I have a weather station with wind speed and rainfall detectors, these both use the pulse_counter option in ESPHome. Because the weather station is out on the roof I’m trying to figure out a good way to run some CAT5 Ethernet most of the way and have the brains located in the attic.
I got really excited when I saw a bunch of articles on stack exchange about this and the idea is to run i²c via PCA9615.
- I2C signal and power over long range (10meter cable) - Electrical Engineering Stack Exchange
- bus - Best way to do I2C/TWI over long distance - Electrical Engineering Stack Exchange
etc.
However, this means that all the distant equipment needs to be communicating over i²c. I thought about this for a while and realized I could use an I/O expander module to get remote GPIO data without having to send it over the Ethernet. I have one of these PCF8574s so I tried to mock it up on a breadboard and see if I could get it to work:
pcf8574:
- id: 'pcf8574_hub'
address: 0x20
pcf8575: False
as3935_i2c:
# irq_pin: D7
irq_pin:
pcf8574: pcf8574_hub
number: 2
indoor: false
- platform: pulse_counter
# pin:
# number: D6
# mode: INPUT_PULLUP
pin:
number: 0
mode: INPUT_PULLUP
unit_of_measurement: 'in'
name: 'Rain Pulses 1min'
icon: 'mdi:weather-rainy'
count_mode:
rising_edge: DISABLE
falling_edge: INCREMENT
internal_filter: 50us
update_interval: 60s
internal: True
filters:
- multiply: 0.011
accuracy_decimals: 3
When I try to validate this, it tells me that [pcf8574] is an invalid option for [pin]. Please check the indentation. It only reports this for the pulse_counter and not for the as3935_i2c device. Reading about ESPHome’s support for the PCF8574, it says:
Any option accepting a Pin Schema can theoretically be used, but some more complicated components that do communication through this I/O expander will not work.
I’m guessing that I’m running into this “more complicated components” issue with the pulse counter but I thought I’d post it here just in case anyone from the community has any ideas.
Thanks!
