Derham
(Derham)
September 8, 2024, 1:22pm
1
Just bought one of these off AliExpress (about £20)…
The device worked fine with the stock software but I couldn’t connect to wifi. I wanted to connected it to HA anyway but couldn’t fine how to do it on the internet. So after a couple of days hacking around I can now report some success.
This is showing my solar battery State-Of-Charge (SOC) but is fairly general purpose.
Derham
(Derham)
September 8, 2024, 1:30pm
2
There is lots of info around for the ‘T-Display S3 Long’ display but this uses a JC3248W535C module requiring the axs15231 drivers - not a lot of info around for that.
I use this for my S3-long which uses the axs15231 driver.
substitutions:
friendly_name: T-display S3 Long
esphome:
friendly_name: ${friendly_name}
platformio_options:
upload_speed: 921600
build_unflags: -Werror=all
board_build.flash_mode: dio
board_build.f_flash: 80000000L
board_build.f_cpu: 240000000L
esp32:
board: esp32-s3-devkitc-1
flash_size: 16MB
framework:
type: esp-idf
# flash 16mb psram 8mb
psram:
mode: octal
speed: 120MHz
# Enable logging
logger:
wifi:
ssid: !secret wifi_ssid2
ap:
ssid: "Fallback Hotspot"
# Enable Home Assistant API
api:
password: !secret ota_password
# Allow Over-The-Air updates
ota:
- platform: esphome
external_components:
- source: github://buglloc/esphome-components
refresh: 10min
# PIN_BAT_VOLT 2
# PIN_BUTTON_1 0
# PIN_BUTTON_2 21
spi:
type: quad
clk_pin: 17
data_pins:
- 13
- 18
- 21
- 14
i2c:
sda: 15
scl: 10
frequency: 50hz
touchscreen:
- platform: axs15231
display: main_display
i2c_id: touchscreen_bus
transform:
swap_xy: true
# mirror_x: false
# mirror_y: true
on_touch:
- lambda: |-
ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
display:
spi_id: quad_spi
dimensions:
height: 640
width: 180
cs_pin: 12
reset_pin: 16
backlight_pin: 1
update_interval: 1s
transform:
swap_xy: false
rotation: 90
# auto_clear_enabled: true
lambda: |-
it.printf(20, 70, id(roboto), Color(255, 0, 0), id(ha_time).now().strftime("%I:%M:%S %p").c_str());
time:
- platform: homeassistant
font:
- file: "gfonts://Roboto"
nickrout
(Nick Rout)
September 8, 2024, 9:46pm
4
Lovely, but are you going to share?
Derham
(Derham)
September 9, 2024, 8:28am
6
My project is still ongoing, I want to be able to interact with the display by touch but I’m stuck on this at the moment. As mentioned before the S3 Long code posted doesn’t work with this device. The yaml so far is posted below but is still work in progress. I’m also new here so go easy please
I would be interested if anyone else is using this device.
# Substitution Variables
substitutions:
device_internal_name: esphome_16
device_wifi_name: esphome-16
device_friendly_name: ESPHome 16
device_ip_address: 192.168.1.16
device_sampling_time: 30s
# Globals
globals: ##to set default reboot behavior
- id: wifi_connection
type: bool
restore_value: no
initial_value: "false"
- id: bgcolor
type: Color
initial_value: "Color::random_color()"
# Board Configuration
esphome:
friendly_name: ${device_friendly_name}
psram:
mode: octal
speed: 120MHz
esp32:
variant: ESP32S3
flash_size: 16MB
framework:
type: esp-idf
components: [ axs15231 ]
# Enable logging
logger:
logs:
component: ERROR
api:
reboot_timeout: 0s
encryption:
key: !secret api_encryption_key
# OTA
ota:
platform: esphome
password: !secret web_server_password
# WiFi
wifi:
networks:
- ssid: !secret wifi_ssid
manual_ip:
static_ip: ${device_ip_address}
gateway: !secret gateway_address
subnet: !secret subnet_address
ap:
ssid: ${device_wifi_name}
# Web Server
web_server:
port: 80
version: 2
include_internal: true
auth:
username: !secret web_server_user
local: true
# Switch
switch:
- platform: restart
- platform: safe_mode
name: Use Safe Mode
- platform: output
output: lcdbacklight
restore_mode: ALWAYS_ON
# Interval
interval:
- interval: 10s
then:
- if:
condition:
wifi.connected:
then:
- lambda: |-
id(wifi_connection) = true;
else:
- lambda: |-
id(wifi_connection) = false;
time:
# Sensors
# WiFi
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: ${device_sampling_time}
# Uptime
- platform: uptime
internal: true
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(${device_internal_name}_uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
entity_id: sensor.1be6e4_remaining_battery_capacity
internal: true
# Text Sensors
text_sensor:
# ESP32 internal sensors
- platform: wifi_info
ip_address:
ssid:
mac_address:
name: Mac Wifi Address
# Custom Text sensors
name: Uptime Human Readable
icon: mdi:clock-start
binary_sensor:
# Global Button
#- platform: touchscreen
# name: Page_Switch
# x_min: 0
# x_max: 320
# y_min: 0
# y_max: 480
# on_press:
# - logger.log: "Page Switch was touched."
# - display.page.show_next: main_display
image:
- file: "image.png"
# resize: 640x180
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_blue
red: 0%
green: 0%
blue: 100%
- id: my_gray
red: 50%
green: 50%
blue: 50%
- id: my_white
red: 100%
green: 100%
blue: 100%
- id: my_black
red: 0%
green: 0%
blue: 0%
font:
glyphs: "!\"%()+=,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz/\\[]|&@#'"
- file: "gfonts://Roboto@700"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
captive_portal:
spi:
- id: display_qspi
type: quad
clk_pin: 47
data_pins:
- 21
- 48
- 40
- 39
i2c:
sda: 4
scl: 8
display:
spi_id: display_qspi
dimensions:
height: 480
width: 320
cs_pin: 45
reset_pin: 16
transform:
swap_xy: false
rotation: 90
lambda: |-
it.rectangle(0, 0, it.get_width(), it.get_height(), id(my_blue));
it.filled_rectangle(20, 20, it.get_width()-40, it.get_height()-40, id(my_gray));
it.strftime((it.get_width() / 2), (it.get_height() / 6) * 1, id(arial_24), id(my_black), TextAlign::CENTER, "%Y-%m-%d", id(esptime).now());
it.strftime((it.get_width() / 2), (it.get_height() / 6) * 2, id(arial_24), id(my_black), TextAlign::CENTER, "%H:%M:%S", id(esptime).now());
it.printf((it.get_width() / 2), (it.get_height() / 6) * 3 - 25, id(arial_128), id(my_yellow), TextAlign::TOP_CENTER , "%.0f%%", id(battery_soc).state);
touchscreen:
transform:
swap_xy: true
on_touch:
- lambda: |-
Color newColor;
do { newColor = Color::random_color(); } while (newColor == id(bgcolor));
id(bgcolor) = newColor;
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
output:
- platform: gpio
pin:
number: GPIO01
# allow_other_uses: true
nickrout
(Nick Rout)
September 9, 2024, 9:40am
7
Sorry, I wasn’t referring to you, but I perhaps didn’t make that clear.
Derham
(Derham)
September 19, 2024, 11:26am
9
Update: I’ve had some more success with this display - left display in photo.
My solar and battery charging status is looking good. I can draw shapes and images on the screen using the esphome graphics and interact with other HA devices using the buttons on the right side. Thats the good news.
The bad news in that I cant get the display working with LVGL properly. The device on the right in the photo shows the standard LVGL meter and displays fine on first boot. Any update to the screen, however, seems to corrupt the image. It looks like it’s creating an update section for the image and locating it at 0,0. This may be down to the device settings but I’ve tried many many changes and not got any further.
Has anyone seen this sort behaviour using LVGL?
ageurtse
(Arnold)
September 29, 2024, 5:56pm
11
Do you have it git adress where we can observe your updated code.
and maybe use it to make it beter. i order a display my self, so i hope in a few days i can try to build somthing myself
Derham
(Derham)
September 29, 2024, 6:29pm
12
Hi Arnold,
Sorry no git address set up yet - very new here. I’ve only been successful in using standard esphome graphics as show in the screen above. Still haven’t got the LVGL working properly yet. But… I have also invested in this 7" Waveshare ( ESP32-S3-Touch-LCD-7 ) device. It’s taken a few days but tonight I have successfully got LVGL working on it. So, what I want to do next is go back to the 3.5" display and apply what I’ve learnt to see if I can progess it further. Let me know how you get on with your device.
roussell
(Terry Roussell)
October 3, 2024, 4:01pm
13
I both the same display, using your link in the OP. I am having a hard time getting any meaningful response from it. I copied your code, but only set a screen full of colorful “static” and the following repeating errors in the logs:
[11:23:26][W][component:237]: Component display took a long time for an operation (52 ms).
[11:23:26][W][component:238]: Components should block for at most 30 ms.
[11:23:26][E][axs15231.touchscreen:040]: Failed to communicate!
Have you (or anyone else) seen that behavior? If so how did you solve it? I’m wondering if something changes in the hardware revisions, even though I used your original link to purchase…
TIA,
Terry
Derham
(Derham)
October 3, 2024, 4:29pm
14
Hi Terry,
Make sure you copied my code not the S3 Long code as mentioned, that would give that coloured effect.
I’ve just recompiled mine as there has been a recent ESPHome update but all is working fine.
cheers
Derham
roussell
(Terry Roussell)
October 3, 2024, 4:32pm
16
I’m an idiot. I did in fact copy the wrong code and just figured that out. Thanks for the reponse!! One question on the arial font though - do I need to copy that somewhere onto the device or in the ESS folder structure? I seem to be getting errors referencing it.
Terry
Derham
(Derham)
October 3, 2024, 4:44pm
17
Great. Yes, I copied the arial.ttf file from my Windows laptop into the config\esphome folder. There are lots of Google fonts you can reference online, might be worth a look.
I’ve also modified the board config, using the ESP32S3BOX, which now looks like this…
esphome:
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.arduino.memory_type: qio_opi
psram:
mode: octal
speed: 120MHz
esp32:
board: esp32s3box
variant: ESP32S3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
COMPILER_OPTIMIZATION_SIZE: y
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
CONFIG_ESPTOOLPY_FLASHSIZE_8MB: "y"
Derham
Derham
(Derham)
October 3, 2024, 4:48pm
18
Still no success with LVGL though so it’s a pain working with the touchpad. The 7" device I referenced is a pleasure to do the LVGL although I can’t use the standard graphics on that, very strange.
ageurtse
(Arnold)
October 5, 2024, 12:51pm
19
i have my display up and runnning, so far so good.
now i’m looking into LVGL and how to use it, in the search for a bear minimum example
after some try, i have LVGL running, but the same problem like the topic starter.
nickrout
(Nick Rout)
October 5, 2024, 8:02pm
20
What problem exactly?
If you want help, yaml and logs.
ageurtse
(Arnold)
October 6, 2024, 6:24am
21
here is my yaml, after some trying it isn’t the niced code
log shows no error’s
the display seems to be very slow.
see a video on what is playing https://youtu.be/Yd0yymlYRNM
substitutions:
friendly_name: WEKKER
color:
- id: White
red: 100%
green: 100%
blue: 100%
- id: Black
red: 0%
green: 0%
blue: 0%
- id: Red
red: 100%
green: 0%
blue: 0%
esphome:
min_version: 2024.6.0
name_add_mac_suffix: false
platformio_options:
project:
version: dev
psram:
mode: octal
speed: 120MHz
esp32:
board: esp32s3box
variant: ESP32S3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
- source: github://ageurtse/esphome-components
# Enable logging
logger:
logs:
component: NONE
api:
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
# To have a "next url" for improv serial
web_server:
spi:
- id: display_qspi
type: quad
clk_pin: 47
data_pins:
- 21
- 48
- 40
- 39
i2c:
sda: 4
scl: 8
switch:
- platform: output
output:
- platform: gpio
pin:
number: GPIO01
display:
# backlight_pin: GPIO01
dimensions:
height: 480
width: 320
cs_pin: 45
reset_pin: 16
transform:
swap_xy: true
rotation: 270
auto_clear_enabled: false
touchscreen:
transform:
swap_xy: false
# mirror_x: false
# mirror_y: true
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
time:
on_time_sync:
- script.execute: time_update
- if:
condition:
lambda: 'return id(device_last_restart).state == "";'
then:
state: !lambda 'return id(homeassistant_time).now().strftime("%a %d %b %Y - %I:%M:%S %p");'
# Update the clock every second
on_time:
- seconds: "*"
then:
script:
- id: time_update
then:
- lvgl.indicator.update:
value: !lambda |-
return id(homeassistant_time).now().second;
value: !lambda |-
return id(homeassistant_time).now().minute;
value: !lambda |-
auto now = id(homeassistant_time).now();
return std::fmod(now.hour, 12) * 60 + now.minute;
text_sensor:
- platform: version
icon: mdi:clock
entity_category: diagnostic
binary_sensor:
- platform: status
lvgl:
displays:
- main_display
touchscreens:
- main_touch
style_definitions:
- id: no_checked_color
bg_color: 0xCC5E14
text_color: 0xB6B6B6
theme:
button:
text_font: roboto24
scroll_on_focus: true
radius: 0px
width: 150px
height: 109px
pad_all: 10px
shadow_width: 0 # This is required even though the default is suposed to be 0
bg_color: 0x313131
checked:
bg_color: 0xCC5E14
page_wrap: false
top_layer:
widgets:
- obj:
layout:
type: flex
flex_flow: COLUMN_WRAP
width: 480px
height: 320px
text_font: roboto24
scrollbar_mode: 'off'
bg_color: White
bg_opa: COVER
radius: 0
pad_all: 0
widgets:
- image:
src: boot_logo
pad_bottom: 0
- label:
text: "WiFi Strength: 0%"
- label:
text:
format: "ESPHome Version: %s"
args: [ 'id(esphome_version).state.c_str()' ]
- obj:
radius: 0
pad_all: 0
border_width: 0
width: 480px
height: 320px
flex_grow: 1
widgets:
- button:
align: center
radius: 15
width: 200
height: 100
checkable: true
widgets:
- label:
text_color: White
align: center
text: "OK"
on_press:
- lvgl.widget.hide: boot_screen
pages:
- id: main_page
width: 100%
bg_color: Black
widgets:
# Outer Clock Container
- obj:
height: 300px
width: 300px
align: center
pad_all: 0
bg_color: Black
border_width: 0
widgets:
- meter:
height: 100%
width: 100%
align: center
bg_color: White
scales:
# Minor ticks
- ticks:
width: 2
count: 61
length: 10
color: Black
range_from: 0
range_to: 60
angle_range: 360
rotation: 270
# Minuite hand
indicators:
- line:
width: 3
color: Black
r_mod: -1
# Major ticks
- angle_range: 330
rotation: 300
range_from: 1
range_to: 12
ticks:
width: 3
count: 12
length: 20
color: Black
# Hour hand
- angle_range: 360
rotation: 270
range_from: 0
range_to: 720
indicators:
- line:
width: 4
color: Black
r_mod: -40
# Second hand
- angle_range: 360
rotation: 270
range_from: 0
range_to: 60
indicators:
- line:
width: 2
color: Red
r_mod: -10
# Graphics and Fonts
image:
- file: https://esphome.io/_static/logo-text-on-light.svg
type: RGB565
resize: 470x95
use_transparency: true
font:
bpp: 4
extras:
# http://materialdesignicons.com/cdn/7.4.47/
- file: 'https://github.com/Templarian/MaterialDesign-Webfont/raw/v7.4.47/fonts/materialdesignicons-webfont.ttf'
glyphs: [
"\U000F004B",
"\U0000f0ed",
"\U000F006E",
"\U000F012C",
"\U000F179B",
"\U000F0748",
"\U000F1A1B",
"\U000F02DC",
"\U000F0A02",
"\U000F035F",
"\U000F0156",
"\U000F0C5F",
"\U000f0084",
"\U000f0091",
edit: new video uploaded
