Hello! I’m trying to install an assistant for this instruction: Hass.io on VMWare ESXi 6.7 - Step By Step
But for some reason, Home Assistant does not start, a message is displayed that the operating system was not found. What can be wrong? I cannot install a newer version of the ESXi, because of the compatibility problems of my hardware.
@DimChik2903 If you want help you need to provide more info, e.g. your version of the image in step 13 showing the VM configuration.
Most likely you have missed a step somewhere. I’m running HA on ESXi 6.5 with no issues.
Hmm, really, I installed version 6.5, everything started right away. Thank you!
I’m not sure if this has been sorted.
I repeated steps 14 and 15 from Home Assistant installation manual:
14. Right-click the .vmx file and select Open with > Notepad.
15. Under .encoding, add a line. Enter `firmware = “efi”
- manually save file before closing it
And it works fine now
