nickrout
(Nick Rout)
June 20, 2024, 4:39am
1
In esphome 2024.6 the ota configuration has changed, and it you have ota: in your yaml file it won’t compile without fixing.
The old invocation was
ota:
password: secretstuff
You now need to add platform, so it will look like this:
ota:
- password: secretstuff
platform: esphome
this will get you there. There is now also a platform: http_request
as well, hence the need for a change.
This is dealt with in the changelog ESPHome 2024.6.0 - 19th June 2024 — ESPHome , but I just wanted to post to help anyone who didn’t read it.
Brought to you by your team of regulars.
olesj
(Ole Jakobsen)
June 20, 2024, 4:47am
2
Thanks that worked for me .
istapeter
(Istapeter)
June 20, 2024, 5:45am
4
That is not all. I use a dallas sensor and i need to replace that with one_wire.
However this is generating other errors. Still searching what changed.
tom_l
June 20, 2024, 5:48am
5
istapeter
(Istapeter)
June 20, 2024, 5:52am
6
Thanks, did not find it yet.
mcarty
(Arturo)
June 20, 2024, 8:23am
7
I am gonna wait a while until updating, like two or three weeks
Taomyn
June 20, 2024, 8:48am
8
What do I change this to?
ota:
safe_mode: true
password: !secret ota_password
on_begin:
then:
- logger.log: "OTA start"
on_progress:
then:
- logger.log:
format: "OTA progress %0.1f%%"
args: ["x"]
on_end:
then:
- logger.log: "OTA end"
on_error:
then:
- logger.log:
format: "OTA update error %d"
args: ["x"]
If I add “platform” in any position or format I get this at the top of the editor in Home Assistant, e.g.:
ota:
platform: esphome
safe_mode: true
on_begin:
tom_l
June 20, 2024, 8:58am
9
Edit: Deleted to avoid confusion. See below for correct config: Heads up for Esphome 2024.6 - #13 by Troon
tom_l
June 20, 2024, 9:04am
11
How is update_interval:30
used now with 1-wire?
Troon
(Troon)
June 20, 2024, 9:42am
13
safe_mode
is its own component (ref ):
ota:
- platform: esphome
safe_mode:
dallas
becomes one_wire
like this (ref ):
one_wire:
- platform: gpio
pin: D7
and the sensors change to dallas_temp
(ref ) (for temperature sensors like DS18B20) including the update_interval
here rather than under one_wire
- platform: dallas_temp
update_interval: 30s
address: ...
tom_l
June 20, 2024, 9:47am
14
Ah, so that is required in addition to this?
https://esphome.io/components/ota
EDIT: that document is out of date. Do not use it.
What’s with dallas old option “index” ? It’s unknown feature now…?
i’ve had setup below, since i have three dallas sensors, but each on it’s own gpio, so i don’t use dallas addresses.
Also: has “update_interval” moved from “dallas” config to “platform: dallas_temp” ?
- platform: dallas
index: 0
name: "Temperatura sanitarne vode"
dallas_id : dallas_hub_1
accuracy_decimals: 0
filters:
- offset: 1.0
Ahh… wondering what the problem with my update was. Thanks for the post.
tom_l
June 20, 2024, 9:51am
17
Yes. Just changed all of mine:
address: 0x1a3c01e07605b228
name: "Tank Temperature"
update_interval: 3s
filters:
- sliding_window_moving_average:
window_size: 10
send_every: 10
send_first_at: 1
address: 0x58000000167d7228
name: "HP Inlet Temperature"
update_interval: 3s
filters:
window_size: 10
send_every: 10
send_first_at: 1
Troon
(Troon)
18
No, that doc is out of date.
Hm… when entering exactly above lines then line “safe_mode: true” is underlined with red, error is that safe mode has moved from ota to it’s own component…
tom_l
June 20, 2024, 9:54am
21
Yes the docs are incorrect and need updating. See the post directly above yours by Troon.
