The esp8266 is on the network but I’m not able to upload to it wirelessly. I’m brand new to this so anything stand out as possibly being an issue? I’m also using Home Assistant 6.1 and I can ping the device.
Here is my error:
========================= [SUCCESS] Took 7.28 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.86.95
ERROR Connecting to 192.168.86.95:8266 failed: timed out
Here is its yaml:
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "bdbc98dadee61a2b746c1912707f2f79"
wifi:
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.86.95
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.86.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
ssid: "...searching"
ap:
ssid: "Esp8266 Fallback Hotspot"
password: "qkI6NJ7RnnYa"
captive_portal:
Until you plug it in and flash it manually, you cannot flash wirelessly. This board had no built-in intelligence really, lots of capability, but comes with 4M of emptieness.
That’s what I would have thought. It gives me those types of options when I’m trying to Install the .yaml file on the device. Though I’m not able to upload to the device using the top 3 options. I have to manually download then use a flashing program to update the device.
Hi dhust. Welcome to the community.
I’ve only been here a few weeks myself.
The NodeMCU devices are my favourite IoT
First, please re-upload your code with these extras on the end.
This will help rule out a few things.
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
api:
ota:
wifi:
manual_ip:
ap:
captive_portal:
status_led:
pin:
number: GPIO2
inverted: yes
switch:
- platform: gpio
pin: 5
inverted: false
status_led, we can get some visual information via that blue built in LED on your 8266.
Once you’ve uploaded this, the indicator will now flash while its trying to connect to HA. It will eventually stop once it has achieved this.
go into overview, add a button, and add the entity ‘switch.dhust_output’ to it.
Even though you won’t see anything, just check that you can switch it off and on.
If that’s all good, please tell me what message your getting when you try to upload ota when clicking “Plug into the computer running ESPHome dashboard” ?
