I tried this doesn’t work. What I can see in iobroker:
eufy-security.0.stationID.cameras.cameraID.stop_stream.
What did you use in stream sensor?
Double click where?
Tell me what you have done to make it working please?
It’s no longer working due to changes to the adapter in ioBroker. I have not had time to retry. Please read the whole thread, or at the very least the last month or so.
This is great, thank you. I’ve found the groups particularly useful to create a single switch (or groups of switches).
I then moved to HA automations based on device trackers and rest-commands:
e.g., when enter home zone Disarm cameras 1,3,4; when leave set to Home.
(I don’t use Away, Schedule, or Geofencing, and find HA’s location tracking (for geofencing) superior to Eufy’s).
Never have to actually flip a switch again, unless I want to override. And it sends me a notification so I know it did its thing.
alias: My House - Set Eufy Camera 'Location' to 'Disarm' When Present
description: ''
- platform: zone
entity_id: person.me
zone: zone.my_zone
event: enter
condition: []
- service: rest_command.eufy_myhome_location_guard_mode_disarmed
- service: notify.mobile_app_my_iphone
message: >-
It looks like you've arrived. I've set your "Location" camera to
"Disarmed"
title: My Home Eufy Cameras
I open port by port on my firewall when I need it for a new application, so I thought it could be a reason.
Otherwise, I already could access my lan and particulary to the HomeBase 2 with the Eufy application.
But it doesn’t works anymore.
IO Broker works well.
I add that in my configuration.yaml but
- platform: rest
name: Eufy Doorbell Guard Mode
resource: "http://HassosIP:8087/getPlainValue/eufy-security.0.T8210XXXXXXXXXXX.station.guard_mode"
scan_interval: 10
value_template: >-
{% set v = value | replace('"', "")|int %}
{{ {0: "Away",
1: "Home",
2: "Schedule",
3: "Custom1",
4: "Custom2",
5: "Custom3",
47: "Geofence",
63: "Disarmed"}[v] | default("Unknown state:" + (value|urlencode)) }}
- platform: rest
name: Eufy Doorbell Stream
resource: "http://HassosIP:8087/getPlainValue/eufy-security.0.T8210XXXXXXXXXXX.cameras.T8210XXXXXXXXXXX.livestream"
scan_interval: 10
value_template: >-
{% if (value) is not none and (value) != 'error: datapoint "Livestream URL" not found' %}
{{ value.replace('"', "") }}
No Stream
switch:
switches:
eufy_doorbell:
friendly_name: "Front Door - Guard Mode"
icon_template: mdi:doorbell-video
value_template: "{{ is_state('sensor.eufy_doorbell_guard_mode', 'Home') }}"
turn_on:
service: rest_command.eufy_doorbell_home
turn_off:
service: rest_command.eufy_doorbell_disarmed
rest_command:
eufy_doorbell_disarmed:
url: "http://HassosIP:8087/set/eufy-security.0.T8210XXXXXXXXXXX.station.guard_mode?value=GUARD_MODE_VALUE&ack=false"
eufy_start_stream:
url: "http://HassosIP:8087/toggle/eufy-security.0.T8210XXXXXXXXXXX.cameras.T8210XXXXXXXXXXX.start_stream"
eufy_stop_stream:
url: "http://HassosIP:8087/toggle/eufy-security.0.T8210XXXXXXXXXXX.cameras.T8210XXXXXXXXXXX.stop_stream"
camera:
- platform: generic
still_image_url: http://HassosIP:8082/eufy-security.0/T8210XXXXXXXXXXX.jpg
- platform: generic
stream_source: "{{ states('sensor.eufy__T8210XXXXXXXXXXX_stream') }}"
And a card in one of my views :
But it doesn’t look to works well…please @jbrukardt @MaxW @fuzzymistborn , could you help me please?
Question 1 : Does it works only for https://www.amazon.fr/eufy-Security-Résolution-nécessite-existants/dp/B07R3WY95C
and also for https://www.amazon.fr/gp/product/B08DY9HZ5V/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 please ?
Question 2 : Which is the IOBROKER_SERVER_IP adress please ? Is it the Home Base IP, the HassOS IP or the IOBroker IP adress of the docker please ?
Question 3 : Must I have to active the RSTP on the cam please ?
Question 4 : Must I choose a less quality on the Eufy App like 1080 HD or 720 HD than 2K because it is too heavy for HA ?
Question 5 :
I suppose it is the station…etc you have with a copy paste of that :
Question 6
On Fuzzy link Controlling Eufy Security Devices with ioBroker
The livestream is in text.url :
in mine it’s only url :
When I use the url, here is the result :
If I try with : http://HassOSIP:8082/eufy-security.0.T80xxxxxxxxxxxxx.cameras.T81xxxxxxxxxxxxx.hardware_version :
Any idea ?
Thanks, I become bored of the Eufy integration unwhile I integrated lot of others things like ESP, Zwave…Etc…PLEAAAASSE, Helllp
What do you mean by “changes in ioBroker”? Do you mean I should discard it?
Changes to the adapter. IE there have been improvements/breaking changes made to the code so what I have in my blog post no longer works. There’s likely a way to make it work, it’s just nobody (that I’ve seen) has posted it.
I went up one by one the 1100 posts in this thread and found this one.
I have exactly the same issue, so have uninstalled everything and reinstalled everything but the issue is not solved.
I do have installed ioBroker Eufy Security version 0.5.2.
I have set (in the Eufy app) the quality of streaming video to “Low” and the quality of recording video to “Full HD (1080p)” - only 2 choices proposed 2K and Full HD.
In the log I see that the video is in H264 but it looks like there is issue with codec or something.
Do you know how to update FFMEG to the latest version as suggested in the log ?
TIA
Edit: I thought the issue is linked with audio, so unchecked the audio recording. Manage to obtain once the stream - don’t know how - but only once, then again unable to obtain the stream.
2021-04-18 11:54:29.446 - error: eufy-security.0 (6239) ffmpegStreamToHls(): An error occurred: ffmpeg exited with code 1:
2021-04-18 11:54:29.447 - error: eufy-security.0 (6239) ffmpegStreamToHls(): ffmpeg output:
2021-04-18 11:54:29.447 - error: eufy-security.0 (6239) ffmpegStreamToHls(): ffmpeg stderr:
ffmpeg version 4.3.2-static https://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 8 (Debian 8.3.0-6)
configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libaom --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libdav1d --enable-libxvid --enable-libzimg
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
[h264 @ 0x1f6e90a0] error while decoding MB 94 67, bytestream -5
[h264 @ 0x1f6e90a0] concealing 75 DC, 75 AC, 75 MV errors in I frame
Input #0, h264, from 'unix:/tmp/eufy-security.0.1.sock':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080, 24 fps, 24 tbr, 1200k tbn, 48 tbc
[aac @ 0x1f6e9a90] More than one AAC RDB per ADTS frame is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
[aac @ 0x1f6e9a90] channel element 1.7 is not allocated
[aac @ 0x1f6e9a90] channel element 2.2 is not allocated
[aac @ 0x1f9ec900] decoding for stream 0 failed
[aac @ 0x1f9ec900] Could not find codec parameters for stream 0 (Audio: aac (LTP), 5.0, fltp, 45 kb/s): unspecified sample rate
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #1, aac, from 'unix:/tmp/eufy-security.0.2.sock':
Duration: N/A, bitrate: 45 kb/s
Stream #1:0: Audio: aac (LTP), 5.0, fltp, 45 kb/s
[hls @ 0x1f713d80] sample rate not set
Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #1:0 -> #0:1 (copy)
Last message repeated 1 times
2021-04-18 11:54:29.449 - error: eufy-security.0 (6239) EufySecurity.onStartLivestream(): station: Txxxxxxxxxxxxxxx channel: 0 - Error: Error: ffmpeg exited with code 1: - Stopping livestream...
Does anyone have an idea please ? 3 weeks looking for a solution…I am quite bored
Me too…
I’ve just bought an Arlo Essential, more expensive than Eufy but way easier to integrate into HA and there is also a doorbell… Although no “pan & tilt” feature which I appreciate much in the Eufy camera range.
you are kind of all over the place with your code. I think you need to start from scratch with small goals.
What is the first thing you would like to do with your cameras?
Integrate them into home assistant
Thx for your advices, my code only repeats the 2 tutorials mentioned by Fuzzy and MaxW for a camera. So, it looks difficult to do much less
integrate them how? There are three main things
- View a stream
- Change variables (guard mode, enabled, etc)
- Receive notifications (crying, motion detected, etc)
Each one has its own code path.
I peronally would like to see the last motion still picture and on click the stream (and e.g. integrate it in push message, if I have the working stream url)). That’s it.
More or less what is working with the old Eufy Security integration, but without the problems of having to start the stream manually, reload the page, etc. to see the stream. Beside all the warnings in the log, this one is running still very fine. And all this without iobroker.
Thx jbrukardt, same things of @arganto , I need the stream which, I think having understood that should works in an explorer with :
by replacing that copy-paste after “Value/” of that:
and replacing HassOSIP by the Hass’host IP, isn’t it ?
ok, theres going to be a couple steps here
- Verify you have IObroker access from HA. Have you configured the ports correctly in the iobroker addon configuration? Do you have 8082 mapped to 8082, and 8086 mapped to 8087?
thank you buddy, all my hope is on you
Indeed, my port 8087 was forwarded from my 8087 … first error which in terms of addressing can explain that I did not have access. I come back to the news asap
New config:
I used Home Assistant Supervised rather than the HASSos image, so i may not have the IP addresses right. To access home assistant addons from HA, i use the same IP I use for HA, with the port for the addon. Im not sure if HASSos does the same thing.
strike that 8086 to 8087 guidance! It looks like MaxW has updated his addon so you can do 8087:8087 mapping. Sorry about that, switch it back.
We’re going to see if your rest commands are working.
In a browser, put the following in the address bar and hit enter:
http://whateveraddressyouaccessiobrokerwith:8087/getPlainValue/copypastedvalueyoumentioned
Cut and paste two things here:
That address above (anonymized)
The web response you get back, it should be an rmtp stream address.
