Quick question. With Sonoff-Tasmota, it’s fairly straightforward to connect external switches, such as push button or even rocker switches to a Sonoff device and have Tasmota still work with them by connecting a cable from the switch to the GPIO(s).
Can the same be done with ESPhome? Can it still be configured so that I can control, say a light, with both a standard switch and with Home Assistant together? That is, if I turn the light off with the switch, I can reactivate it with HA via ESPhome?
I haven’t actually swapped over to the api yet. I like to be able to use a client to sub to # on my mqtt server to see what is going on when things go tits-up.
I have many sonoffs basics running EspHome with external switches. I’ve used GPIO14, TX and TX to attach three different physical switches with single, double, triple, quadruple, many and long presses modes, so I can use them with automations do do whatever you want with those click types. If you use it with three switches, you will have 17 possible functions, excluding the first switch, single press that is attached to the main relay. There is also a text sensor to publish the last switch number and click type so it can be used as automation triggers.
Here is the code I’ve created:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: ${wifi_ssid}
password: ${wifi_psw}
fast_connect: false
ap:
ssid: ${friendly_name}
password: ${ap_psw}
logger:
web_server:
api:
password: ${api_psw}
ota:
binary_sensor:
## Buton 01
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 400ms
then:
- light.toggle: main_light
- timing:
- ON for at most 1s
- OFF for at most 399ms
- ON for at most 1s
then:
- text_sensor.template.publish:
state: "button_pressed"
- delay: 50ms
state: "button_01_double"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_01_triple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_01_quadruple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_01_many"
- timing:
- ON for at least 2s
then:
- delay: 50ms
state: "button_01_long"
## Buton 02
- platform: gpio
pin:
number: GPIO1
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_multi_click:
- timing:
- ON for at most 1s
then:
- delay: 50ms
state: "button_02_single"
- timing:
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_02_double"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_02_triple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_02_quadruple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_02_many"
- timing:
then:
- delay: 50ms
state: "button_02_long"
## Buton 03
- platform: gpio
pin:
number: GPIO3
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_multi_click:
- timing:
- ON for at most 1s
then:
- delay: 50ms
state: "button_03_single"
- timing:
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_03_double"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_03_triple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_03_quadruple"
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
- delay: 50ms
state: "button_03_many"
- timing:
then:
- delay: 50ms
state: "button_03_long"
output:
- platform: gpio
pin: GPIO12
light:
- platform: binary
output: main_relay
- platform: wifi_signal
update_interval: 60s
name: ${friendly_name} - Wifi signal
unit_of_measurement: '%'
accuracy_decimals: 0
icon: "mdi:wifi"
lambda: |-
if (id(wifi).state < -92.0)
return 100.0;
if (id(wifi).state > -21.0)
return 1.0;
else
return round(( -0.0154 * id(wifi).state * id(wifi).state ) - ( 0.3794 * id(wifi).state ) + 98.182 );
text_sensor:
name: ${friendly_name} - Switches
icon: "mdi:light-switch"
status_led:
pin:
number: GPIO13
inverted: true
There is also a nice formula to calculate the current wifi signal quality using percentage.
Hi Guys
The codes looks really great @Schneider. I have just starting using ESPHome and look forward to testing this over the coming days. It is exactly what I have been looking for.
Cheers
@Schneider. I wonder if you can assist me with a small error
I have a validated Yaml file as per your code, thank you
However I am getting this UNKNOWN error
${friendly_name} - Switches Unknown
I think it has something to do with the Text Sensor
These entries are used on the code I’ve sent: it will search for ${project_name} and substitute for what you have set on project_name (between the single quotes), so just substitute the ones you need. Some of these from the above are not used on this specific template shared but I use it on others that have, for example, switches. You can leave it blank.
Try it and send a validate now whit this substitutions above everything, on the same yaml as your code.
Hi again @Schneider
Well I have loaded the additional comments from the substitutions and unfortunately have not had great success
I added project_name, friendly_name, device_id, switch_entity_id, and light_entity_id
I left out wifi, ap, and api as I have my own wifi config setup
Sadly after running OTA update the sonoff would not reconnect to wifi. I then had to recompile the binary and use USB to re-flash the sonoff as OTA was not available due to not reconnecting to wifi.
I removed one line at a time to see which line was potentially causing, recompile the bin file, and re-flash each time.
Unfortunately it was not until I had remove every line from the substitution list, including substitution: that I finally got a bin file that allowed the sonoff to reconnect to wifi
So basically taking the yaml file back to the original format that I had before posting the previous error message to you
I am now at a loss as to why the upload was causing the sonoff not to reconnect to wifi???
I can only imagine it is something simple (or hopefully something simple) that is causing this issue
I wonder if I could post my yaml file somewhere for you to review?
Also of note
I am only using 2 buttons connected to GPIO14 and GIPO3
Button 1 connected to GPIO14 - No response
Button 2 connected to GPIO3 - working and getting on/off response in log when press and release the button.
Will check Button 1 config shortly
My setup has a Sonoff Dual R2 controlling a dumb window shutter motor. Also, there is a 3-position rocker switch connected to Button0 (GPIO9) and Button1 (GPIO0) on the 4-pin header in the Sonoff.
I have setup ESPHome for a time-based cover. It works well via HA. The button on the Sonoff also works open-stop-close-stop.
Adding control via the rocker switch is proving difficult as I do not know what to set for ‘mode’ & ‘inverted’. I have tried the following:
I already have a basic configuration for controlling a relay connected to a NODEMCU, and it works very well in Hassio, however, I have picked up enough to implement a physical switch (pulsator) in this context and to be able to use both options in harmony. I have a push button attached to pin D2 and the Nodemcu GND, but it never recognizes the touch of the switch and turns the relay on or off. Can anyone help me?
