Hello everyone,
I hope I am posting at the right place… This is my first post!
after searching for houres, and not finding any helpful posts, i would like to share my problem with the community.
I am trying to set up a custome thermostate, using a nodumcu (through ESPHome) a Nextion display and a Generic Thermostat from Home Assistant.
The plan is the following:
- display the current temperature, humidity, and target temperature to the Nextion Display
- display the current temperature, humidity, and target temperature to the thermostate card in lovelace
- “conect” the target temperature of nextion display and thermostat card, so when changing the target temperature from the display, the lovelace card is being change as well and vice versa.
So far, 1 and 2 are working fine, but I am having difficulties on number 3.
Following are the YAML files of the ESPHome and the Home Assistant configuration
ESPHome YAML:
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "***"
password: "****"
manual_ip:
static_ip: 192.168.1.113
gateway: 192.168.1.1
subnet: 255.255.255.0
dns1: 192.168.1.1
dns2: 192.168.1.1
ap:
ssid: "****"
password: "****"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
- platform: dht
pin: D3
model: dht11
temperature:
name: "Thermostat Temperature"
humidity:
name: "Thermostat Humidity"
update_interval: 30s
- platform: homeassistant
entity_id: sensor.thermostat_temperature
entity_id: sensor.thermostate_humidity
name: "Set Temperature"
lambda: |-
return {id(set_temp)};
update_interval: 1s
switch:
- platform: gpio
pin: D5
inverted: yes
binary_sensor:
- platform: gpio
pin:
number: D7
mode: INPUT_PULLUP
inverted: yes
on_state:
then:
- switch.toggle: heater
- platform: nextion
page_id: 0
component_id: 6
name: "Minus Set Temperature"
on_press:
lambda: |-
id(set_temp) = id(set_temp) - 1;
if (id(set_temp) == 14){
id(set_temp) = 15;
- platform: nextion
page_id: 0
component_id: 5
name: "Plus Set Temperature"
on_press:
lambda: |-
id(set_temp) = id(set_temp) + 1;
if (id(set_temp) == 36){
id(set_temp) = 35;
i2c:
display:
- platform: nextion
update_interval: 1s
lambda: |-
// Do not wait for ack (this delays the whole procedure a lot, and has no use)
it.set_wait_for_ack(false);
it.set_component_text_printf("temperature","%2.1f",id(therm_temp).state);
it.set_component_text_printf("humidity","%2.1f",id(therm_hum).state);
it.send_command_printf("n0.val=%d",id(set_temp));
it.send_command_printf("n1.val=%d",id(set_temp));
uart:
rx_pin: GPIO1
tx_pin: GPIO3
baud_rate: 9600
globals:
- id: set_temp
type: int
initial_value: '15'
restore_value: no
configuration YAML: (only what is relevant)
climate:
- platform: generic_thermostat
heater: switch.heater
target_sensor: sensor.thermostat_temperature
min_temp: 15
So the question is, what do I have to do, in order to connect “set_temp” from the ESPHome YAML (the dispay variable) with the thermostat target temperature, so when I change, the other changes as well.
In the configuration YAML I also tryied to do this:
set_temp: '{{ ((states(''sensor.set_temperature_2'') }}'
but it does not convert to float, so no luck theire!
Any help will be much appreciate!!
Thank you in advance.
