whenever I try to install a .yaml file HA gets unresponsive.
the log is showing this:
INFO Reading configuration /config/esphome/slimmelezer.yaml...
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Deleting /data/slimmelezer/.pioenvs
INFO Deleting /data/slimmelezer/.piolibdeps
INFO Compiling app...
INFO Running: platformio run -d /config/esphome/slimmelezer
Processing slimmelezer (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Library Manager: Installing Update
Library Manager: Already installed, built-in library
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
| |-- <ESP8266WiFi> 1.0
|-- <ESPAsyncWebServer-esphome> 1.3.0
| |-- <Hash> 1.0
| |-- <Crypto> 0.2.0
| |-- <ArduinoJson-esphomelib> 5.13.3
|-- <ESP8266mDNS> 1.2
|-- <Dsmr> 0.3.0
|-- <Crypto> 0.2.0
|-- <DNSServer> 1.1.1
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/api_connection.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/api_server.cpp.o
but the complete webinterface gets unresponsive.
I attached a console to check what happends. And the output is this:
I get this 10 times with increasing seconds:
[ 1841.125552] INFO: task kworker/0:05959 blocked for more than 122 seconds.
[ 1841.125731] Tainted: G C 5.10.17-v7 #1
[ 1841.125844] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this messages.
after 10 times I get an out of memory exception.
[ 5578.596640] Out of memory: Killed process 4338 (python3) total-vm:264092kB, anon-rss:93560kB, file-res:0kB, shmem-rss:0kB, UID:0 pgtables:264kB oom_score_adj:0
[ 5585.445159] systemd-coredump[8083]: Process 112 (systemd-jouirnal) of user 0 dumped core.
Can anyone tell me what I’m doing wrong here?
Thank you.
