Having a lot of devices in esphome. When using the “update all” button I would like to be able to have a selector per device to be excluded from these auto updates.
I have some devices which “break” when they are updated to a newer version of esphome and I would like them to be excluded form auto updating.
Would be great, I do have the same “problem”. ESPHome can’t compile all devices on ARM.
I do have one device, with need’s compiled at a x86 cpu. I’d like / need to exclude this device.
Stop updating.
The devices work and they are on your local network and have no need for internet.
So why update them?
It’s s most likely not a security patch since they don’t have internet access.
(Or you could block them from internet on the router)
The only time I update is if I need to make a change on the device, but if I had the option to compile on the same version it’s already on then I would do that.
I’d rather have an option to “ignore all updates” for a device. Currently devices I don’t want to update, like the WLED-reactive devices, constantly come up after every update. Other devices, like the Unifi wifi, I’d rather update at a certain time etc. That might be another feature request, actually, to auto-update at certain times. Might be feasible with automation. In any case, I’m going off, the feature “ignore all updates” please
There is ota: component in ESPHome for over the air updates. By default ota: is included in every code. I assume, if I comment out #ota, updates will not work?
Never tested it.
Sorry, you are right, it’s button.
Do you mean, I can disable update.esphome_update, but this way I disable update for ESPHome addon, for all my ESP devices?
I need to keep only esp32-1-wire device not updated. All other my ESPHome devices must update when available.
