I’m looking for some help with my ESPHome project.
Goal:
I’m trying to control this cat toy which works over 433 MHz.
I thought it was IR when I bought it and realized after purchasing it that it doesn’t need line of sight to work.
I finally took it apart and saw the crystal oscillator that says 6.7458
Something in this thread made me think it’s a 433 MHz device because:
433.92 / 6.7458 = 64.3244685582 – if you know if this confirms the frequency then please let me know!
So that led me down the rabbit hole looking for how to read the 433mhz codes so I can automate the cat toy throughout the day.
I purchased the WL-101 Receiver and WL-102 Transmitter combo on amazon because one of the reviews mentioned ESPHome
I’m using an ESP32 right now FYI.
I can receive codes just fine.
remote_receiver:
pin: GPIO 23
dump: all
# Settings to optimize recognition of RF devices
tolerance: 50%
filter: 250us
idle: 4ms
buffer_size: 2kb
Log:
In this long, I’m just pressing the off button on the remote for a normal tap until it turns off the cat toy. that’s it.
INFO ESPHome 2023.10.6
INFO Reading configuration /config/esphome/cat-toy-controller-esp32.yaml...
INFO Starting log output from cat-toy-controller-esp32.local using esphome API
INFO Successfully connected to cat-toy-controller-esp32.local
[22:06:27][I][app:102]: ESPHome version 2023.10.6 compiled on Nov 4 2023, 22:04:32
[22:06:27][C][wifi:546]: WiFi:
[22:06:27][C][wifi:382]: Local MAC: B4:E6:2D:FB:1A:7D
[22:06:27][C][wifi:383]: SSID: 'network name'[redacted]
[22:06:27][C][wifi:384]: IP Address: 192.168.1.129
[22:06:27][C][wifi:386]: BSSID: 24:5A:4C:13:5F:2D[redacted]
[22:06:27][C][wifi:387]: Hostname: 'cat-toy-controller-esp32'
[22:06:27][C][wifi:389]: Signal strength: -52 dB ▂▄▆█
[22:06:27][C][wifi:393]: Channel: 1
[22:06:27][C][wifi:394]: Subnet: 255.255.255.0
[22:06:27][C][wifi:395]: Gateway: 192.168.1.1
[22:06:27][C][wifi:396]: DNS1: 192.168.1.1
[22:06:27][C][wifi:397]: DNS2: 0.0.0.0
[22:06:27][C][logger:416]: Logger:
[22:06:27][C][logger:417]: Level: DEBUG
[22:06:27][C][logger:418]: Log Baud Rate: 115200
[22:06:27][C][logger:420]: Hardware UART: UART0
[22:06:27][C][template.switch:068]: Template Switch 'Power Off Button'
[22:06:27][C][template.switch:091]: Restore Mode: always OFF
[22:06:27][C][template.switch:057]: Optimistic: NO
[22:06:27][C][remote_transmitter:015]: Remote Transmitter...
[22:06:27][C][remote_transmitter:016]: Channel: 3
[22:06:27][C][remote_transmitter:017]: RMT memory blocks: 1
[22:06:27][C][remote_transmitter:018]: Clock divider: 80
[22:06:27][C][remote_transmitter:019]: Pin: GPIO22
[22:06:27][C][remote_receiver.esp32:054]: Remote Receiver:
[22:06:27][C][remote_receiver.esp32:055]: Pin: GPIO23
[22:06:27][C][remote_receiver.esp32:060]: Channel: 0
[22:06:27][C][remote_receiver.esp32:061]: RMT memory blocks: 3
[22:06:27][C][remote_receiver.esp32:062]: Clock divider: 80
[22:06:27][C][remote_receiver.esp32:063]: Tolerance: 50%
[22:06:27][C][remote_receiver.esp32:064]: Filter out pulses shorter than: 50 us
[22:06:27][C][remote_receiver.esp32:065]: Signal is done after 4000 us of no changes
[22:06:27][C][captive_portal:088]: Captive Portal:
[22:06:27][C][mdns:115]: mDNS:
[22:06:27][C][mdns:116]: Hostname: cat-toy-controller-esp32
[22:06:27][C][ota:097]: Over-The-Air Updates:
[22:06:27][C][ota:098]: Address: cat-toy-controller-esp32.local:3232
[22:06:27][C][ota:101]: Using Password.
[22:06:27][C][api:139]: API Server:
[22:06:27][C][api:140]: Address: cat-toy-controller-esp32.local:6053
[22:06:27][C][api:142]: Using noise encryption: YES
[22:07:02][I][remote.canalsatld:100]: Received CanalSatLD: device=0x7F, address=0x1F, command=0x6E, repeat=0x1
[22:07:02][I][remote.pronto:237]: Received Pronto: data=0000 006D 00C1 0000 000F 000B 001C 000D 0006 0005 0029 0003 0004 0007 0020 0016 000A 0014 000A 001A 0010 0010 0009 0005 000D 0013 0003 0006 0004 0019 001C 000C 0002 000E 0002 0019 000A 000F 000D 0016 0008 0002 0021 0005 0020 0006
[22:07:02][I][remote.pronto:239]: 0012 000F 0017 000C 0007 0004 0006 001C 0000 0006 0007 001C 0015 0007 0016 0011 000F 000A 0005 0005 0007 001D 0007 000F 0003 0055 000B 000A 001E 0004 0005 000F 001B 0005 0016 000A 0041 0003 0004 000D 000C 000C 0009 0008 0008 001D 0003 0005 0008 000D 001D 000D 0008 0017 0005 0004 0008 000D 0005 0006 0008 0034 0002 000B 0009 0009 0002 0005 000E 0006 0007 0004 001F 0004 0012 0013 0010 000B 0013 0002 0001 0009 000B 000C 0012 0006 0005 0006 0022 0005 000D 000B 0010 0018 0008 0015
[22:07:02][W][component:214]: Component remote_receiver took a long time for an operation (0.09 s).
[22:07:02][W][component:215]: Components should block for at most 20-30ms.
[22:07:02][I][remote.pronto:237]: Received Pronto: data=0000 006D 0019 0000 0014 002B 0030 0010 0011 002E 0011 002E 0010 002F 002E 0012 000F 0030 002D 0013 000E 0031 000F 0030 002D 0013 000E 0031 000E 0030 000F 0030 002D 0013 000E 0031 000E 0031 000E 0031 000E 0031 000F 0030 000F 0030
[22:07:02][I][remote.pronto:239]: 000E 0031 002D 0012 002D 0013 000E 009B 06C3
[22:07:02][I][remote.drayton:209]: Received Drayton: address=0x6366 (0xc6cc), channel=0x001 command=0x018
[22:07:02][I][remote.rc_switch:261]: Received RCSwitch Raw: protocol=2 data='010001010010001000000011'
[22:07:02][W][component:214]: Component remote_receiver took a long time for an operation (0.06 s).
[22:07:02][I][remote.pronto:237]: Received Pronto: data=0000 006D 0019 0000 0014 002C 0030 0010 0011 002F 0010 002F 0010 002F 002E 0012 000F 0030 002D 0013 000E 0031 000F 0031 002D 0013 000E 0031 000F 0030 000F 0030 002D 0013 000E 0031 000E 0031 000E 0031 000E 0030 000F 0031 000E 0031
[22:07:02][I][remote.pronto:239]: 000F 0030 002E 0012 002D 0013 000E 009B 06C3
[22:07:03][I][remote.pronto:237]: Received Pronto: data=0000 006D 0019 0000 0013 002C 0031 0010 0011 002E 0011 002F 0010 0030 002D 0012 000F 0030 002D 0013 000E 0031 000E 0030 002D 0012 000E 0031 000E 0031 000E 0031 002D 0013 000E 0032 000E 0031 000E 0031 000E 0031 000E 0031 000F 0030
[22:07:03][I][remote.pronto:239]: 000F 0030 002D 0013 002D 0013 000E 009B 06C3
[22:07:03][I][remote.drayton:209]: Received Drayton: address=0x6366 (0xc6cc), channel=0x001 command=0x018
[22:07:03][I][remote.rc_switch:261]: Received RCSwitch Raw: protocol=1 data='010001010010001000000011'
[22:07:03][W][component:214]: Component remote_receiver took a long time for an operation (0.05 s).
[22:07:03][W][component:215]: Components should block for at most 20-30ms.
[22:07:03][I][remote.pronto:237]: Received Pronto: data=0000 006D 0019 0000 0014 002C 0030 0010 0011 002F 0010 002F 000F 0030 002E 0012 000F 0030 002D 0013 000F 0030 000F 0030 002D 0012 000E 0031 000E 0031 000E 0031 002D 0014 000D 0031 000E 0031 000E 0031 000F 0030 000F 0030 000F 0030
[22:07:03][I][remote.pronto:239]: 000F 0030 002D 0013 002D 0013 000D 009B 06C3
[22:07:03][I][remote.rc_switch:261]: Received RCSwitch Raw: protocol=2 data='010001010010001000000011'
[22:07:03][I][remote.pronto:237]: Received Pronto: data=0000 006D 0001 0000 0008 009B 06C3
[22:07:03][I][remote.pronto:237]: Received Pronto: data=0000 006D 0001 0000 0006 009B 06C3
[22:07:03][I][remote.pronto:237]: Received Pronto: data=0000 006D 0005 0000 0003 0048 0002 000F 0007 0037 000D 0068 0007 009B 06C3
The issue I’m having is transmitting the code that I’m seeing in the logs
With transmitting, I can’t get any reaction. I’m wondering if it’s a frequency thing or my code. Love to hear your thoughts on it!
For reference, to turn it on with the remote, it says “hold down for 2 seconds”. I’ve tried increasing the amount of repeats in the code, however it’s causing my esp32 to disconnect from the Home Assistant API and I think the system gets overwhelmed or something. Transmitting the “On” code for 2 seconds is another challenge.
ESPHome YAML:
esphome:
friendly_name: cat-toy-controller-esp32
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "secret"
ota:
password: "secret"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Cat-Toy-Controller-Esp32"
password: "secret"
captive_portal:
remote_receiver:
pin: GPIO 23
dump: all
tolerance: 50%
filter: 250us
idle: 4ms
buffer_size: 2kb
remote_transmitter:
pin: GPIO22
# RF uses a 100% carrier signal
carrier_duty_percent: 100%
switch:
#### RC Switch Raw
### this is not working
name: Power On Button
turn_on_action:
- remote_transmitter.transmit_rc_switch_raw:
code: '010001010010001000000001'
protocol: 2
repeat:
times: 30
wait_time: 0s #500ms
name: Power Off Button
turn_on_action:
code: '010001010010001000000011'
protocol: 2
repeat:
times: 30
name: Slow Speed Button
turn_on_action:
code: '010001010010001000000111'
protocol: 2
repeat:
times: 30
name: 20 Minute Timer Button
turn_on_action:
code: '010001010010001000010000'
protocol: 2
repeat:
times: 30
#### drayton
### this is also not working
turn_on_action:
- remote_transmitter.transmit_drayton:
address: '0x6366'
channel: '0x001'
command: '0x018'
repeat:
times: 30
