[ESPHome] iPod Dock IR Remote
Apple IR Remote (A1156) to control an iPod Dock
In this example I have used a Wemos D1 Mini and an infrared shield to control an iPod dock from Home Assistant. Comment below if you still use your iPod in 2020!!!
I enjoy listening to Soulection Radio on my iPod as background music while I work.
Each show is two hours, so it’s nice to not think about what songs to play next like on Spotify and also automate things with Home Assistant that don’t have an internet connection, like an iPod.
I’ve added this to the cookbook because the iPod remote codes were getting hard to find and wanted to document this use-case for others to enjoy.
This is the Apple White Remote model A1156 that we are replacing:
Hardware configuration
Hardware is easy! Just solder the shield or wire up a IR transmitter LED using the Wemos D1 mini pins below:
Only four connections are needed:
  • VCC - Power
  • GND - Ground
  • D3 - GPIO for Receiver
  • D4 - GPIO for Transmitter
Hardware Procurement
I bought the Wemos D1 Mini IR Shield by searching on Aliexpress and eBay for <$4 USD. I couldn’t find any links on Amazon but I’m sure it’s always changing.
Software configuration
We are emulating a 6 button remote so the configuration is simple:
Dumping Other IR Codes
This is only required if you want to add other codes for other remotes.
    ### This is only needed to dump other remote codes.
     remote_receiver:
       pin: D4
       dump: all
The Configuration
    remote_transmitter:
      pin: D3
      # Infrared remotes use a 50% carrier signal
      carrier_duty_percent: 50%
    switch:
        name: Apple Remote Volume Up Button
        turn_on_action:
          - remote_transmitter.transmit_nec:
              address: 0x77E1
              command: 0xD04E
        name: Apple Remote Volume Down Button
        turn_on_action:
              address: 0x77E1
              command: 0xB04E
        name: Apple Remote Previous Button
        turn_on_action:
              address: 0x77E1
              command: 0x104E
        name: Apple Remote Next Button
        turn_on_action:
              address: 0x77E1
              command: 0xE04E
        name: Apple Remote Play/Pause Button
        turn_on_action:
              address: 0x77E1
              command: 0x2000
        name: Apple Remote Menu Button
        turn_on_action:
              address: 0x77E1
              command: 0x404E
Fast Forward and Rewind
Fast Forward and Rewind (by holding the Next/Previous buttons on the remote) aren’t available in this configuration yet but maybe someone can add it by adding in a button press duration.
Lovelace Button Card Configuration
PS: the Menu button doesn’t do anything to the iPod when it’s playing music but it might for a Mac or if you were for some reason watching a video off of your iPod. It’s just added here for symmetry but might be useful for others who have an appleTV or old Mac with an IR port.
    cards:
      - cards:
          - action: toggle
            color: 'rgb(253,216,53)'
            color_off: 'rgb(68,115,158)'
            entity: switch.apple_remote_previous_button
            icon: 'mdi:skip-previous'
            show_state: false
            type: 'custom:button-card'
          - action: toggle
            entity: switch.apple_remote_play_pause_button
            icon: 'mdi:play-pause'
            show_state: false
          - action: toggle
            entity: switch.apple_remote_next_button
            icon: 'mdi:skip-next'
            show_state: false
        type: horizontal-stack
      - cards:
          - action: toggle
            entity: switch.apple_remote_volume_down_button
            icon: 'mdi:minus'
            show_state: false
          - action: toggle
            entity: switch.apple_remote_menu_button
            icon: 'mdi:dots-horizontal-circle-outline'
            show_state: false
          - action: toggle
            entity: switch.apple_remote_volume_up_button
            icon: 'mdi:plus'
            show_state: false
    type: vertical-stack
    title: iPod IR Remote
Sources of IR Codes
Thank you for sharing this project! I was recently inspired to dig out my old iPod and attempt to ditch Spotify after realising most of the music I listen to, I already have on my iPod.
I ordered lolin variants of the d1 mini and ir shield and someone had kindly designed a 3d printed case on thingiverse
https://www.thingiverse.com/thing:3930823
I think the IR codes must be different for my remote but after dumping codes worked great.
Awesome! Glad you were able to get it working and thanks for sharing. I’ll check out the 3d printed case
I consider to make ipod classic remote control as well , but not IR. I wanna use Advance Ipod Protocol instead.
I have that almost done but need to write up some details to share. I’ll tag you when I publish it. I’ve been sitting on that project like 90% done for 2+ years :weary:
Most basic commands work just scroll commands are not implemented yet. I had an idea to control the iPod remotely over a webcam on the homeassistant dashboard lol
@VaAndCob @chonnymon thanks for interest in this project. You gave me the motivation to share the other iPod remote I’ve been working on.
Incredible !! This is exactly what I was looking for to listen to the Soulection Shows. I’ll give it a try in the coming weeks. Thanks !
