ESP32-S3 compatibily and M5 Paper S3
Hello, not sure I’m understanding this right, but I was looking at the following product: M5PaperS3 ESP32S3 Development Kit (960x540, 4.7" eInk Display, 235 ppi) | m5stack-store
I don’t see it listed in the products compatible with ESPHOME, however, looking at the docs for the M5 Stack I understand they use the same controller:
Can I just then “flash” ESPHOME on the M5 Paper S3 or the support required include the actual HW plugged into the controller?
I’m looking basically for a ready to use epaper display, I would prefer not to build it myself, especially because I like a more polished finish of enclosure, if there is any other product I can consider let me know!
Esp32-s3 doesn’t give you any hard time.
The display probably does. So try to look for support for that.
The device appears to be Waveshare compatible, but that doesn’t mean it will work out of the box if at all.
The compatible displays afor ESPHome are listed here:
Waveshare and Nextion both have nicely finished displays with bevels if you are after ePaper.
Anyone make any progress with this? Just ordered an M5paper s3.
Try my YAML. No Deep Sleep Support Now.
esphome:
  friendly_name: m5papers3
  build_path: /config/esphome/m5papers3
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
  libraries:
    - https://github.com/patrick3399/epdiy
  on_boot:
    then:
      - rtttl.play: 'siren:d=8,o=5,b=100:d,e,d,e,d,e,d,e'
      - delay: 5s
      - component.update: ed047tc1_display
      - lambda: |-
          id(system_initialized) = true;
esp32:
  board: esp32-s3-devkitc-1
  flash_size: 16MB
  framework:
    type: esp-idf
    version: latest
    sdkconfig_options:
      CONFIG_EPD_OUTPUT_LUT_ASSEMBLY: "y"
      CONFIG_ESP32S3_INSTRUCTION_SET_AI_DSP: "y"
      CONFIG_ESP32S3_VECTOR_INSTRUCTIONS_SUPPORT: "y"
globals:
  - id: system_initialized
    type: bool
    restore_value: no
    initial_value: 'false'
psram:
  mode: octal
  speed: 80MHz
interval:
  - interval: 8s
    then:
      - light.turn_on: statled
      - delay: 1s
      - light.turn_off: statled
logger:
  level: DEBUG
  baud_rate: 0
  logs:
    api.service: WARN
    wifi: WARN
    esp-idf: NONE
    light: WARN
debug:
  update_interval: 10s
api:
  # encryption:
  #   key: !secret api_key
  reboot_timeout: 6h
ota:
  - platform: esphome
    #password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 6h
  #power_save_mode: LIGHT
external_components:
  - source: github://patrick3399/esphome_components
  # - source: github://n-serrette/esphome_sd_card   #If need SD Card Support
i2c:
  sda: GPIO41
  scl: GPIO42
  scan: true
  frequency: 200kHz
# sd_mmc_card:  #If need SD Card Support
#   id: micro_sd
#   mode_1bit: true
#   clk_pin: GPIO7
#   cmd_pin: GPIO8
#   data0_pin: GPIO9
#   data3_pin: GPIO10
# sd_file_server:  #If need SD Card Support
#   id: file_server
#   url_prefix: file
#   root_path: "/"
#   enable_deletion: true
#   enable_download: true
#   enable_upload: true
touchscreen:
  platform: gt911
  interrupt_pin: GPIO48
  transform:
    mirror_x: true
    mirror_y: true
    swap_xy: false
  on_touch:
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
light:
  - platform: monochromatic
    output: gpio_0
    restore_mode: ALWAYS_OFF
    internal: True
    disabled_by_default: True
output:
  - platform: ledc
    pin: 21
  - platform: ledc
    pin: 0
    inverted: True
rtttl:
  output: rtttl_pin
  gain: 60%
text_sensor:
  - platform: debug
    device:
    reset_reason:
  - platform: debug
    free:
    block:
      name: "Heap Max Block"
    loop_time:
    psram:
  - platform: internal_temperature
  - platform: adc
    pin: GPIO3
    update_interval: 30s
    attenuation: 12db
    filters:
      - multiply: 2.0
  - platform: adc
    pin: GPIO5
    attenuation: 12db
    filters:
      - multiply: 2.0
  - platform: bmi270
    address: 0x68
    acceleration_x:
      name: "BMI270 Accel X"
    acceleration_y:
      name: "BMI270 Accel Y"
    acceleration_z:
      name: "BMI270 Accel Z"
    gyroscope_x:
      name: "BMI270 Gyro X"
    gyroscope_y:
      name: "BMI270 Gyro Y"
    gyroscope_z:
      name: "BMI270 Gyro Z"
    temperature:
      name: "BMI270 Temperature"
    power_save_mode: LOW_POWER
    update_interval: 60s'2000dps' [cite: 5]
  # - platform: sd_mmc_card  #If need SD Card Support
  #   type: used_space
  #   name: "SD card used space"
  #   type: total_space
  #   name: "SD card total space"
# text_sensor:
  #   sd_card_type:
  #     name: "SD card type"
binary_sensor:
  - platform: gpio
    pin:
      number: 4
      inverted: True
    device_class: battery_charging
time:
  - platform: pcf8563  #BM8563
    address: 0x51
    timezone: Asia/Taipei
    update_interval: never
  - platform: homeassistant
    update_interval: 1h
    on_time_sync:
      then:
        pcf8563.write_time:
display:
  - platform: ed047tc1
    pwr_pin: GPIO45
    bst_en_pin: GPIO46
    xstl_pin: GPIO13
    xle_pin: GPIO15
    spv_pin: GPIO17
    ckv_pin: GPIO18
    pclk_pin: GPIO16
    d0_pin: GPIO6
    d1_pin: GPIO14
    d2_pin: GPIO7
    d3_pin: GPIO12
    d4_pin: GPIO9
    d5_pin: GPIO11
    d6_pin: GPIO8
    d7_pin: GPIO10
    rotation: 90
    lambda: |-
       it.print(it.get_width() / 2, it.get_height() / 12 *1 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline01).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *2 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline02).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *3 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline03).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *4 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline04).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *5 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline05).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *6 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline06).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *7 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline07).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *8 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline08).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *9 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline09).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *10 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline10).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *11 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline11).state.c_str());
       it.print(it.get_width() / 2, it.get_height() , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline12).state.c_str());
font:
  - file: "gfonts://Roboto"
text:
    name: "Text Line 01"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 01'
    mode: text
    on_value:
      then:
        - if:
            condition:
              lambda: 'return id(system_initialized) == true;'
            then:
    name: "Text Line 02"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 02'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 03"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 03'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 04"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 04'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 05"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 05'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 06"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 06'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 07"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 07'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 08"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 08'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 09"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 09'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 10"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 10'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 11"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 11'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 12"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 12'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
Hi @patrick339, thanks for your work. The bmi270 code fails to compile. Without it, I managed to flash it.
Hi @p-boon and @patrick339 I spent a long time trying out this code on my new Paper S3. I’m not super knowledgeable on this stuff, however, for the life of me I could not get this code to compile, even after taking out the BMI270 lines. Using the straight up code of Patrick’s, this is the first compile error I get:
Download esphome-web-29cd14.yaml
INFO ESPHome 2025.9.0
INFO Reading configuration /config/esphome/esphome-web-29cd14.yaml...
Failed config
esp32: [source /config/esphome/esphome-web-29cd14.yaml:18]
flash_size: 16MB
ESP-IDF latest may be supported by platformio/espressif32; please specify 'platform_version'.
framework:
type: esp-idf
version: latest
sdkconfig_options:
CONFIG_EPD_OUTPUT_LUT_ASSEMBLY: y
CONFIG_ESP32S3_INSTRUCTION_SET_AI_DSP: y
CONFIG_ESP32S3_VECTOR_INSTRUCTIONS_SUPPORT: y
I then went down a rabbit hole with AI trying to figure out the issue by adding a platform_version line… but I don’t know if that was it or not.
Eventually I got my code to this, and it moved on from the error
esphome:
  platformio_options:
    platform: espressif32
    platform_version: "5.3.0"
    framework: espidf
    framework_version: "5.1.1"
  libraries:
  on_boot:
    then:
      - delay: 5s
      - lambda: |-
esp32:
  flash_size: 16MB
  framework:
    type: esp-idf
    version: "5.1.1"
    sdkconfig_options:
But I doubt that’s right… after this I went through a whole slew of libraries and epdiy.h errors… and never got it working.
Any tips or hints to get this display working in ESPhome?
Hi @ibarker3 I noticed after upgrading esphome that my build also failed with the config I used before. For me the relevant parts look like this now:
I had to prefix this github link like this:
esphome:
  libraries:
    - epidy=https://github.com/patrick3399/epdiy
esphome:
  build_path: build
  platformio_options:
  libraries:
  on_boot:
    then:
#      - rtttl.play: 'siren:d=8,o=5,b=100:d,e,d,e,d,e,d,e'
      - delay: 5s
      - lambda: |-
esp32:
  flash_size: 16MB
  framework:
    type: esp-idf
    version: 5.4.2
    sdkconfig_options:
Hi All,
thank you for the hint, but I’m failing as well while compiling the bmi270.
Any Ideas on how to get it running?
BR
Thank You!
Hi All,
I fixed the issue in the epdiy library and create a new fork for it.
The M5Stack Paper S3 is now working with Homeassistant and ESPHome.
More Infos in this post:
