markbajaj
(Mark Bajaj)
July 26, 2023, 2:18pm
421
Well spotted thanks! Updated it. I think it was because in testing (that had my creds in) I used a private repo that had the underscores
mb
egaz1119
(Egaz1119)
July 30, 2023, 12:55am
422
Very nice integration.
I’m using Hybrid L35+, but I’m stuck because I don’t know how to check the IP address.
The MAC address displayed by EufyClean does not exist on NetWork.
Please advise how to check.
markbajaj
(Mark Bajaj)
August 7, 2023, 12:40pm
423
Eufy 30 here. Anyone else’s stopped working on update to latest HA? Nothing obvious in logs except
The robovac custom integration is using deprecated vacuum feature
This stops working in version 2024.2.0. Please address before upgrading.
The custom integration robovac is extending the deprecated base class VacuumEntity instead of StateVacuumEntity.
Please report it to the author of the robovac custom integration.
Once an updated version of robovac is available, install it and restart Home Assistant to fix this issue.
cheers
mb
sacua
(Sacua)
August 7, 2023, 12:53pm
424
My programing skill in regards to home assistant are pretty low, but I believe a part of the answer on how to solve this problem can be found here.
home-assistant:dev
← mib1185:ecovacs/refactor-from-VacuumEntity-to-StateVacuumEntity
opened 06:54PM - 05 Jul 23 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
The Ecovacs integration has been migrated to the new StateVacuumEntity under the hood.
The states of the vacuum entity now reports not only on or off, instead `cleaning`, `paused`, `docked` (_implicit mean charging_), `returning` (_to base_), `idle` and `error`. Further the actions `turn_on` (_start cleaning_) and `turn_off` (_stop cleaning and return to base_) were superseded by three single actions `start`, `stop` and `return_to_base`
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [x] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] I have followed the [perfect PR recommendations][perfect-pr]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
If nobody solve it, at my very slow pace, I may look on how to update the file vacuum.py in the integration.
markbajaj
(Mark Bajaj)
August 9, 2023, 5:16pm
426
Just changed my HACS repo to GitHub - CodeFoodPixels/robovac: Add a Eufy RoboVac easily to Home Assistant and works perfectly!
This is a fork of the orig repo.
In HA remove the integration, then remove from HACS, then add this repo:
As a custom repo.
It worked straight away and i didn’t need to re-input put my Local ID or network key or change any entity names
sacua
(Sacua)
August 9, 2023, 6:10pm
427
I support, it is working.
liamb
(Liam)
August 20, 2023, 8:22pm
428
I have the LR30 Robovac, I’ve added the integration.
I hit configure, and it can see the name of my Robovac but I’ve tried every IP address of any unknown device on the network but nothing changes still 0 devices.
A) how can I pull the IP address. It doesn’t show on my network.
B) upon adding the correct IP does that change the devices to 1?
liamb
(Liam)
September 22, 2023, 6:46am
432
I got mine sorted.
When you look on your network you’ll see a random device, it’s not listed as the robot and doesn’t match the Mac address from the app.
CJT57
(Cjt57)
September 25, 2023, 12:17am
433
Update: If Vac is not properly returned to “Charging” and docked status in between tests, the room ID may not work and it’ll act like the room doesn’t exist.
CJT57
(Cjt57)
September 26, 2023, 4:19pm
434
To re-emphasize this: RoomIds START AT 0!!!
I beat my head against the wall far too long before correcting my mistake. Kept being unable to find that “last” room ID… -_-
Did you ever find an answer to this? I’m looking to do something similiar, but have drawn a blank
nope, nothing was found nor did someone else find a solution I am aware of
ok, thanks for getting back!
Any one know how to fix the feb 2024 notification.
Credo102
(Credo102)
November 4, 2023, 11:33am
440
Sorry for the late reply. Maybe you have already sorted this.
For the extra buttons on the vacuum card follow for both Options 1 and 2 the following page.
For the Mushroom cards with individual room cleaning. I made scripts for each room as detailed here.
yes you can right a script like to clean a single room.
NB “roomIds” just have to be worked out by trial and error, start with 0 and work your way up.
“count” is how many times it will do the clean [1,2 or 3]
"alias: "X8 Livingroom Clean "
service: vacuum.send_command
command: roomClean
params:
roomIds:
- 1
count: 2
device_id:
icon: mdi:television-classic"
Credo102
(Credo102)
November 4, 2023, 11:42am
441
I also found this if in the Eufy map the door to a room was previously closed when it did its last run.
Eufy will then come off the charging dock, position itself, then say it can’t reach destination point, and go back to charging station
Bloody infuriating!
To get around this i have to open ALL the doors to each room and do an “Auto Clean” then it re-maps with the doors open and all works well again… until the next time a door is closed during a scheduled auto clean.
But this is a Eufy program issue, not a Home Assistant one. so not much i can do with code to solve this one.
