Error installing Home Assistant Green
Error log as below:
I delete earlier part due to many character.
2024-05-11 23:52:53.715 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-05-11 23:52:53.752 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-05-11 23:52:53.753 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-05-11 23:52:53.761 INFO (MainThread) [supervisor.host.services] Updating service information
2024-05-11 23:52:53.780 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-05-11 23:52:53.787 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-05-11 23:52:53.788 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-05-11 23:52:54.206 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-05-11 23:52:54.227 WARNING (SyncWorker_7) [supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server
2024-05-11 23:52:54.232 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-05-11 23:52:54.556 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-11 23:52:54.557 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-05-11 23:52:54.557 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
I am trying my hand at home assistant green in a effort to move away from homey pro after the acquisition. I got it started went to onboarding. Filled it out to create new user and it would just sit there. Power cycled it and now it wants a user name and password to log in and the one I put in during the onboarding does not work. Any ideas? This should not be this hard. I am not a programmer but I have set up homey, hubitat, smart things. Any help would be greatly appreciated.
Hi, I have no experience with the green.
Have you conducted a search: Search results for 'green' - Home Assistant Community
BTW: strange topic title you have chosen to get help
If you can’t login using the (administrator) account you created, you will need to perform a factory reset (because there’s no utility available to retrieve an account’s password).
It’s more involved than merely pushing a reset button so be certain you have exhausted all username/password combinations before resorting to a factory reset.
As you seem to have a new installation, I’d suggest just to do a reinstall - fresh. :slight_smile: Why bother?
It shouldn’t be that hard, and normally it isn’t. So must be something different not working here, or, and that’s what I’d guess, it was just a hickup, that happens sometimes. :slight_smile:
Just to be clear, what you’ve done for now was trying to work with the pre-installed image on the GREEN, right? Or did you already try to reset or install the OS on the SD-card?
This happened to me as well…and it is very frustrating!
A post was merged into an existing topic: Error installing Home Assistant on Green
