Hi, I flashed my ESPCam according to this : https://www.youtube.com/watch?v=-towjof_ixU Using ESPHome, the same board and even the same code.
I also tried every code I found at esphome site, but I can’t get it working.
I am able to add it in integration by adding 666.local for 6053 port, but I can’t see the image in integration as others do.
ESPHome log says:
Blockquote
INFO Reading configuration…
INFO Starting log output from 666.local using esphome API
INFO Connecting to 666.local:6053 (192.168.0.107)
INFO Successfully connected to 666.local
[20:21:21][I][application:097]: esphome-core version 1.12.2 compiled on Apr 24 2019, 19:01:57
[20:21:21][C][wifi:371]: WiFi:
[20:21:21][C][wifi:253]: SSID: [redacted]
[20:21:21][C][wifi:254]: IP Address: 192.168.0.107
[20:21:21][C][wifi:256]: BSSID: [redacted]
[20:21:21][C][wifi:257]: Hostname: ‘666’
[20:21:21][C][wifi:261]: Signal strength: -38 dB ▂▄▆█
[20:21:21][C][wifi:262]: Channel: 11
[20:21:21][C][wifi:263]: Subnet: 255.255.255.0
[20:21:21][C][wifi:264]: Gateway: 192.168.0.1
[20:21:21][C][wifi:265]: DNS1: 192.168.0.1
[20:21:21][C][wifi:266]: DNS2: 0.0.0.0
[20:21:21][C][logger:142]: Logger:
[20:21:21][C][logger:143]: Level: DEBUG
[20:21:21][C][logger:144]: Log Baud Rate: 115200
[20:21:21][C][logger:145]: Hardware UART: UART0
[20:21:21][C][esp32_camera:044]: ESP32 Camera:
[20:21:21][C][esp32_camera:045]: Name: bedroom
[20:21:21][C][esp32_camera:046]: Board Has PSRAM: YES
[20:21:21][C][esp32_camera:048]: Data Pins: D0:5 D1:18 D2:19 D3:21 D4:36 D5:39 D6:34 D7:35
[20:21:21][C][esp32_camera:049]: VSYNC Pin: 25
[20:21:21][C][esp32_camera:050]: HREF Pin: 23
[20:21:21][C][esp32_camera:051]: Pixel Clock Pin: 22
[20:21:21][C][esp32_camera:052]: External Clock: Pin:0 Frequency:20000000
[20:21:21][C][esp32_camera:053]: I2C Pins: SDA:26 SCL:27
[20:21:21][C][esp32_camera:054]: Reset Pin: -1
[20:21:21][C][esp32_camera:075]: Resolution: 640x480 (VGA)
[20:21:21][C][esp32_camera:098]: JPEG Quality: 10
[20:21:21][C][esp32_camera:100]: Contrast: 0
[20:21:21][C][esp32_camera:101]: Brightness: 0
[20:21:21][C][esp32_camera:102]: Saturation: 0
[20:21:21][C][esp32_camera:103]: Vertical Flip: ON
[20:21:21][C][esp32_camera:104]: Horizontal Mirror: ON
[20:21:21][C][esp32_camera:121]: Test Pattern: NO
[20:21:21][C][api:101]: API Server:
[20:21:21][C][api:102]: Address: 666.local:6053
[20:21:21][C][ota:127]: Over-The-Air Updates:
[20:21:21][C][ota:128]: Address: 666.local:3232
[20:21:29][D][esp32_camera:159]: Got Image: 0x3ffc7c78 len=16775 width=640 height=480 format=3
Can anyone help?
