I purchased one of these ESP32 Touchscreens to put a small display in a few rooms. I’ve used ESPHome for several small devices but this is my first venture into using a display with ESPHome.
So I’ve borrowed some code from examples I found and have the device setup with a basic configuration that seems to mostly work except I can’t get anything to print on the screen. The backlight comes on after boot and the “auto on-dim-off” script works when the screen is tapped. Able to toggle the LED on the back. The touch screen calibration works.
This seems to be the spec sheet for the part number (ESP32-2432S028) printed on the device. Pretty sure I have the pin assignments correct based on the IO Table .
But instead of a friendly “Hello World” greeting, I just get this.
Am I missing something or do I possibly have a bad display?
Debug log included below the code.
substitutions:
friendly_name: bedroom-display
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
project:
version: dev
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
logs:
component: ERROR
# Enable Home Assistant API
api:
encryption:
key: !secret haapi_key
# Allow Over-The-Air updates
ota:
- platform: esphome
password: !secret ota_password
# Allow provisioning Wi-Fi via serial
improv_serial:
#improv_serial:
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 10.0.0.135
gateway: 10.0.0.1
subnet: 255.255.255.0
dns1: 75.75.75.75
dns2: 75.75.76.76
fast_connect: off
ap:
ssid: "Bedroom Display"
password: !secret ap_password
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
# captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
# esp32_improv:
# authorizer: none
# To have a "next url" for improv serial
web_server:
time:
- platform: homeassistant
spi:
- id: lcd
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
- id: touch
clk_pin: GPIO25
mosi_pin: GPIO32
miso_pin: GPIO39
i2c:
sda: GPIO27
scl: GPIO22
scan: true
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_blue
red: 0%
green: 0%
blue: 100%
- id: my_gray
red: 50%
green: 50%
blue: 50%
- id: my_orange
red: 100%
green: 50%
blue: 0%
- id: my_teal
red: 0%
green: 100%
blue: 100%
- id: my_white
red: 100%
green: 100%
blue: 100%
- id: my_black
red: 0%
green: 0%
blue: 0%
#Font declaration
font:
- file: 'gfonts://Roboto'
display:
- platform: ili9xxx
model: ili9341
spi_id: lcd
dc_pin: GPIO02
lambda: |-
it.print(0, 0, id(roboto_20), id(my_black), "Hello World");
# Define pins for backlight display and rear LED
output:
- platform: ledc
pin: GPIO21
- platform: ledc
pin: GPIO4
inverted: true
- platform: ledc
pin: GPIO16
inverted: true
- platform: ledc
pin: GPIO17
inverted: true
# speaker P4
# - platform: ledc
# pin: GPIO26
# id: rtttl_out
# Define a monochromatic, dimmable light for the backlight
light:
- platform: monochromatic
output: backlight
name: "Display Backlight"
restore_mode: ALWAYS_ON
- platform: rgb
red: output_red
green: output_green
blue: output_blue
restore_mode: ALWAYS_OFF
touchscreen:
platform: xpt2046
spi_id: touch
cs_pin: 33
interrupt_pin: 36
update_interval: 50ms
# report_interval: 1s
threshold: 400
calibration:
x_min: 288
x_max: 3779
y_min: 193
y_max: 3647
on_touch:
- script.stop: backlight_timer
- script.execute: backlight_timer
#Uncomment for calibrations
# - lambda: |-
# ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
# touch.x,
# touch.y,
# touch.x_raw,
# touch.y_raw
#This is the script for turn off the backlight after some seconds of inactivity
script:
then:
- light.turn_on:
brightness: 100%
- delay: 5s
- light.turn_on:
brightness: 50%
- delay: 10s
- light.turn_off: back_light
INFO Upload took 9.33 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from xxx using esphome API
INFO Successfully connected to bedroom-display @ xxx in 7.184s
INFO Successful handshake with bedroom-display @ xxx in 0.099s
[13:29:24][I][app:100]: ESPHome version 2024.8.3 compiled on Sep 14 2024, 13:28:41
[13:29:24][I][app:102]: Project esphome.web version dev
[13:29:24][C][wifi:600]: WiFi:
[13:29:24][C][wifi:428]: Local MAC: xxx
[13:29:24][C][wifi:433]: SSID: xxx
[13:29:24][C][wifi:436]: IP Address: xxx
[13:29:24][C][wifi:440]: BSSID: xxx
[13:29:24][C][wifi:441]: Hostname: 'bedroom-display'
[13:29:24][C][wifi:443]: Signal strength: -29 dB ▂▄▆█
[13:29:24][C][wifi:447]: Channel: 11
[13:29:24][C][wifi:448]: Subnet: 255.255.255.0
[13:29:24][C][wifi:449]: Gateway: xxx
[13:29:24][C][wifi:450]: DNS1: 75.75.75.75
[13:29:24][C][wifi:451]: DNS2: 75.75.76.76
[13:29:24][C][logger:185]: Logger:
[13:29:24][C][logger:186]: Level: DEBUG
[13:29:24][C][logger:188]: Log Baud Rate: 115200
[13:29:24][C][logger:189]: Hardware UART: UART0
[13:29:24][C][logger:193]: Level for 'component': ERROR
[13:29:24][C][spi:064]: SPI bus:
[13:29:24][C][spi:065]: CLK Pin: GPIO14
[13:29:24][C][spi:066]: SDI Pin: GPIO12
[13:29:24][C][spi:067]: SDO Pin: GPIO13
[13:29:24][C][spi:072]: Using HW SPI: SPI
[13:29:24][C][spi:065]: CLK Pin: GPIO25
[13:29:24][C][spi:066]: SDI Pin: GPIO39
[13:29:24][C][spi:067]: SDO Pin: GPIO32
[13:29:24][C][spi:072]: Using HW SPI: HSPI
[13:29:24][C][i2c.arduino:071]: I2C Bus:
[13:29:24][C][i2c.arduino:072]: SDA Pin: GPIO27
[13:29:24][C][i2c.arduino:073]: SCL Pin: GPIO22
[13:29:24][C][i2c.arduino:074]: Frequency: 50000 Hz
[13:29:24][C][i2c.arduino:086]: Recovery: bus successfully recovered
[13:29:24][I][i2c.arduino:096]: Results from i2c bus scan:
[13:29:24][I][i2c.arduino:098]: Found no i2c devices!
[13:29:24][C][ili9xxx:094]: ili9xxx
[13:29:24][C][ili9xxx:094]: Rotations: 0 °
[13:29:24][C][ili9xxx:094]: Dimensions: 240px x 320px
[13:29:24][C][ili9xxx:095]: Width Offset: 0
[13:29:24][C][ili9xxx:096]: Height Offset: 0
[13:29:24][C][ili9xxx:105]: Color mode: 8bit 332 mode
[13:29:24][C][ili9xxx:111]: Data rate: 40MHz
[13:29:24][C][ili9xxx:115]: DC Pin: GPIO2
[13:29:24][C][ili9xxx:117]: Color order: BGR
[13:29:24][C][ili9xxx:118]: Swap_xy: NO
[13:29:24][C][ili9xxx:119]: Mirror_x: YES
[13:29:24][C][ili9xxx:120]: Mirror_y: NO
[13:29:24][C][ili9xxx:125]: Update Interval: 1.0s
[13:29:24][C][ledc.output:176]: LEDC Output:
[13:29:24][C][ledc.output:177]: Pin GPIO21
[13:29:24][C][ledc.output:178]: LEDC Channel: 0
[13:29:24][C][ledc.output:179]: PWM Frequency: 1000.0 Hz
[13:29:24][C][ledc.output:180]: Phase angle: 0.0°
[13:29:24][C][ledc.output:181]: Bit depth: 16
[13:29:24][C][ledc.output:177]: Pin GPIO4
[13:29:24][C][ledc.output:178]: LEDC Channel: 1
[13:29:24][C][ledc.output:177]: Pin GPIO16
[13:29:24][C][ledc.output:178]: LEDC Channel: 2
[13:29:24][C][ledc.output:177]: Pin GPIO17
[13:29:24][C][ledc.output:178]: LEDC Channel: 3
[13:29:24][C][light:103]: Light 'Display Backlight'
[13:29:24][C][light:105]: Default Transition Length: 1.0s
[13:29:24][C][light:106]: Gamma Correct: 2.80
[13:29:24][C][light:103]: Light 'LED'
[13:29:24][C][homeassistant.time:010]: Home Assistant Time:
[13:29:25][C][homeassistant.time:011]: Timezone: 'MST7MDT,M3.2.0,M11.1.0'
[13:29:25][C][xpt2046:062]: XPT2046:
[13:29:25][C][xpt2046:064]: IRQ Pin: GPIO36
[13:29:25][C][xpt2046:065]: X min: 288
[13:29:25][C][xpt2046:066]: X max: 3779
[13:29:25][C][xpt2046:067]: Y min: 193
[13:29:25][C][xpt2046:068]: Y max: 3647
[13:29:25][C][xpt2046:070]: Swap X/Y: NO
[13:29:25][C][xpt2046:071]: Invert X: NO
[13:29:25][C][xpt2046:072]: Invert Y: NO
[13:29:25][C][xpt2046:074]: threshold: 400
[13:29:25][C][xpt2046:076]: Update Interval: 0.050s
[13:29:25][C][psram:020]: PSRAM:
[13:29:25][C][psram:021]: Available: NO
[13:29:25][C][web_server:145]: Web Server:
[13:29:25][C][web_server:146]: Address: xxx
[13:29:25][C][mdns:116]: mDNS:
[13:29:25][C][mdns:117]: Hostname: bedroom-display
[13:29:25][C][esphome.ota:073]: Over-The-Air updates:
[13:29:25][C][esphome.ota:074]: Address: xxx
[13:29:25][C][esphome.ota:075]: Version: 2
[13:29:25][C][esphome.ota:078]: Password configured
[13:29:25][C][safe_mode:018]: Safe Mode:
[13:29:25][C][safe_mode:020]: Boot considered successful after 60 seconds
[13:29:25][C][safe_mode:021]: Invoke after 10 boot attempts
[13:29:25][C][safe_mode:023]: Remain in safe mode for 300 seconds
[13:29:25][C][api:139]: API Server:
[13:29:25][C][api:140]: Address: xxx
[13:29:25][C][api:142]: Using noise encryption: YES
[13:29:25][C][improv_serial:032]: Improv Serial:
[13:29:25][D][api:102]: Accepted xxx
[13:29:25][D][api.connection:1389]: Home Assistant 2024.9.1 (10.0.0.239): Connected successfully
[13:29:25][D][time:051]: Synchronized time: 2024-09-14 13:29:25
[13:30:16][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[13:30:16][D][esp32.preferences:114]: Saving 1 preferences to flash...
[13:30:16][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
