ageurtse
(Arnold)
October 12, 2024, 11:22am
42
When working with an image i get the below error
/config/esphome/esphome-web-220778.yaml: In lambda function:
/config/esphome/esphome-web-220778.yaml:165:46: error: 'class esphome::image::Image' has no member named 'get_lv_img_dsc'
src: boot_logo
Compiling .pioenvs/esphome-web-220778/libb78/lvgl/core/lv_disp.o
*** [.pioenvs/esphome-web-220778/src/main.o] Error 1
i use the below code
substitutions:
friendly_name: WEKKER
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.arduino.memory_type: qio_opi
on_boot:
- delay: 5s
- lvgl.widget.hide: boot_screen
project:
version: dev
psram:
mode: octal
speed: 120MHz
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
# Enable logging
logger:
logs:
component: DEBUG
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
# To have a "next url" for improv serial
web_server:
external_components:
- source: github://clydebarrow/esphome@lvgl-rounding
components: [lvgl]
- source: github://ageurtse/esphome-components
components: [ axs15231 ]
spi:
type: quad
clk_pin: 47
data_pins: [21,48,40,39]
time:
- platform: homeassistant
# Define a PWM output on the ESP32
output:
- platform: ledc
pin: 1
# Define a monochromatic, dimmable light for the backlight
light:
- platform: monochromatic
output: gpio_backlight_pwm
name: "Display Backlight"
restore_mode: ALWAYS_ON
entity_id: light.your_dimmer
attribute: brightness
on_value:
- lvgl.slider.update:
value: !lambda return x;
i2c:
sda: 4
scl: 8
image:
- file: https://esphome.io/_static/favicon-512x512.png
resize: 200x200
type: RGB565
use_transparency: true
display:
- platform: qspi_amoled
model: RM67162
data_rate: 40MHz
dimensions:
height: 480
width: 320
cs_pin:
number: 45
ignore_strapping_warning: true
auto_clear_enabled: false
update_interval: never
touchscreen:
- platform: axs15231
display: main_display
i2c_id: touchscreen_bus
lvgl:
draw_from_origin: true
draw_rounding: 8
widgets:
- slider:
x: 20
y: 50
width: 30
height: 220
pad_all: 8
min_value: 0
max_value: 255
on_release:
- homeassistant.action:
action: light.turn_on
brightness: !lambda return int(x);
- obj:
x: 0
y: 0
width: 100%
height: 100%
bg_color: 0xffffff
bg_opa: COVER
radius: 0
pad_all: 0
border_width: 0
widgets:
- image:
src: boot_logo
- spinner:
align: CENTER
y: 95
height: 50
width: 50
spin_time: 1s
arc_length: 60deg
arc_width: 8
indicator:
arc_color: 0x18bcf2
arc_width: 8
on_press:
font:
- file: "fonts/Seven Segment.ttf"
glyphs: "!\"%()+=,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz/\\[]|&@#'"
clydebarrow
(Clyde Stubbs)
October 12, 2024, 11:34am
43
Use the dev or beta ESPHome, or add image to the external component where lvgl is defined. There are changes to the image component not yet released, but in beta.
clydebarrow
(Clyde Stubbs)
October 12, 2024, 11:45am
44
Here is an updated config, with touchscreen support. There are or will be PRs for the external components in ESPHome.
This works around the limitations of the chip and still delivers reasonable performance. As written it will build against the ESPHome release version.
The display can’t be rotated to landscape with transform as the chip does not support axis swapping, but software rotation as shown below works - there is some performance impact, but it’s not too bad as the screen is pretty fast to begin with.
For portrait mode with no rotation, remove the rotation option from the display and the transform from the touchscreen.
substitutions:
friendly_name: JC3248W535
esphome:
friendly_name: ${friendly_name]
platformio_options:
build_unflags: -Werror=all
board_build.flash_mode: dio
esp32:
framework:
type: esp-idf
sdkconfig_options:
components: [lvgl, image]
- source: github://clydebarrow/esphome@qspi
components: [qspi_dbi]
- source: github://pr#7592
components: [axs15231]
- source: github://pr#7591
components: [touchscreen]
psram:
mode: octal
speed: 80MHz
spi:
type: quad
clk_pin: 47
power_supply:
pin: 1
enable_on_boot: true
display:
- platform: qspi_dbi
model: CUSTOM
data_rate: 40MHz
dimensions:
height: 480
width: 320
transform:
mirror_x: false
mirror_y: false
cs_pin:
number: 45
rotation: 270
init_sequence:
i2c:
sda: 4
scl: 8
touchscreen:
platform: axs15231
transform:
swap_xy: true
mirror_x: false
mirror_y: true
lvgl:
ageurtse
(Arnold)
October 12, 2024, 2:17pm
45
Looks like there is somthing broken, i can’t get it to compile.
i’m using the normal ESPhome, when using beta or dev, i get even more error’s
i get a error
INFO ESPHome 2024.9.2
INFO Reading configuration /config/esphome/esphome-web-220778.yaml...
INFO Unable to import component image: No module named 'puremagic'
Failed config
image: [source /config/esphome/esphome-web-220778.yaml:111]
Component not found: image.
resize: 200x200
type: RGB565
use_transparency: True
when removing image i get a error on component LVGL is missing.
Derham
(Derham)
October 12, 2024, 8:52pm
47
Good morning, good afternoon or good evening guys.
I know your going down a different route now with this but I’ve been ploughing on with the original drivers. I believe I’ve fixed the redraw, rotation and touchpad issues so everthing look good to me. I’ve also created a github account and uploaded it there.
The drivers and an example are included…
The drivers work with my standard graphics example as well.
The error ‘[draw_from_origin] is an invalid option for [lvgl]’ has returned again although this time it prevents the complilation, previously it compiled and ran fine.
Must be doing something wrong
I removed that option from LVGL and put it into the driver instead, which is where it belongs. See my earlier post.
ageurtse
(Arnold)
October 12, 2024, 9:04pm
49
Woukd you include the link ?
clydebarrow
(Clyde Stubbs)
October 13, 2024, 10:44am
51
The partial update problem is solved, performance is now normal, even with software rotation (swapping axes in hardware does not work.)
esphome:dev ← clydebarrow:qspi
opened 01:14AM - 13 Oct 24 UTC
# What does this implement/fix?
* Rename the `qspi_amoled` display driver… to `qspi_dbi` since it now supports other displays.
* Add custom model and custom init sequences
* Add `draw_from_origin` to support certain broken display driver chips.
## Types of changes
- [ ] Bugfix (non-breaking change which fixes an issue)
- [x] New feature (non-breaking change which adds functionality)
- [ ] Breaking change (fix or feature that would cause existing functionality to not work as expected)
- [x] Other
**Related issue or feature (if applicable):** fixes <link to issue>
**Pull request in [esphome-docs](https://github.com/esphome/esphome-docs) with documentation (if applicable):** esphome/esphome-docs#4335
## Test Environment
- [ ] ESP32
- [x] ESP32 IDF
- [ ] ESP8266
- [ ] RP2040
- [ ] BK72xx
- [ ] RTL87xx
## Example entry for `config.yaml`:
Supplying a configuration snippet, makes it easier for a maintainer to test
your PR. Furthermore, for new integrations, it gives an impression of how
the configuration would look like.
Note: Remove this section if this PR does not have an example entry.
```yaml
# Example config.yaml
display:
model: AXS15231
data_rate: 40MHz
dimensions:
height: 480
width: 320
cs_pin:
number: 45
rotation: 270
## Checklist:
- [x] The code change is tested and works locally.
- [x] Tests have been added to verify that the new code works (under `tests/` folder).
If user exposed functionality or configuration variables are added/changed:
- [x] Documentation added/updated in [esphome-docs](https://github.com/esphome/esphome-docs).
Touchscreen supported with PR:
esphome:dev ← clydebarrow:ax15231
opened 11:21AM - 12 Oct 24 UTC
Add support
## Types of changes
- [ ]… Bugfix (non-breaking change which fixes an issue)
- [ ] Other
**Pull request in [esphome-docs](https://github.com/esphome/esphome-docs) with documentation (if applicable):** esphome/esphome-docs#4334
## Test Environment
- [ ] ESP32
- [x] ESP32 IDF
- [ ] ESP8266
- [ ] RP2040
- [ ] BK72xx
- [ ] RTL87xx
```yaml
## Checklist:
ageurtse
(Arnold)
October 13, 2024, 11:43am
52
Here is my test project, it was realy fun to do, i make use of the alterd driver from DerHam. later i will try to see how far i will get with the alterd driver from clydebarrow.
https://github.com/ageurtse/esphome-clock
Derham
(Derham)
October 13, 2024, 12:27pm
53
That looks good Arnold…
I was going to look into how to dim the backlight, you’ve done that as well
Derham
(Derham)
October 13, 2024, 12:30pm
54
Being new to this I’ve been learning github, c++, yaml, HA and sometimes it starts doing my head in
I stil not quite sure what to do with… pip install puremagic ?
ageurtse
(Arnold)
October 13, 2024, 12:52pm
55
Derham:
me to, but when googling on puremagic, it has somthing to do with the #number ’s from github.
to me it looks it only works on the dev version from ESPhome.
maybee clydebarrow, could explain us a bit what he did, and how to use it, so we can learn a bit from it.
ageurtse
(Arnold)
October 13, 2024, 1:36pm
56
clydebarrow:
Can’t get your newly updates changes to work.
I don’t know what i’m doing wrond.
where and why do i need to install puremagic.
sorry, i’m not as good with github and programming, still learning and trying to understand.
i have includes your external components but the compilers give this error, can’t make anything about it.
INFO ESPHome 2024.11.0-dev
ERROR Unable to import component qspi_dbi.display:
File "/esphome/esphome/loader.py", line 177, in _lookup_module
module = importlib.import_module(f"esphome.components.{domain}")
File "/usr/lib/python3.11/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1206, in _gcd_import
File "<frozen importlib._bootstrap>", line 1178, in _find_and_load
File "<frozen importlib._bootstrap>", line 1149, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/data/external_components/534b7061/esphome/components/qspi_dbi/display.py", line 5, in <module>
from esphome.const import (
ImportError: cannot import name 'CONF_INIT_SEQUENCE' from 'esphome.const' (/esphome/esphome/const.py)
Failed config
display.qspi_dbi: [source /config/esphome/esphome-web-220778.yaml:316]
Platform not found: 'display.qspi_dbi'.
platform: qspi_dbi
model: AXS15231
data_rate: 40MHz
dimensions:
height: 480
width: 320
cs_pin:
number: 45
ignore_strapping_warning: True
auto_clear_enabled: False
rotation: 270
That’s because there are core changes, which the external component does not bring in. You’ll need to wait at least until it’s merged into the Dev branch, then you can use the ESPHome Dev add-on in HA. Might be a week or two, outside my control.
The alternative right now is to clone my repo and use the CLI, but it sounds like that’s not part of your skill set ATM.
ageurtse
(Arnold)
October 14, 2024, 4:20am
58
I will wait a while and try it in a week or 2
The cli is one step to much at the moment.
ageurtse
(Arnold)
October 17, 2024, 5:19pm
59
a short update, downloaded the latest dev version off esphome 2014.11.0-dev
and running the code below works out of the box, no external components needed.
@clydebarrow thanks for the work.
@derham , thanks for the first setup with a working example
buglloc, for the very first driver
the below clock, display’s a simple clock.
the font can be download from here. https://github.com/ageurtse/esphome-clock
# Substitution Variables
substitutions:
device_internal_name: wekker
device_wifi_name: esphome-wekker
device_friendly_name: WEKKER
device_ip_address: 192.168.0.128
device_sampling_time: 30s
# Globals
globals:
- id: wifi_connection
type: bool
restore_value: no
initial_value: "false"
- id: bgcolor
type: Color
initial_value: "Color::random_color()"
- id: my_selection
type: int
initial_value: "0"
# Board Configuration
esphome:
friendly_name: ${device_friendly_name}
platformio_options:
on_boot:
priority: -100
then:
psram:
mode: octal
speed: 120MHz
esp32:
board: esp32s3box
variant: ESP32S3
flash_size: 8MB
framework:
type: esp-idf
# Bluethooth tracker
bluetooth_proxy:
# Enable logging
logger:
logs:
component: NONE
api:
reboot_timeout: 0s
# OTA
ota:
- platform: esphome
# WiFi
wifi:
ssid: !secret wifi_ssid
output_power: 10
use_address: ${device_ip_address}
on_connect:
- lvgl.label.update:
text:
format: "IP Address: %s"
args: [ 'id(ip_address).state.c_str()' ]
ap:
ssid: ${device_wifi_name}
password: !secret esphome_pwd
captive_portal:
# Web Server
web_server:
port: 80
version: 2
include_internal: true
# Output
output:
- platform: ledc
pin:
number: GPIO01
# Switch
switch:
- platform: restart
- platform: safe_mode
name: Use Safe Mode
# Light
light:
output: lcdbacklight
# Sensors
# WiFi
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: ${device_sampling_time}
# Uptime
- platform: uptime
internal: true
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(${device_internal_name}_uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
# Interval
interval:
- interval: 10s
then:
- if:
condition:
wifi.connected:
then:
- lambda: |-
id(wifi_connection) = true;
else:
- lambda: |-
id(wifi_connection) = false;
time:
on_time:
- minutes: "*"
then:
text:
format: "%s"
args: [ 'id(current_time).state.c_str()' ]
# Text Sensors
text_sensor:
- platform: wifi_info
ip_address:
entity_category: diagnostic
ssid:
mac_address:
- platform: version
hide_timestamp: true
on_value:
then:
text: !lambda |-
return ("ESPHome Version: " + id(esphome_version).state).c_str();
update_interval: 60s
lambda: return id(esptime).now().strftime("%H:%M");
# Custom Text sensors
name: Uptime Human Readable
icon: mdi:clock-start
# SPI and I2C
spi:
type: quad
clk_pin: 47
i2c:
sda: 4
scl: 8
frequency: 800khz
# Display and Touchscreen
display:
model: CUSTOM
data_rate: 40MHz
dimensions:
height: 480
width: 320
transform:
mirror_x: false
mirror_y: false
cs_pin:
number: 45
rotation: 270
init_sequence:
touchscreen:
platform: axs15231
transform:
swap_xy: true
mirror_x: false
mirror_y: true
# Image, Fonts and color
image:
resize: 200x200
type: RGB565
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_pink
red: 100%
green: 10%
blue: 40%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_blue
red: 0%
green: 0%
blue: 100%
- id: my_gray
red: 50%
green: 50%
blue: 50%
- id: my_white
red: 100%
green: 100%
blue: 100%
- id: my_black
red: 0%
green: 0%
blue: 0%
font:
- file: "fonts/digital-dismay.regular.otf"
glyphs: ":0123456789"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "arial.ttf"
- file: "gfonts://Roboto"
bpp: 4
# LVGL
lvgl:
bg_color: my_black
text_font: arial_12
width: 320
height: 480
align: center
style_definitions:
- id: date_style
align: center
text_color: 0x000000
bg_opa: cover
radius: 4
pad_all: 2
widgets:
- label:
text_font: font_std
text_color: my_red
align: CENTER
text: "99:99"
on_press:
- lvgl.widget.show: boot_screen
- obj:
x: 0
y: 0
width: 100%
height: 100%
bg_color: 0xffffff
bg_opa: COVER
radius: 0
pad_all: 0
border_width: 0
widgets:
- image:
src: boot_logo
- spinner:
align: CENTER
y: 95
height: 50
width: 50
spin_time: 1s
arc_length: 60deg
arc_width: 8
indicator:
arc_color: 0x18bcf2
arc_width: 8
- label:
x: 200
y: 50
text:
format: "MAC Address: %s"
args: [ 'id(mac_address).state.c_str()' ]
- label:
x: 200
y: 65
text:
- label:
x: 200
y: 110
text:
format: "ESPHome Version: %s"
args: [ 'id(esphome_version).state.c_str()' ]
on_press:
Derham
(Derham)
October 21, 2024, 11:25am
60
Well, 1 step forward and 2 back! My demo works fine under ESPHome 2024.9.2 but something has changed at 2024.10.0 - now the touchpad coordinates are out so the buttons don’t press in the right location anymore - graphics are fine though.
You can wind back the ESPHome version using this add-on…
I tried 2024.11 but was getting strange results there as well so I think I’ll keep to 9.2, for this device, until the full release version is available.
Derham
(Derham)
October 28, 2024, 1:25pm
61
UPDATE:
My demo project is now working fine in all rotations using Clyde’s lastest axs15231 driver in Esphome Dev env. Great, thanks for the work on this.
