thanx, no it validated the code without error.
OK tried to both of this configs
#RGB#
number:
- platform: "tuya"
number_datapoint: 110
min_value: 0
max_value: 2
step: 1
light:
- platform: tuya
dimmer_datapoint: 111
switch_datapoint: 11
min_value: 1
color_datapoint: 108
color_type: rgb
and this one
#RGB#
select:
- platform: "tuya"
enum_datapoint: 110
options:
0: Rainbow
1: Static
2: Spa Green
light:
- platform: tuya
min_value: 1
color_type: rgb
It didnāt go āmentalā as @sgvj wrote it went before. I didnāt need to reflash the diffuser, ESPHome and my HA still are connected, it wasnāt lost.
But unfortuanlty I canāt pick what color I want and I canāt dim the light.
Maybe someone that is better with ESPHome could look at it now, might be the code I put in my ESPHome yaml file is wrong now since the latest version.
IMO your code is OK, now it looks it simply does not workā¦
Maybe testing with rgbhsv but I am not convinced at all.
rgvhsv didnāt help.
Iām thinking of, if itās possible to get to the LED and connect that to another ESP32 and use it with WLED, or install another LED strip, like WS2812B.
But not sure it can be open to that part.
Looks complicated, out of my competences anyway
By reading again the tasmota template it looks like the dimmer can have a minimum value of 0 instead of 1 but it does not look changing anything.
It has worked, then it crasheed, now it simply does not work for RGB. Very strange.
My Asakuki with ESPHome, ran out ow water and the sensor changed to empty, but now I canāt clear it, it state the tank is out of water. Can any help me to clear the sensor state
This is how my ESPHome water sensor looks like this:
# enable tuya sensor platform
tuya:
- platform: "tuya"
name: $device_name out of water
sensor_datapoint: 12
I used a binary sensor:
binary_sensor:
- platform: "tuya"
name: Eau Diffuseur Bureau
device_class: "problem"
When out of water it is set to on but as soon as I put some water and switch the diffuser on again the binary sensor is set to off.
I will try your configuration, thanx.
Hi, I am trying to get my Asakuki 500ml link diffuser to work with Tasmosa. I have replaced the original WBR3 with a ESP-12F. Flashed the ESP-12F and followed following guide: Asakuki 500ml Aroma Diffuser Configuration for Tasmota
Then I noticed it appeared twice so I disabled the automatic discovery by changing SetOption19 to 1.
Now it is using the set up in my configuration.yaml. I did have to change the code slightly to get it, at least partially, to work:
fan:
unique_id: "diffuser_fan"
state_topic: "stat/diffuser/RESULT"
state_value_template: "{% if value_json.POWER1 is defined %}{{ value_json.POWER1 }}{% endif%}"
command_topic: "cmnd/diffuser/POWER1"
preset_modes:
- "high"
- "low"
preset_mode_state_topic: "stat/diffuser/fanmode"
preset_mode_command_topic: "cmnd/diffuser/tuyaenum1"
preset_mode_command_template: '{{ 1 if value == "high" else 0 }}'
availability_topic: "tele/diffuser/LWT"
payload_available: "Online"
payload_not_available: "Offline"
binary_sensor:
unique_id: "diffuser_error"
state_topic: "stat/diffuser/error"
value_template: "{{ 'ON' if value != '0X00' else 'OFF' }}"
device_class: problem
light:
unique_id: "diffuser_led"
command_topic: "cmnd/diffuser/POWER2GW"
state_value_template: "{% if value_json.POWER2 is defined %}{{ value_json.POWER2 }}{% endif %}"
payload_on: "ON"
payload_off: "OFF"
rgb_command_topic: "cmnd/diffuser/tuyasend3"
rgb_command_template: "{% set brightness = state_attr('light.diffuser_led','brightness') | int %}{{ '108,%02x%02x%02x646464' | format(red, green, blue)}}{{ '%02x' | format(brightness) }}"
rgb_value_template: "{% if value_json.POWER2 is defined and value_json.POWER2 == 'ON' %}{{value_json.Color.split(',')[0:3]|join(',')}}{% endif %}"
rgb_state_topic: "stat/diffuser/RESULT"
brightness_command_topic: "cmnd/diffuser/dimmer"
brightness_state_topic: "stat/diffuser/RESULT"
brightness_scale: 100
brightness_value_template: "{% if value_json.POWER2 is defined and value_json.POWER2 == 'ON' %}{{value_json.dimmer}}{% endif %}"
effect_list:
- "cycle"
- "solid"
effect_command_topic: "cmnd/diffuser/tuyaenum2GW"
effect_state_topic : "stat/diffuser/RESULT"
effect_value_template : "{% if value_json.TuyaEnum2 is defined and value_json.TuyaEnum2 == 0 %}{{'cycle'}}{% elif value_json.TuyaEnum2 is defined and value_json.TuyaEnum2 is defined and value_json.TuyaEnum2 == 1 %}{{'No'}}{% endif %}"
And added the automations in the automations.yaml:
automation:
- alias: "Diffuser Forwarder MQTT1"
- platform: mqtt
topic: 'cmnd/diffuser/POWER2GW'
condition:
condition: template
value_template: "{{ trigger.payload | lower != states('light.diffuser_led') }}"
- service: mqtt.publish
data_template:
topic: 'cmnd/diffuser/POWER2'
payload: "{{ trigger.payload }}"
- alias: "Diffuser Forwarder MQTT2"
- platform: mqtt
topic: 'cmnd/diffuser/tuyaenum2GW'
data_template:
topic: 'cmnd/diffuser/tuyaenum2'
payload_template: >
{% if 'cycle' in trigger.payload -%}
{{ 0 }}
{%- elif 'solid' in trigger.payload -%}
{{ 1 }}
{%- else -%}
{{ 2 }}
{%- endif %}
The diffuser fan etc seems to work, however I get errors with the light:
Parsing template
for entitylight.diffuser_light
failed with error: ValueError: Template error: int got invalid input āNoneā when rendering template ā{% set brightness = state_attr(ālight.diffuser_ledā,ābrightnessā) | int %}{{ ā108,%02x%02x%02x646464ā | format(red, green, blue)}}{{ ā%02xā | format(brightness) }}ā but no default was specified.
Failed to call service light/turn_on. color_RGB_to_hs() missing 2 required positional arguments: āiGā and āiBā
I am not sure what is asking me to do. Does anyone have any tips?
too confusing, I have a Maxcio 440ml, is there a 100% functional template for esphome?
100% functional, as fare as I know, no.
With my config all you loose is RGB control using HA, if it is essential for your use you might consider to switch to Tasmota.
I have not set anything to switch from different color mode because I wonāt use it, which is something which could be added.
thanks for reply, i am currently on Tasmota and waiting to migrate to Esphome, since it is the only device I need to make.
So if you really want to migrate to ESPHome you might have to accept some compromise with this diffuser except if I have missed something and someone else in this topic have succeeded with RGB.
Hi @Nardol @roberdlv , technically if it work in tasmota it should work in esphome.
Juste need to find how to create the RGB/light/template to drive those led.
Indeed you didnāt use it I already know why and understand.
I set log level to debug and it is very strange because it looks color value is never updated.
When there is a new value it is always FFFFFF000000FF
and when I switch the diffuser on, the value never changes even if color changes on the diffuser itself, I checked with someone who confirmed light color was changing.
The light config is as follow:
light:
- platform: tuya
min_value: 0
color_type: rgbhsv
entity_category: CONFIG
If ESPHome debug mode does not report change, there is a bug on ESPHome or something wrong on all my three devices.
This is what Iām using as an alternative. I hope it helps someone.
You have to switch on the LED before you can change the color.
substitutions:
devicename: master_bedroom_aroma_diffuser
friendly_name: Master Bedroom Aroma Diffuser
device_description: Tellur XD800W - TYWE3S
esphome:
friendly_name: ${friendly_name}
platformio_options:
board_build.f_cpu: 160000000L
esp8266:
board: esp_wroom_02
restore_from_flash: true
preferences:
flash_write_interval: 1min
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
reboot_timeout: 1h
encryption:
key: !secret api_encryption_key
ota:
safe_mode: true
password: !secret ota_password
web_server:
port: 80
auth:
username: !secret username
password: !secret password
include_internal: true
time:
- platform: homeassistant
wifi:
ssid: !secret wifi_ssid
power_save_mode: none
ap:
ssid: "${friendly_name}"
captive_portal:
uart:
baud_rate: 9600
tx_pin: GPIO1
rx_pin: GPIO3
tuya:
button:
- platform: restart
entity_category: diagnostic
- platform: factory_reset
internal: true
- platform: safe_mode
name: Safe Mode Boot
text_sensor:
- platform: wifi_info
ip_address:
ssid:
bssid:
mac_address:
name: MAC WiFi Address
- platform: version
- platform: tuya
internal: true
sensor_datapoint: 8
on_value:
then:
- lambda: |-
if (x == "00000000000000") {
id(${devicename}_color).publish_state("None");
} else if (x == "ff00000000ffff") {
id(${devicename}_color).publish_state("Bright Red");
} else if (x == "8000000000ff80") {
id(${devicename}_color).publish_state("Dark Red");
} else if (x == "ffff00003cffff") {
id(${devicename}_color).publish_state("Bright Yellow");
} else if (x == "808000003cff80") {
id(${devicename}_color).publish_state("Dark Yellow");
} else if (x == "00ff000078ffff") {
id(${devicename}_color).publish_state("Bright Green");
} else if (x == "0080000078ff80") {
id(${devicename}_color).publish_state("Dark Green");
} else if (x == "00ffff00b4ffff") {
id(${devicename}_color).publish_state("Bright Cyan");
} else if (x == "00808000b4ff80") {
id(${devicename}_color).publish_state("Dark Cyan");
} else if (x == "0000ff00f0ffff") {
id(${devicename}_color).publish_state("Bright Blue");
} else if (x == "00008000f0ff80") {
id(${devicename}_color).publish_state("Dark Blue");
} else if (x == "ff00ff012cffff") {
id(${devicename}_color).publish_state("Bright Magenta");
} else if (x == "800080012cff80") {
id(${devicename}_color).publish_state("Dark Magenta");
binary_sensor:
# sense water alert. 1 = fine. 0 = Out of water
- platform: tuya
name: Out of water
sensor_datapoint: 2
device_class: safety
filters:
- invert:
- platform: status
- platform: wifi_signal
update_interval: 60s
- platform: uptime
switch:
- platform: tuya
switch_datapoint: 1
light:
- platform: tuya
switch_datapoint: 5
on_turn_off:
- delay: 1s
- script.execute: ${devicename}_turn_off_led
select:
- platform: tuya
enum_datapoint: 6
options:
0: Static Color
1: RGB Cycle
- platform: tuya
enum_datapoint: 3
options:
0: "Off"
1: 1 Hour
2: 3 Hours
3: 6 Hours
optimistic: true
options:
- None
- Bright Red
- Dark Red
- Bright Yellow
- Dark Yellow
- Bright Green
- Dark Green
- Bright Cyan
- Dark Cyan
- Bright Blue
- Dark Blue
- Bright Magenta
- Dark Magenta
initial_option: None
on_value:
then:
- if:
condition:
lambda: |-
return x != "None";
then:
- light.turn_on: ${devicename}_led
- lambda: |-
if (x == "Bright Red") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "ff00000000ffff");
} else if (x == "Dark Red") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "8000000000ff80");
} else if (x == "Bright Yellow") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "ffff00003cffff");
} else if (x == "Dark Yellow") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "808000003cff80");
} else if (x == "Bright Green") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "00ff000078ffff");
} else if (x == "Dark Green") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "0080000078ff80");
} else if (x == "Bright Cyan") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "00ffff00b4ffff");
} else if (x == "Dark Cyan") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "00808000b4ff80");
} else if (x == "Bright Blue") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "0000ff00f0ffff");
} else if (x == "Dark Blue") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "00008000f0ff80");
} else if (x == "Bright Magenta") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "ff00ff012cffff");
} else if (x == "Dark Magenta") {
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "800080012cff80");
else:
- lambda: |-
id(master_bedroom_aroma_diffuser).set_string_datapoint_value(8, "00000000000000");
- light.turn_off: ${devicename}_led
status_led:
pin:
number: GPIO13
inverted: true
script:
- id: ${devicename}_turn_off_led
mode: parallel
then:
- lambda: |-
Hey everyone,
I recently ran into an issue with my ASAKUKI diffuser that had a WBR3 chip. The chip stopped working, so I replaced it with an ESP12F and flashed Tasmota on it. Now, Iād like to restore it to the original firmware.
Does anyone have a backup of the original firmware on a flashable chip? If possible, could you send it to my email at [email protected]? Iād really appreciate any help you can offer.
Thanks!
