I connected the 4 wire to GPIO14 and used this binary sensor, but it didn’t show anything, and there is no information in the logs, there is no message that the sensor saw something
binary_sensor:
- platform: gpio
pin:
number: GPIO14
mode:
input: true
on_press:
then:
- logger.log: "WakeUP signal detected"
Next, I decided to use the APS sensor, which also did not see anything, which is quite expected, since taking readings through an oscilloscope I saw noise and voltage up to 300 mv. After breaking the 4 wire, the coffee machine turns on quietly.
- platform: adc
pin: GPIO39
update_interval: 500ms
accuracy_decimals: 7
attenuation: auto
[17:00:13][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 2 decimals of accuracy
[17:00:15][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 2 decimals of accuracy
[17:00:16][D][sensor:094]: ‘Voltage’: Sending state 0.08400 V with 2 decimals of accuracy
[17:00:17][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 2 decimals of accuracy
[17:00:18][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 2 decimals of accuracy
[17:00:19][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 2 decimals of accuracy
[17:00:20][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 2 decimals of accuracy
[17:00:36][D][sensor:094]: ‘Voltage’: Sending state 0.90200 V with 2 decimals of accuracy
[17:00:37][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 2 decimals of accuracy
[17:04:59][D][sensor:094]: ‘Voltage’: Sending state 0.07500 V with 7 decimals of accuracy
Measuring 4 wires through a logic analyzer
It’s not a fact that the 4 wire is a Wake UP, since the scheme was drawn by an amateur radio enthusiast for a coffee machine of another series, not for the 5400.
As a result, I soldered the wire to the resistor R110 and connected it to an 8-channel zigbee relay for testing. It works well, I can turn it on and off, but the on and off button itself does not work while the wire is in the relay. If I disconnect the wiring from the relay, the button on the control panel works. To make it work, you need to take GND, you can from ESP, you can from a coffee machine, no difference, connect a capacitor from 10 to 47 pf to GND and connect it all to a relay that will short and open GND.
After a successful experiment, I ordered such a relay. The module is based on the AXICOM IM01 3vdc SMD electromechanical relay from TE. The control voltage is 3 Volts. Plug-in load up to 2A, 250V AC. It can be used in various projects, including on Arduino, where it is required to switch the voltage, for example, to include a load of 220 volts.
