Getting this error a lot. I only have a Netatmo Presence (camera) and Netatmo Healthy Home Coach (Air quality monitor). They both work, except for the fact that I cannot use the floodlight on the Presence camera. However my config keeps giving me errors setting up a climate component. Do I need to exclude this somehow?
I tried setting discovery: false on the Netatmo component, and manually adding what I have, but I haven’t had any luck getting that working. Without discovery, I cannot get anything to show.
Thu Mar 21 2019 22:42:55 GMT+0100 (Central European Standard Time)
Error while setting up platform netatmo
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/src/app/homeassistant/components/netatmo/climate.py", line 87, in setup_platform
homes = home_data.get_home_names()
File "/usr/src/app/homeassistant/components/netatmo/climate.py", line 301, in get_home_names
self.setup()
File "/usr/src/app/homeassistant/components/netatmo/climate.py", line 315, in setup
self.home_id = self.homedata.gethomeId(self.home)
File "/usr/local/lib/python3.7/site-packages/smart_home/Thermostat.py", line 84, in gethomeId
home = self.default_home
AttributeError: 'HomeData' object has no attribute 'default_home'
2019-04-15 21:59:18 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
return fut.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 96, in setup_platform
for room_id in room_data.get_room_ids():
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 344, in get_room_ids
if not self.setup():
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 355, in setup
self.homestatus = pyatmo.HomeStatus(self.auth, home=self.home)
File "/usr/local/lib/python3.7/site-packages/smart_home/Thermostat.py", line 130, in __init__
raise NoDevice("No device found, errors in response")
smart_home.NoDevice: No device found, errors in response
I have the netatmo Thermostat, the Welcome camera and the Weather Station. All works fine in previous versions (0.89), but now the thermostat don’t show up and report this error
I try with the discovery: false and the climate: platform: netatmo but still reports the same error.
Same error here. Could anyone be so kind to direct us towards “HomeData” - anyone? I just love meaningless error messages - I actually collects bad error messages. Microsoft SQL Server has been one of the worst I have experienced but MS has improved a lot there lately.
Hi, I have the same problem with a 0.92.1 and 0.92.2 versions, I have a Netatmo Weather and Netatmo Camera but not a Netatmo Termostat. Are you change something in a configuration.yaml?
No, nothing. Seems to be fixed in version 0.92.1. Still with version 0.92.2 no problems. Perhaps you could disconnect and reconnect the Netatmo devices from your power outlets.
2019-05-06 09:36:52 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 126, in _async_setup_platform
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 416, in wait_for
return fut.result()
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py”, line 97, in setup_platform
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py”, line 345, in get_room_ids
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py”, line 356, in setup
File “/usr/local/lib/python3.7/site-packages/smart_home/Thermostat.py”, line 130, in init
raise NoDevice(“No device found, errors in response”)
I move my hassio setup from a pi to a nuc. Problem still exists (hassio last versión):
Thu May 16 2019 00:41:31 GMT+0200 (hora de verano de Europa central)
return fut.result()
