Needed some help to developed a smart mailbox using a d1 mini, esphome and home assistant. Got different examples on the internet, but none with esphome. I got the ground connected to RST with a switch to wake up the d1 mini from deep sleep, when the mailbox lid is open. But need to create a sensor that will turn on and off state for the mail box and send the info to home assistant.
Below is an example that I started creating, but template already doesn’t support the on_boot
You’re using mqtt instead of the api which is good. The api isn’t the best for deep sleep applications.
You don’t need to publish anything on boot. If your sensor has changed it will be sent to home assistant and from there you can automate a notification.
Catching the state change can be tricky on boot if your mail-man is as fast as mine. So the delay/on/off may be of some use.
Here’s my mailbox ESP config to show you what I mean. It has two sensors (door and lid) which I use in home assistant to determine full / empty. These are commoned to another input using diodes as when I wrote this only one wake input was available for the ESP32. None of this is relevant to you as you are using an ESP2866 board that only supports one wake input and you only have one input anyway. Just thought I’d clarify the code. The important bit is the wake time, what happens if a sensor (lid or door ) is left open (it goes to sleep) and the delay times for debouncing the switch and allowing for the wake up to capture the switch transition.
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: 'WAPLO'
password: !secret wifi_pwd
manual_ip:
static_ip: 10.1.1.77
gateway: 10.1.1.1
subnet: 255.255.255.0
logger:
level: WARN
mqtt:
broker: 10.1.1.100
username: !secret mqtt_usr
password: !secret mqtt_pwd
ota:
password: !secret esp_pwd
deep_sleep:
run_duration: 2min #### <---- overkill, takes about 45sec to wake up and report in
sleep_duration: 720min ### <---- report in twice a day
wakeup_pin_mode: INVERT_WAKEUP ### <----- go to sleep even if the door or lid is left open
wakeup_pin: GPIO12
- platform: wifi_signal
name: "Mailbox WiFi Signal" ### <---- get a signal strength reading on wake, but most of the time 'unknown'
update_interval: 4s
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
- platform: adc
pin: GPIO36
name: "Mailbox Battery" ### <---- This turned out to not be useful as my Li Bat to 5V power supply is low side switched so the battery voltage always looks like 4.2V
attenuation: 6db
unit_of_measurement: "V"
update_interval: 4s
filters:
- multiply: 1.89
window_size: 15
send_every: 15
binary_sensor:
- platform: status
name: "Mailbox Status" ### <--- useful to make sure the device wakes at least twice a day or HA alerts me
- platform: gpio
pin:
number: GPIO25
device_class: door
filters:
- delayed_on: 100ms ### <---- debounce time
- delayed_off: 10s ### <---- delay to capture state change on wake up
- platform: gpio
pin:
number: GPIO26
device_class: door
filters:
- platform: gpio
pin:
number: 12
mode: INPUT_PULLDOWN
name: "Mailbox Wake Pin"
Thanks for your feedback and appreciated it. Yes when researching, I read about the api isn’t ideal for deep sleep, as I implemented a septic level detector (ultrasonic sensor) running on D1 mini with mqtt, battery and a solar panel.
If I understood correctly, adding the filter to the platform, I can capture the information correctly for the automation.
### MQTT information
mqtt:
broker: XXX.XXX.X.XX
discovery: true
username: XXXXXXX
password: XXXXXXX
### Mailbox open and close notification
binary_sensor:
- platform: gpio
pin:
number: GPIO16
device_class: door
filters:
### Battery Monitoring
- platform: adc
icon: "mdi:battery"
pin: VCC
filters:
- multiply: 1.175
update_interval: 15s
### Mailbox Wifi information
name: "Mailbox WiFi Strength"
- platform: uptime
### DeepSleep
deep_sleep:
run_duration: 60s
As I had the issue when mimicking the delivery of the postman, as when the D1 connected the mailbox state was closed already.
Did you use retain option to remember the mqtt state, as I see in the screenshot it’s showing unavailable.
Yes I did use retain (it’s the default so does not have to be stated) .
They are unavailable is because of the LWT messages.
Supposedly it is possible to override this behaviour by setting blank birth and will message topics.
I tried this once when I didn’t know much about mqtt and could not get it to work. Now I realise it was because of retained LWT topics that needed to be deleted from the broker. I may get around to fixing this one day. But I would have to undo a fair bit of ‘workarounds’ first.
Hi, I understand but maybe you could clarify some things ? On the proto board the + of the battery seems to be connected to the CMD Pin ? Or is the proto board seen from underneath ? I have difficulty finding the right pins. Really would appreciate a little help …
No I did not … So you are saying that f.i. the LID sensor can be a wake pin whilst the DOOR sensor could just be another wake pin, both able to wake the ESP32 from deep sleep ?
Correct. This was introduced after I developed the circuit to OR the lid and door with diodes to a single wake pin.
Advanced features:
esp32_ext1_wakeup ( Optional ): Use the EXT1 wakeup source of the ESP32 to wake from deep sleep to wake up on multiple pins. This cannot be used together with wakeup pin.
pins ( Required , list of pin numbers): The pins to wake up on.
mode ( Optional ): The mode to use for the wakeup source. Must be one of ALL_LOW (wake up when all pins go LOW) or ANY_HIGH (wake up when any pin goes HIGH).
