ESP Home devices requesting 'Platform' Key
Just updated esphome and now I cant access the devices, error message:
INFO ESPHome 2024.6.1
INFO Reading configuration /config/esphome/cylinder-temp.yaml…
Failed config
ota.unknown: [source /config/esphome/cylinder-temp.yaml:27]
‘ota’ requires a ‘platform’ key but it was not specified.
Any idea how to add the required platform key to resolve my issue please
It’s in the docs (the requirement has changed):
Because of this breaking change mentioned in the release notes:
Though the release notes do not make very clear what is needed. But the error does.
Many thanks for the swift replies, to experienced users the instructions are ‘noddy proof’, but after reading, for me the simplest is to flatten the ESP device and restart.
Here, read this in case it helps. Someone has already gone through the trouble of creating simple instructions and pinned the post so others would find it.
Thanks for your contribution @nickrout
Thanks for the info to the guide, it worked which is great, I was adding the platform detail before the password as per the ESP OTA config, but it didn’t like it, anyhoo it works now.
Thanks for you help, much appreciated.
The order shouldn’t matter.
I had the same problem. Essentially, the “platform” key is missing. The easiest way is just to create a new device and compare the config YAML.
To make this super clear
change
ota:
  password: !secret ota_password
to
ota:
  platform: esphome
Hi.
I have tha same problem.
I have ‘ota’ requires a ‘platform’ key but it was not specified.
Whan I added platform key esphome, Validated is ok, but new problem is:
INFO ESPHome 2024.11.3
INFO Reading configuration /config/esphome/livingroom.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing livingroom (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Library Manager: Installing ESP8266WiFi
Warning! Could not find the package with ‘ESP8266WiFi’ requirements for your system ‘linux_aarch64’
Library Manager: Installing ESP8266mDNS
Warning! Could not find the package with ‘ESP8266mDNS’ requirements for your system ‘linux_aarch64’
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 1.1.0
|-- noise-c @ 0.1.6
Compiling .pioenvs/livingroom/src/esphome/components/api/api_connection.cpp.o
In file included from src/esphome/components/network/ip_address.h:16,
from src/esphome/components/network/util.h:5,
from src/esphome/components/api/api_connection.cpp:6:
/data/cache/platformio/packages/framework-arduinoespressif8266/cores/esp8266/Arduino.h:43:10: fatal error: core_esp8266_version.h: No such file or directory
  • Looking for core_esp8266_version.h dependency? Check our library registry!
  • CLI > platformio lib search “header:core_esp8266_version.h”
  • Web > PlatformIO Registry
43 | #include “core_esp8266_version.h”
compilation terminated.
*** [.pioenvs/livingroom/src/esphome/components/api/api_connection.cpp.o] Error 1
========================= [FAILED] Took 13.80 seconds =========================
No yaml, what the heck do you want anyone to do?
I have just pressed ‘edit’ in esphome compiler, added key and pressed ‘save’.
What I do wrong?
Link ‘install’ was gone. I tried to press install in the … right menu.
No yaml, no issue.
esphome:
  friendly_name: LivingRoom
  on_boot:
    priority: 600
    then:
      - switch.turn_off: D0Buzzer
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "KbJRFiTE1OzisDeB+p6qGyPV7HdA8S4IbOFxlzp1CEo="
ota:
  platform: esphome
  password: "qqqqqqqqqqqqqqqqqqq"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.99.22
    gateway: 192.168.99.1
    subnet: 255.255.255.0
  ap:
    ssid: "Livingroom Fallback Hotspot"
    password: "qqqqqqqqqqqqqq"
mdns:
  disabled: false
captive_portal:
binary_sensor:
  - platform: gpio
    name: "LivingRoom D5 switch sensor"
    pin:
      number: D5
      inverted: false
      mode:
        input: true
        pullup: true
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
    on_press:
      then:
        - switch.toggle: D2output
        - switch.turn_on: D0Buzzer
        - delay: 100 ms
  - platform: status
    name: "LivingRoom D5 switch Status"
  - platform: gpio
    name: "LivingRoom D6 switch sensor"
    pin:
      number: D6
      inverted: false
      mode:
        input: true
        pullup: true
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
    on_press:
      then:
        - switch.toggle: D1output
        - delay: 100 ms
  - platform: status
    name: "LivingRoom D6 switch Status"
      # Blink the Blue LED
switch:
  - platform: output
    name: "LivingRoom D0 Buzzer Output"
    inverted: false
    output: D0Buzzer_output
  - platform: output
    name: "LivingRoom D1 Output"
    inverted: false
    output: light_output1
  - platform: output
    name: "LivingRoom D2 Output"
    inverted: false
    output: light_output2
output:
  - id: light_output1
    platform: gpio
    pin: D1
  - id: light_output2
    platform: gpio
    pin: D2
  - id: D0Buzzer_output
    platform: gpio
    pin: D0
Try changing to
ota:
  - platform: esphome
If that doesn’t work, do a clean then an install. If that doesn’t work. post the log (not a picture) of the install.
Not sure how to fix this error with the recent update. Appreciate any help…
substitutions:
  friendly_name: Pool Fill
packages:
  esphome.esp_web_tools_example: github://esphome/example-configs/esp-web-tools/esp8266.yaml@v1
esphome:
  name_add_mac_suffix: false
  friendly_name: ${friendly_name}
ota:
  - platform: esphome
wifi:
  password: !secret wifi_password```
Error Message
INFO ESPHome 2025.2.0
INFO Reading configuration /config/esphome/esp-web-tools-example-3658f7.yaml...
Failed config
esphome: [source /data/packages/ee679354/esp-web-tools/esp8266.yaml:6]
  Please remove the `platform` key from the [esphome] block and use the correct platform component. This style of configuration has now been removed.
  platform: ESP8266
  board: esp01_1m
  name_add_mac_suffix: False
  project:
    version: 1.0
You have it defined in esp like this
esphome:
  friendly_name: xxxxxxx
esp8266:
  board: d1_mini
This did not fix the issue… not sure I understand what you wanted me to do… same error
substitutions:
packages:
esphome:
esp8266:
  board: d1_mini
ota:
  - platform: esphome
wifi:
I got it fixed by replacing @v1 with @main
These docs are bad.
They need examples of what changes to what, not just “…”.
This is a breaking change, and it should be OVER explained.
The change was 8 months ago. I can’t remember exactly what was in the docs back then. Maybe it is not so strange the docs now consider it as current and not new.
