Hi everyone,
I’m pretty new to the ESP world and I just received a few lonlin S2 mini, and installed ESP Home add-on on my Raspberry Pi 3b+ running Home Assistant OS.
For the configuration, I just selected ESP32-S2 as device type and left everything as default for now:
esphome:
esp32:
board: esp32-s2-saola-1
framework:
type: esp-idf
Then, I connect the device on my Raspberry, set it in DFU mode, and click install.
Unfortunately it seems not to set up the build toolchain correctly, here is the log:
INFO Reading configuration /config/esphome/kettle.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing kettle (board: esp32-s2-saola-1; framework: espidf; platform: platformio/espressif32 @ 3.5.0)
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
- framework-espidf 3.40302.0 (4.3.2)
- tool-cmake 3.16.9
- tool-ninja 1.10.2
- toolchain-riscv32-esp 8.4.0+2021r2-patch2
- toolchain-xtensa-esp32s2 8.4.0+2021r2-patch2
Reading CMake configuration...
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Found assembler: /data/cache/platformio/packages/toolchain-xtensa-esp32s2/bin/xtensa-esp32s2-elf-gcc
-- Check for working C compiler: /data/cache/platformio/packages/toolchain-xtensa-esp32s2/bin/xtensa-esp32s2-elf-gcc
-- Check for working C compiler: /data/cache/platformio/packages/toolchain-xtensa-esp32s2/bin/xtensa-esp32s2-elf-gcc -- broken
-- Configuring incomplete, errors occurred!
See also "/data/kettle/.pioenvs/kettle/CMakeFiles/CMakeOutput.log".
See also "/data/kettle/.pioenvs/kettle/CMakeFiles/CMakeError.log".
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
CMake Error at /data/cache/platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeTestCCompiler.cmake:60 (message):
The C compiler
"/data/cache/platformio/packages/toolchain-xtensa-esp32s2/bin/xtensa-esp32s2-elf-gcc"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: /data/kettle/.pioenvs/kettle/CMakeFiles/CMakeTmp
Run Build Command(s):/data/cache/platformio/packages/tool-ninja/ninja cmTC_e41a9 && [1/2] Building C object CMakeFiles/cmTC_e41a9.dir/testCCompiler.c.obj
FAILED: CMakeFiles/cmTC_e41a9.dir/testCCompiler.c.obj
/data/cache/platformio/packages/toolchain-xtensa-esp32s2/bin/xtensa-esp32s2-elf-gcc -mlongcalls -o CMakeFiles/cmTC_e41a9.dir/testCCompiler.c.obj -c testCCompiler.c
/bin/sh: 1: /data/cache/platformio/packages/toolchain-xtensa-esp32s2/bin/xtensa-esp32s2-elf-gcc: not found
ninja: build stopped: subcommand failed.
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
/data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:311 (__project)
CMakeLists.txt:3 (project)
========================= [FAILED] Took 19.46 seconds =========================
On my first attempt, I realized the storage on my Raspberry was full, and maybe it could have not installed something correctly. So I removed the ESP Home add-on completely, did some cleanup dans reinstalled it again.
I also tried to use the arduino framework but I encountered some issues because the board is not officially supported.
Here is the full log where it initially gathered the dependancies:
Full installation log
Platform Manager: Installing platformio/espressif32 @ 3.5.0
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: espressif32 @ 3.5.0 has been installed!
The platform 'platformio/espressif32 @ 3.5.0' has been successfully installed!
The rest of the packages will be installed later depending on your build environment.
Tool Manager: Installing platformio/toolchain-esp32s2ulp @ ~1.22851.0
Tool Manager: toolchain-esp32s2ulp @ 1.22851.191205 has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32s2 @ 8.4.0+2021r2-patch2
Tool Manager: toolchain-xtensa-esp32s2 @ 8.4.0+2021r2-patch2 has been installed!
Tool Manager: Installing espressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch2
Tool Manager: toolchain-riscv32-esp @ 8.4.0+2021r2-patch2 has been installed!
Tool Manager: Installing platformio/framework-espidf @ ~3.40302.0
Tool Manager: framework-espidf @ 3.40302.0 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.30100.0
Tool Manager: tool-esptoolpy @ 1.30100.210531 has been installed!
Tool Manager: Installing platformio/tool-cmake @ ~3.16.0
Tool Manager: tool-cmake @ 3.16.9 has been installed!
Tool Manager: Installing platformio/tool-ninja @ ^1.7.0
Tool Manager: tool-ninja @ 1.10.2 has been installed!
Tool Manager: Installing platformio/tool-scons @ ~4.40300.0
Tool Manager: tool-scons @ 4.40300.220706 has been installed!
- tool-cmake 3.16.9
- tool-ninja 1.10.2
Installing ESP-IDF's Python dependencies
Collecting future>=0.15.2
Downloading future-0.18.2.tar.gz (829 kB)
Collecting pyparsing<2.4.0,>=2.0.3
Downloading pyparsing-2.3.1-py2.py3-none-any.whl (61 kB)
Building wheels for collected packages: future
Building wheel for future (setup.py): started
Building wheel for future (setup.py): finished with status 'done'
Created wheel for future: filename=future-0.18.2-py3-none-any.whl size=491058 sha256=6310e2e82ad88f0daa1d62299c32112b36e7e15e9d7210dfb028f5f2141097ee
Stored in directory: /root/.cache/pip/wheels/2f/a0/d3/4030d9f80e6b3be787f19fc911b8e7aa462986a40ab1e4bb94
Successfully built future
Installing collected packages: pyparsing, future
Attempting uninstall: pyparsing
Found existing installation: pyparsing 3.0.9
Uninstalling pyparsing-3.0.9:
Successfully uninstalled pyparsing-3.0.9
Successfully installed future-0.18.2 pyparsing-2.3.1
-- Found Git: /usr/bin/git (found version "2.30.2")
The C compiler
Run Build Command(s):/data/cache/platformio/packages/tool-ninja/ninja cmTC_f17b8 && [1/2] Building C object CMakeFiles/cmTC_f17b8.dir/testCCompiler.c.obj
FAILED: CMakeFiles/cmTC_f17b8.dir/testCCompiler.c.obj
/data/cache/platformio/packages/toolchain-xtensa-esp32s2/bin/xtensa-esp32s2-elf-gcc -mlongcalls -o CMakeFiles/cmTC_f17b8.dir/testCCompiler.c.obj -c testCCompiler.c
======================== [FAILED] Took 2031.09 seconds ========================
Anyone has managed to install correctly a ESP32-S2 board ?
I also found this topic: ESP32-S2 DevkitM-1 V1.0, but it’s not the same problem as he manage to get to the compilation.
