything in the logs indicating a problem with the recorder function.
I have problems with mobile App and PC browsers.
On PC browser the errore message is Error during logbook entry retrieval date value is not finite in DateTimeFormat.format()
On mobile App Invalid time value
Occurs on 2021.11.4 and 2021.11.5. UPDATE
I opened the loogbook with Chrome (I don’t use this browser commonly) and the logbook was displayed correctly, but after a while a riceved the message to reload the fronted. After that I got the issue above.
So the problem is not the DB, is something with the Lovelace frontend when rendering the output.
I guess that the issue arises only with specific entries, so when you select randomly entries you get, most of the times, entries with correct time format.
I verified the same behavior.
