ESPHome + Pulscounter with IN-Z61 (Gascounter)
I just don’t get any valid pulse counter values and don’t know what I’m doing wrong. Sometimes pulses are counted, but these cannot be valid values.
Is it the GIPO or the pulse counter settings?
  # GPIO12: gas meter counter...
  # Pulse transmitter Elster IN-Z61
  - platform: pulse_counter
    pin:
      number: GPIO12
      mode: INPUT_PULLUP
    unit_of_measurement: "m³"
    update_interval: ${update_interval}
    accuracy_decimals: 3
    icon: "mdi:fire"
    state_topic: ${topic_prefix}/gas_current
    filters:
      - multiply: 0.001
    total:
      filters:
        - multiply: 0.001
The IN-Z61 Pulse Transmitter (reed switch) is connected to a Kom Schroder gas diaphragm meter BK-G2.5 and works.
The remaining sensors (water pressure, water temperature) work properly and provide valid data.
If someone has an idea or a tip what I could do, it would help me a lot.
Hallo @petsie
Did you have any success with your setup?
I try to use a slightly different using NodeMCU ESP8266 with a IN-Z65 on the BK-G4
Wbr
Yes. but i do use a binary sensor - not the pulse_counter. The pulse_counter do not work for me.
## ESP32 DEV  - GAS & WASSER 2021 - SENSOREN
## ESP32 NodeMCU Module WLAN WiFi Development Board mit CP2102
##   - GPIO19: Pulscounter Gaszähler
##   - GPIO34: Druck Kaltwasser
##   - GPIO17: Kaltwasser Temperatur
substitutions:
  platform: ESP32
  board: esp32dev
  device_name_short: "wasserundgas" # used by esp-home config
  friendly_name: "WUG"
  device_description: "Gaszähler, Kaltwassertemperatur, Kaltwasserdruck"
  update_interval: 60s
  impulsfactor: "0.100"
  appversion: "1.1.4"
  ## all used pins on ESP32
  gipo_pressure_SEN0257: GPIO34   # COLD WATER PRESSURE SENSOR
  gipo_dallas_sensor: GPIO17      # COLD WATER SENSOR
  gipo_puse_counter: GPIO19       # GASCOUNTER ZI-61 REED CONTACT
esphome:
  comment: ${device_description}
  platform: ${platform}
  board: ${board}
  arduino_version: recommended
  project:
    version: ${appversion}
  on_boot:
    then:
      - logger.log:
          level: info
          format: "BOOTMESSAGE:${device_name_short} API is connected, Device ready!"
      - globals.set:
          value: !lambda "return id(boot_counter)+=1;"
  on_shutdown:
    then:
      - logger.log: ${device_name_short} is down!
# Global variables
globals:
  - id: z61count
    type: int
    restore_value: yes
    initial_value: "0"
  - id: z61counter
    type: float
    restore_value: yes
    initial_value: "0.0"
  - id: m3kw
    type: float
    restore_value: yes
    initial_value: "10.94"
  - id: gas_meter_displayvalue
    type: float
    restore_value: yes
    initial_value: "29126.2"
  - id: gas_meter_totalm3
    type: float
    restore_value: yes
  - id: gas_meter_displayinital
    type: float
    restore_value: yes
    initial_value: "29060.6"
# Base packages wifi, timeserver...
packages:
  base: !include common/base.yaml
# Native API Component
api:
  port: 6053
  reboot_timeout: 5min
  services:
    - service: set_gasmeterdisplay
      variables:
        my_newdisplayvalue: float
      then:
        - logger.log:
            format: "Setting Gasmeter Display value: %.1f"
            args: [my_newdisplayvalue]
        - globals.set:
            value: !lambda 'return (my_newdisplayvalue);'
        - globals.set:
        - globals.set:
            value: !lambda 'return ((my_newdisplayvalue) - id(gas_meter_displayinital));'
        - globals.set:
            value: !lambda 'return ( ((my_newdisplayvalue) - id(gas_meter_displayinital))/${impulsfactor} );'
        - logger.log:
            format: "Gasmeter Display value: %.1f"
            args: [id(gas_meter_displayvalue)]
# GPIO02: used for temperatur sensors data wired
dallas:
  pin: ${gipo_dallas_sensor}
# Switch to restart, reset all, reset bootcounter
switch:
  - platform: restart
    name: ${friendly_name} reset all
    turn_on_action:
      then:
        - lambda: |-
            id(boot_counter) = 0;
            id(z61counter) = 0.0;
            id(z61count) = 0;
            id(gas_meter_totalm3)= 0.0;
            id(gas_meter_displayvalue)= 0.0;
            id(daily_value)= 0.0;
            id(bootcounter).update();
            id(gas_meter_display).update();
            id(gas_meter_total_m3).update();
            id(gas_meter_total_kw).update();
            id(gas_meter_total_kw_day).update();
        - logger.log: ${device_name_short} all values reset!
# GPIO19 <-- o-RC-o <--- GND
#            o-10k ----> +5V
# Gasmeter: Krom Schröder BK-G,25
# Q_max: 4 m³/h
# Q_min: 0.025 m³/h
# V: 1.2 dm³
# p_max: 0.5 bar
# 1 imp = 0.1 m³
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO19
      mode: INPUT_PULLUP  ## set ESP32 pin to input pull-up mode
      inverted: false
    name: ${friendly_name} Gaszähler Z-61 Impuls
    device_class: window
    filters:
      - delayed_off: 10ms
    ## This automation will be triggered when a button press ends,
    ## or in other words on the falling edge of the signal.
    on_release:
      then:
        - lambda: |-
            ESP_LOGI("main", " -------  Z-61 SET NEW VALUES !!!!!");
            id(z61count) += 1;
            id(z61counter) += ${impulsfactor};
            id(gas_meter_displayvalue) += ${impulsfactor};
            id(gas_meter_totalm3) += ${impulsfactor};
            id(daily_value) += ${impulsfactor};
            id(gas_meter_m3_today).publish_state(${impulsfactor});
# ALL SENSORS
    name: ${friendly_name} Gaszähler Anzeige
    accuracy_decimals: 1
    icon: "mdi:counter"
    device_class: gas
    lambda: |-
      return id(gas_meter_displayvalue);
    name: ${friendly_name} Gaszähler aktuell
    state_class: measurement
    device_class: gas
    accuracy_decimals: 2
    name: ${friendly_name} Gaszähler Impulse
    accuracy_decimals: 0
    lambda: |-
      return (id(z61count));
    name: ${friendly_name} Gasverbrauch gesamt
    device_class: gas
    state_class: total_increasing
    lambda: |-
      return id(gas_meter_totalm3);
    name: ${friendly_name} Gasverbrauch heute
    icon: mdi:gauge
    lambda: |-
      return (id(daily_value));
    name: ${friendly_name} Kilowattstunde Gas gesamt
    device_class: power
    unit_of_measurement: "kW"
    lambda: |-
      return (id(gas_meter_totalm3) * id(m3kw));
    name: ${friendly_name} Kilowattstunde Gas heute
    device_class: gas
    lambda: |-
      return (id(daily_value) * id(m3kw));
  # DFRobot SEN0257 water pressure sensor 1 GPIO 34
  - platform: adc
    name: ${friendly_name} Kaltwasser Wasserdruck
    pin: ${gipo_pressure_SEN0257}
    update_interval: 10s
    unit_of_measurement: "bar"
    device_class: pressure
    attenuation: 11db
    filters:
      - lambda: |-
          ESP_LOGI("main", "adc volt: %f", id(coldwater_pressure).raw_state);
          if(x-0.41<0) return 0.00;
          return ((x) * 2.00) - 0.82;
  # PIN GIPO17: DS18B20 Digital temperature sensor 1
  # Unique ID: 'dallas-7900000C8579C728'
  - platform: dallas
    # index: 0
    address: 0x7900000C8579C728
    unit_of_measurement: "°C"
    name: ${friendly_name} Kaltwasser Temperatur
    device_class: temperature
    icon: mdi:thermometer-lines
logger:
  level: INFO
  # baud_rate: 9600
  # baud_rate: 0
Hi petsie,
I’m trying to achieve something similar: I bought an ELV ES-GAS-2 module for my ELSTER gas meter. I don’t have proper results with pulse_counter either and stumbled across your post.
I think your setup is very “creative” (= advanced) - I did not know you could do this sort of thing with ESPHOME. I’m trying to adapt your code, but it seems there is something missing, e.g. variables
boot_counter,
daily_value,
bootcounter
are those defined in common/base.yaml ? Would you make that file available, too?
Thanks in advance,
@socrates
You can try this:
@petsie - Perfect, thank you!
Hi @petsie,
if you don’t mind my asking, I have two more questions:
  1. I discovered, that you have implemented a service in ESPHome to “reset” the Displayvalue and re-calculating related values. Under which circumstances do you use this? Currently I have a delta of about 0.5 to 0.9 m3 per day between the calculated value and the value displayed on the gas meter. Do you have a similar experience or do those values match in your setup?
  2. I couldn’t figure out how the daily values are reset. There seems to be nothing in the ESPHome .yaml file capable of reseting the values and I don’t see a corresponding service from HomeAssistant (like for the display value adjustment.)
Thanks in advance!
See: base.yaml → SNTP Time server
time:
  - platform: sntp
    timezone: Europe/Berlin
    servers:
      - 0.at.pool.ntp.org
      - 0.pool.ntp.org
      - 1.pool.ntp.org
    on_time:
      - seconds: 0
        minutes: 0
        hours: 0
        then:
          - lambda: |-
              if(id(daily_value)){
                 id(daily_value)=0.00;
      - seconds: 0
        minutes: 0
        then:
          - lambda: |-
              if(id(hour_value)){
                 id(hour_value)=0.00;
    on_time_sync:
      then:
        - logger.log: "Synchronized sntp clock"
I discovered, that you have implemented a service in ESPHome to “reset” the Displayvalue and…
Negativ, i use only “reset” the Displayvalue when I have the device offline or use a new one.
I would check filters: - delayed_off: 10ms, maybe this is too short?
Oh dear … THERE I did not look :upside_down_face:
I will have a look at the filter section – thanks a lot!
You can also enable the logger:
and be shure that you use a pulldown resistor.
Another could be the power supply, there are some that cause interference.
I changed to binary_sensor as well. The pulses where count in HA using history_stats.
From that I use template sensor to calculate gas consumption in m³. This sensor I add to the energy dashboard.
Works good for now
cheers
- platform: history_stats
  entity_id: binary_sensor.gasverbrauch_pulser
  state: "on"
  type: count
  start: "{{ now().replace(hour=0, minute=0, second=0) }}"
  end: "{{ now() }}"
template:
  - sensor:
      - name: "gasverbrauchaktuell_m3"
        state: "{{ states('sensor.GasVerbrauchPulser')|float(0) * 0.01 }}"
        device_class: gas
Are you shure ?
Bildschirmfoto 2022-03-03 um 07.47.10
I use:
{{ states('sensor.GasVerbrauchPulser')|float(0) * 0.1 }}
I have an BK-G4M and for me 1 imp is 0.01m3.
It looks like the counters are different.
Yes, they are different, my BK-G4 has
1 imp ≙ 0.01m³
I would like to use this, too. I also use an ESP32 but with the IN-Z65. I would like to know how to install this in Home Assistant? Or do i just have to copy the files and folders to the /config/esphome-directory?
My current code works, but the recorded values and the real value on the meter are more and more different while it records.
This is my current Yaml-Code in ESPhome:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "<OTA_password>"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Gassensor Fallback Hotspot"
    password: "<Fallback_Password>"
captive_portal:
    pin:
      number: GPIO19
      mode: INPUT_PULLDOWN
      inverted: false
    update_interval : 15s
    filters:
      - lambda: |-
          static float total_value = 6258.56;
          total_value += x * 0.01;
          return total_value;
    unit_of_measurement: m³
    device_class: gas
    icon: 'mdi:fire'
Wirering:
ESP32 → GPIO19 → IN-Z65 → GND → ESP32
i do not use an hardware-resistor, cause i read that the ESP32 has build-in resistors…right?
This is my first experience with ESPhome and any help would be appreciated. Thank you.
I had no success with the pulse_counter, so use the binary sensor.
See: ESPHome - Home Assistant
Go to integration and add ESPHome
Bildschirmfoto 2022-03-10 um 19.18.56
Bildschirmfoto 2022-03-10 um 19.19.04
Thank you for your answer. i had installed esphome via settings > esphome. it is up and running and i was able to flash my esp32 with the yaml-code i posted.
My Question was how i could install this for my sensor?
Just copy the files and folders to the /config/esphome-directory..
/config/esphome
|-- _static
|   |-- webserver-v1.min.css
|   `-- webserver-v1.min.js
|-- common
|   |-- base.yaml
|   |-- base_global.yaml
|   |-- base_webserver.yaml
|   `-- secrets.yaml
`-- gasmeter.yaml
starte esp-home dashboard
esphome-dashboard='cd ~/ && esphome dashboard ./'
Compile and install the app to the ESP
i will try it and give feedback if it works. Thank you so much!
i have an Gasmeter with imp = 0.01 m³ so i will have to change this
substitutions:
  platform: ESP32
  board: esp32dev
  device_name_short: "gasmeter" # used by esp-home config
  friendly_name: "GM2021"
  device_description: "Gasmeter"
  appversion: "1.1.7"
to this
substitutions:
  platform: ESP32
  board: esp32dev
  impulsfactor: "0.010"
  appversion: "1.1.7"
right?
