Use an SSD and it works great.
Use an SSD and it works great!
same here in a rpi 4, micro ssd, after power loss, nothing helps.
This is ridiculous that this problem is so common and have not been fixed for 2 years??? HA on my syonlogy hangs few times a week⌠this is nightmare⌠;////
Hello everyone!
After many hours of trying I finally found the problem.
In my case it is the eWelink addon:
to solve the problem I had to uninstall the addon.
home assistant is installed on raspberry pi 5 4gb, on SD Card 32Gb app A2, UHS-I, class 10, U3, V30
I think the problem of this addon is due to an external or internal call that times out supervisor, generating the error in question.
it would be interesting to use an ssd hard disk instead of an sd card to see if the problem persists.
I hope I was helpful.
How did you uninstall it?
Did you do so from HA Cli while supervisor was frozen?
In my case âbannerâ does not work and for âloginâ I do not know what to enter as my username isnât found. âAdminâ or ârootâ is also not found.
So I do not know how to work with the client ![]()
Hi, i didnât do anything on CLI side.
Before to unistall the addon, when i reboot the Raspberry Pi, i need to wait until the error appear and after a minute i can type the âbannerâ command.
maybe in your case you have to wait for more long time before you can type the banner command successfully.
also the error trying to login is because your HA is very busy to do something that wonât let resources to do anything else, thats why the error log say: âSystem is not ready with state: setupâ
now, to be clear, i want to show you what iâm talking about, look at this pics:
as you can see the addon that was making a mess on my HA is not installed.
So in your case my best suggest is to start with a fresh install of HA and make a backup everytime you add something on it and reboot using this command from CLI: âhost restartâ
If will be displayed the system informations as usually you can proceed to install another addon, make another backup and so on, until you got the error.
As this point you can make a step back reloading the previous working backup.
finally you know what is making a mess with your system.
hope was helpful.
UPDATE !!!
For all the people are using âeWelinkâ addon in combination with this Switch
and they have the same problem i have, is possible to use the âSonoffâ addon, it works like a charm!
Thanks for your reply.
Unfortunately I wasnât even able to get to that interface and couldnât uninstall addons. I found a solution though without using the client as I was able to access backups. ![]()
LMAO, banner worked for me too
How did you figure that out? Worked for me too!
This issue happened for me for the first time for maybe 2 years. Iâm running HA on a Raspberry Pi 3B, wired network connection, no UPS or similar.
Last night I couldnât log in to the web page but I could log in via SSH, although the directory structure was not familiar at all) and my house devices were not behaving.
This morning I got my Pi connected up to a monitor and keyboard and saw the âSystem is not ready with state: setupâ message.
I tried these things:
supervisor restart and supervisor repair both ran successfully but didnât solve the problem.
banner didnât solve it either
But whilst running both I did notice some errors relating to my SD card storage that caused me to wonder if I had had a power outage during the night that the Pi /SD card did not like.
I then decided to try a couple of easy tests to see if they could provide some clues.
- I have a standby SD card with HA installed from Jul-2024 already restored with a backup from that time and decided to try that fully expecting it to work. It didnât! Same error! Now I am confused and this does not seem logical to me.
- Then I swapped my Pi 3B out for another one. Same issue (not surprised at all).
Thankfully, one of the best things I did was to set up regular backups to Google Cloud (using the Add-on) backing up every 4 days at night (Iâll be doubling the backup up frequency once Iâm up and running again). I also tested that the backup/restore process works for me.
Then I decided to start from scratch on the backup SD card, and I have written HA to it from the Raspberry Pi website. Hence, my attempts to fix the issue end here and Iâm going for a full restore insteadâŚ
The restore worked and the issue seems to have gone away. However, donât expected the restore web page - part of the onboarding process for new installs, to tell you when the restore has happened. I was getting curious after an hour and randomly clicked on the link to my HA in Chrome and there it was! It had changed IP, installed everything else, restarted and running!
I still donât know the cause, buit I do hope it doesnât happen again. Now to shutdown, move the Pi back to itâs place and rebootâŚsurely that should work!
âŚit did work thank goodness!
Actually, the issue repeated itself. But only after I tried to install this recent update: âHome Assistant Core 2024.11.2â. During installation, the app and web pages become unavailable and there is no further device control in my home.
After it failed, I restored again from my most recent backup, and all up and running again. Thank goodness I am doing very frequent backups now.
Up to now, I have installed every HA update thatâs been made available for my system + Add-ons and Integrations, with no problem at all, but this particular update seems to cause a major headache for my system.
Iâm going to refrain from installing this update, and wait for the next one to see if that makes a difference.
Same here, just rolled back to 2024.11.1 because 2024.11.2 each time I try to modify something on dashboard or reboot. I have to repair supervisor.
Thanks Mike, really appreciate the full description, exactly whatâs happened to me this evening. I really cannot face a full re-installation and backup retrieval this evening. Back to using a ruler to reach the bedroom light switch until I can face the stress. ![]()
Just adding Iâm getting the same error with 2024.12.3
If I restart the virtual machine it will have this error 90% of the time
for example if Iâm restoring a snapshot then I have to try a dozen of them
Iâve finally concluded that I should just ignore the âError returned from supervisor: System is not ready with state: setupâ - and just wait (my system can take 8-10 mins to start)
that is what I do.
I have a more specific problem: a few months ago I switched HA to wifi connection, then the aforementioned supervisor problem appeared. However, what I noticed is: if the ethernet cable is plugged in, there is a problem with the supervisor, and the only way to solve the problem is to type the âbannerâ command, but if I unplug the ethernet cable, there is no supervisor problem, but it will not connect to the network until I plug the cable in. What do you think, what is a good solution for this?
