Thanks OP, this worked very well. I have the exact same diffuser. Compiled the firmware with ESPHome, then flashed with tuya-convert.
I made some changes to your config, mainly to move away from API/service calls to switches.
For all of these I have assumed_state=True, since I may use the buttons on the device itself. If you donāt plan on using the buttons, or donāt care that the state may become incorrect, you can set these to False.
Replace the service block from the OP with this:
switch:
name: ${devicename} Light Static
icon: mdi:lightbulb
optimistic: true
assumed_state: true
turn_on_action:
- if:
condition:
switch.is_off: light_rainbow
then:
- uart.write: [0x55, 0xaa, 0x00, 0x06, 0x00, 0x05, 0x0b, 0x01, 0x00, 0x01, 0x01, 0x18]
- uart.write: [0x55, 0xaa, 0x00, 0x06, 0x00, 0x05, 0x6e, 0x04, 0x00, 0x01, 0x01, 0x7E]
- switch.template.publish:
state: OFF
turn_off_action:
- uart.write: [0x55, 0xAA, 0x00, 0x06, 0x00, 0x05, 0x0B, 0x01, 0x00, 0x01, 0x00, 0x17]
state: OFF
name: ${devicename} Light Rainbow
icon: mdi:lightbulb
optimistic: true
assumed_state: true
turn_on_action:
state: OFF
turn_off_action:
state: OFF
name: ${devicename} Power High
icon: mdi:fan
optimistic: true
assumed_state: true
turn_on_action:
- uart.write: [0x55, 0xAA, 0x00, 0x06, 0x00, 0x05, 0x67, 0x04, 0x00, 0x01, 0x01, 0x77]
state: OFF
turn_off_action:
- uart.write: [0x55, 0xaa, 0x00, 0x06, 0x00, 0x05, 0x67, 0x04, 0x00, 0x01, 0x02, 0x78]
state: OFF
name: ${devicename} Power Low
icon: mdi:fan
optimistic: true
assumed_state: true
turn_on_action:
- uart.write: [0x55, 0xAA, 0x00, 0x06, 0x00, 0x05, 0x67, 0x04, 0x00, 0x01, 0x00, 0x76]
state: OFF
turn_off_action:
state: OFF
