Eufy Security Integration
What I personally did was add a date/time helper or two for times that I can set on my dashboard when it should arm/disarm and create a fairly simply automation to switch between armed home and armed away based on those time.
Extended with things such as when the entire house goes in ‘nightmode’ or ‘vacationmode’ or when all members are away it also turns it into armed away and the schedule is ignored. (and a few NFC tags that can trigger HA toggles for the alarm also)
HA will offer a lot more freedom to create and switch between modes then the Eufy app offers :slight_smile:
if you want to use eufy’s schedule implementation, you can call service eufy_security.alarm_guard_schedule.
Documentation is not my strong suit :slight_smile:
Hi.
I have a problem with this integration. I made everything said on tutorial but i don’t have stream. It works but after a some time i have an error as in the image.
If i restart the addon, camera goes up again.
At the logs everything fine, i think:
Can you help me :upside_down_face:
Enable debug logs for integration and share them over GitHub issue. if i am not mistaken, some users are having similar problems with webrtc, did you give it a try with native HA streaming or rtsptowebrtc/go2rtc add-on?
question? what is this i see many logging for the eufy doorbell with this
These sensors are used for debugging purposes only and they meant to show number of waiting frames to be forwarded to rtsp. in my cases, this value never reaches to 10-15, something is off here.
Has anyone setup successfully the PTZ function for Eufy Indoor Cam Pan&Tilt camera?
I saw that there are some services available like eufy_security.ptz_up but I can’t figure out how to use them.
I tried:
service: eufy_security.ptz_up
entity_id: camera.entryway
which returns no errror but nothing happens on the PTZ on the camera
Can you format your code please and double check if streaming is working while sending ptz command
Hi, this is the code that I’m using:
–EDIT–
RTSP stream is also enabled and camera is streaming when I’m trying to move it via the ptz service :confused:
-EDIT 2-
I saw the logs and I’m getting these error messages:
2022-09-15 08:32:35.556  INFO  Timeout connecting to station T8410...AD5
2022-09-15 08:36:59.137  ERROR P2PClientProtocol.lookup(): station: T8410...AD5 - All address lookup tentatives failed.
2022-09-15 08:36:59.141  INFO  Timeout connecting to station T8410...AD5
2022-09-15 08:37:50.568  ERROR P2PClientProtocol.lookup(): station: T8410...AD5 - All address lookup tentatives failed.
2022-09-15 08:37:50.571  INFO  Timeout connecting to station T8410...AD5
2022-09-15 08:38:45.182  ERROR P2PClientProtocol.lookup(): station: T8410...AD5 - All address lookup tentatives failed.
2022-09-15 08:38:45.184  INFO  Timeout connecting to station T8410...AD5
Also, no other funtions like turn off LED etc is working via Home Assistant UI. I don’t know why.
I purchase the indoor camera recently , and I had already installed the integration when I pair it with the homebase2… .
Next time, neither use plain paste nor screenshot, but this one.
can you help me with the integration?
I have this code and come to the app. But I want to enter directly to the cam. The same like the notification from the app.
this is my code from the browser_mod:
service: notify.mobile_app_tablet_eg
  message: command_launch_app
    package_name: com.oceanwing.battery.cam
Is there a possibily to get directly to the cam view?
Thanks!
I want to see this:
At the moment I see only this. Only the overview!
grafik
sorry, this is beyond my skills.
for me this works perfectly;
service: eufy_security.ptz_right
  entity_id: camera.garden
apparently, you have some connection issues with the devices, we need to sort it out first
yes, thats right. But you cant answer somebody.
Its only possible via the app. So when the doorbell is pressed you need to open the app.
Just see your reply now and indeed, works for me as well! Thanks a lot for the hint, much appreciated!
Yesterday I was super excited as I finally got the Eufy Doorbell working in home assistant. Now I notice that after some time the camera stops working. I see the following error message in the logs of the eufy-security-ws container:
2022-09-20 07:04:35.443  ERROR Message error
 LivestreamNotRunningError  Livestream for device T8200N0020081594 could not be stopped, because it is not running
error stack:
• message_handler.ts:146 handle
    src/lib/device/message_handler.ts:146:31
• task_queues:96 processTicksAndRejections
    node:internal/process/task_queues:96:5
• server.ts:103 receiveMessage
    src/lib/server.ts:103:21
After I reload the integration in Home assistant the camera will be working again. Anyone familiar with this error?
@anon63427907 is it possible to add compatibility for T8530? Thank you! :slight_smile:
eufy_security - Exception - process_messages: 55 is not a valid DEVICE_TYPE - traceback: Traceback (most recent call last): File “/config/custom_components/eufy_security/websocket.py”, line 57, in process_messages await self.on_message(msg) File “/config/custom_components/eufy_security/websocket.py”, line 68, in on_message await self.message_callback(message) File “/config/custom_components/eufy_security/coordinator.py”, line 313, in on_message await self.process_get_device_properties_response( File “/config/custom_components/eufy_security/coordinator.py”, line 260, in process_get_device_properties_response device.set_properties(properties) File “/config/custom_components/eufy_security/const.py”, line 446, in set_properties type = DEVICE_TYPE(self.type_raw) File “/usr/local/lib/python3.10/enum.py”, line 385, in call return cls.new(cls, value) File “/usr/local/lib/python3.10/enum.py”, line 710, in new raise ve_exc ValueError: 55 is not a valid DEVICE_TYPE - message: WSMessage(type=<WSMsgType.TEXT: 1>, data=’{“type”:“result”,“success”:true,“messageId”:“get_device_properties”,“result”:{“serialNumber”:“T8530------------------”,“properties”:{“name”:“Front Door”,“model”:“T8530”,“serialNumber”:“T8530---------------”,“type”:55,“hardwareVersion”:“P1”,“softwareVersion”:“1.1.5.4”,“stationSerialNumber”:“T8021----------------”}}}’, extra=’’)
(I dashed out the serial numbers!) Hope this error log helps!
Hey Lulu Could you solved this problem?
