The buttons are working correctly. Here is the copied code
[{“encKey”: 152,
“address”: 1368635,
“rcode”: 956,
“command”: “Down”,
“rssi”: -53,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [10053,97282,2545,2581,2537,2549,4872,1255,1307,645,653,1265,671,621,1305,624,669,628,659,633,649,1269,661,628,1316,608,661,629,670,1273,660,624,1291,1289,650,617,1303,641,649,645,654,638,659,620,644,25,1285,666,622,1295,1266,672,621,655,638,1284,645,655,1266,671,620,1306,623,666,1280,1283,645,653,639,660,620,645,634,661,1267,1320,1265,1301,1280,1293,644,652,614,657,646,644,1282,1289,651,660,631,640,1269],
“time”: “2023-08-04T20:38:07.113-0300”
{“encKey”: 150,
“address”: 1368635,
“rcode”: 957,
“command”: “Up”,
“rssi”: -53,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [10052,97272,2545,2591,2517,2578,4846,1277,1312,617,676,1266,1303,1253,666,622,1322,613,660,1272,650,639,1309,619,676,613,659,1272,1302,641,650,1271,659,632,1290,632,659,628,665,623,657,1285,645,626,656,640,1306,1272,660,616,672,621,1307,624,667,1252,658,646,1294,639,658,1271,1304,626,644,650,658,618,651,645,645,1290,1300,1252,1309,1269,1311,620,669,636,660,627,644,1274,1310,617,676,611,658,1272],
“time”: “2023-08-04T20:38:08.768-0300”
{“encKey”: 149,
“address”: 1368635,
“rcode”: 958,
“command”: “My”,
“rssi”: -53,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [10036,97291,2550,2575,2527,2560,4852,1289,1300,630,662,1264,1294,1290,1301,1254,1309,1270,660,630,1299,631,660,630,651,643,652,1262,1322,1259,656,642,1296,641,651,618,676,1264,1300,1258,663,621,1319,1265,673,619,654,614,1309,644,653,1266,672,619,1306,615,670,1272,1290,644,648,636,661,625,670,627,660,1266,1297,1262,1316,1254,1308,644,652,637,657,622,667,1259,1316,628,660,615,679,1244],
“time”: “2023-08-04T20:38:10.260-0300”
{“encKey”: 154,
“address”: 1368635,
“rcode”: 959,
“command”: “Up+Down”,
“rssi”: -57,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [2549,2572,2518,2586,4820,1307,1287,25,648,650,1268,670,631,1258,1347,1250,674,620,1305,609,673,1247,683,633,646,645,633,660,622,661,622,672,1267,641,680,1255,671,621,657,631,1301,622,659,632,648,643,628,1304,1269,649,639,639,672,1270,669,619,1300,631,650,1286,632,658,1285,1296,613,659,642,641,683,607,649,648,1279,1286,1295,1281,1299,1297,623,667,606,680,612,659,1296,1280,647,646,656,631,1276],
“time”: “2023-08-04T20:38:13.727-0300”
{“encKey”: 154,
“address”: 1368635,
“rcode”: 959,
“rssi”: -54,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 14,
“pulses”: [621,32351,2537,2554,2548,2567,2536,2573,2525,2567,2533,2546,2555,2564,2551,2547,4862,1267,1305,613,692,1260,657,619,1319,1268,1295,637,662,1250,670,611,1316,621,670,634,664,620,667,629,657,631,665,1246,660,628,1315,635,660,614,673,1272,661,615,673,620,652,615,1308,1273,658,642,650,618,1326,625,640,1276,660,623,1319,611,659,1271,1326,601,664,625,683,614,664,619,675,1261,1315,1265,1290,1271,1315,619,670,637,663,626,645,1277,1291,643,647,637,665,1277],
“time”: “2023-08-04T20:38:13.859-0300”
{“encKey”: 156,
“address”: 1368635,
“rcode”: 960,
“command”: “Prog”,
“rssi”: -58,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [10044,97290,2550,2555,2542,2578,4846,1280,1307,621,653,1285,640,625,657,635,1304,623,657,635,664,1270,660,631,1291,1281,1307,620,657,639,657,620,671,1262,652,644,1297,1267,1294,1288,650,618,676,613,1310,1269,1311,1273,1302,1252,670,634,635,628,1321,1260,664,618,675,613,659,623,668,629,659,615,1303,1277,1313,1268,659,633,649,619,1301,1291,1293,1267,647,644,1307,624,645,1276,660,621,1316],
“time”: “2023-08-04T20:38:21.505-0300”
{“encKey”: 152,
“address”: 1368635,
“rcode”: 961,
“command”: “Down”,
“rssi”: -54,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [10042,97269,2546,2591,2512,2573,4869,1280,1306,620,655,1266,671,621,1306,625,668,628,658,633,650,1271,658,615,1302,1276,1309,643,652,1266,1298,1285,655,620,1294,1266,1321,1261,1303,1274,1310,1268,1311,1270,1303,1251,669,640,630,654,1295,1260,654,643,648,636,661,616,671,622,654,635,1308,1271,1286,1270,655,640,656,619,1320,1266,1296,1261,679,618,1298,641,648,1269,660,639,1290],
“time”: “2023-08-04T20:38:34.126-0300”
{“encKey”: 150,
“address”: 1368635,
“rcode”: 962,
“command”: “Up”,
“rssi”: -57,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [10044,97281,2554,2574,2526,2565,4857,1289,1302,626,659,1261,1297,1288,651,618,1300,640,649,1269,659,642,1299,1256,1308,1270,1311,644,646,1261,654,645,1295,1266,1316,614,659,1273,674,613,1309,1269,1311,1270,1304,1253,670,635,634,26,654,1295,1261,654,643,646,637,661,615,672,620,654,639,1283,1270,1310,1269,656,634,665,618,1299,1267,1319,1265,648,644,1304,625,645,1275,659,623,1318],
“time”: “2023-08-04T20:38:35.858-0300”
{“encKey”: 149,
“address”: 1368635,
“rcode”: 963,
“command”: “My”,
“rssi”: -55,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [10055,97272,2546,2569,2542,2548,4879,1245,1316,642,646,1285,1290,1281,1306,1271,1286,1268,657,635,1315,1252,1317,1269,659,632,1292,1278,657,619,1294,1284,1293,638,659,625,669,1255,1310,1268,1314,1271,1306,1251,672,634,634,654,1297,1261,655,643,646,634,639,641,649,645,655,637,1285,1271,1312,1270,653,638,641,623,1321,1260,1293,1283,665,619,1300,632,649,1294,632,653,1291],
“time”: “2023-08-04T20:38:37.060-0300”
{“encKey”: 151,
“address”: 1368635,
“rcode”: 964,
“command”: “My+Up”,
“rssi”: -70,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [2551,2547,2544,2561,4859,1262,1316,625,679,1241,1325,1263,658,646,620,662,1284,1271,653,637,1308,1250,685,626,1300,611,685,599,661,1300,633,644,1296,1260,666,621,674,613,663,619,669,607,1333,1245,1298,1293,1298,1277,643,634,657,627,1317,1261,663,619,670,611,659,649,623,650,652,636,1284,1301,1286,1270,653,638,659,621,1320,1254,1317,1242,24,660,671,1273,643,644,1278,661,624,1298],
“time”: “2023-08-04T20:38:39.081-0300”
{“encKey”: 151,
“address”: 1368635,
“rcode”: 964,
“command”: “My+Up”,
“rssi”: -64,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 14,
“pulses”: [669,1261,666,621,1322,32940,2561,2545,2548,2570,2536,2545,2546,2561,2547,2549,2560,2554,2546,2553,4868,1277,1298,615,653,1296,1285,1273,649,637,666,625,1297,1290,650,618,1300,1267,668,629,1288,646,644,632,660,1291,644,628,1311,1275,647,635,634,645,643,632,659,640,1295,1261,1314,1278,1283,1295,635,640,648,644,1279,1282,668,632,634,655,646,622,655,639,658,620,1297,1288,1297,1261,654,643,648,635,1290,1271,1310,1273,650,635,1311,617,650,1289,649,644,1277],
“time”: “2023-08-04T20:38:39.981-0300”
{“encKey”: 153,
“address”: 1368635,
“rcode”: 966,
“command”: “My+Down”,
“rssi”: -69,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 8,
“pulses”: [690591,40528,15432,40706,7535,2652,271,5143,2409,50,2651,2520,2569,2532,2601,2495,2569,4844,1295,1320,616,667,1252,660,660,1277,662,628,1287,1296,1268,643,655,1282,1271,672,614,660,648,1272,667,618,1295,657,637,1279,1278,662,622,1317,1266,651,621,1324,1240,1314,1288,1289,1277,659,624,670,604,1307,1274,671,614,664,622,670,605,682,607,679,618,1323,1254,1320,1237,671,624,679,591,1333,1248,1314,1269,679,609,1308,622,681,1242,675,620,1307],
“time”: “2023-08-04T20:38:43.826-0300”
{“encKey”: 153,
“address”: 1368635,
“rcode”: 967,
“rssi”: -67,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [2560,2548,2547,2563,4860,1266,1322,609,664,1276,667,610,1311,619,672,1260,1307,1278,661,625,1296,1262,677,616,648,638,666,625,1298,1264,677,617,1298,1269,664,629,1311,620,672,1255,1306,1273,1311,1242,1335,1246,675,615,659,622,1319,1269,647,618,676,611,685,597,667,630,660,613,1315,1263,1328,1251,660,624,667,630,1309,1247,1328,1250,669,609,1312,642,646,1264,678,618,1297],
“time”: “2023-08-04T20:38:44.284-0300”
{“encKey”: 153,
“address”: 1368635,
“rcode”: 968,
“rssi”: -69,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [2538,2584,2524,2564,4869,1265,1319,616,681,1244,655,662,1281,626,652,1288,1298,1261,656,643,1295,614,691,604,680,606,667,644,646,634,661,1275,646,637,1308,624,643,637,661,1246,695,610,660,644,1272,1295,1299,1262,1308,1276,658,616,667,607,1333,1245,673,614,662,647,647,630,656,637,653,620,1297,1266,1320,1255,666,607,682,614,1294,1311,1280,1278,661,624,1299,635,666,1244,670,611,1336],
“time”: “2023-08-04T20:38:47.744-0300”
{“encKey”: 153,
“address”: 1368635,
“rcode”: 968,
“rssi”: -63,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 14,
“pulses”: [32942,2534,2571,2522,2570,2533,2573,2529,2568,2554,2548,2521,2582,2521,2566,4888,1246,1324,613,666,1255,685,595,1317,616,683,1245,1328,1249,670,636,1290,644,646,635,660,623,665,634,655,631,649,1271,662,613,1329,627,658,615,663,1277,660,614,667,629,1310,1246,1327,1250,1321,1258,664,630,660,632,1304,1253,662,644,641,631,661,615,665,619,671,636,1286,1270,1306,1266,674,616,664,624,1295,1289,1301,1253,684,621,1296,636,658,1271,653,613,1309],
“time”: “2023-08-04T20:38:47.915-0300”
{“encKey”: 154,
“address”: 1368635,
“rcode”: 969,
“rssi”: -68,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 4,
“pulses”: [2543,2570,2541,2554,4870,1251,1333,620,670,1242,668,629,1303,1269,1287,685,608,1296,629,670,1286,632,656,637,659,622,671,1240,1332,1256,657,644,1271,669,630,645,645,1287,1284,1282,1312,1246,1330,1246,1312,1286,634,656,626,642,1295,1284,658,619,670,611,658,643,101,152,225,274,322,347,548,75,778,100,150,175,501,75,757,1280,1280,1285,1296,632,632,661,620,1321,1263,1313,1263,634,672,1272,664,627,1296,627,655,1286],
“time”: “2023-08-04T20:38:50.892-0300”
{“encKey”: 154,
“address”: 1368635,
“rcode”: 969,
“rssi”: -66,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 14,
“pulses”: [32946,2534,2606,2499,2575,2538,2557,2540,2591,2529,2550,2518,2599,2502,2595,4847,1248,1309,672,622,1311,608,672,1275,1287,1285,633,657,1274,669,611,1309,619,694,616,635,670,621,1311,1284,1275,661,616,1297,642,662,623,666,1263,1316,1250,1309,1272,1304,1272,1296,1265,670,607,681,614,1315,1250,664,641,643,654,655,612,664,619,670,610,1311,1271,1328,1242,673,635,632,646,1296,1267,1320,1259,667,623,1303,624,663,1275,634,662,1274],
“time”: “2023-08-04T20:38:51.044-0300”
{“encKey”: 154,
“address”: 1368635,
“rcode”: 969,
“rssi”: -60,
“bits”: 56,
“proto”: 1,
“valid”: true,
“sync”: 14,
“pulses”: [32964,2541,2567,2541,2565,2543,2558,2535,2544,2544,2569,2532,2568,2540,2563,4857,1268,1297,632,662,1266,669,628,1311,1245,1329,628,646,1273,665,627,1294,636,660,614,672,621,655,1267,1323,1259,655,618,1321,617,677,618,673,1265,1299,1255,1308,1269,1311,1271,1306,1250,671,637,661,602,1322,1262,655,618,671,635,667,612,649,644,653,614,1310,1269,1311,1269,655,639,656,615,1294,1293,1296,1263,652,641,1298,638,641,1275,667,623,1294],
“time”: “2023-08-04T20:38:51.188-0300”
