It is almost impossible to confuse spotlight with IR. Spotlight is bright and white, IR looks like couple of red LEDs.
I’m trying to make an automation to auto stop the streaming after 2 minutes 50 seconds
However, i need the state change then
BUT
I cant use the state from idle cause of the % in it, to Streaming - rtsp
How did you guys made this automation (service call?)
This is how it looks now, but is not complete
- id: 'Stopping tuin camera'
alias: Stop streaming camera tuin
description: ''
- platform: state
entity_id: camera.tuin
to: "Streaming - rtsp"
for:
minutes: 2
seconds: 50
condition: []
- data:
service: eufy_security.stop_rtsp
I got it working
Recording starts 5-6 sec after triggered, that’s why I had to add 10 + 6 sec delay to get full 10 sec of recording, otherwise I get a shorter video. Can something be done to shorten the delay?
Back to here, please open your issues on GitHub so we can debug together.
hi, is there a known way of starting the stream for the floodlight camera? camera.turn_on does not seem to do anything, and eufy_security.start_livestream gives
2021-09-20 12:11:07 ERROR (MainThread) [homeassistant.components.camera] Timeout getting stream source
Whilst looking in the log, I also see
2021-09-20 12:10:54 WARNING (MainThread) [homeassistant.components.camera] The camera entity camera.garage does not support requesting width and height, please open an issue with the integration author
Any help would be great.
EDIT: I should note that the floodlight cam does NOT appear to be RTSP-compatible.
hey, about issues you are having on p2p streaming, please create an issue on github and share your camera with me. we can fix it together.
Hi @anon63427907,
I have recently installed your Eufy Security Integration and I immediately appreciated it. The sensors seem to work fine.
Excellent instructions, I followed them without problems and I configured everything in a short time.
There seems to be no switch to turn the device on and off, I try to open a request on github.
Hey, thanks for your feedback, there are services called enable/disable, you can use them
It works
Thanks!
Hey
is it possible to run the RTSP Simple Server Add On as a seperate docker image too (Without HASS Add On, Core HA?)
Thank you
first of all, thanks @anon63427907 for the great work!
Hope you can help me. I followed the procedure on https://github.com/fuatakgun/eufy_security#readme
The Repository is installed on HACS, the eufy_secutity folder is present on custom_components
After reboot I try to do Configuration - > Integrations > add integration although when I search for eufy no integration is returned.
Can you guess what may be missing?
Hey, issue should be cache related but not specific to this integration, check out this: https://github.com/fuatakgun/eufy_security/issues/48
Thanks! You are right… The basic cache problem
I am trying to set the alarm mode to custom1 with and automation and it doesn’t seem to be working. Is it possible or am missing something?
Have you set your custom1 mode through eufy app? By default, there was no custom mode setup for me. Custom modes should be created via app first and can be used via integration
Thanks for the quick reply. I’ve setup a custom mode called ‘Night’ in the eufy app. When I set it in the app I can see it is set to ‘Custom1’ in HA using developer tools. However I don’t seems to be able to select ‘Custom1’ or ‘Night’ as modes in HA automations, only, ‘Home’, ‘Away’ and Disarm’.
Yes, there is no corresponding option in home assistant, you are right and i don’t have a solution in place yet.
