I have created a number of input_numbers in my config and I set the values via the UI. Pumping speeds (fan percentage) and Pumping times (seconds).
I have managed to create this in a script where the values set in the UI are used when the script is run. However, I can’t get this to work when creating a blueprint script and I get this error: “message: Failed to perform the action script/nutrient_dosing7. expected int for dictionary value @ data[‘percentage’]”. I believe this is happening at this section of the code:
- action: fan.set_percentage
percentage: !input set_pump_priming_speed
target: !input pump_entity
This also happens for the delay. What I am trying to do is:
- When creating a script from the blueprint, to select the input_number’s for the specific steps (which works) but when running that script, it uses the values set in the UI for the delays and fan percentages
This is what I have written so far:
blueprint:
description: This blueprint allows create a dosing schedule
domain: script
input:
pump_entity:
description: "Select the fan entity to control"
selector:
entity:
domain: fan
#Priming pump according to input_number values
set_pump_priming_speed:
name: Select Pump Priming Speed
default: 0
selector:
entity:
domain: input_number
set_pump_priming_time:
name: Select Pump Priming Time
selector:
entity:
#Dosing Nutrients according to input_number values
set_pump_feed_speed:
name: Select Pump Feed Speed
default: 0
selector:
entity:
set_pump_feed_time:
name: Select Pump Feed Time
selector:
entity:
domain: sensor
variables:
#pump_entity: !input pump_entity
priming_speed: !input set_pump_priming_speed
priming_time: !input set_pump_priming_time
feed_speed: !input set_pump_feed_speed
feed_time: !input set_pump_feed_time
sequence:
#Priming pump
- action: fan.set_direction
direction: forward
percentage: '{{ priming_speed }}'
#!input set_pump_priming_speed
#'{{ states(!input set_pump_priming_speed) | int }}'
#'{{ states(''!input set_pump_priming_speed'') | float }}'
#'{{ _set_pump_priming_speed }}'
- action: fan.turn_on
data: {}
- delay: '{{ priming_time }}'
- action: fan.turn_off
data: {}
#Starting pump to feed
percentage: '{{ feed_speed }}'
- delay: '{{ feed_time }}'
data: {}
#Clearing pump of remaining nutrients
direction: reverse
data: {}
#percentage: "{{ states('input_number.clear_nutrient_speed') | float }}"
#- delay: "{{ states('input_number.clear_nutrient_time') | float }}"
data: {}
Config.yaml:
template:
- sensor:
- name: Nutrient Dosing Time - Canna A
unique_id: nutrient_dosing_canna_a
state: "{{ (states('input_number.nutrient_amount_canna_a') | float) * (states('input_number.water_volume') | float) * (states('input_number.nutrient_feed_rate_canna_a') | float) }}"
unit_of_measurement: s
- name: Nutrient Dosing Amount - Canna A
unique_id: nutrient_dosing_amount_canna_a
state: "{{ (states('input_number.nutrient_amount_canna_a') | float) * (states('input_number.water_volume') | float) }}"
unit_of_measurement: mL
input_number:
# Canna A Pump Settings
nutrient_amount_canna_a:
name: Nutrient Amount - Canna A
unit_of_measurement: mL/l
step: 0.01
min: 0
max: 10000
mode: box
nutrient_feed_rate_canna_a:
name: Nutrient Feed Rate - Canna A
unit_of_measurement: s/mL
step: 0.01
min: 0
max: 10000
mode: box
nutrient_feed_speed_canna_a:
name: Nutrient Feed Speed - Canna A
unit_of_measurement: percentage
min: 0
max: 100
mode: box
nutrient_priming_time_canna_a:
name: Nutrient Priming Time - Canna A
step: 0.01
min: 0
max: 10000
mode: box
nutrient_priming_speed_canna_a:
name: Nutrient Priming Speed - Canna A
min: 0
max: 100
mode: box
# Canna B Pump Settings
# Generic settings for all pumps
water_volume:
unit_of_measurement: l
step: 0.01
min: 0
max: 7
mode: box
clear_nutrient_speed:
name: Clear Nutrients From Pump - Speed
min: 0
max: 100
mode: box
clear_nutrient_time:
name: Clear Nutrients From Pump - Time
min: 0
max: 100
mode: box
UI values:
