ESXi HAOS cant download latest supervisor when starting
I’ve i big problem when I try to use the latest version of HAOS for ESXi.
I can create and start everything, but during the start it’s trying to download the latest supervisor 2022.9.4 but I get an error all the time. It says that there is an server error and that the cient timed out, see below.
22-09-18 17:47:09 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4
22-09-18 17:47:09 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.9.4.
22-09-18 17:52:44 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.9.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.9.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-09-18 17:52:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
These messages keep coming over and over again.
When I try to go to https://ghcr.io/v2/ in the browser I get:
{"errors":[{"code":"UNAUTHORIZED","message":"authentication required"}]}
I’m trying to use the latest version for ESXi “haos.ova.9.0.vmdk” and I’m following this guide Hass.io on VMWare ESXi 6.7 - Step By Step
The ESXI version is 7.0U3g-20328353.
Does anyone have any ideas what I’m doing wrong?
If there is any other information needed to help me?
