Is this possible to define the input_select entity with the option list evaluated when it is needed? Which for my case means when I am opening the dashboard.
The list of options available is the result of iterating over some entities from a particular device, and then checking if some condition is met.
What I am trying to achieve is a working version of:
input_select:
test_select:
options: >
{{ device_entities('c65373d57e19a5f717fa330e1970157e') }}
The final version would be more complex, as the output of the device_entities() will be processed to determine if and what should be provided for each entity. But for starters I would like this (or a functional counterpart) working.
The problem is, that it seems the template is not evaluated here, and the result of this configuration snippet is that I have an input_select field proposing the single option being {{ device_entities(‘c65373d57e19a5f717fa330e1970157e’) }}
Any suggestion how to achieve it?
