I am trying to compile binaries for an esp32 module (MH-ET Live Esp32 Dev kit), using EspHome.
Unluckily the process get stack at the compile step, and the only think I can do is to restart the HASSIO but, disconnecting the RPi3 from the power outlet.
I am not sure what is causing the issue.
I have tried reinstalling the addon with no luck.
I was able to compile and upload firmwares before (with older versions of Hassio) with no problem.
Following is the log from EspHope Compile step:
Processing xiaomi_ble_esp32 (board: mhetesp32devkit; framework: arduino; platform: [email protected])
Tool Manager: Installing platformio/tool-scons @ ~4.40001.0
Downloading [####################################] 100%
Unpacking [####################################] 100%
Tool Manager: tool-scons @ 4.40001.0 has been installed!
Tool Manager: Removing tool-scons @ 3.30102.0
Tool Manager: tool-scons @ 3.30102.0 has been removed!
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif32 3.10004.200129 (1.0.4)
- tool-esptoolpy 1.20600.0 (2.6.0)
- toolchain-xtensa32 2.50200.80 (5.2.0)
Library Manager: Installing AsyncTCP-esphome @ 1.1.1
Library Manager: AsyncTCP-esphome @ 1.1.1 has been installed!
Library Manager: Installing ESPAsyncWebServer-esphome @ 1.2.7
Downloading [############################--------] 80%
Downloading [################################----] 90%
Library Manager: ESPAsyncWebServer-esphome @ 1.2.7 has been installed!
Library Manager: Installing dependencies...
Library Manager: Installing ESPAsyncTCP-esphome
Library Manager: ESPAsyncTCP-esphome @ 1.2.3 has been installed!
Library Manager: Installing Hash
Library Manager: Already installed, built-in library
Dependency Graph
|-- <AsyncTCP-esphome> 1.1.1
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <FS> 1.0
|-- <ESPAsyncWebServer-esphome> 1.2.7
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <DNSServer> 1.1.0
| |-- <WiFi> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Compiling /data/xiaomi_ble_esp32/.pioenvs/xiaomi_ble_esp32/src/esphome/components/api/api_connection.cpp.o
Compiling /data/xiaomi_ble_esp32/.pioenvs/xiaomi_ble_esp32/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/xiaomi_ble_esp32/.pioenvs/xiaomi_ble_esp32/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/xiaomi_ble_esp32/.pioenvs/xiaomi_ble_esp32/src/esphome/components/api/api_server.cpp.o
It proceeds very fast until the compilation of api_server.cpp.o
, at the point the system freezes and the only thing I can do is to unplug the RPi3 and plug it back in to restart it.
Thanks a lot for your help
