M5Stack PaperS3 + ESPHome: Working with ESP-IDF 5.5.1 (epdiy fork)
Hi everyone,
I wanted to share my updated fork of the epdiy library that now works with ESP-IDF 5.5.1 and the M5Stack PaperS3 on ESPHome. The original library had several compilation errors with the latest ESP-IDF version, which I’ve fixed.
:wrench: What Was Fixed
ESP-IDF 5.5.1 introduced breaking changes that prevented the epdiy library from compiling:
  1. gpio_hal_iomux_func_sel removal - Replaced with inline function using PIN_FUNC_SELECT
  2. __DECLARE_RCC_ATOMIC_ENV macro removal - Added compatibility shim for the removed RCC atomic environment macro
  3. GDMA API deprecations - The old API still works but shows warnings (harmless)
All fixes maintain backward compatibility with ESP-IDF 4.x and 5.0-5.4.
:white_check_mark: Tested and Working
  • ESP-IDF: 5.5.1 (also works with 4.x and 5.0-5.4)
  • ESPHome: 2024.11.0+
  • Hardware: M5Stack PaperS3 (ESP32-S3 with 4.7" e-paper display)
  • Home Assistant: Full integration via ESPHome text entities
:package: Repository
GitHub - Frogy76/epdiy · GitHub
:rocket: Quick Start Example
Here’s a minimal ESPHome configuration to get started:
esphome:
  libraries:
    - epidy=https://github.com/Frogy76/epdiy
external_components:
  - source: github://patrick3399/esphome_components
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    version: latest  # ESP-IDF 5.5.1 works!
psram:
  mode: octal
  speed: 80MHz
display:
  - platform: ed047tc1
    # M5Stack PaperS3 pin configuration
    pwr_pin: GPIO45
    bst_en_pin: GPIO46
    xstl_pin: GPIO13
    xle_pin: GPIO15
    spv_pin: GPIO17
    ckv_pin: GPIO18
    pclk_pin: GPIO16
    d0_pin: GPIO6
    d1_pin: GPIO14
    d2_pin: GPIO7
    d3_pin: GPIO12
    d4_pin: GPIO9
    d5_pin: GPIO11
    d6_pin: GPIO8
    d7_pin: GPIO10
    rotation: 90
    update_interval: never
    lambda: |-
      it.print(240, 50, id(my_font), TextAlign::CENTER, id(line1).state.c_str());
      it.print(240, 150, id(my_font), TextAlign::CENTER, id(line2).state.c_str());
font:
  - file: "gfonts://Roboto"
text:
    name: "Display Line 1"
    optimistic: true
    max_length: 30
    on_value:
      - component.update: epaper_display
    name: "Display Line 2"
    optimistic: true
    max_length: 30
    on_value:
:house: Control from Home Assistant
Once the device is added to Home Assistant, you can update the display using services:
Via UI:
  • Go to Developer Tools → Services
  • Select text.set_value
  • Choose entity: text.display_line_1
  • Enter your text
Via Automation:
service: text.set_value
  entity_id: text.display_line_1
  value: "Temperature: {{ states('sensor.living_room_temperature') }}°C"
Example Dashboard Card:
type: entities
entities:
  - entity: text.display_line_1
  - entity: text.display_line_2
title: E-Paper Display Control
:clipboard: Full Example
A complete working example with 12 text lines, touchscreen, battery monitoring, and RTC is available in the repository: papers3.yaml
:bullseye: Use Cases
  • Information Display: Weather, calendar, to-do lists
  • Sensor Dashboard: Room temperatures, energy usage
  • Notifications: Doorbell alerts, delivery notifications
  • Status Board: Home Assistant automation status
The e-paper display is perfect for low-power, always-visible information that doesn’t need frequent updates.
:light_bulb: Tips
  • Set update_interval: never and trigger updates manually via component.update
  • Use a system_initialized flag to prevent updates during boot
  • The display has excellent readability in bright light (no backlight)
  • Battery life is excellent due to e-paper’s ultra-low power consumption
Hope this helps anyone trying to use M5Stack PaperS3 with the latest ESPHome/ESP-IDF!
Followed your Quick Start Example and got the response:
INFO ESPHome 2025.11.0
INFO Reading configuration /config/esphome/display1.yaml…
INFO Unable to import component ed047tc1.display: No module named ‘esphome.components.ed047tc1’
Failed config
Platform not found: ‘display.ed047tc1’
You are missing:
Thanks I updated the Quick Start Example
Just wanted to say thanks for this, it got me started once I’d added the wifi credentials etc.
I am looking for an e-paper battery-powered device that can show a touchable HA dashboard (see pic). I went down the Kindle rabbit hole, and it was a fail because battery life would only last 24-36 hours… so long story short, is this epdiy fork what I am looking for? Will an M5Stack PaperS3 work on ESPHome as an interactive dashboard? Sorry if this is a stupid question, but I don’t want to buy any more stuff until I know it will work like I (kind of) want it to.
Thx
i get the following error during compiling:
src/esphome/components/ed047tc1/ed047tc1.cpp: In member function 'virtual void esphome::ed047tc1::ED047TC1Display::dump_config()':
src/esphome/components/ed047tc1/ed047tc1.cpp:208:58: error: 'get_pin_name' was not declared in this scope
  208 |         if (d_pins_[i] != nullptr && hasattr(d_pins_[i], get_pin_name)) {
src/esphome/components/ed047tc1/ed047tc1.cpp:208:38: error: 'hasattr' was not declared in this scope
In file included from src/esphome/core/component.h:9,
                 from src/esphome/components/ed047tc1/ed047tc1.h:3,
                 from src/esphome/components/ed047tc1/ed047tc1.cpp:1:
src/esphome/components/ed047tc1/ed047tc1.cpp:209:65: error: 'class esphome::GPIOPin' has no member named 'get_pin_name'
  209 |              ESP_LOGCONFIG(TAG, "  D%d Pin: %s", i, d_pins_[i]->get_pin_name().c_str());
src/esphome/core/log.h:98:101: note: in definition of macro 'esph_log_config'
   98 |   ::esphome::esp_log_printf_(ESPHOME_LOG_LEVEL_CONFIG, tag, __LINE__, ESPHOME_LOG_FORMAT(format), ##__VA_ARGS__)
src/esphome/components/ed047tc1/ed047tc1.cpp:209:14: note: in expansion of macro 'ESP_LOGCONFIG'
*** [.pioenvs/m5paper/src/esphome/components/ed047tc1/ed047tc1.cpp.o] Error 1
========================= [FAILED] Took 191.84 seconds =========================
yeah, unfortunately this seems to have stopped working. I get the same error messages :frowning:
I had the same Problem.
I´ve tried to compile with an older ESPHome Version (2025.8) and it worked.
Legacy ESPHome versions add-on
    for (int i=0; i<8; ++i) {
        #if ESPHOME_VERSION_CODE >= VERSION_CODE(2023, 1, 0)
        if (d_pins_[i] != nullptr) {
            ESP_LOGCONFIG(TAG, "  D%d Pin: Configured (Pin: %d)", i, esphome_pin_to_gpio_num(d_pins_[i]));
        } else { ESP_LOGCONFIG(TAG, "  D%d Pin: NONE", i); }
        #else
        ESP_LOGCONFIG(TAG, "  D%d Pin: %s", i, d_pins_[i] ? "Configured" : "NONE");
        #endif
as temp solution
I’m not getting compilation errors with ESPHome 2026.2.4, though after flashing and booting nothing seems to happen.
This is my config:
esphome:
  friendly_name: "M5 Paper S3 Dashboard"
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
  libraries:
  on_boot:
    then:
      - rtttl.play: 'siren:d=8,o=5,b=100:d,e,d,e,d,e,d,e'
      - delay: 5s
      - component.update: ed047tc1_display
      - lambda: |-
          id(system_initialized) = true;
esp32:
  flash_size: 16MB
  framework:
    type: esp-idf
    version: latest
    sdkconfig_options:
      CONFIG_EPD_OUTPUT_LUT_ASSEMBLY: "y"
      CONFIG_ESP32S3_INSTRUCTION_SET_AI_DSP: "y"
      CONFIG_ESP32S3_VECTOR_INSTRUCTIONS_SUPPORT: "y"
globals:
  - id: system_initialized
    type: bool
    restore_value: no
    initial_value: 'false'
psram:
  mode: octal
  speed: 80MHz
interval:
  - interval: 8s
    then:
      - light.turn_on: statled
      - delay: 1s
      - light.turn_off: statled
logger:
  level: DEBUG
  baud_rate: 0
  logs:
    api.service: WARN
    wifi: WARN
    esp-idf: NONE
    light: WARN
debug:
  update_interval: 10s
api:
  encryption:
    key: !secret api_key
  reboot_timeout: 6h
ota:
  - platform: esphome
    password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 6h
  #power_save_mode: LIGHT
  # - source: github://n-serrette/esphome_sd_card   #If need SD Card Support
i2c:
  sda: GPIO41
  scl: GPIO42
  scan: true
  frequency: 200kHz
# sd_mmc_card:  #If need SD Card Support
#   id: micro_sd
#   mode_1bit: true
#   clk_pin: GPIO7
#   cmd_pin: GPIO8
#   data0_pin: GPIO9
#   data3_pin: GPIO10
# sd_file_server:  #If need SD Card Support
#   id: file_server
#   url_prefix: file
#   root_path: "/"
#   enable_deletion: true
#   enable_download: true
#   enable_upload: true
touchscreen:
  platform: gt911
  interrupt_pin: GPIO48
  transform:
    mirror_x: true
    mirror_y: true
    swap_xy: false
  on_touch:
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
light:
  - platform: monochromatic
    output: gpio_0
    restore_mode: ALWAYS_OFF
    internal: True
    disabled_by_default: True
output:
  - platform: ledc
    pin: 21
  - platform: ledc
    pin: 0
    inverted: True
rtttl:
  output: rtttl_pin
  gain: 60%
text_sensor:
  - platform: debug
    device:
    reset_reason:
  - platform: debug
    free:
    block:
      name: "Heap Max Block"
    loop_time:
    psram:
  - platform: internal_temperature
  - platform: adc
    pin: GPIO3
    update_interval: 30s
    attenuation: 12db
    filters:
      - multiply: 2.0
  - platform: adc
    pin: GPIO5
    attenuation: 12db
    filters:
      - multiply: 2.0
  #- platform: bmi270
  #  address: 0x68
  #  accel_x:
  #    name: "BMI270 Accel X"
  #  accel_y:
  #    name: "BMI270 Accel Y"
  #  accel_z:
  #    name: "BMI270 Accel Z"
  #  gyro_x:
  #    name: "BMI270 Gyro X"
  #  gyro_y:
  #    name: "BMI270 Gyro Y"
  #  gyro_z:
  #    name: "BMI270 Gyro Z"
  #  temperature:
  #    name: "BMI270 Temperature"
  #  power_save_mode: LOW_POWER # OR NORMAL
  #  update_interval: 60s
    # Add new configuration options specific to BMI270 if needed
    # For example, accelerometer and gyroscope range selection:
    # accel_range: '8g' # Options: '2g', '4g', '8g', '16g' [cite: 5]
    # gyro_range: '2000dps' # Options: '125dps', '250dps', '500dps', '1000dps', '2000dps' [cite: 5]
  # - platform: sd_mmc_card  #If need SD Card Support
  #   type: used_space
  #   name: "SD card used space"
  #   type: total_space
  #   name: "SD card total space"
# text_sensor:
  #   sd_card_type:
  #     name: "SD card type"
binary_sensor:
  - platform: gpio
    pin:
      number: 4
      inverted: True
    device_class: battery_charging
time:
  - platform: pcf8563  #BM8563
    address: 0x51
    timezone: Asia/Taipei
  - platform: homeassistant
    update_interval: 1h
    on_time_sync:
      then:
        pcf8563.write_time:
display:
    pwr_pin: GPIO45
    bst_en_pin: GPIO46
    xstl_pin: GPIO13
    xle_pin: GPIO15
    spv_pin: GPIO17
    ckv_pin: GPIO18
    pclk_pin: GPIO16
    d0_pin: GPIO6
    d1_pin: GPIO14
    d2_pin: GPIO7
    d3_pin: GPIO12
    d4_pin: GPIO9
    d5_pin: GPIO11
    d6_pin: GPIO8
    d7_pin: GPIO10
    rotation: 90
    lambda: |-
       it.print(it.get_width() / 2, it.get_height() / 12 *1 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline01).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *2 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline02).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *3 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline03).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *4 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline04).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *5 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline05).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *6 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline06).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *7 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline07).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *8 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline08).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *9 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline09).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *10 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline10).state.c_str());
       it.print(it.get_width() / 2, it.get_height() / 12 *11 , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline11).state.c_str());
       it.print(it.get_width() / 2, it.get_height() , id(Roboto70), TextAlign::BOTTOM_CENTER, id(textline12).state.c_str());
font:
text:
    name: "Text Line 01"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 01'
    mode: text
    on_value:
      then:
        - if:
            condition:
              lambda: 'return id(system_initialized) == true;'
            then:
    name: "Text Line 02"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 02'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 03"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 03'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 04"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 04'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 05"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 05'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 06"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 06'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 07"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 07'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 08"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 08'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 09"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 09'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 10"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 10'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 11"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 11'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
    name: "Text Line 12"
    optimistic: true
    min_length: 0
    max_length: 26
    initial_value: 'TEXT 12'
    mode: text
    on_value:
      then:
        - if:
            condition:
            then:
And when I look at the logs and reset the device, this is as far as it gets:
[15:12:36]ESP-ROM:esp32s3-20210327
[15:12:36]Build:Mar 27 2021
[15:12:36]rst:0x15 (USB_UART_CHIP_RESET),boot:0x8 (SPI_FAST_FLASH_BOOT)
[15:12:36]Saved PC:0x40377ef2
[15:12:36]SPIWP:0xee
[15:12:36]mode:DIO, clock div:1
[15:12:36]load:0x3fce2820,len:0x158c
[15:12:36]load:0x403c8700,len:0xd24
[15:12:36]load:0x403cb700,len:0x2f28
[15:12:36]entry 0x403c891c
[15:12:36]I (24) boot: ESP-IDF 5.5.2 2nd stage bootloader
[15:12:36]I (24) boot: compile time Mar 10 2026 13:12:56
[15:12:36]I (25) boot: Multicore bootloader
[15:12:36]I (25) boot: chip revision: v0.2
[15:12:36]I (27) boot: efuse block revision: v1.3
[15:12:36]I (31) boot.esp32s3: Boot SPI Speed : 80MHz
[15:12:36]I (35) boot.esp32s3: SPI Mode       : DIO
[15:12:36]I (39) boot.esp32s3: SPI Flash Size : 4MB
[15:12:36]I (42) boot: Enabling RNG early entropy source...
[15:12:36]I (47) boot: Partition Table:
[15:12:36]I (49) boot: ## Label            Usage          Type ST Offset   Length
[15:12:36]I (56) boot:  0 otadata          OTA data         01 00 00009000 00002000
[15:12:36]I (62) boot:  1 phy_init         RF data          01 01 0000b000 00001000
[15:12:36]I (69) boot:  2 app0             OTA app          00 10 00010000 001c0000
[15:12:36]I (75) boot:  3 app1             OTA app          00 11 001d0000 001c0000
[15:12:36]I (82) boot:  4 nvs              WiFi data        01 02 00390000 0006d000
[15:12:36]I (88) boot: End of partition table
[15:12:36]I (92) esp_image: segment 0: paddr=00010020 vaddr=3c030020 size=1a7f8h (108536) map
[15:12:36]I (118) esp_image: segment 1: paddr=0002a820 vaddr=3fc90300 size=02e44h ( 11844) load
[15:12:36]I (121) esp_image: segment 2: paddr=0002d66c vaddr=40374000 size=029ach ( 10668) load
[15:12:36]I (125) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=2321ch (143900) map
[15:12:36]I (155) esp_image: segment 4: paddr=00053244 vaddr=403769ac size=09878h ( 39032) load
[15:12:36]I (164) esp_image: segment 5: paddr=0005cac4 vaddr=50000000 size=00020h (    32) load
[15:12:36]I (170) boot: Loaded app from partition at offset 0x10000
[15:12:36]I (170) boot: Disabling RNG early entropy source...
The screen is totally blank
Okay scratch that! I guess my device wasn’t powered down or something? Just turned it on today after leaving for 24hrs and it booted straight up, played the little song, and is showing all 12 text lines!
Your readme mentions support for other displays such as the ED133UT2, but I’m unable to compile it with errors such as Platform not found: 'display.ed133ut2'. Do you have any examples for other displays just use the epdiy v7 without a touchscreen, etc?
