i’m trying to integrate my finger print scanner with esphome. fingerprint_grow component and fingerprint_grow platform not found errors are coming. How do i fix this? please help.
Regards,
Aslam
Regards,
Aslam
The GROW Fingerprint module was added to ESPHome in November 2020, and available in early Spring 2021. What is your release version of ESPHome?
I had trouble with every fingerprint reader I attempted to use, UNTIL I used the exact same ESP8266 pin assignments as the original author.
# setup UART after WIFI
uart:
baud_rate: 57600
tx_pin: D0
rx_pin: D1
# Declare Grow Fingerprint Reader
fingerprint_grow:
password: 0x12345678
sensing_pin: D2
Tell us what software you are using (incl versions) yaml and logs.
Thanks for the support. error screenshot attached.
Thanks & Regards,
Aslam
What version of esphome?
upgraded to latest version. i’m using as608 finger scanner. the pinouts are below.
Thanks & regards,
Aslam
Latest is not a version.
Sorry, Current version: 2021.8.0
Is that a grow sensor? I think not.
TCH == TOUCH == sense signal
