ESPHome and BME680: strange VOC values
Dear community,
yesterday, I have implemented a ESP32 with a BME680 to measure the air quality in our living room.
The sensor is providing data: temperature and humidity seem to be in an expected range, but the VOCs are just way off.
I do have to old Airthings Wave Plus devices: one in the basement, one in the second floor.
I can see the radon coming from the basement to the second floor. there is a correlation between values in the basement and in the second floor. So there is an airflow going upward through the house
VOCs in the basement are very low, VOCs in the second floor jump up and down. (50 - 1100 ppb)
The newly BME680 is running for almost 12h and VOC values are way to high. If this was true, the sensor in the second floor (screenshot red) would be much higher.
Question: who has experience with this sensor? Is this expected behaviour? How long does the calibration period take? (BME680 Numeric IAQ Accuracy is switching between 2 and 3.)
Any help is very much appreciated.
ESPHome yaml
# sources:
  # https://esphome.io/components/sensor/airthings_ble
  # https://esphome.io/components/sensor/bme680_bsec.html
# Variablen
substitutions:
  device_name: "esphome-wohnzimmer2"
  friendly_name: "Wohnzimmer2"
  node_name: "esphome_wohnzimmer2"
  device_description: "Sensor liest den Airthings Wave Plus Sensor im Keller via Bluetooth aus und liefert Daten ĂŒber den BME680"
# ESPHome Core Configuration
esphome:
  friendly_name: '${friendly_name}'
  comment: '${device_description}'
  # Loop, der nach erfolgreicher WLAN-Verbindung und Zeitabfrage ausgefĂŒhrt wird
  on_boot:
    priority: -100  # Setze die PrioritĂ€t niedriger als die WLAN-Verbindung (standardmĂ€ĂŸig -10)
    then:
      - while:
          condition:
            not:
              lambda: 'return id(homeassistant_time).now().is_valid();'
          then:
            - delay: 1s # Warte eine Sekunde, bevor erneut ĂŒberprĂŒft wird
      - lambda: |-
          // Sobald die Zeit verfĂŒgbar ist, berechne den Boot-Zeitpunkt
          id(${node_name}_last_boot_time).publish_state(
            id(homeassistant_time).now().timestamp - (int) id(${node_name}_uptime_seconds).state
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
# Airthings Wave Plus finden
esp32_ble_tracker:
# airthings_ble:
# Enable Home Assistant API
api:
  encryption:
    key: "j...x"
ota:
  - platform: esphome
    password: "e7....1c"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: 192.168.30.26
    # Set this to the IP address of the router. Often ends with .1
    gateway: 192.168.30.1
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: 255.255.255.0
  use_address: ${node_name}.internal
  domain: .internal
  ap:
    ssid: '${device_name}'
    password: "Bf...6"
captive_portal:
# Zeit von HomeAssistant abfragen -> fĂŒr Last Boot nötig
time:
  - platform: homeassistant
switch:
  - platform: restart
    name: "ESPHome '${friendly_name}' neu starten"
# Airthings Wave Plus einbinden
ble_client:
  - mac_address: A4:DA:32:B9:5A:A5
# i2c-config fĂŒr BME680-Sensor
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: false
bme680_bsec:
  address: 0x77
  temperature_offset: 0
  iaq_mode: static
  supply_voltage: 3.3V
  sample_rate: ulp
  state_save_interval: 6h
  # Airthings Wave Plus Keller
  - platform: airthings_wave_plus
    ble_client_id: awp_Keller
    update_interval: 5min # default
    battery_update_interval: 24h # default
    temperature:
      name: "Keller Temperatur"
    radon:
    radon_long_term:
      name: "Keller Radon Long Term"
    pressure:
      name: "Keller Luftdruck"
    humidity:
      name: "Keller Feuchtigkeit"
    co2:
    tvoc:
    illuminance:
      name: "Keller ambient light"
    battery_voltage:
      name: "Keller Batterie Spannung"
  # Airthings Wave Plus Keller: Batterieanzeige in %
  - platform: copy
    source_id: awp_Keller_volt
    name: 'Keller Battery Level'
    unit_of_measurement: "%"
    device_class: battery
    accuracy_decimals: 0
    filters:
      - calibrate_linear:
        - 2.2 -> 0
        - 3.1 -> 100
# Airthings Wave Plus Keller: Taupunkt berechnen
    name: "Keller Taupunkt"
    lambda: |-
      return (243.5*(log(id(awp_Keller_humidity).state/100)+((17.67*id(awp_Keller_temp).state)/
      (243.5+id(awp_Keller_temp).state)))/(17.67-log(id(awp_Keller_humidity).state/100)-
      ((17.67*id(awp_Keller_temp).state)/(243.5+id(awp_Keller_temp).state))));
    device_class: temperature
    state_class: measurement
    unit_of_measurement: °C
    icon: 'mdi:thermometer-water'
# Example configuration entry for BME680
#  - platform: bme680
#    temperature:
#      name: "BME680 Temperature"
#    pressure:
#      name: "BME680 Pressure"
#    humidity:
#      id: "humidity"
#      name: "BME680 Humidity"
#    gas_resistance:
#      id: "gas_resistance"
#      name: "BME680 Gas Resistance"
#    i2c_id: bus_a
#    address: 0x77
#    update_interval: 60s
#  - platform: template
#    name: "BME680 Indoor Air Quality"
#    id: iaq
#    icon: "mdi:gauge"
#    # calculation: comp_gas = log(R_gas[ohm]) + 0.04 log(Ohm)/%rh * hum[%rh]
#    lambda: |-
#      return log(id(gas_resistance).state) + 0.04 *  id(humidity).state;
#    state_class: "measurement"
  - platform: bme680_bsec
    # ID of the bme680_bsec component to use for the next sensors.
    # Useful when working with multiple devices
    bme680_bsec_id: bme680_internal
    temperature:
      # Temperature in °C
      filters:
        - median:
            window_size: 5
            send_every: 1
            send_first_at: 1
    pressure:
      # Pressure in hPa
      sample_rate: ulp
      filters:
        - median:
            window_size: 5
            send_every: 1
            send_first_at: 1
    humidity:
      # Relative humidity %
      sample_rate: ulp
      filters:
        - median:
            window_size: 5
            send_every: 1
            send_first_at: 1
    gas_resistance:
      # Gas resistance in Ω
      filters:
        - median:
            window_size: 5
            send_every: 1
            send_first_at: 1
    iaq:
      # Indoor air quality value
      filters:
        - median:
            window_size: 5
            send_every: 1
            send_first_at: 1
    iaq_accuracy:
      # IAQ accuracy as a numeric value of 0, 1, 2, 3
      name: "BME680 Numeric IAQ Accuracy"
    co2_equivalent:
      # CO2 equivalent estimate in ppm
      name: "BME680 CO2 Equivalent"
      filters:
        - median:
            window_size: 5
            send_every: 1
            send_first_at: 1
    breath_voc_equivalent:
      # Volatile organic compounds equivalent estimate in ppm
      name: "BME680 Breath VOC Equivalent Source"
      internal: true
      filters:
        - median:
            window_size: 5
            send_every: 1
            send_first_at: 1
    name: "BME680 Breath VOC Equivalent"
    lambda: |-
      return ( (id(voc_source).state) * 1000) ;
    device_class: volatile_organic_compounds_parts
    unit_of_measurement: ppb
    icon: 'mdi:molecule'
  # Last Boot Sensor definieren (Berechnung findet einmalig beim Boot statt)
  - platform: uptime
    name: "Uptime Sekunden"
    internal: true
    device_class: timestamp
    entity_category: diagnostic
    update_interval: never # Kein regelmĂ€ĂŸiges Update nötig
text_sensor:
  # Air Quality-Angaben
    name: "BME680 IAQ Classification"
    icon: "mdi:checkbox-marked-circle-outline"
    lambda: |-
      if (int(id(iaq).state) <= 50) {
        return {"Excellent"};
      else if (int(id(iaq).state) <= 100) {
        return {"Good"};
      else if (int(id(iaq).state) <= 150) {
        return {"Lightly polluted"};
      else if (int(id(iaq).state) <= 200) {
        return {"Moderately polluted"};
      else if (int(id(iaq).state) <= 250) {
        return {"Heavily polluted"};
      else if (int(id(iaq).state) <= 350) {
        return {"Severely polluted"};
      else if (int(id(iaq).state) <= 500) {
        return {"Extremely polluted"};
      else {
        return {"unknown"};
  # Send IP Address of ESP-device
  - platform: wifi_info
    ip_address:
    iaq_accuracy:
      # IAQ accuracy as a text value of Stabilizing, Uncertain, Calibrating, Calibrated
      name: "BME680 IAQ Accuracy"
EDIT
I have put the sensor in a freshly printed case (PLA). I have read that PLA emits VOCs during printing, but I found no information about emiting VOCs afterwards as well?
EDIT2
AFAIK, there should be a correlation between gas resistance and VOC-values?
I have gone back to the documentation and have realised that ESPhome recommends to use this:
So I did.
I am still very disappointed by this sensor. VOC-values are still x-times to high - although not jumping around anymore - and temperature is 7°C too high.
The temperature offset is configurable, but the VOCs are not - AFAIK.
Has anybody the same experiences? Is there someone, who can explain, how to properly configure this sensor? Any help is very much appreciate.
new ESPhome yaml
# sources:
  # https://esphome.io/components/sensor/bme68x_bsec2.html
# Variablen
substitutions:
esphome:
  on_boot:
    then:
      - while:
          condition:
            not:
          then:
      - lambda: |-
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
esp32_ble_tracker:
# airthings_ble:
api:
  encryption:
    key: "xxx"
ota:
  - platform: esphome
    password: "xxx"
wifi:
  manual_ip:
  domain: .internal
  ap:
    password: "xxx"
captive_portal:
time:
switch:
  - platform: restart
ble_client:
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: false
bme68x_bsec2_i2c:
  address: 0x77
  model: bme680
  operating_age: 28d
  sample_rate: ULP
    temperature:
    radon:
    radon_long_term:
    pressure:
    humidity:
    co2:
    tvoc:
    illuminance:
    battery_voltage:
  - platform: copy
    filters:
      - calibrate_linear:
        - 2.2 -> 0
        - 3.1 -> 100
    lambda: |-
  # Konfiguration fĂŒr BME680 Sensor
  - platform: bme68x_bsec2
    temperature:
    pressure:
    humidity:
    iaq:
    co2_equivalent:
      name: "BME680 Breath VOC Equivalent original"
      internal: false
    lambda: |-
  - platform: uptime
    internal: true
text_sensor:
    iaq_accuracy:
    lambda: |-
      if ( int(id(iaq).state) <= 50) {
      else if (int(id(iaq).state) >= 51 && int(id(iaq).state) <= 100) {
        return {"Good"};
      else if (int(id(iaq).state) >= 101 && int(id(iaq).state) <= 150) {
      else if (int(id(iaq).state) >= 151 && int(id(iaq).state) <= 200) {
      else if (int(id(iaq).state) >= 201 && int(id(iaq).state) <= 250) {
      else if (int(id(iaq).state) >= 251 && int(id(iaq).state) <= 350) {
      else if (int(id(iaq).state) >= 351) {
      else {
        return {"error"};
    ip_address:
That’s a lot
 Do you have it inside an enclosure?
It could mess up temperature compensation for other values as well.
You will never find two VOC-sensors that output same value. Also CO2 equivalent will never be like true NDIR sensor output, because it’s just an estimation based on VOCs.
Hi @Karosm,
thank you for your reply.
Yes, I have designed my own case. I just opened it up to improve ventilation - but doesn’t seem to change anything.
Well, I am aware that sensors are not at all an exact thing - well, at least in that price segment. But I was expecting something comparable? My goal is to define a template, indicating when opening the windows would be a good idea. (logic based on air quality, radon, temperature, dew point (indoor vs. outdoor))
For temp, RH and pressure yes. For VOC no.
But for your use case it’s enough to detect relative values and that’s IAQ should give you.
But until you find out why temp is off so much, I wouldn’t trust that sensor.
Well, I assume, the temperature is too high, because the gas resistance sensor heats up to do his measurement. I could try to force the sensor to take values at different times, and average them with a filter.
Do you know, what happens, if I configure the temperature offset for the BME680? (There is a configuration variable on top level of the sensor.) Will this affect only temperature or all sensor value calculation, such as VOC and CO2?
As said VOC sensors will give you a relative value.
What you can do is try to make a translation table between your VOC sensors.
Place them side by side to each other. Run a couple of days and compare the graphs.
Then switch their places around and do it again.
Next put them on top of each other and do it again.
Then switch them around here too and do it again.
I found some posts indicating that the temperature offset will have an influence on the other values as well. The BSEC-library should do the calculation, but I haven’t had the time to properly test it.
Unfortunately, I was not able to find the source on the bosch website to support this.
Thank you for the proposal. Well, I decided to focus on the IAQ-values. That should - in theory - be sufficient for my use case.
But if I compare the IAQ-value from the BME680 to my AirthingsWave Plus, the BME680 indicates “moderately polluted” (IAQ of 160, just after closing the windows), where as the Airthings sensor provides an all green state. (Outside air quality here in Switzerland is usually very very good, so I tend to believe the Airthings
 :slight_smile:)
In the end, they both should tell me to open the windows at the same sate of indoor air quality.
I will do some more research and try to find a way to get rid off the temperature differences. Might even re-design my casing.
EDIT: is there a cheap and exact CO2-sensor? If VOC-sensors are just useless, exact CO2-values would be a feasible work around
Not really, good NDIR sensors are expensive. But compared to VOC sensors Co2 equivalent even the cheapest one are way better.
Senseair S8, MH-Z19, SCD40
any recommendations?
btw: someone has had the same issue and opened up a github issue
Not really, depends on price/availability. Also SCD in aliexpress cost 1/3 compared to other markets, so I expect those to be something else than (first grade) products form Sensirion.
How are the temp values with bme680 component?
I just used the old BME680 component. This is running now for 10min and temperature readings and humidity seems to be fine. IAQ seems to be a bit low.
There is one thing unclear to me in the documentation: the calculation of the IAQ.
There is this example provided:
The actual calculation (-> lambda) is then a bit different:
    icon: "mdi:gauge"
    lambda: |-
Source: BME680 Temperature+Pressure+Humidity+Gas Sensor — ESPHome
What is correct?
That’s good. Maybe your sensor is ok.
I don’t know. I don’t care. Consider it as a relative output. Compare values after few hours of open windows to few days of closed.
Well, if the math is wrong, there is probably not the intended output?
I will keep it running for a couple of days and then reconsider my strategy/choosing of a different sensor. :slight_smile:
I’m trying to say, there is not wrong or right. There is no formula based on math or physics to give right output. There are different VOC sensors measuring several (different) gases different way and there are different formulas to give some output. Take it like this: output 1 or 10 doesn’t matter. But 2 is twice as 1 and 20 is twice as 10.
Turns out, there was a bug in the BME68x component. After installing the newest version, VOC readings got more stable and IAQ seems to make sense. I decided to follow your recommendation and focus on the IAQ-values and not too much an VOC and CO2 values.
I have been having an issue with one of my BME680s
 the other has been running for months without issue. This one I just brought up in the last couple days
 it can be fine for hours, then all of a sudden it just spikes immediately and doesn’t come down unless i reboot it
[17:15:34.103][D][sensor:133]: ‘IAQ’: Sending state 141.27470 IAQ with 0 decimals of accuracy
[17:15:34.115][D][light:091]: ‘Onboard RGB LED’ Setting:
[17:15:34.133][D][light:079]: Brightness: 55%
[17:15:34.149][D][light:115]: Red: 17%, Green: 100%, Blue: 0%
[17:15:34.164][D][light:142]: Transition length: 1.0s
[17:15:34.230][D][sensor:133]: ‘IAQ Static’: Sending state 147.82269 IAQ with 0 decimals of accuracy
[17:15:34.249][D][sensor:133]: ‘CO2 Equivalent’: Sending state 1478.22693 ppm with 1 decimals of accuracy
[17:15:34.265][D][sensor:133]: ‘Breath VOC Equivalent’: Sending state 4.59491 ppm with 1 decimals of accuracy
[17:15:34.280][D][sensor:133]: ‘Pressure’: Sending state 977.91998 hPa with 1 decimals of accuracy
[17:15:34.330][D][sensor:133]: ‘Gas Resistance’: Sending state 72998.74219 Ω with 0 decimals of accuracy
[17:15:34.346][D][sensor:133]: ‘Temperature’: Sending state 2.49985 °C with 1 decimals of accuracy
[17:15:34.363][D][sensor:133]: ‘Humidity’: Sending state 46.33840 % with 1 decimals of accuracy
[17:15:37.129][D][sensor:133]: ‘IAQ’: Sending state 368.35410 IAQ with 0 decimals of accuracy
[17:15:37.160][D][light:091]: ‘Onboard RGB LED’ Setting:
[17:15:37.204][D][light:079]: Brightness: 80%
[17:15:37.233][D][light:115]: Red: 100%, Green: 0%, Blue: 0%
[17:15:37.246][D][light:142]: Transition length: 1.0s
[17:15:37.269][D][sensor:133]: ‘IAQ Static’: Sending state 392.13330 IAQ with 0 decimals of accuracy
[17:15:37.283][D][sensor:133]: ‘CO2 Equivalent’: Sending state 3921.33301 ppm with 1 decimals of accuracy
[17:15:37.323][D][sensor:133]: ‘Breath VOC Equivalent’: Sending state 1000.00000 ppm with 1 decimals of accuracy
[17:15:37.341][D][sensor:133]: ‘Pressure’: Sending state 977.92682 hPa with 1 decimals of accuracy
[17:15:37.373][D][sensor:133]: ‘Gas Resistance’: Sending state 74492.11719 Ω with 0 decimals of accuracy
[17:15:37.390][D][sensor:133]: ‘Temperature’: Sending state 2.47707 °C with 1 decimals of accuracy
[17:15:37.416][D][sensor:133]: ‘Humidity’: Sending state 46.16291 % with 1 decimals of accuracy
[17:15:37.431][D][sensor:133]: ‘IAQ Accuracy’: Sending state 2.00000 with 0 decimals of accuracy
has anyone come across an issue like this?
the spike is in co2 (1478 ->3921), but the breath voc jumps randomly to like 1000ppm.
This sensor is in my garage, so don’t worry
 these readings are not inside.
