Hi All,
I would like to share my knowledge regarding Daly BMS that have UART functionality to be integrated using ESP base board (NodeMCU) to Home Assistant.
List of guide and links that I use to make it happen. Credit to them!
For starters, below is the list of items that needed:
Daly BMS (with UART) sometimes they share it with Bluetooth port
ESP base board (I’m using NodeMCU ESP32)
PH2.0 Mini Micro JST 2.0 Connector (The connector may vary base on BMS model)
Wiring
Cut the dupont Male connector
Strip the cable and plug into the Wire Connector
- Base on the guide, we need to plug the RX, TX, 3.3V and GND, but in my case i just need RX, TX and GND. I have issues when connecting the 3.3V it wont boot. My NodeMCU ESP32 will be powered from the standard Micro USB.
- For extra precautions, i did a continuity test using my multi-meter end to end of the wiring. This should be compulsory for those who have a multi-meter.
ESPHome Configuration
- Below is the yaml config file for my setup. Do note that this is for NodeMCU ESP32. You may refer to ESPHome Daly BMS for ESP8266
#General
esphome:
esp32:
board: nodemcu-32s
#Logging
logger:
level: DEBUG
baud_rate: 0
#Network
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 172.16.0.14
gateway: 172.16.0.1
subnet: 255.255.255.128
ap:
ssid: "Esp-Demo Fallback Hotspot"
password: "11sOsn77e2G1"
#Sensor
- platform: daly_bms
voltage:
current:
battery_level:
max_cell_voltage:
name: "Max Cell Voltage"
max_cell_voltage_number:
name: "Max Cell Voltage Number"
min_cell_voltage:
name: "Min Cell Voltage"
min_cell_voltage_number:
name: "Min Cell Voltage Number"
max_temperature:
name: "Max Temperature"
max_temperature_probe_number:
name: "Max Temperature Probe Number"
min_temperature:
name: "Min Temperature"
min_temperature_probe_number:
name: "Min Temperature Probe Number"
remaining_capacity:
name: "Remaining Capacity"
cells_number:
temperature_1:
temperature_2:
#Binary Sensor
binary_sensor:
charging_mos_enabled:
discharging_mos_enabled:
#UART
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
daly_bms:
update_interval: 20s
text_sensor:
status:
#Others
api:
ota:
- Update - yaml config with my ESP8266
#General
esphome:
platform: ESP8266
board: nodemcuv2
#Logging
logger:
level: DEBUG
baud_rate: 0
#Network
wifi:
manual_ip:
static_ip: 172.16.0.16
gateway: 172.16.0.1
ap:
#i2c
i2c:
sda: 4
scl: 5
#Sensor
voltage:
name: "BMS Battery Voltage"
current:
name: "BMS Battery Current"
battery_level:
name: "BMS Battery Level"
max_cell_voltage:
name: "BMS Max Cell Voltage"
name: "BMS Max Cell Voltage Number"
min_cell_voltage:
name: "BMS Min Cell Voltage"
name: "BMS Min Cell Voltage Number"
max_temperature:
name: "BMS Max Temperature"
name: "BMS Max Temperature Probe Number"
min_temperature:
name: "BMS Min Temperature"
name: "BMS Min Temperature Probe Number"
remaining_capacity:
name: "BMS Remaining Capacity"
cells_number:
name: "BMS Cells Number"
temperature_1:
name: "BMS Temperature 1"
temperature_2:
name: "BMS Temperature 2"
- platform: bmp280
temperature:
name: "yard-esp8266-multisensor BMP280 Temperature"
oversampling: 2x
pressure:
name: "yard-esp8266-multisensor BMP280 Pressure"
address: 0x76
update_interval: 15s
- platform: dht
model: DHT22_TYPE2
pin: 13
temperature:
name: "yard-esp8266-multisensor DHT22 Temperature"
# filters:
# - calibrate_linear:
# - 0.0 -> 0.0
# - 20.0 -> 19.0
# - 23.0 -> 21.9
# - 27.0 -> 25.7
# - 31.0 -> 29.7
humidity:
name: "yard-esp8266-multisensor DHT22 Humidity"
- platform: wifi_signal
#Binary Sensor
binary_sensor:
- platform: gpio
pin: 12
name: "yard-esp8266-multisensor AM312 PIR"
device_class: motion
name: "BMS Charging MOS"
name: "BMS Discharging MOS"
#UART
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
daly_bms:
text_sensor:
status:
#Others
api:
ota:
Flash it with any mean necessary (I’m using ESPHome-Flasher)
Add it in your HA environment, in the Integration (ESPHome)
Done!
List of sensor
