kcr
November 28, 2025, 12:41pm
1
I’ve just got one of these devices:
ESP32-S3 1.8inch AMOLED Touch Display Development Board, 32-bit LX7 Dual-core Processor, 368×448 Pixels, Accelerometer And Gyroscope Sensor, ESP32 With Display | ESP32-S3-Touch-AMOLED-1.8
SH8601 Display Driver and FT3168 Touch
It is not officially supported by ESPHome, but I wondered if anyone has managed to get it working and could share an example? I’ve had a search through the forum and I can see some references to working with the SH8601 and FT3168 separately.
kcr
December 4, 2025, 3:29pm
2
I can’t find a specific example for this device, but I managed to get a basic configuration together by cribbing bits and pieces from data sheets and various ESPHome and non ESPHome configs that other people have built for similar boards.
The display works successfully, but I can’t get the touch screen working. When I tap the screen, I just get the following errors logged:
[15:20:10.094][D][esp-idf:000]: E (29193) i2c.master: I2C hardware NACK detected
[15:20:10.094][D][esp-idf:000]: E (29194) i2c.master: I2C transaction unexpected nack detected
[15:20:10.096][D][esp-idf:000]: E (29195) i2c.master: s_i2c_synchronous_transaction(945): I2C transaction failed
[15:20:10.098][D][esp-idf:000]: E (29197) i2c.master: i2c_master_execute_defined_operations(1401): I2C transaction failed
I’ve experimented with various frequencies, without success.
Config with working display but non-working touch screen:
esphome:
esp32:
variant: esp32s3
framework:
type: esp-idf
flash_size: 16MB
psram:
mode: octal
# Enable logging
logger:
# Enable Home Assistant API
api:
on_client_connected:
- logger.log: "api_connected"
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.51
gateway: 192.168.1.254
subnet: 255.255.255.0
i2c:
scl: GPIO14
sda: GPIO15
frequency: 40kHz
scan: false
pca9554:
- id: 'pca9554_device'
touchscreen:
platform: cst816
display: display_1
i2c_id: i2c_1
interrupt_pin: GPIO21
reset_pin:
pca9554: pca9554_device
number: 0
skip_probe: true
on_touch:
- lambda: |-
ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
spi:
type: quad
clk_pin: GPIO11
data_pins: [GPIO4, GPIO5, GPIO6, GPIO7]
# Display configuration
display:
- platform: mipi_spi
bus_mode: quad
dimensions:
width: 368
height: 448
model: CUSTOM
cs_pin: GPIO12
init_sequence:
- [0x00]
- delay 120ms
- [0x01, 0xD1]
- [0x00]
- [0x20]
- delay 10ms
- [0x00, 0x00, 0x01, 0x6F]
- [0x00, 0x00, 0x01, 0xBF]
- [0x00]
- delay 10ms
- [0x00]
- delay 10ms
- [0xFF]
lvgl:
#buffer_size: 25%
widgets:
- label:
align: CENTER
text: 'Hello World!'
- button:
x: 84
y: 100
width: 200
height: 80
checkable: true
widgets:
- label:
align: center
text: "Tap me"
on_value:
then:
- logger.log:
format: "Button checked state: %d"
args: [ x ]
- slider:
x: 20
y: 50
width: 30
height: 220
pad_all: 8
min_value: 0
max_value: 255
Karosm
(Karosm)
December 4, 2025, 5:11pm
3
schematic gives ext02 for touch reset pin…
kcr
December 4, 2025, 5:23pm
4
You’re correct. The “0” in the config I posted was incorrectly included because I wasn’t sure if I was reading the spec correctly and was experimenting with different values.
I get the same error using pin 2, so I think there is something else wrong with my configuration.
kcr
December 5, 2025, 12:31am
5
Success!
I dug through the Waveshare example repository (GitHub - waveshareteam/ESP32-display-support: Waveshare ESP32 with screen product code summary ) and found the two missing pieces of information to get the touchscreen working:
Backtracking on the preceding discussion, pin 0 is actually the correct value for the pca9554 I/O extender reset_pin, not pin 2 (in retrospect this is obvious from the schematic pin names: LCD_RESET EXIO0 rather than TP_RESET EXIO2)
address: 0x38 is required for the touchscreen: definition
I also removed the frequency: value from my i2c: definition and it seems to be running OK on the default.
There are a lot of other features on this device (like audio I/O) that I have not attempted to configure, but it does appear to be functional for display and touch with ESPHome.
esphome:
esp32:
variant: esp32s3
framework:
type: esp-idf
flash_size: 16MB
psram:
mode: octal
# Enable logging
logger:
api:
ota:
- platform: esphome
wifi:
manual_ip:
i2c:
scl: GPIO14
sda: GPIO15
scan: false
pca9554:
touchscreen:
platform: cst816
display: display_1
address: 0x38
i2c_id: i2c_1
reset_pin:
number: 0
skip_probe: true
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
spi:
type: quad
clk_pin: GPIO11
display:
bus_mode: quad
dimensions:
width: 368
height: 448
model: CUSTOM
cs_pin: GPIO12
init_sequence:
- [0x00]
- delay 120ms
- [0x01, 0xD1]
- [0x00]
- [0x20]
- delay 10ms
- [0x00]
- delay 10ms
- [0x00]
- delay 10ms
- [0xFF]
lvgl:
#buffer_size: 25%
widgets:
- label:
align: CENTER
- button:
x: 84
y: 100
width: 200
height: 80
checkable: true
widgets:
- label:
align: center
text: "Tap me"
on_value:
then:
- logger.log:
args: [ x ]
- slider:
x: 20
y: 50
width: 30
height: 220
pad_all: 8
min_value: 0
max_value: 255
kcr
December 5, 2025, 10:32am
6
A small change that fixes some issues and simplifies the config:
I couldn’t get brightness working with the CUSTOM display model: configuration I had cobbled together from some code examples, but discovered that I could drop the custom init_sequence and just use the model: WAVESHARE-ESP32-S3-TOUCH-AMOLED-1.75 option, which seems to work fine (the pin errors in my initial config efforts obscured the fact that this option was valid).
[Edit: I have an unresolved issue with the touchscreen only working immediately after flashing; if I subsequently power cycle the device the touch screen no longer responds ]
Updated config:
esphome:
esp32:
variant: esp32s3
framework:
type: esp-idf
flash_size: 16MB
psram:
mode: octal
# Enable logging
logger:
api:
ota:
- platform: esphome
wifi:
manual_ip:
i2c:
scl: GPIO14
sda: GPIO15
scan: false
frequency: 100kHz
pca9554:
touchscreen:
platform: cst816
display: display_1
address: 0x38
i2c_id: i2c_1
reset_pin:
number: 0
skip_probe: true
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
spi:
type: quad
clk_pin: GPIO11
display:
brightness: 150
bus_mode: quad
dimensions:
width: 368
height: 448
cs_pin: GPIO12
# init_sequence:
# - [0x00]
# - delay 120ms
# - [0x01, 0xD1]
# - [0x00]
# - [0x20]
# - delay 10ms
# - [0x00, 0x00, 0x01, 0x6F]
# - [0x00, 0x00, 0x01, 0xBF]
# - [0x00]
# - delay 10ms
# - [0x00]1
# - delay 10ms
# - [0xFF]
lvgl:
#buffer_size: 25%
pages:
- id: main_page
bg_color: black
widgets:
- label:
align: CENTER
text_color: white
- button:
bg_color: LightGreen
x: 84
y: 100
width: 200
height: 80
checkable: true
checked:
bg_color: Grey
widgets:
- label:
align: center
text: "Tap me"
on_value:
then:
- logger.log:
args: [ x ]
- slider:
x: 20
y: 50
width: 30
height: 220
pad_all: 8
min_value: 0
max_value: 255
argsnd
(argsnd)
December 7, 2025, 5:03pm
7
You can get the touch screen working reliably like this:
touchscreen:
- platform: ft5x06
display: my_display
address: 0x38
kcr
December 7, 2025, 6:33pm
8
Thanks very much. That was a well timed reply because I was just about to post another message after failing to find a solution to the reboot problem.
I switched to platform: ft5x06 and can confirm that the touchscreen is working correctly when flashed, and also continuing to work when the device is rebooted.
My revised configuration is below. With the fx5x06 plaform, the reset_pin and skip_probe options are no longer valid, and the pca9554 definition is therefore no longer required.
Thanks again!
Revised config:
esphome:
esp32:
variant: esp32s3
framework:
type: esp-idf
flash_size: 16MB
psram:
mode: octal
# Enable logging
logger:
api:
ota:
- platform: esphome
wifi:
manual_ip:
i2c:
scl: GPIO14
sda: GPIO15
scan: true
frequency: 100kHz
touchscreen:
platform: ft5x06
display: display_1
address: 0x38
i2c_id: i2c_1
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
spi:
type: quad
clk_pin: GPIO11
display:
brightness: 150
bus_mode: quad
dimensions:
width: 368
height: 448
cs_pin: GPIO12
lvgl:
#buffer_size: 25%
pages:
- id: main_page
on_swipe_right:
- lvgl.page.previous:
on_swipe_left:
- lvgl.page.next:
bg_color: black
widgets:
- label:
align: CENTER
text_color: white
- button:
x: 84
y: 100
width: 200
height: 80
checkable: true
checked:
bg_color: Grey
widgets:
- label:
align: center
text: "Tap me"
on_value:
then:
- logger.log:
args: [ x ]
- slider:
x: 20
y: 50
width: 30
height: 220
pad_all: 8
min_value: 0
max_value: 255
- id: page_2
on_swipe_right:
on_swipe_left:
- lvgl.page.next:
bg_color: black
widgets:
- label:
align: CENTER
text: 'Hello World 2!'
text_color: white
argsnd
(argsnd)
December 7, 2025, 7:54pm
9
Audio works fine too, here’s a tap to talk voice assistant with a volume slider:
esphome:
friendly_name: esp-assistant
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
psram:
mode: octal
logger:
api:
ota:
wifi:
captive_portal:
# I2C Bus - Shared by touchscreen (FT5x06) and audio codec (ES8311)
i2c:
sda: GPIO15
scl: GPIO14
frequency: 200kHz
scan: true
# Quad SPI Bus - AMOLED display
spi:
- id: quad_spi
type: quad
clk_pin: GPIO11
data_pins:
- GPIO4 # D0
- GPIO5 # D1
- GPIO6 # D2
- GPIO7 # D3
# AMOLED Display (368x448)
display:
brightness: 150
bus_mode: quad
dimensions:
width: 368
height: 448
cs_pin: GPIO12
# FT5x06 Capacitive Touchscreen
touchscreen:
- platform: ft5x06
display: my_display
address: 0x38
transform:
swap_xy: false
mirror_x: false
mirror_y: false
# AUDIO CONFIGURATION
# I2S Audio Bus - Connects ESP32 to ES8311 codec
i2s_audio:
- id: i2s_audio_bus
i2s_lrclk_pin: GPIO45 # Word select / left-right clock
i2s_bclk_pin: GPIO9 # Bit clock
i2s_mclk_pin: GPIO16 # Master clock
# ES8311 Audio Codec
audio_dac:
- platform: es8311
address: 0x18
i2c_id: i2c_bus
use_mclk: true
use_microphone: false # Analog microphone (not PDM digital)
bits_per_sample: 16bit
sample_rate: 16000
mic_gain: 18DB
# Speaker - Audio output through ES8311 DAC
speaker:
- platform: i2s_audio
dac_type: external
audio_dac: es8311_codec
i2s_audio_id: i2s_audio_bus
i2s_dout_pin: GPIO8
sample_rate: 16000
timeout: 2s
# Microphone - Audio input through ES8311 ADC
microphone:
adc_type: external
i2s_din_pin: GPIO10
sample_rate: 16000
# Power Amplifier - GPIO46 controls speaker amplifier enable
switch:
- platform: gpio
pin: GPIO46
name: "Speaker Amplifier"
restore_mode: ALWAYS_ON
internal: false
# Volume Control - Synced with ES8311 hardware volume and UI slider
number:
min_value: 0
max_value: 100
initial_value: 70
step: 5
optimistic: true
set_action:
- lambda: |-
id(es8311_codec).set_volume(x / 100.0);
ESP_LOGI("volume", "Volume set to: %.0f%%", x);
# RTTTL Ringtone Player - Plays simple tones and melodies
rtttl:
speaker: external_speaker
# VOICE ASSISTANT
voice_assistant:
microphone: external_microphone
# Listening state - Button turns blue
on_listening:
- logger.log: "Voice assistant started listening"
- lvgl.label.update:
text: "Listening..."
- lvgl.widget.update:
bg_color: DodgerBlue
# Speech-to-text complete - Display recognized text
on_stt_end:
- logger.log:
format: "Speech recognized: %s"
args: [ 'x.c_str()' ]
text: !lambda 'return "You said: " + x;'
# Text-to-speech starting - Display speaking status
on_tts_start:
- logger.log: "Speaking response..."
text: "Speaking..."
# Session complete - Button returns to green
on_end:
- logger.log: "Voice assistant session ended"
text: "Ready"
# Error handling - Flash red, then return to green
on_error:
- logger.log:
format: "Voice assistant error: %s"
args: [ 'code.c_str()' ]
text: "Error!"
bg_color: Red
- delay: 1s
text: "Ready"
# USER INTERFACE (LVGL)
lvgl:
pages:
- id: main_page
bg_color: black
widgets:
# Status label - Shows current voice assistant state
- label:
align: CENTER
y: 50
text: 'Ready'
text_color: white
# Main voice assistant button - Tap to activate
- button:
x: 84
y: 100
width: 200
height: 160
widgets:
- label:
align: center
text: "Tap to Talk"
on_click:
then:
- if:
condition:
not: voice_assistant.is_running
then:
- rtttl.play: 'beep:d=16,o=5,b=100:c6'
- delay: 200ms
- voice_assistant.start:
else:
- logger.log: "Ignored tap: Voice Assistant already running"
# Volume slider - Vertical slider on left side
- slider:
x: 20
y: 50
width: 30
height: 308
pad_all: 8
min_value: 0
max_value: 100
value: 70
on_value:
then:
- logger.log:
format: "Volume slider: %d"
args: [ x ]
- number.set:
value: !lambda 'return x;'
# Volume label
- label:
x: 60
y: 180
text_color: white
text: "Vol"
asyd
(Bruno)
December 26, 2025, 9:39am
10
Thanks to everyone for you work! I just received this device
cobaltfish
(Cobaltfish)
December 30, 2025, 11:52pm
11
Thanks for the previous posts - I started with the example @argsnd gave at the beginning of the month last night. Then today, while thinking about wake words rather than continuous listening, I stumbled across the examples in realdeco xiaozhi-esphome gh repo for the waveshare esp32-s3 1.85C lcd . I replaced the values for gpio pins and display settings and such like for the values in the examples here, and fairly quickly had my first protype up and running.
I’ll do a bit more checking on how it works / behaves, and will also compare with the 206 watch config, as I have seen a comment on using that.
I got mine working with ESP-NOW, LVGL, Touch on ESPHome.
Repo for yaml (along with a few other devices).
The project is for an offline GPS receiver that runs on an ESP32C6 and sends data over to two displays running ESPHome using ESP-NOW
ESP32 based GPS location source for NINA astro
All three ESP32 things (on the left is the ESP32-C6-LCD-1.47
Waveshare ESP32-S3-Touch-AMOLED-1.8 :
Sender GPS ESP32C6 also running the dashboard:
mavanmanen
(mavanmanen)
January 10, 2026, 2:43pm
13
Having problems with this one, any ideas?
[15:43:29][D][rtttl:062]: Playing song beep
[15:43:29][D][i2s_audio.speaker:102]: Starting
[15:43:29][D][i2s_audio.speaker:106]: Started
[15:43:29][D][ring_buffer:034][speaker_task]: Created ring buffer with size 16000
[15:43:29][D][voice_assistant:478]: State changed from IDLE to START_MICROPHONE
[15:43:29][D][voice_assistant:485]: Desired state set to START_PIPELINE
[15:43:29][D][voice_assistant:207]: Starting Microphone
[15:43:29][D][ring_buffer:034]: Created ring buffer with size 16384
[15:43:29][D][voice_assistant:478]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[15:43:29][E][i2s_audio.microphone:516]: Driver failed to start; retrying in 1 second
[15:43:29][E][component:362]: i2s_audio.microphone set Error flag: unspecified
[15:43:29][D][i2s_audio.speaker:111]: Stopping
[15:43:29][D][i2s_audio.speaker:116]: Stopped
[15:43:29][D][rtttl:405]: Playback finished
[15:43:30][E][component:379]: i2s_audio.microphone cleared Error flag
[15:43:30][D][voice_assistant:478]: State changed from STARTING_MICROPHONE to START_PIPELINE
[15:43:30][D][voice_assistant:228]: Requesting start
[15:43:30][D][voice_assistant:478]: State changed from START_PIPELINE to STARTING_PIPELINE
[15:43:30][D][voice_assistant:500]: Client started, streaming microphone
[15:43:30][D][voice_assistant:478]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[15:43:30][D][voice_assistant:485]: Desired state set to STREAMING_MICROPHONE
m-gnaedig
(Manfred)
January 15, 2026, 10:12pm
14
Hi together
I have received my ESP32-S3-Touch-AMOLED-1.8 today.
Thanks or ll the detailed information in this forum about it.
Should i be possible to use this device with the “ESP32-S3-BOX voice assistant” configuration? Has already anybody thy this?
PBDUB
January 19, 2026, 4:15pm
15
Mine was delivered 2 days ago, thanks to the work others have done setting up the config file. I would like to use this little 1.8 as a remote to control entities in HA for my motorhome. I’m just starting to learn how to set this up. I would like to create several pages with buttons for control, with the status being displayed. Any help would be appreciated.
PBDUB
January 20, 2026, 2:24am
16
Has anyone set it up to show the battery percentage on the display? I’ve already run the battery down several times testing out code.
wizmo
(Wizmo Home)
May 15, 2026, 2:30am
17
Here's a (more-or-less complete) Home-Assistant 'WAKE_WORD_VOICE_ASSISTANT' script for this device.
It is based on the esphome HA example, and includes micro-wake-word and timer support.
# Home-Assistant Voice Assistant #
# for Waveshare ESP32-S3-Touch-AMOLED-1.8 or clone #
# Version: 2026.05.16 #
substitutions:
friendly_name: esp32-s3-touch
# These unique characters have been extracted from every test file of every language available
# on https://github.com/home-assistant/intents (14 March 2024)
# However, the Figtree font only contains Latin characters, so there is no point using this...
# unlessyou change the font configuration accordingly.
allowed_characters: " !#%'()+,-./0123456789:;<>?@ABCDEFGHIJKLMNOPQRSTUVWYZ[]_abcdefghijklmnopqrstuvwxyz{|}°²³µ¿ÁÂÄÅÉÖÚßàáâãäåæçèéêëìíîðñòóôõöøùúûüýþāăąćčďĐđēėęěğĮįıļľŁłńňőřśšťũūůűųźŻżŽžơưșțΆΈΌΐΑΒΓΔΕΖΗΘΚΜΝΠΡΣΤΥΦάέήίαβγδεζηθικλμνξοπρςστυφχψωϊόύώАБВГДЕЖЗИКЛМНОПРСТУХЦЧШЪЭЮЯабвгдежзийклмнопрстуфхцчшщъыьэюяёђєіїјљњћאבגדהוזחטיכלםמןנסעפץצקרשת،ءآأإئابةتجحخدذرزسشصضطظعغفقكلمنهوىيٹپچڈکگںھہیےংকচতধনফবযরলশষস়ািু্చయలిెొ్ംഅആഇഈഉഎഓകഗങചജഞടഡണതദധനപഫബഭമയരറലളവശസഹാിീുൂെേൈ്ൺൻർൽൾაბგდევზთილმნოპრსტუფქყშჩცძჭხạảấầẩậắặẹẽếềểệỉịọỏốồổỗộớờởợụủứừửữựỳ—、一上不个中为主乾了些亮人任低佔何作供依侧係個側偵充光入全关冇冷几切到制前動區卧厅厨及口另右吊后吗启吸呀咗哪唔問啟嗎嘅嘛器圍在场執場外多大始安定客室家密寵对將小少左已帘常幫幾库度庫廊廚廳开式後恆感態成我戲戶户房所扇手打执把拔换掉控插摄整斯新明是景暗更最會有未本模機檯櫃欄次正氏水沒没洗活派温測源溫漏潮激濕灯為無煙照熱燈燥物狀玄现現瓦用發的盞目着睡私空窗立笛管節簾籬紅線红罐置聚聲脚腦腳臥色节著行衣解設調請謝警设调走路車车运連遊運過道邊部都量鎖锁門閂閉開關门闭除隱離電震霧面音頂題顏颜風风食餅餵가간감갔강개거게겨결경고공과관그금급기길깥꺼껐꼽나난내네놀누는능니다닫담대더데도동됐되된됨둡드든등디때떤뜨라래러렇렌려로료른를리림링마많명몇모무문물뭐바밝방배변보부불블빨뽑사산상색서설성세센션소쇼수스습시신실싱아안않알았애야어얼업없었에여연열옆오온완외왼요운움워원위으은을음의이인일임입있작잠장재전절정제져조족종주줄중줘지직진짐쪽차창천최추출충치침커컴켜켰쿠크키탁탄태탬터텔통트튼티파팬퍼폰표퓨플핑한함해했행혀현화활후휴힘,?"
# Add support for non-unicode characters by using better glyphset
font_glyphsets: "GF_Latin_Core"
font_family: Figtree
font_size: 30
# Voice Assistant settings.
# These are direct links to te v1 models. The v2 models dont fit in the tensor space.
# The alex model was much easier to trigger than the okay_nabu.
micro_wake_word_model: github://esphome/micro-wake-word-models/models/alexa.json@main
#micro_wke_word_model: github://esphome/micro-wake-word-models/models/okay_nabu.json@main
esphome:
friendly_name: ${friendly_name}
min_version: 2025.2.0
name_add_mac_suffix: true
on_boot:
priority: 600
then:
- delay: 0.4s
- if:
condition:
lambda: 'return id(auto_off).state > 0;'
then:
- light.turn_on: led
# - if:
# condition:
# lambda: 'return id(auto_sleep).state > 0;'
# then:
# - lambda: |-
# id(sleep_0).set_run_duration(id(auto_sleep).state * 60000);
# - deep_sleep.allow: sleep_0
#- component.update: batpercent
# - delay: 30s
# - if:
# condition:
# lambda: return id(init_in_progress);
# then:
# - lambda: id(init_in_progress) = false;
# - script.execute: draw_display
- pcf85063.read_time
esp32:
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_COMPILER_OPTIMIZATION: "Performance"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
# CONFIG_FATFS_LFN_STACK: "y"
# advanced:
# enable_idf_experimental_features: true
psram:
mode: octal
speed: 80MHz
logger:
hardware_uart: USB_SERIAL_JTAG
level: DEBUG
api:
- lvgl.image.update:
src: casita_initializing
on_client_disconnected:
src: error_no_ha
ota:
- platform: esphome
password: !secret basic_pwd
# on_begin:
# then:
# - deep_sleep.prevent: sleep_0
# - logger.log: "OTA started!"
# - lambda: |-
# id(ota_active) = true;
# - lambda: |-
# id(main_display).update();
wifi:
#ssid: !secret wifi_ssid
#password: !secret wifi_password
ap:
ssid: $friendly_name Hotspot
on_connect:
src: error_no_ha
on_disconnect:
src: error_no_wifi
captive_portal:
i2c:
sda: GPIO15
scl: GPIO14
frequency: 200kHz
scan: true
spi:
- id: quad_spi
type: quad
clk_pin: GPIO11
data_pins:
- GPIO4 # D0
- GPIO5 # D1
- GPIO6 # D2
- GPIO7 # D3
pca9554:
- id: ext_io
i2c_id: i2c_bus
time:
- platform: pcf85063
i2c_id: i2c_bus
# repeated synchronization is not necessary unless the external RTC
# is much more accurate than the internal clock
update_interval: never
- platform: homeassistant
# instead try to synchronize via network repeatedly ...
on_time_sync:
then:
# ... and update the RTC when the synchronization was successful
pcf85063.write_time:
display:
brightness: 150
bus_mode: quad
dimensions:
width: 368
height: 448
cs_pin: GPIO12
# no reset_pin support so sometimes needs reboot!
touchscreen:
- platform: ft5x06
display: my_display
address: 0x38
transform:
swap_xy: false
mirror_x: false
mirror_y: false
i2s_audio:
- id: i2s_audio_bus
audio_dac:
- platform: es8311
address: 0x18
i2c_id: i2c_bus
use_mclk: true
sample_rate: 16000
mic_gain: 18DB
speaker:
dac_type: external
i2s_dout_pin: GPIO8
sample_rate: 16000
timeout: 2s
microphone:
adc_type: external
i2s_din_pin: GPIO10
sample_rate: 16000
button:
- platform: factory_reset
internal: true
switch:
# Power Amplifier - mute_pin not supported by dac driver
# currently uses the media player on_mute/unmute
- platform: gpio
pin: GPIO46
internal: true
# Touchscreen - reset_pin not supported by touch driver
# touch screen sometimes does not initialize. This does not help!
- platform: gpio
pin:
pca9554: ext_io
number: 2
internal: false
icon: "mdi:microphone-off"
optimistic: true
restore_mode: RESTORE_DEFAULT_OFF
entity_category: config
on_turn_off:
- script.execute: start_voice_assistant
on_turn_on:
- script.execute: stop_voice_assistant
icon: "mdi:alarm-note"
optimistic: true
internal: false
restore_mode: ALWAYS_OFF
on_turn_off:
# Turn off the repeat mode and disable the pause between playlist items
- lambda: |-
id(speaker_media_player)
->make_call()
.set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_OFF)
.set_announcement(true)
.perform();
id(speaker_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 0);
# Stop playing the alarm
- media_player.stop:
announcement: true
- delay: 500ms
on_turn_on:
- delay: 200ms
# Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
- lambda: |-
->make_call()
.set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
.perform();
id(speaker_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
- media_player.speaker.play_on_device_media_file:
media_file: timer_finished_sound
announcement: true
src: casita_timer_finished
- text_sensor.template.publish:
state: "Timer complete!"
- delay: 15min
- switch.turn_off: timer_ringing
text_sensor:
- id: text_request
platform: template
on_value:
text: !lambda "return x.c_str();"
- id: text_response
platform: template
on_value:
select:
name: Wake word engine location
icon: "mdi:account-voice"
optimistic: true
restore_value: true
options:
- In Home Assistant
- On device
initial_option: On device
on_value:
#- wait_until:
# lambda: return id(voice_assistant_phase) == ${voice_assist_muted_phase_id} || id(voice_assistant_phase) == ${voice_assist_idle_phase_id};
- delay: 200ms
number:
min_value: 0
max_value: 100
initial_value: 70
step: 5
optimistic: true
disabled_by_default: true
set_action:
- lambda: |-
optimistic: true
restore_value: true
min_value: -1
max_value: 300
step: 1
unit_of_measurement: s
icon: 'mdi:television-off'
initial_value: 0
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: true
on_multi_click:
# Click
- timing:
- ON for at most 500ms
- OFF for at least 200ms
then:
- script.execute: press_to_talk
# Double-click
- timing:
- OFF for at most 400ms
then:
- switch.toggle: mute
# Press-and-hold
# - timing:
# - ON for at least 2s
# - OFF for at least 400ms
# then:
# - deep_sleep.enter: sleep_0
# Press-and-hold-long
- timing:
- ON for at least 10s
then:
- button.press: factory_reset_btn
output:
type: float
write_action:
- lambda: |-
id(my_display).set_brightness(state*255);
light:
- platform: monochromatic
icon: "mdi:television"
output: backlight_output
restore_mode: RESTORE_DEFAULT_ON
default_transition_length: 250ms
on_turn_on:
then:
- if:
condition:
then:
- delay: !lambda 'return id(auto_off).state*1000;'
- light.turn_off:
transition_length: 10s
media_player:
- platform: speaker
volume_min: 0.5
volume_max: 0.9
announcement_pipeline:
speaker: i2s_speaker
format: FLAC
sample_rate: 48000
files:
- id: timer_finished_sound
file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/timer_finished.flac
on_mute:
- switch.turn_off: pa_enable
on_unmute:
- switch.turn_on: pa_enable
#on_announcement:
# - if:
# condition:
# not:
# voice_assistant.is_running:
# then:
# - script.execute: set_idle_status
on_idle:
#- deep_sleep.allow: sleep_0
#on_play:
# VOICE ASSISTANT
micro_wake_word:
models:
- ${micro_wake_word_model}
on_wake_word_detected:
- logger.log: "MWW detected"
wake_word: !lambda return wake_word;
voice_assistant:
microphone: i2s_microphone
media_player: speaker_media_player
use_wake_word: true
noise_suppression_level: 2 #4
auto_gain: 31dBFS
volume_multiplier: 8.0
on_listening:
#- deep_sleep.prevent: sleep_0
- logger.log: "ASSIST listening"
src: casita_listening
state: "..."
on_stt_vad_end:
- logger.log: "ASSIST stt_vad_end"
src: casita_thinking
on_stt_end:
- logger.log: "ASSIST stt_end"
state: !lambda return x;
on_tts_start:
- logger.log: "ASSIST tts_start"
src: casita_replying
on_end:
- logger.log: "ASSIST end"
- wait_until:
and:
- not:
media_player.is_announcing:
- not:
- if:
condition:
and:
- switch.is_off: mute
- lambda: return id(wake_word_engine_location).state == "On device";
#- lambda: return id(voice_assistant_phase) != ${voice_assist_timer_finished_phase_id};
then:
- micro_wake_word.start:
on_error:
- if:
condition:
lambda: return !id(init_in_progress);
then:
src: casita_error
- delay: 1s
src: error_no_ha
on_timer_started:
- wait_until:
- voice_assistant.stop:
- script.execute: set_timer_status
on_timer_cancelled:
on_timer_updated:
on_timer_tick:
- if:
condition:
not:
- voice_assistant.is_running
then:
on_timer_finished:
- switch.turn_on: timer_ringing
globals:
- id: ota_active
type: bool
initial_value: 'false'
- id: mic_muted
type: bool
restore_value: no
- id: init_in_progress
type: bool
restore_value: false
initial_value: "true"
- id: global_first_active_timer
type: voice_assistant::Timer
- id: global_is_timer_active
type: bool
- id: global_first_timer
type: bool
script:
- id: update_timers
then:
- lambda: |
const auto timers = id(va).get_timers();
auto output_timer = timers.begin()->second;
bool output = false;
auto active_timer = timers.begin()->second;
bool active = false;
for (auto &timer : timers) {
if (timer.second.seconds_left <= output_timer.seconds_left) {
output_timer = timer.second;
output = true;
if (timer.second.is_active && timer.second.seconds_left <= active_timer.seconds_left) {
active_timer = timer.second;
active = true;
id(global_first_active_timer) = active_timer;
id(global_is_timer_active) = active;
id(global_first_timer) = output_timer;
id(global_is_timer) = output;
- id: set_timer_status
then:
- script.execute: update_timers
- logger.log: "TIMER update"
- lambda: |
auto seconds = 0;
auto total_seconds = 100;
if (id(global_is_timer_active)) {
seconds = id(global_first_active_timer).seconds_left;
total_seconds = id(global_first_active_timer).total_seconds;
} else if (id(global_is_timer)) {
seconds = id(global_first_timer).seconds_left;
total_seconds = id(global_first_timer).total_seconds;
int percent = 0;
if (total_seconds > 0) {
percent = round( 100 * seconds / total_seconds );
auto *bar = id(progress_id);
lv_bar_set_value(bar, percent, LV_ANIM_ON);
std::string display_string = "00:00";
if (seconds > 0) {
int hours_left = floor(seconds / 3600);
int minutes_left = floor((seconds - hours_left * 3600) / 60);
int seconds_left = seconds - hours_left * 3600 - minutes_left * 60 ;
auto display_hours = (hours_left < 10 ? "0" : "") + std::to_string(hours_left);
auto display_minute = (minutes_left < 10 ? "0" : "") + std::to_string(minutes_left);
auto display_seconds = (seconds_left < 10 ? "0" : "") + std::to_string(seconds_left) ;
if (hours_left > 0) {
display_string = display_hours + ":" + display_minute;
} else {
display_string = display_minute + ":" + display_seconds;
auto *label = id(timer_id);
lv_label_set_text(label, display_string.c_str());
- id: start_voice_assistant
then:
- if:
condition:
then:
- if:
condition:
switch.is_off: mute
then:
- if:
condition:
lambda: return id(wake_word_engine_location).state == "In Home Assistant";
then:
- lambda: id(va).set_use_wake_word(true);
- voice_assistant.start_continuous:
- if:
condition:
then:
- lambda: id(va).set_use_wake_word(false);
- id: stop_voice_assistant
then:
- if:
condition:
then:
- micro_wake_word.stop:
- id: set_idle_status
then:
- if:
condition:
switch.is_off: mute
then:
src: casita_idle
else:
- id: press_to_talk
then:
- if:
condition:
- switch.is_on: timer_ringing
then:
else:
#- rtttl.play: 'beep:d=16,o=5,b=100:c6'
- delay: 200ms
image:
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/casita/error_320_240.png
resize: 320x240
type: RGB565
transparency: alpha_channel
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/casita/idle_320_240.png
resize: 320x240
type: RGB565
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/casita/listening_320_240.png
resize: 320x240
type: RGB565
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/casita/thinking_320_240.png
resize: 320x240
type: RGB565
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/casita/replying_320_240.png
resize: 320x240
type: RGB565
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/casita/timer_finished_320_240.png
resize: 320x240
type: RGB565
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/casita/loading_320_240.png
resize: 320x240
type: RGB565
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/error_box_illustrations/error-no-wifi.png
resize: 320x240
type: RGB565
- file: https://github.com/esphome/wake-word-voice-assistants/raw/main/error_box_illustrations/error-no-ha.png
resize: 320x240
type: RGB565
font:
- file:
type: gfonts
family: ${font_family}
weight: 300
italic: true
glyphsets:
- ${font_glyphsets}
- file:
type: gfonts
weight: 300
glyphsets:
- ${font_glyphsets}
- file:
type: gfonts
weight: 300
glyphsets:
- ${font_glyphsets}
lvgl:
pages:
- id: main_page
bg_color: black
widgets:
# Timer
- container:
align: TOP_MID
y: 2
widgets:
- bar:
min_value: 0
max_value: 100
value: 0
align: TOP_MID
height: !lambda 'return ${font_size} + 8;'
- label:
text: '00:00'
text_font: font_timer
text_color: white
align: TOP_MID
# Voice Assistant
- button:
bg_color: black
align: CENTER
widgets:
- image:
align: center
src: error_no_wifi
radius: 11
clip_corner: true
- label:
text: '...'
align_to:
align: OUT_TOP_LEFT
y: ${font_size}
width: 320
height: !lambda 'return ${font_size} + 10;'
text_font: font_request
text_color: white
#text_align: LEFT
long_mode: SCROLL_CIRCULAR
- label:
align_to:
align: OUT_BOTTOM_RIGHT
y: ${font_size}
width: 320
text: '...'
text_font: font_response
text_color: white
text_align: RIGHT
on_click:
then:
#- slider:
# id: volume_slider
# align: TOP_MID
# y: 2
# min_value: 0
# max_value: 100
# value: 70
# on_value:
# then:
# - logger.log:
# format: "Volume slider: %d"
# args: [ x ]
# - number.set:
# id: volume_control
# value: !lambda 'return x;'
Definitely, still room for improvement, but a good step forwards! Struggling with LVGL and there may still be stability issues when switching between modes,
mash727
(Mash727)
September 10, 2026, 2:51pm
18
Thanks for the helpfull information. I now have a working system. As I am trying to learn about the device and add HA entities such as toggle a switch is there an example or a guide that i could read regarding the componets needed and the process? Many thanks
kcr
September 30, 2026, 2:58pm
19
After starting off this discussion, I never came back and posted about what happened to my own project:
The first dashboard animation reports where my electricity is going. I installed PV, a heat pump and a battery last year, and started using Predbat, so it has been useful to keep an eye on what everything is doing and iron out some teething issues. The second dashboard reports weather forecast data from the HomeAssistant Met Office add-on, and I have another screen monitoring home temperatures.
The strip on the side is a set of addressable leds wired to an output on the ESP32 board. I use these to highlight unlocked doors or if the power is on in my external garage (the main touch display powers off when unused).
Thanks once more to everyone who contributed to the thread and helped me get this working. I think it is a really handy device, and it is interesting to see the different uses people have made of it.
