Lol just saw the update notification, restarting after applying. Thanks for the speed of light updates
Yeah !
Yeah !
Brilliant! Works like a charm. Now that the basics work I look forward to explore these new features.
On the doorbell I had to reduce quality but the delay is now less than 3 seconds with webrtc. Thanks!
Hi fuatakgun,
I am getting this still.
2021-12-15 05:06:37.931 ERROR Status return code not 200
status: 423,
statusText: âLockedâ
2021-12-15 05:06:38.754 ERROR Status return code 401, invalidate token
status: 401,
statusText: âUnauthorizedâ
2021-12-15 05:06:38.757 ERROR Status return code not 200
status: 401,
2021-12-15 05:06:38.839 ERROR Status return code not 200
status: 423,
Please create a github issue to track this and double check if your account has 2 factor authentication enabled, integration does not support it
Nice work.
Also good move on the versioning, I was going to ask
Minor bug: the icon of the binary_sensor.doorbell_status_led_enabled appears to be set to mdi: led-on (with a space in between)
Iâve just submitted a PR
Ur going as fast as lightning! Thx !
Thanks for the PR, merged
It is not feasible to catch up with 2k streaming inside home assistant, we need to downgrade the quality
Still present here⌠
Does anyone have an automation built for when motion or a human is detected to send a notification with an image to your iPhone?
Not me, sorry
i am just interested in developing the custom integration but not using the whole functionality of the hardware
No worries! Is it normal for the thumbnail image to not update after turning RTSP on and then off on the camera. I have everything set up/working, but the thumbnail image is from daytime even if it is night. I thought turning RTSP would change/update the thumbnail but that doesnât work. Any idea if this is normal behavior? (Side note, if I open the eufy app and view the camera, it will update the thumbnail, but viewing through HA does not do this)
Hello fellow eufy-users.
I am curious about a thing:
is it possible to read the changed attribute-state or timestamp of a eufy camera and use it in an automation of HA?
I have a eufy-cam by the front-door and donât want to recieve notifications all day when I go in and out the door so I only set the âawayâ mode with notifications on at night. But have set that when in âhomeâ mode the camera records to my homebase.
In home-assistant I also see that if motion has happened in the daytime (home-modus) the thumbnail changes, and attributes like pictureUrl changes.
Is it possible to read out the changed pictureUrl-attribute, and make an automation for it? So for example I can turn on my porch-light when camera sees motion (even in home-modus)
Did you ever figure this out? I have the T8222 1080P battery doorbell that shows up in Home Assistant with snapshots when it detects motion but I canât view live streams.
I think this may be normal behaviour, indeed I can see the old thumbnail as I open the app, and it then gets replaced. I suspect the app get the latest thumbnail on opening and may then upload this)
not 100% sure what youâre asking, but yes you get the last_updated or last_changed attribute for any entity, including the eufy cam.
too bad, canât get it to work with template-script:
camera_changed1:
device_class: timestamp
value_template: >-
"{{states.camera.voordeur.last_changed}}"
camera_changed2:
value_template: >-
"{{states.camera.voordeur.last_updated}}"
any tips?
and question 2: is it then possible to trigger an automation when last_updated or last_changed changed value?
a few tips:
If you use >-, you should not enclose your template in single or double quotes
I just checked and there are several timestamps available in the camera.xxx from the eufy integration, why donât you use this instead? Admitedly I have a doorbell, not just a cam so not sure what exactly shows for you, you may have to adjust.
Try to replace
value_template: >-
with
value_template: >-
{{ (state_attr("camera.doorbell", "inherited")["properties"]["pictureUrl"]["timestamp"]) | int / 1000}}
You can then run an automation based on a value_template indeed:
platform: template
value_template: >-
(double check indentations)
This will trigger only when the timestamp changes
has anyone run it this in there logs for the eufy add on
2021-12-18 03:02:10.569 INFO Disconnected from station T8420N10203300B5
2021-12-18 03:02:15.851 INFO Connected to station T8420N10203300B5 on host 10.0.0.166 and port 17110
2021-12-18 03:03:31.805 INFO Disconnected from station T8420N10203300B5
2021-12-18 03:03:37.088 INFO Connected to station T8420N10203300B5 on host 10.0.0.166 and port 12303
2021-12-18 03:04:52.163 INFO Disconnected from station T8420N10203300B5
2021-12-18 03:04:57.373 INFO Connected to station T8420N10203300B5 on host 10.0.0.166 and port 14848
